电子显微镜
M2N(微纳实验耗材)_导电胶
M2N(微纳实验耗材)_导电胶
进口
荷兰/Micro to Nano
15-001130、15-001133
面议
众所周知,优质显微镜用品和耗材是微束分析领域样品制备和产生理想结果的必要条件。成功的样品制备是从样品中获取优质图像和可靠数据的关键步骤。由南京覃思科技有限公司(www.tansi.com.cn)代理的荷兰Micro to Nano(简称M2N)进口显微镜耗材及用品,遵循“创新、实用和优质”之理念,产品用于电子显微镜和扫描探针显微镜技术领域。M2N公司在电子显微镜、样品制备、成像技术和产品分销领域拥有50多年的行业经验,对客户的需求有着深刻的理解。我们的显微镜用品,特别是电子显微镜用品,能为客户提供当前任务所需的耗品耗材。
荷兰M2N持续从事基于显微镜新需求的耗品研发,是SEM、TEM、FIB、AFM、SPM、LM等微纳领域之贴心伙伴,提供优质和创新的样品桩、样品座、碳膜载网、校准标样、靶材、碳棒、碳绳、工具、配件、银导电胶、碳胶带、铜胶带、储存盒、清洁用品、真空密封、安全防护等各种耗材器具,琳琅满目,应有尽有,显微分析领域耗材之理想选择!
导电胶规格和指标如下:
Paint /   Cement
EM-Tec
  C30
EM-Tec
  C32
EM-Tec
  C33
EM-Tec
  C38
EM-Tec
  AG15
EM-Tec AG42
EM-Tec AG44
EM-Tec AG46
EM-Tec
  NI41
Product   #
15-001130
  15-001131
15-001132
15-001133
15-001138
15-002114
  15-002115
15-002141
  15-002142
15-002143
  15-002144
15-002145
  15-002146
15-004141
Filler   Type
wt%
Graphite   20%
Graphite   10%
Graphite
10%
Carbon
15%
Silver
58%
Silver
73%
Silver
61%
Silver
60%
Nickel
50%
Type
thin   paste
thin   paste
thin   paint
thin   paste
paint
thin   paste
thin   paste
paint
thin   paste
Resistance   (dry)
30   ohm/sq
30   ohm/sq
1200   ohm/sq
50   ohm/sq
0.015   ohm/sq
0.01   ohm/sq
0.01   ohm/sq
0.01   ohm/sq
0.7   ohm/sq
Binder
gel
gel
polymer
acrylic
thermoplastic   resin
acrylic
acrylic
urethane
acrylic
Solvent
Water
Water
Isopropanol
Acetone/   MEK
MEK
Toluene
  /acetone
Acetone
Water
Toluene/
  acetone
Density
1.12g/cm3
1.08g/cm3
0.84g/cm3
0.85g/cm3
1.63g/cm3
2.05g/cm3
1.7g/cm3
1.5g/cm3
2.1g/cm3
Touch dry
5min
5min
>1 min
3min
10min
5min
3min
5min
5min
Full   cure time @ 22°C
24hr
24hr
15min
24hrs
8hrs
24hrs
24hrs
24hrs
24hrs
Full   cure time @ 65°C
45min
45min
>5min
30min
30min
30min
30min
3hrs
30min
Minimum   temperature
-20°C
-20°C
-20°C
-40°C
-20°C
-40°C
-40°C
-40°C
-40°C
Maximum   temperature
+140°C
+140°C
+200°C
+120°C
+105°C
+120°C
+120°C
+120°C
+120°C
Mechanical   strength
low
low
low
high
medium
high
low
low
high
Vacuum   compatible (dry)
excellent
excellent
yes
yes
yes
yes
yes
yes
yes
RoHs   compliant
yes
yes
yes
yes
yes
yes
yes
yes
yes
Weight
40g/100g
25g
15g
25g
15g /   25g
15g /   25g
15g /   25g
15g /   25g
25g
Bottle   size
60cc/100cc
30cc
30cc
30cc
15cc /   30cc
15cc/15cc
15cc/30cc
15cc/30cc
30cc
Thinner-Extender
Water
Water
Isopropanol
Acetone
MEK
Acetone
Acetone
Water
Acetone
Shelf   life @ 20°C
> 3   year
> 3   year
> 3   year
> 3   year
> 3   year
> 3   year
> 3   year
> 3   year
> 3   year
银导电胶
 15-002114   EM-Tec AG15 silver paint, 15g bottle
15-002115   EM-Tec AG15 silver paint, 25g bottle
EM-Tec AG15 silver paint, 15g bottle EM-Tec AG15 is a conductive silver paint based on very fine silver flakes with a thermoplastic resin binder with MEK / acetone as diluent. EM-Tec AG15 is fully comparable to EDAG 1415M and DAG 915 from Acheson / Henkel. Applications are making grounding paths and conductive glue for SEM samples, electronic and shielding applications. Achieves good bonding properties on a wide variety of materials including, plastics, ceramics, glass, metals, wood, rubber, epoxies and textiles. The low viscosity silver paint is ideal for making grounding tracks and to bond SEM samples on sample stubs. Samples can be easily removed. This silver cement has the consistency of a paint. Dries relatively quickly, depending on thickness; reduce drying time with moderate heat up to 70°C. Solution contains 57.5 – 59 % silver. EM-Tec AG15 exhibits excellent conductivity.
15-002141   EM-Tec AG42 strong and highly conductive silver cement, 15g bottle
EM-Tec AG42 is a strong conductive silver cement based on fine silver flakes (10-1μm) with an acrylic binder. Achieves excellent bonding properties on a wide variety of materials including, plastics, ceramics, glass, metals, wood, rubber, epoxies and textiles. The strong and tough acrylic binder reduces material loss where as the silver flakes ensure excellent conductivity. Use when highest conductivity is needed. Ideal for making grounding tracks and to bond SEM samples on sample stubs. This silver cement has the consistency of a paste. Dries relatively quickly, depending on thickness; drying time can be reduced with moderate heat up to 65°C. Can be used on flexible surfaces. Solvent is acetone, solution contains approximately 73% silver, acrylic based binder. Excellent conductivity. Supplied in a 15cc glass bottle with a brush, 15 gram.
15-002145   EM-Tec AG46 water-based conductive silver paint, no VOC, 15g bottle
EM-Tec AG46 is a conductive silver paint based on fine silver flakes (10-1um size) with a water based urethane binder. It does not contain VOC, is solvent-free and is non-flammable. Achieves excellent bonding properties on a wide variety of materials including, plastics, ceramics, glass, metals, wood, paper and paints. Safe to use on even the most delicate plastics. The water-based urethane binder reduces material loss whereas the silver flakes ensure excellent conductivity. Ideal for making grounding tracks and to bond SEM samples on sample stubs. Samples can be easily removed. This silver cement has the consistency of a paint. Dries relatively quickly, depending on thickness; reduce drying time with moderate heat up to 65°C. Solvent is water, solution contains 60% silver, urethane based binder. EM-Tec AG46 exhibits excellent conductivity. Supplied in a 15cc glass bottle with a brush, 15 gram. Keep container above 0 degrees Celcius; do not freeze!
银胶稀释液
 15-002170   EM-Tec STC15 solvent / thinner / cleaner for EM-Tec AG15 silver paint, 30ml bottle
EM-Tec STC15 solvent / thinner / cleaner for EM-Tec AG15 silver paint, 30ml bottle EM-Tec STC 15 extender, thinner and cleaner for the EM-Tec AG15 conductive silver paint. 99.9% pure Methyl Ethyl Ketone (MEK). Supplied in a 30cc glass bottle.
碳导电胶
15-001130   EM-Tec C30 water based conductive carbon paint, no VOC, 40g bottle
 EM-Tec C30 is a premium, water based conductive carbon paint with fine dispersed graphite flakes (~3μm). The EM-Tec C30 carbon paint does not contain any hydro-carbon based solvents and is fully compatible with high vacuum (HV) systems and even UHV systems when dry. Due to its low viscosity, cracks and small gaps are easily filled. EM-Tec C30 shows good conductivity when dry. Ideal for mounting SEM specimens and making grounding paths. Samples can be easily removed afterwards due to its low mechanical strength. Good bonding properties on a wide variety of sample materials such as metals, rocks, concrete, ceramics, epoxies, wood and textiles. Other applications are lubrication on moving surfaces and shielding. EM-Tec C30 contains approx. 20% graphite in the solution. On hydrophobic materials, we advise to use the solvent based carbon paints #15-001133 or 15-001139. Supplied in a 60cc glass bottle with 40g contents and a cap with brush. Keep container above 0 degrees Celcius; do not freeze!
 15-001133   EM-Tec C33 fast drying conductive carbon paint, 15g bottle
  EM-Tec C33 is an extremely fast drying thin carbon paint (similar to aerosol sprays). EM-Tec C33 has been developed to cover large areas quickly with a thin conductive layer. Ideal for making grounding paths and for covering parts of non-conductive epoxy mounts. Due to its low viscosity it easily fills cracks and narrow gaps. EM-Tec C33 is one of the fastest drying carbon paint on the market. Samples can be removed relatively easily due to its low bonding strength. EM-Tec C33 dries very quickly; thin layers within 10 seconds. It is less suitable for flexible surfaces. Solvent is isopropanol, solution contains approximately 10% graphite with a polymer based binder. Good conductivity. Supplied in a 30cc glass bottle with 15g contents and a separate brush.
碳胶稀释液
 15-001150   EM-Tec STC33 Isopropanol solvent / thinner / cleaner, 30ml bottle
 EM-Tec STC 33 Isopropanol thinner and cleaner for the EM-Tec C33 fast drying carbon paint. 99.8% pure Isopropanol. Supplied in a 30cc glass bottle.
南京覃思科技有限公司成立于2004年,总部位于南京,在北京设有分公司,业务覆盖全国及港澳地区。公司专注于电子光学与实验室科研领域的仪器及耗材销售与技术服务,主要产品涵盖电子显微镜、光学显微镜、X射线、Micro CT 等相关仪器及配套软硬件。
作为多家国际知名品牌的中国区授权代理,覃思科技长期合作的品牌包括:荷兰 Delmic、美国 JC Nabity、瑞士 Safematic、美国 Tousimis、加拿大 Dragonfly、荷兰 ASI、美国 PIE Scientific、法国 TRAD、丹麦 DeltaPix、加拿大 KA Imaging、韩国 LabSpinner 和荷兰 Micro to Nano。
此外,我们也提供一系列自研和国产配套产品,如 TS3000 清洁度检查系统、ACCUR 系列电动扫描平台,并承接显微镜数字化改造及微束分析类非标定制服务。
我们的客户广泛分布于高校、科研院所、医疗机构、政府机关及工业企业,长期合作单位包括北大、清华、浙大、南大、东大、复旦、同济、上海交大、中科大等名校;中科院微生物所、遗传所、生物物理所、近代物理所、微电子所、等离子所、植生所、水生所、寒旱所、金属所、海洋三所、上海光机所、长春应化所、山西煤化所、广州能源所、上海石化院、大庆油田、胜利油田、国家纳米中心、紫金山天文台等知名科研机构;广西、山东、宁波等检验检疫局,北京法医鉴定中心等国家机构;Intel英特尔、博世Bosch、希捷Seagate等跨国企业;华为、天马、首钢等国内骨干企业。
公司秉持“诚信经营、诚实服务”的宗旨,致力于为客户提供先进可靠的产品与专业周到的服务,愿与各界携手共进,共创未来。
南京市中山北路281号新城市广场虹桥中心2-728B
85432278
010-62908712
