其它各类仪器
德国进口空气压缩机德国爱安达 LW100
进口
德国
LW100
德国爱安达呼吸空气压缩机:
1.高精度,将缸体和曲轴箱内壁在机械加工过程中成为一体
2.缸体和曲轴箱之间无泄漏可能性,没有泄漏点
3.高效散热功能减少了变形所带来的磨损
4.可更换缸套筒
LW100型是三级,三缸。空冷,油润滑高压压缩机。
产地:德国
Specifications
>> Fully wired, ready to start with cable and plug, start/stop switch
>> Aluminium frame
>> All pistons with steel piston rings
>> 2 oil/water separators
>> Inter-stage and final stage air coolers
>> Savety valves for each stage
>> Pressure maintaining and non return valve for extended filter duration
>> Filling hose with filling valve and pressure gauge
>> 200/232 bar version with DIN/Yoke connection, 300 bar version with DIN connection
>> Breathing air purification in accordance with EN 12021
Options
>> Auto start
>> Carrying handles
>> Additional filling hose
>> Thermal overload switch
>> Automatic condensation drain
>> 200/300 bar switch over device
>> Automatic stop and hours counter
>> Special voltages / frequencies on request
>> Conversion set petrol/electric drive
Technical Data
  LW 100 E ECO
Type: Air cooled, reciprocating piston comp.
Capacity [litre/min] / [Nm³/h] / [cfm]: 100 / 6 / 3.5
Max. Pressure [bar]: 330*
RPM [1/min]: 2300
No of cylinders / No of stages: 3 / 3
Prime mover type: 3 Phase E-motor 400V / 50Hz 1)
Drive power [kW] / [HP]: 2.2 / 3.0
Cooling air requirement [Nm³/h]: 660
Lubrication type: Splash oil
Oil capacity[litre]: 0.5
Air outlet temperature [°C]: 6°C above ambient
Filter capacity [m3 at + 20°C] 2): 108
Dimensions L x W x H(cm): 65 x 39 x 40
Weight [kg]: 39
Noise level [dB]: 82 measured at 1 m
一直专注于在各种工作环境保护人体呼吸健康的解决方案。产品涵盖了空气呼吸器,空气充气泵,各类工作环境中的劳动保护用品。
上海市杨浦区隆昌路619号1号楼b207室
