分子生物学试剂
奥地利Smart-elements高纯黑磷
Black Phosphorus - crystal pieces
进口
奥地利 Smart-elements
Purity :~99.998%
2千-1万
A leading supplier for high purity elements, periodic table display samples for research, education and collection - Living science
提供高纯度元素实物!
重庆渝时兴科技有限公司供应奥地利 Smart-elements 高纯度元素实物产品,如有需要,请直接联系我们,以便我们及时回复您!
邮箱:order@yuslab.com;电话:15826070259;企业微信号:yuslab
产品1:
供应奥地利 Smart-elements高纯度的黑磷!
高纯度黑磷小晶片 – 氩气保护安培瓶装
包装规格Amount: 35mg, 100mg, 403mg, 500mg, 600mg, 1.0g, 1500mg, 1509mg, 2212mg, 5g, 10g.
产品纯度Purity: ~99.998%
包装材料Packing: ampoule, Argon
High pure black Phosphorus crystals produced by gas phase transport.
Small crystalline pieces from cutting black P - sealed in ampoule.
高纯黑磷晶体 - 高度光泽和非常稳定的晶体,有蓝黑色的金属光泽。从晶体簇中可分离出1 - 2单晶。用透明胶带方法可制作非常薄的“2D层”。这些黑磷晶体样本非常适合半导体实验。
供应奥地利 Smart-elements高纯度的红磷
红磷, 超纯半导体级红磷
Red Phosphorus - 7N semiconductor grade - 99.99999% 0.5g
This is ultrapure semiconductor grade Phosphorus incl. COA
Amount: 0.5g
Purity :99,999999%
产品2:
氩气下5g高纯金属铕 – 纯度99.99%,货号:03457;
5g High purity Europium metal under argon – 99.99% purity
SKU: 03457 Category: Pure Elements
实验室和收集用优质材料 - 表面无油,在干燥的氩气环境下进行机械清洗。安瓿在出厂前将正确贴上标签。
Description
Top quality material for laboratory and collection – Surface is oil free and was cleaned mechanically under dry argon atmosphere.
The ampoule will be correctly labelled before delivery.
在氩气下,在安瓿中发光>1g–99.99%,货号:03257;
Europium metal crystals distilled, shiny > 1g in Ampoule under Argon – 99.99%
SKU: 03257 Category: Pure Elements
1g+克蒸馏铕金属晶体,表面光亮-在氩气下,安瓿纯度为99.99%。
镧系元素中含量最少、活性最强的一种。在氩气下密封在有吸引力的安瓿中,防止氧化破坏。固体碎片!暴露在空气中,这种金属会在几分钟内分解,生成黄色的Eu(II)氢氧化物!
Description
1g+ gram distilled Europium metal crystals with shiny surface – 99.99% purity in Ampoule under Argon.
One of the least abundant and most reactive Lanthanides. Sealed in attractive ampoule under argon to prevent its destruction by oxidation. Solid pieces! Exposed to air this metal would decompose within minutes to build yellow Eu (II)Hydroxide!
产品3:
Europium (III) – Oxide 99.99% - Eu2O3 – 50.0 grams
SKU:03620
产品4:
High purity Europium metal 10g under argon – 99.99% purity
SKU:03456
10g High purity Europium metal under argon – 99.99% purity
产品5:
1.5克锗断裂多晶体,纯度99.999%,密封在小硼硅酸盐安瓿中(直径12毫米)。
1.5 grams germanium fractures 99.999% polycrystalline
SKU: 03652 Category: Pure Elements
Description
sealed in small boro-silicate ampoule (12mm diameter).
Mini ampoule Germanium fractures under Argon 0.65 gram
SKU: 02920 Category: Pure Elements
Description
sealed under argon in small boro-silicate ampoule (6mm diameter).
产品6:
10 pcs. Indium Metal Ingot 99,995% min. – 100 grams
SKU: 02997 Category: Pure Elements
Description
10 pcs. High purity Indium Metal Ingots – 100 grams each
Size about 52x30x10mm – This is a true opportunity –
Indium is a very rare metal which is essential for production of semiconductors, at screens, TV, Mobile phones and solar technology, however its price is very low at the moment. This is a limited special offer!
Indium Metal Granules / shot 99,999% min.
SKU:03651-1 Categories: Investment/Noble metals, Pure Elements.
Description
High purity Indium Metal shot / granules
particle size ~ 3 – 5mm
Indium is a very rare metal which is essential for production of semiconductors, at screens, TV, Mobile phones and solar technology, however its price is quite low at the moment.
Indium Sulfate 99,99% – In2(SO4)3 – 50g
SKU: 01223 Category: Pure Elements
Description
Indium Sulfate – In2(SO4)3 is a white, water soluble, hygroscopic solid. It’s an important source for the production of Indium Metal.
产品7:
铼粉,5克,纯度>99.95%,货号:01049
密封玻璃瓶中的高纯铼金属粉末。净重5克。用于实验室使用和元素收集。
Rhenium Powder, 5 grams, purity > 99.95%
SKU:01049 Categories: Powder, Pure Elements.
Description
High purity Rhenium Metal Powder in sealed glass bottle. 5g net weight. For laboratory use and elements collection.
产品8:
1克金属钌粉末,纯度99.97%,
1gram ruthenium metal powder, 99.97% purity. SKU:02889.
Description
Fine ruthenium powder, 99.97% purity – 1gram
Sealed in ampoule – For laboratory use and your element collection.
产品9:
供应奥地利 Smart-elements 高纯度锑!
Antimony, 99,9999% purity crystalline pieces – 1.5 grams.
锑,99,9999%纯晶片 – 1.5g
高纯度锑,晶莹剔透- 安瓿纯度99.9999%,这种纯度的锑非常稀有,显示出美丽的晶体结构,可用于半导体应用和高级元素收集。
Description
shiny crystalline pieces of high purity antimony – 99.9999% purity in ampoule. Antimony of such purity is very rare and shows beautiful crystalline structure. For semiconductor applications and for the advanced elements collection.
产品10:
磷化硅单晶,o-SiP大块正交磷化硅单晶
性能:铜光泽,红色半透明晶体血小板。空气稳定,浓度稳定。非氧化性酸。熔点~1110–1130°C。
Silicon phosphide single crystals
o-SiP bulk orthorhombic Silicon phosphide single crystals
Properties: Copper-shining, red translucent crystal platelets. Air stable, stable in conc. non-oxidizing acids. Melting point ~ 1110–1130 °C.
Description
Orthorhombic SiP (o-SiP) is a 2D layered crystal and may have a significant impact on optoelectronic technologies. Differentialscanning calorimetry (DSC) and thermogravimetric analysis (TGA) curves show that o-SiP is thermally stable even at a temperature of 1045 °C. This is very important for device fabrication and practical applications. Unlike graphene, o-SiP has an appropriate band gap that is determined to be 1.7 eV. Bulk o-SiP is a p-type semiconductor with a carrier mobility of 2.034 × 103 cm2 V−1 s−1, which is tenfold that of MoS2. The photoresponse properties of o-SiP were investigated by excitation using a 671 nm laser with different powers of 20, 40, 60, 80, 100 and 120 mW, respectively. Its appropriate band gap and high enough carrier mobility, together with clear photoswitching behavior and relatively fast response, make it possible for o-SiP to be a 2D electronic and optoelectronic material.
产品11:
纯锡粉,<40μ - 20克,纯度99.9%, 货号:03011,用于实验室使用和元素收集。
Pure Tin powder, <40µ - 20 grams, purity 99.9%
SKU:03011; Categories: Powder, Pure Elements.
Description
Pure Tin powder, <40µ – 20 grams, purity 99.9%
产品12:
高纯度金属铽 – 氩气下纯度99,95%,货号:00184;分类:纯元素
High purity Terbium Metal – 99,95% purity under Argon
SKU: 00184 Category: Pure Elements
在氩气下,安瓿里有一块闪亮的铽金属。由于它的空气敏感性,很难找到这种形式。拿去收藏吧!全套稀土金属(16安瓿)可供选择!
Description
Nice shiny piece of Terbium Metal in Ampoule under Argon. Due to its air sensitivity its hard to find in this form. Get it for your collection! A complete Set of all Rare Earth metals (16 Ampoules) is available!
产品13:
氧化铽99.99%/TREO–Tb4O7–5.0克,货号:03619;分类:纯元素
Terbium Oxide 99.99%/TREO – Tb4O7 – 5.0 grams
SKU: 03619 Category: Pure Elements
5g高纯氧化铽(Terbia)是彩电用绿色荧光粉的重要活化剂。同时氧化铽也被用于特殊激光器和固态器件的掺杂。
Description
5 grams high pure Terbium Oxide, also called Terbia, has important role as an activator for green phosphors used in color TV tubes. Meanwhile Terbium Oxide is also used in special lasers and as a dopant in solid-state devices.
产品14:
1.5克金属钇,纯度99.95%,密封在氩气下安瓿中~,货号:01396;类别:纯元素
为你的收藏准备了一件漂亮的作品。材料在氩气下密封在安瓿中以防氧化。全套稀土金属(16安瓿)可供选择!
1.5 grams Yttrium Metal sealed in ampoule ~1.5g 99.95%
SKU: 01396; Category: Pure Elements
Description
1.5 grams Yttrium metal 99.95% sealed in ampoule under Argon. Beautiful piece for your Collection. The material is sealed in ampoule under argon to prevent oxidation. A complete Set of all Rare Earth metals (16 Ampoules) is available!
5克钇金属片装在氩气下密封的小瓶中,货号:03390,类别:纯元素
5 grams Yttrium Metal pieces sealed vial under Argon
SKU: 03390 Category: Pure Elements
高纯度钇金属片,纯度99.95%,装在氩气下密封的小瓶中-无需工具即可打开卷曲盖密封-供实验室使用和收集元素。
Description
High purity Yttrium Metal pieces 99,95% in sealed vial under Argon – The crimp cap seal can be opened simply without tools – For laboratory use and your elements collection.
产品15:
氧化钇(III)99,99%–Y2O3–5,0克,货号:03383,类别:化合物
Yttrium (III) oxide 99,99% – Y2O3 – 5.0 grams
SKU: 03383 Category: Compounds.
氧化钇,高纯氧化钇是制备彩色电视和电脑管红色三波段稀土荧光粉的重要材料。在光学工业中,氧化钇被用来生产钇铁石榴石,这是非常有效的微波滤波器。低纯度氧化钇在电子陶瓷中有着广泛的应用。熔点:2410摄氏度。用这种材料很容易生产出其他钇化合物。
Description:
High pure Yttrium (III) oxide 99,99% 5 grams
Yttrium Oxide, also called Yttria, high purity Yttrium Oxides are the most important materials for tri-bands Rare Earth phosphors which give the red color in color television & computer tubes. In optical industry, the Yttrium Oxide is used to produce yttrium-iron garnets, which are very effective microwave filters. Low purity of Yttrium Oxide is widely applied in electronic ceramics.
Melting point: 2410 Grad C.
It’s easy to produce other Yttrium compounds with this material.
重庆渝时兴科技有限公司(YusLabTechnologyCo.,Ltd.)由科研仪器试剂领域的专业团队组建而成,致力于提供高品质的实验仪器、科研设备、特种化学品、生物试剂产品和实验耗材等;同时也为客户量身定制实验室系统解决方案。
渝时兴科技,创立以来始终以诚信的经营之道赢得客户的信任。
渝时兴科技与国内外优秀的仪器和试剂供应商保持着密切的合作关系,为研究人员提供前沿的资讯和完备的产品。凭借多年积累的丰富销售经验、完善的售后服务以及雄厚的技术支持力量,渝时兴已是多家世界著名品牌的独家代理、一级代理或特约代理。目前,渝时兴科技主要经营产自欧、美等国家的品牌产品,同时为支持国家民族产业,也经营国内产品。中国科学院和众多国内知名高校皆已成为渝时兴科技的尊贵客户。
安礼路128号大学科技园科创中心
