201000281沃特世2489/2998光源灯检测器氘灯
Waters氘灯光源,检测器氘灯
The Waters® Performance Maintenance Kit for the ACQUITY UPLC TUV/PDA contains all of the Waters Quality Parts® necessary to keep your instrument operating at peak performance on an annual basis. It is used in ACQUITY UPLC PDA Detectors, ACQUITY eLambda PDA Detector, ACQUITY UPLC TUV Detectors, 2489 Dual Wavelength UV Detector and the 2998 PDA Detector. The old part number was 201000186. The Waters® Performance Maintenance Kit includes the following parts: PerformancePLUS™ Long Life Lamp which is warranted for a lifetime of 2000 hours or 1 year, whichever comes first.
产品编号 : 201000281
186000307C | LCGC Certified Clear Glass 12 x 32mm Screw Neck Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg | 2mL透明样品瓶套装 |
186000272C | LCGC Certified Clear Glass 12 x 32mm Screw Neck Vial, with Cap and PTFE/silicone Septum , 2 mL Volume, 100/pkg | 2mL透明样品瓶套装 |
186000847C | LCGC Certified Amber Glass 12 x 32mm Screw Neck Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg | 2mL棕色样品瓶套装 |
186000305 | Blue, 12 x 32mm Screw Neck Cap and preslit PTFE/silicone Septum, 100/pkg | 蓝色样品瓶盖垫 |
186000385C | LCGC Certified Clear Glass 12 x 32mm Screw Neck Total Recovery Vial, with Cap and Preslit PTFE/Silicone Septa, 1 mL Volume, 100/pkg | 1mL透明样品瓶套装 |
186000327C | LCGC Certified Clear Glass 12 x 32mm Screw Neck Max Recovery Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg | 2mL透明样品瓶套装 |
WAT094171 | Low volume insert, 150 μL, w/plastic spring 100/pkg | 150uL内插管 |
WAT094170 | Low volume insert, 300 μL, 6x29mm with plastic spring 100/pkg | 300uL内插管 |
201000281 | ACQUITY PDA/TUV 2489/2998 PERF MAINT KIT | 氘灯 |
上海希言科学仪器有限公司位于上海市松江高科技园区,是一家专业经营实验室耗材的年轻公司,专注于色谱、光谱、环境监测、实验室通用设备的研究、销售、技术支持的体系化服务,主要客户分布于生物医药、食品日化、环境检测、化工纤维等行业。
单位名称: |
上海市松江区涞寅路1025号立同商务广场3067室
联系电话: |
Email: |
