色谱柱
zxk蛋白层析柱
zxk蛋白层析柱
上海
zxk
ZXK夹套式蛋白层析柱特点及产品参数:
我们可以提供高质量,高精确性的ZXK蛋白层析柱柱管,结合多种层析介质,可得到满意的分离效果
  层析柱特点:
1:耐压高,透明
2:快速锁定的适配器确保均一的流速和最小的死体积
3:特定的装柱器保证好的柱效
4:材质有很好的化学耐受性
5:热稳定的夹套可维持一定的操作温度
6:操作温度4-60度
7:PH稳定性
8:可以按照客户要求提供不同孔径筛网
9:在水溶剂和常规溶剂中可以稳定使用
10:可以完美替代XK层析柱,零配件可以任意互换,相关配件请咨询当地代理商
ZXK protein chromatographic column
 We provide high quality, high accuracy chromatographic column tube. With various of chromatography media combined, satisfactory result can be achieved.
Features of the chromatographic column:
1. Transparent and high-pressure tolerance.
2. Adapter fast locking to ensure even flow rate and minimize dead volume.
3. Specific packing reservoir guarantees good column efficiency.
4. Materials are of excellent chemical durability.
5. Thermostabilizing jacket can maintain a certain operation temperature.
6. Operation temperature:4-60℃.
7. PH stability.
8. We can supply screen of different apertures according to clients’ requirements.
9. Steady in hydrosolvent or other conventional solvent.
10. It’s a perfect alternative for XK chromatographic column. Parts can be exchanged freely. For related parts, please contact local representative
货号
Item No.
产品名称
product name
内径ID(mm) 耐压Pressure(bar) 床层高度Bed height(mm) 床层体积(mL)Bed Volume 床层高度范围Bed Height Range 规格Spec(mm*mm) 筛网Screen
ZXK16200 ZXK蛋白层析柱 16 5 200 4-33 20-165 16×200 10um
ZXK16300 ZXK蛋白层析柱 16 5 300 24-53 120-265 16×300 10um
ZXK16400 ZXK蛋白层析柱 16 5 400 44-73 220-365 16×400 10um
ZXK16700 ZXK蛋白层析柱 16 5 700 104-133 520-665 16×700 10um
ZXK161000 ZXK蛋白层析柱 16 5 1000 164-193 820-965 16×1000 10um
ZXK26200 ZXK蛋白层析柱 26 5 200 13-76 25-145 26×200 10um
ZXK26300 ZXK蛋白层析柱 26 5 300 66-130 125-245 26×300 10um
ZXK26400 ZXK蛋白层析柱 26 5 400 119-183 225-345 26×400 10um
ZXK26700 ZXK蛋白层析柱 26 5 700 278-342 525-645 26×700 10um
ZXK261000 ZXK蛋白层析柱 26 5 1000 437-501 825-945 26×1000 10um
ZXK50200 ZXK蛋白层析柱 50 3 200 29-323 15-165 50×200 10um
ZXK50300 ZXK蛋白层析柱 50 3 300 225-520 115-265 50×300 10um
ZXK50600 ZXK蛋白层析柱 50 3 600 814-1109 415-565 50×600 10um
ZXK50700 ZXK蛋白层析柱 50 3 700 1010-1305 515-665 50×700 10um
ZXK501000 ZXK蛋白层析柱 50 3 1000 1599-1894 815-965 50×1000 10um
ZXKZZQ16 16mm内径装柱器 16 3 16mm内径装柱器
ZXKZZQ26 26mm内径装柱器 26 3 26mm内径装柱器
ZXKZZQ50 50mm内径装柱器 50 3 50mm内径装柱器
zxk16LJ16 16规格连接件 将2根16的层析柱串联
zxk26LJ26 26规格连接件 将2根26的层析柱串联
zxk50LJ50 50规格连接件 将2根50的层析柱串联
假如您的柱管零配件损坏,请参照下面货号订购相关配件
产品名称 200mm 300mm 400mm 600mm 700mm 1000mm
16mm规格ZXK蛋白层析柱内管 ZXKBL16200 ZXKBL16300 ZXKBL16400   ZXKBL16700 ZXKBL161000
26mm规格ZXK蛋白层析柱内管 ZXKBL26200 ZXKBL26300 ZXKBL26400   ZXKBL26700 ZXKBL261000
50mm规格ZXK蛋白层析柱内管 ZXKBL50200 ZXKBL50300   ZXKBL50600 ZXKBL50700 ZXKBL501000
16mm规格ZXK蛋白层析夹套管 ZXKPA16200 ZXKPA16300 ZXKPA16400   ZXKPA16700 ZXKPA161000
26mm规格ZXK蛋白层析夹套管 ZXKPA26200 ZXKPA26300 ZXKPA26400   ZXKPA26700 ZXKPA261000
50mm规格ZXK蛋白层析夹套管 ZXKPA50200 ZXKPA50300   ZXKPA50600 ZXKPA50700
产品名称 货号
ZXKZZQ16柱管(装柱器管子) ZXKPA16
ZXKZZQ26柱管(装柱器管子) ZXKPA26
ZXKZZQ50柱管(装柱器管子) ZXKPA50
货号 描述
ZXKSPQ16 16mm适配器(上)
ZXKSPQ26 26mm适配器(上)
ZXKSPQ50 50mm适配器(上)
ZXKSPQ16-1 16mm适配器(下)
ZXKSPQ26-1 26mm适配器(下)
ZXKSPQ50-1 50mm适配器(下)
描述 货号 备注
16规格分配器 ZXK16FP 16规格分配器(一包2个)
26规格分配器 ZXK26FP 26规格分配器(一包2个)
50规格分配器 ZXK50FP 50规格分配器(一包2个)
货号 描述
ZXK16SW10 16mm规格筛网,10um(一包10个)
ZXK26SW10 26mm规格筛网,10um(一包10个)
ZXK50SW10 50mm规格筛网,10um(一包10个)
ZXK16ZS 16规格支撑架(一包10个)
ZXK26ZS 26规格支撑架(一包10个)
ZXK50ZS 50规格支撑架(一包10个)
产品名称 货号 描述
50层析柱密封圈 ZXK50m 50层析柱密封圈(10个/包)
26层析柱密封圈 ZXK26m 26层析柱密封圈(10个/包)
16层析柱密封圈 ZXK16m 16层析柱密封圈(10个/包)
50法兰密封圈 ZXK50F 50法兰密封圈(和夹套管之间的密封,2套/包)
26法兰密封圈 ZXK26F 26法兰密封圈(和夹套管之间的密封,2套/包)
16法兰密封圈 ZXK16F 16法兰密封圈(和夹套管之间的密封,2套/包)
产品名称 货号 描述
50装柱器转接头密封圈 ZXK50ZJT 50装柱器转接头密封圈(2个/包)
50装柱器密封O型圈 ZXK50683 50装柱器密封O型圈(10个/包)
26装柱器转接头密封圈 ZXK26ZJT 26装柱器转接头密封圈(2个/包)
26装柱器密封O型圈 ZXK26683 26装柱器密封O型圈(10个/包)
16装柱器转接头密封圈 ZXK16ZJT 16装柱器转接头密封圈(2个/包)
16装柱器密封O型圈 ZXK16683 16装柱器密封O型圈(10个/包)
50装柱器密封圈套装 ZXK50M 50装柱器密封圈套装(1套/包)
26装柱器密封圈套装 ZXK26M 26装柱器密封圈套装(1套/包)
16装柱器密封圈套装 ZXK16M 16装柱器密封圈套装(1套/包)
ZXKJSLM zxk蛋白层析柱紧锁螺帽
货号 产品名称
ZXK50HSG 50规格活塞长内杆
ZXK16HSG 16规格活塞长内杆
ZXK26HSG 26规格活塞长内杆
ZXK50HS1 50规格活塞短内杆
ZXK16HS1 16规格活塞短内杆
ZXK26HS1 26规格活塞短内杆
ZXK50HS2 50规格活塞长外杆
ZXK16HS2 16规格活塞长外杆
ZXK26HS2 26规格活塞长外杆
产品名称 货号 描述
ZXK16配套上法兰 ZXK16F1 ZXK16配套上法兰(含黑色按钮)
ZXK26配套上法兰 ZXK26F1 ZXK26配套上法兰(含黑色按钮)
ZXK50配套上法兰 ZXK50F1 ZXK50配套上法兰(含黑色按钮)
ZXK16配套下法兰 ZXK16F2 ZXK16配套下法兰
ZXK26配套下法兰 ZXK26F2 ZXK26配套下法兰
ZXK50配套下法兰 ZXK50F2 ZXK50配套下法兰
ZxkR4150 黑色软管,套在zxk16,ZXK26管线上面的,10个/包
zxk1.6-1 16mm或者26mm规格层析柱管线/米
zxk3.2-1 50规格层析柱管线/米
4218-1828-10 1/16接头,外螺纹接头,10个/包 1/16接头
4218-1900-10 1/16堵头(内螺纹堵头)10个/包 1/16堵头
4218-1831-10 韧环,塑料材料,匹配1/8管线,10个/包 韧环,锁环
Z1816-516-10 1/8转1/16一体式转接头(外螺纹1/16,内螺纹5/16,塑料),10个/包 转接头
Z1816-1428-10 1/8转1/16一体式转接头(外螺纹1/16,内螺纹1/4塑料),10个/包 转接头
4218-1826-10 1/8接头,1/4l螺纹,穿1/8管线,10个/包 1/8接头
4218-1855-10 1/8接头,5/16螺纹,穿1/8管线,10个/包 1/8接头
 层析柱铁架台
产品名称 货号 描述
层析柱铁架台
Chromatographic column irong stand
TJT1010 适合内径5mm到50mm的层析柱,高度高达2mm都可以,尺寸:100*100cm
Suitable for inner diameter 5mm to 50mm chromatographic column, height can be as high as 2mm.
多功能层析柱支架
muti-functional chromatographic column stand
TJTY1020  适合内径10mm到100mm的层析柱,高度高达1.5mm都可以Suitable for inner diameter 10mm to 100mm chromatographic column, height can be as high as 1.5mm.
层析柱保护装置
Chromatographic column protective device
层析柱保存时需要连接该配件。因为其能提供一个持续的液体压力,以防止进气和干柱,
When storing, chromatographic column needs to be connected to this accessory. This protective device provides a sustainable hydraulic pressure to prevent air suction and column become dry.
订货信息 Ordering information
货号Item No. 产品名称 Product Name
P17689 层析柱保护装置(不包含转接头)
Chromatographic column protective device(without adaptor)
P18980 层析柱保护装置(包含转接头)
Chromatographic column protective device(with adaptor)
上海宸乔生物科技有限公司是一家专门设计及生产中高压玻璃柱,生物层析柱,蛋白纯化层析柱以及各种实验室设备的生产厂家,同时代理英国Hichrom/Alltech色谱柱,德国Dr. Maisch色谱柱,Grom色谱柱,Ultrasep ES色谱柱,Bexsil,Agilent,Waters,SGL等相关产品,我们色谱柱种类非常齐全,如手性色谱柱,凝胶色谱柱,特殊键合相色谱柱,环境类色谱柱,食品分析色谱柱,嵌入式基团分析柱,蛋白分析柱,糖分析色谱柱,以及各种特殊键合相的色谱柱,同时代理sigma,USP,EPmegazyme糖类标准品,Lumiprobe(活性荧光染料),中检所等标准品,欢迎各位来电咨询
上海市嘉定区阿克苏路1187号大卫国际大厦516室
