186000274沃特世蓝色螺口样品瓶盖和隔垫
186000307C | LCGC Certified Clear Glass 12 x 32mm Screw Neck Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg |
186000272C | LCGC Certified Clear Glass 12 x 32mm Screw Neck Vial, with Cap and PTFE/silicone Septum , 2 mL Volume, 100/pkg |
186000847C | LCGC Certified Amber Glass 12 x 32mm Screw Neck Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg |
186000305 | Blue, 12 x 32mm Screw Neck Cap and preslit PTFE/silicone Septum, 100/pkg |
186000385C | LCGC Certified Clear Glass 12 x 32mm Screw Neck Total Recovery Vial, with Cap and Preslit PTFE/Silicone Septa, 1 mL Volume, 100/pkg |
186000327C | LCGC Certified Clear Glass 12 x 32mm Screw Neck Max Recovery Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg |
WAT094171 | Low volume insert, 150 µL, w/plastic spring 100/pkg |
WAT094170 | Low volume insert, 300 µL, 6x29mm with plastic spring 100/pkg |
186000274 | Blue, 12 x 32mm Screw Neck Cap and PTFE/silicone Septum, 100/pkg |
186003524 | Solvent Filter, GHP, 47 mm, 0.2 µm, Aqueous, 100/pkg |
WAT025531 | Solvent Reservoir Filter |
201000281 | ACQUITY PDA/TUV 2489/2998 PERF MAINT KIT |
WAS081142 | TUV DETECTOR PERFORMANCE MAINTENANCE KIT |
201000193 | ACQUITY FLR DETECTOR PERFORM MAINT KIT |
WAT052586 | PDA DETECTOR PERFORMANCE MAINTENANCE KIT |
186006961 | Waters Positive Pressure-96 Processor |
205000343 | ACQUITY UPLC Col. In-Line Filter Kit |
700002775 | Kit, Frit and Nut, 0.2µm, 2.1mm, 5/pkg |
700008842 | TOF G2-S Sample Kit -1 |
WAT027059 | Porapak Q 50-80 mesh, 26 grams |
700000254 | PerformancePLUS™Check Valve Cartridges |
700002399 | PerformancePlus Check Valve Cartridge |
上海希言科学仪器有限公司位于上海市松江高科技园区,是一家专业经营实验室耗材的年轻公司,专注于色谱、光谱、环境监测、实验室通用设备的研究、销售、技术支持的体系化服务,主要客户分布于生物医药、食品日化、环境检测、化工纤维等行业。
单位名称: |
上海市松江区涞寅路1025号立同商务广场3067室
联系电话: |
Email: |
