注射泵
德国CETONI neMESYS 微流量注射泵
neMESYS Syringe Pumps
进口
德国 CETONI
low Pressure Syring
2千-20万
重庆渝时兴科技有限公司供应德国CETONI 公司neMESYS Syringe Pumps 微流量注射泵全套设备,仪器主体主要包含:控制系统 BASE MODULES + Syringe Pumps,其他配套设备可按需选购。
如有需要,请直接联系我们,以便我们及时回复您!邮箱:order@yuslab.com;电话:15826070259;企业微信号:yuslab
Base Modules
微流动控制系统 (型号:BASE 120, BASE 600)
Base modules are the heart of any Qmix system. They include the power supply for all other modules as well as the USB interface to.
The Heart of the CETONI System
Base modules are the heart of their individual Qmix micro-reaction, microfluidic or flow chemistry system. They are the interface to the control PC and provide power to all connected modules. The integrated USB-interface can be used to easily connect base units to any PC. With the innovative plug connector system, additional Qmix modules can be connected to any base module, without wiring or installation. CETONI offers various power ranges depending on how many modules you want to use and how much power they require.
Pumps
微量注射泵执行器
low Pressure Syringe Pump neMESYS 290N
High Pressure Syringe Pump neMESYS 2600N
Mid Pressure Syringe Pump neMESYS 1000N
Ultra HighPressure Syringe Pump neMESYS XL 7000N
OEM Syringe Pump neMESYS OEM310
OEM Syringe Pump neMESYS OEM210
OEM Syringe Pump neMESYS OEM160
Peristaltic Pump peRISYS-S
微量注射泵执行器的产品简介
The high-precision neMESYS syringe pumps, boasting extremely uniform and pulsation-free fluid dosing and an extensive pressure range of up to 1500 bar, are perfectly suited to creating extremely small fluid streams in microfluidic applications or precise dosing of viscous substances under high pressure in flow chemistry applications.
Precise, pulsation-free, expandable
The neMESYS pump doses liquids with extreme accuracy down into the nanoliter range. Special motors inside the pump move the syringe piston without vibration and thereby allow liquids to be delivered extremely smoothly. neMESYS follows a modular design concept and adapts to your needs. You can even combine multiple pumps. In this way your dosing system can grow along with your application.
CETONI’s central software can control individual pumps or your entire pump system in a very intuitive way. The neMESYS pump comes in various sizes. Depending on your application, you can choose from four models, ranging from low-pressure to ultrahigh-pressure operation.
Completely tailored to your needs
You configure your dosing system together with our application specialists. Thanks to the modular design, you can flexibly adapt your system to changing requirements at any time and easily extend it with additional high-precision syringe pumps, microreaction modules or more powerful valves and pressure sensors.
Together with the powerful software package, the neMESYS syringe pumps offer you unprecedented possibilities in the field of high-precision dosing.
Lift your work to a whole new level now. Our application specialists are always at your side.
Possible applications for our highly precise syringe pumps
The pulsation-free technology used in neMESYS pumps enables safe development of chemical processes and the creation of high-efficiency production plants. Following are a number of application examples for precision syringe pumps:
Dosing of reaction solutions for screening applications and miniaturized syntheses in microfluidics
Highly accurate fluid dosing and creation of minimal, precisely defined fluid streams
In industrial and lab applications
Various lab-on-chip applications, such as DNA amplification (PCR chip)
Creation of micro-serial sample flows in high-throughput applications
Dosing of reagents with periodical gradients for the creation of compartment sequences with variable concentration of ingredients (creation of parameter spaces, e.g. in active agent research)
Absolutely smooth piston movements
When compared to a conventional syringe pump or dilutor, our neMESYS system stands apart due to its ability to create nearly pulsation-free fluid streams. The neMESYS pump doses liquids with extreme precision, even in the nanoliter range. Special motors in the neMESYS pump move the syringe piston without any jerking motions, thereby allowing very smooth fluid delivery. The pulsation-free operation is brought about using the following characteristics:
DC servo motor drives
Position and speed control with closed loop PID-controller
High-precision linear axle with 1 mm inclination
Ball screw
29:1 gear ratio
Stirring Systems  (搅拌系统)
The neMIX stirring systems allow the gentle mixing of suspensions during a dosing process and guarantee a consistent concentration of substance mixtures.
Valve Modules
The Qmix valve modules combine customized Rheodyne high-performance multiport valves with a valve control unit in one compact housing.
Tempering- / Reaction Modules
The Qmix tempering / reaction modules can heat and cool microfluidic chips, micro-reactors, flow-reactors, tubes (tube coil) and customized reactors.
I/O Modules
Qmix I/O modules can extend the Qmix system by a multitude of analog and digital inputs and outputs. This lets you connect external devices and sensors (pressure, temperature, etc.) to a Qmix system in a very simple way.
Detection Modules  (检测模块)
Spectrometer modules with a z-cell and camera modules for online media analysis during the dosing process.
Sample Handler
The miniature sample holders from our rotAXYS series are perfect for applications in which small items, such as pipet tips, tube ends or syringes have to be positioned in a very tight space.
Positioning Systems
High-precision, scalable positioning systems for laboratory and industrial applications
LED Arrays
We offer special LED arrays for precise and selective irradiation. Users can activate specific areas of the array, individual LEDs, LED rows, columns, sections or pre-defined LED combinations.
Accessories 可选择的配件)
Syringes
Heated Syringes
Glass Syringes Mid-Pressure Module
Glass Syringes Low-Pressure Module
Stainless Steel Syringes Medium-Pressure Module
Stainless Steel Syringes High-Pressure Module
Stainless Steel Syringes XL Module
Precision-engineered syringes have equal importance to flow rate accuracy as precision drives. Here you will find high-precision syringes made from a variety of materials (such as glass, stainless steel, etc.) and for various pressure ranges, extending up to 1500 bar.
Syringe Holders
Syringe holders, piston holders and syringe receptacles for our standard syringes as well as special customized models.
Valves
3-2-way valves, non-return valves, ball valves as well as valve accessories for all neMESYS syringe pumps
I/O Components
External pressure sensors and other components for the I/O interface of neMESYS syringe pumps
Cables and Plugs
 All cables and plugs for connecting the neMESYS and Qmix modules.
Clamps and Brackets
Clamps and brackets for holding and fixing multiple neMESYS or Qmix modules simplify the installation and transport of complete systems.
Tubes and Fittings
Here you can find accessories for fluidic connections between individual modules.
Microfluidic Chips
重庆渝时兴科技有限公司(YusLabTechnologyCo.,Ltd.)由科研仪器试剂领域的专业团队组建而成,致力于提供高品质的实验仪器、科研设备、特种化学品、生物试剂产品和实验耗材等;同时也为客户量身定制实验室系统解决方案。
渝时兴科技,创立以来始终以诚信的经营之道赢得客户的信任。
渝时兴科技与国内外优秀的仪器和试剂供应商保持着密切的合作关系,为研究人员提供前沿的资讯和完备的产品。凭借多年积累的丰富销售经验、完善的售后服务以及雄厚的技术支持力量,渝时兴已是多家世界著名品牌的独家代理、一级代理或特约代理。目前,渝时兴科技主要经营产自欧、美等国家的品牌产品,同时为支持国家民族产业,也经营国内产品。中国科学院和众多国内知名高校皆已成为渝时兴科技的尊贵客户。
安礼路128号大学科技园科创中心
