其他实验耗材
WAT088084沃特世过滤器滤芯
WAT088084沃特世过滤器滤芯
进口
美国Watres
WAT088084
Precolumn Filter Insert Assembly
部件代码: WAT088084
Product Description
Replacement insert (2µm) for the filter between the pump and injector.
186000307C LCGC Certified Clear Glass 12 x 32mm Screw Neck Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg
186000272C LCGC Certified Clear Glass 12 x 32mm Screw Neck Vial, with Cap and PTFE/silicone Septum , 2 mL Volume, 100/pkg
186000847C LCGC Certified Amber Glass 12 x 32mm Screw Neck Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg
186000305 Blue, 12 x 32mm Screw Neck Cap and preslit PTFE/silicone Septum, 100/pkg
186000385C LCGC Certified Clear Glass 12 x 32mm Screw Neck Total Recovery Vial, with Cap and Preslit PTFE/Silicone Septa, 1 mL Volume, 100/pkg
186000327C LCGC Certified Clear Glass 12 x 32mm Screw Neck Max Recovery Vial, with Cap and Preslit PTFE/Silicone Septa, 2 mL Volume, 100/pkg
WAT094171 Low volume insert, 150 µL, w/plastic spring 100/pkg
WAT094170 Low volume insert, 300 µL, 6x29mm with plastic spring 100/pkg
186000274 Blue, 12 x 32mm Screw Neck Cap and PTFE/silicone Septum, 100/pkg
186003524 Solvent Filter, GHP, 47 mm, 0.2 µm, Aqueous, 100/pkg
WAT025531 Solvent Reservoir Filter
201000281 ACQUITY PDA/TUV 2489/2998 PERF MAINT KIT
WAS081142 TUV DETECTOR PERFORMANCE MAINTENANCE KIT
201000193 ACQUITY FLR DETECTOR PERFORM MAINT KIT
WAT052586 PDA DETECTOR PERFORMANCE MAINTENANCE KIT
186006961 Waters Positive Pressure-96 Processor
205000343 ACQUITY UPLC Col. In-Line Filter Kit
700002775 Kit, Frit and Nut, 0.2µm, 2.1mm, 5/pkg
700008842 TOF G2-S Sample Kit -1
WAT027059 Porapak Q 50-80 mesh, 26 grams
700000254 PerformancePLUS™Check Valve Cartridges
700002399 PerformancePlus Check Valve Cartridge
WAT088084 Precolumn Filter Insert Assembly
上海希言科学仪器有限公司位于上海市松江高科技园区,是一家专业经营实验室耗材的年轻公司,专注于色谱、光谱、环境监测、实验室通用设备的研究、销售、技术支持的体系化服务,主要客户分布于生物医药、食品日化、环境检测、化工纤维等行业。
上海市松江区涞寅路1025号立同商务广场3067室
