M2N(微纳伙伴) 样品台(夹) 样品台
各种样品台(夹)
12-000110 EM-Tec GS10 swivel head sample holder for up to 10mm, gold plated brass, pin
EM-Tec GS10 – A swivel vise which covers a full 180 angle and can also be rotated with the stub. This is the ultimate holder for imaging cross sections at any desired angle. The swivel head size without clamping screws is only 16x16x14mm. The sample is clamped with the two clamping screws; the swivel head can be locked in place with the tilt clamping screw. Made from brass and plated with 1μm of pure gold.
12-000200 EM-Tec V22 compact vise type sample holder for up to 22mm, pin
EM-Tec V22 compact vise sample holder for sample sizes up from 0-22mm with a pin. One fixed jaw and a spindle driven moving jaw. Jaw height is 10mm, clamping width is 25mm. Cost-effective compact vise which can be used in both standard SEMs and table top SEMs. Made from vacuum grade aluminium, brass spindle and stainless steel screws.
12-000300 EM-Tec V22 compact vise type sample holder for up to 22mm, M4
EM-Tec V22 compact vise sample holder for sample sizes up from 0-22mm with M4 thread. One fixed jaw and a spindle driven moving jaw. Jaw height is 10mm, clamping width is 25mm. Cost-effective compact vise which can be used in both standard SEMs and table top SEMs. Made from vacuum grade aluminium, brass spindle and stainless steel screws. More info
12-000320 EM-Tec VS42 universal spring-loaded large vise holder for up to 42mm, M4
EM-Tec VS43 universal double sided spring-loaded larger vise for samples with a maximum vise opening of 42mm. Different type of jaws can be mounted on the EM-Tec universal spring-loaded vise. Opens by pulling the jaws. Dowel pin pins be inserted in the brass slider to extend the opening size and to hold awkwardly shaped samples. With the dowel pins a disc of up 50mm diameter can be held; 4 dowel pins are included. Includes triple grooved/smooth reversible vise jaws. Additional optionally available vise jaws are:
Vise jaw with a single 120° large groove for round samples Standard reversible vise jaws with triple grooved/smooth side; vise jaws can be stacked to increase the jaw heigth from 12 to 24mm. Made from vacuum grade aluminium, brass sliders and stainless steel rods and springs.
The EM-Tec stub based SEM sample holders are all small SEM sample holders based on (modified) SEM sample stubs. They have the same footprint as the original SEM sample stubs and are directly compatible with the SEM stage or SEM sample stub holder. These affordable sample holders increase efficiency and reduce sample preparation time. Using sample holders reduces the use of conductive adhesives which can be a source of contamination. The EM-Tec stub based small sample holders formats are:
The pin stub based sample holders comprise the largest selection; they can be easily used on other SEM platforms by using the cost efficient EM-Tec SEM stub adapters. All EM-Tec compact SEM stub based SEM sample holders are precision machined from vacuum grade aluminium unless otherwise noted. Provided with set screws and allen keys.
Product # |
Type |
Mount sizes |
Dimensions w/o pin |
Mount holding |
SEM stage comp. |
EM-Tec M26 |
?25mm / ?1” |
?34x12.5mm |
Set screw |
Standard 3.2mm pin |
EM-Tec M26 |
?25mm / ?1” |
?34x12.5mm |
Set screw |
M4 thread |
EM-Tec M26 |
?25mm / ?1” |
?34x12.5mm |
Set screw |
?14mm JEOL stub |
EM-Tec M32 |
?30mm / ?32mm / ?1-1/4” |
?40x12.5mm |
Set screw |
EM-Tec M32 |
?40x12.5mm |
Set screw |
M4 thread |
EM-Tec M32 |
?40x12.5mm |
Set screw |
?14mm JEOL stub |
EM-Tec M40 |
?40mm / ?1-1/2” |
?48x12.5mm |
Set screw |
EM-Tec M40 |
?40mm / ?1-1/2” |
?48x12.5mm |
Set screw |
M4 thread |
EM-Tec M40 |
?40mm / ?1-1/2” |
?48x12.5mm |
Set screw |
?14mm JEOL stub |
EM-Tec M51 |
?50mm / ?2” |
?59x12.5mm |
Set screw |
EM-Tec M51 |
?50mm / ?2” |
?59x12.5mm |
Set screw |
M4 thread |
EM-Tec M51 |
?50mm / ?2” |
?59x12.5mm |
Set screw |
?14mm JEOL stub |
我司还有各种各样的样品台,欢迎来电咨询。
南京覃思科技有限公司成立于2004年,总部位于南京,在北京设有分公司,业务覆盖全国及港澳地区。公司专注于电子光学与实验室科研领域的仪器及耗材销售与技术服务,主要产品涵盖电子显微镜、光学显微镜、X射线、Micro CT 等相关仪器及配套软硬件。
作为多家国际知名品牌的中国区授权代理,覃思科技长期合作的品牌包括:荷兰 Delmic、美国 JC Nabity、瑞士 Safematic、美国 Tousimis、加拿大 Dragonfly、荷兰 ASI、美国 PIE Scientific、法国 TRAD、丹麦 DeltaPix、加拿大 KA Imaging、韩国 LabSpinner 和荷兰 Micro to Nano。
此外,我们也提供一系列自研和国产配套产品,如 TS3000 清洁度检查系统、ACCUR 系列电动扫描平台,并承接显微镜数字化改造及微束分析类非标定制服务。
我们的客户广泛分布于高校、科研院所、医疗机构、政府机关及工业企业,长期合作单位包括北大、清华、浙大、南大、东大、复旦、同济、上海交大、中科大等名校;中科院微生物所、遗传所、生物物理所、近代物理所、微电子所、等离子所、植生所、水生所、寒旱所、金属所、海洋三所、上海光机所、长春应化所、山西煤化所、广州能源所、上海石化院、大庆油田、胜利油田、国家纳米中心、紫金山天文台等知名科研机构;广西、山东、宁波等检验检疫局,北京法医鉴定中心等国家机构;Intel英特尔、博世Bosch、希捷Seagate等跨国企业;华为、天马、首钢等国内骨干企业。
公司秉持“诚信经营、诚实服务”的宗旨,致力于为客户提供先进可靠的产品与专业周到的服务,愿与各界携手共进,共创未来。
单位名称: |
南京市中山北路281号新城市广场虹桥中心2-728B
联系电话: |
Email: |
