分子生物学试剂
美国 US-Nano 高纯纳米元素和合金
US Research Nanomaterials Elements and Alloys
进口
美国 US-Nano
(Ag, 99.99%, 80-100
2千-1万
本公司供应美国US Research Nanomaterials  纳米元素和合金  Elements and Alloys。
具体产品目录如下:
重庆渝时兴科技有限公司代理销售美国 US Research Nanomaterials, Inc.  (https://www.us-nano.com/) 全线产品,欢迎订购!
如有需要,请直接联系我们,以便我们及时回复您!邮箱:order@yuslab.com;电话:15826070259;企业微信号:yuslab
CAS Number Stock# Product Descriptions
7440-22-4 US1008 Silver Nanopowder (Ag, 99.99%, 80-100 nm, metal basis)
7440-22-4 US1018 Silver Nanopowder ( Ag, 99.99% , 50-80 nm, w/~0.2% PVP )
7440-22-4 US1028 Silver Nanopowder (Ag, 99.99%, 50-80 nm, metal basis)
7440-22-4 US1035 Silver Nanopowder (Ag, 99.99%, 30-50 nm, w/~0.2 wt% PVP Coated)
7440-22-4 US1036 Silver Nanopowder (Ag, 99.99%, 30-50nm, metal basis)
7440-22-4 US1037 Silver Nanopowder (Ag, 99.99%, 20nm, w/~0.2% PVP )
7440-22-4 US1038 Silver Nanopowder (Ag, 99.99%, 20nm, metal basis)
7440-22-4 US7130 Ag Dispersion 2nm, 200ppm
7440-22-4 US7150 Ag Dispersion 2nm, 2000ppm
7440-22-4 US7140 Ag Dispersion 15nm, 1000ppm
7440-22-4 US7160 Ag Dispersion 15nm, 50,000ppm
7440-22-4 US1004F Ag Doped Antibacterial Nanopowder
7440-22-4 US1891 Ag Coated Copper 99.5%, 300nm
7440-22-4 US1148M   Ag 99.99%, 0.5, 0.8, 1, 3, 5, 8um
7440-22-4 US5005 Al 99.7%, 0.5, 1, 5, 10, 30, 45um
7429-90-5 US1042 Aluminum Nanoparticles (Al, 99.9%, 800 nm, metal basis)
7429-90-5 US1043 Aluminum Nanopowder (Al, 99.9+%, 100nm, metal basis)
7429-90-5 US1048 *Aluminum Nanopowder (Al, 99.9%, 70nm, metal basis)
7429-90-5 US1050 *Aluminum Nanopowder (Al, 99.9%, 40nm, metal basis)
7429-90-5 US1052 *Aluminum Nanopowder (Al, 99.9%, 18nm, metal basis, Laser synthesized )
7440-57-5 US1056 Gold Nanopowder (Au, 99.99+%, 50-100 nm)
7440-57-5 US1055 Gold Nanopowder (Au, 99.97+%, 28 nm)
7440-57-5 US1054 Gold Nanopowder (Au, 99.95+%, 15 nm)
7440-57-5 US7805 Gold (Au) Nanopowder / Nanoparticles Water Dispersion (Au Nanoparticles Aqueous Dispersion, 14 nm, 1000 ppm, Purple Color)
7440-06-4  US7801 Platinum (Pt) Nanopowder / Nanoparticles Water Dispersion (Pt Nanoparticles Aqueous Dispersion, 3nm, 1,000ppm, Black Color)
7440-42-8 US1057 Boron Nanopowder / Nanoparticles (B, 92%, 1-2um)
7440-42-8 US1016M Boron Nanopowder (B, 99+%, 1-2um)
7440-42-8 US1051 Boron Nanoparticles (B, 99.5+%, 500nm)
7440-42-8 US1151 B Nanopowder / Boron Nanoparticles (B, 99.9%, 100nm)
7440-69-9    US1053 Bismuth Bi Nanoparticles / Nanopowder (Bi, 80nm, 99.9%, Metal Basis)
7782-40-3 US1062 Diamond (C) Nanoparticles / Nanopowder (C, 54.5%, 3-10 nm)
7782-40-3 US1066 Diamond Nanopowder / Nanoparticles (C, >98.3%, 3-10 nm)
7782-42-5 US1058 Graphite (C) Nanopowder / Nanoparticles (C, 400nm - 1.2 um, 99.9%, Natural Graphite)
1333-86-4 US4899 Super Conductive Carbon Black Nanopowder and Carbon Nanotube Mixed
7440-44-0 US1074 Super Activated Porous Carbon (C) Nanopowder / Nanoparticles (C, 20-40nm, Plant as Raw Materials)
7440-44-0 US1075 Super Activated Porous Carbon (C) Nanopowder / Nanoparticles (C, 60-80nm, Plant as Raw   Materials)
7440-44-0 US1076 Super Activated Carbon (C) Nanopowder / Nanoparticles (C, <100nm, Coconut Shell as Raw Materials)
7440-44-0 US1077 Super Activated Carbon (C) Nanopowder / Nanoparticles (C, <100nm, Bamboo as Raw Materials)
7440-44-0 US1078 Super Activated Carbon (C) Nanopowder / Nanoparticles (C, <100nm, Charcoal as Raw  Materials)
7440-44-0 US4898 Super Activated Carbon Nanoparticles and Carbon Nanotubes Mixed
99685-96-8 US4450 Carbon NanoFibers, Purity: >95%, OD: 200-600nm
7782-42-5 US4460 Graphitized Carbon NanoFibers, Purity: >99.9%, OD: 200-600nm
7782-42-5 US1059 Research Grade Graphene Nanoplatelets (99.5+%, Thickness 2-8nm, 3-6 Layers)
7782-42-5 US1073 Graphene Nanoplatelets / Graphene NanoPowder (95+%, Thickness 2-8nm, 3-6 layers)
7782-42-5 US7905 Research Grade Single Layer Graphene Nanoparticles 1wt% Water Dispersion
7782-42-5 US1011 Research Grade Single Layer Graphene Nanopowder with High Purity 99.3%
7782-42-5 US1012 Research Grade Single Layer Graphene Powder N Doped with High Purity 99.3%
7782-42-5 US7906 Research Grade Single Layer Graphene Oxide Water Dispersion (Thickness 0.43 - 1.23 nm, Diameter 1.5 - 5.5 um, Dispersed in water with 2wt%)
7440-48-4 US1079 Cobalt (Co) Micro Powder (Co, high purity, 99.9%, APS 1.3 um, metal basis)
7440-48-4 US1080 Cobalt Co Nanopowder / Nanoparticles (Co, 99.8%, 28 nm, partially passivated, metal basis)
7440-48-4 US1081 Cobalt Co Nanopowder / Nanoparticles (Co, 99.8%, 28 nm, carbon coated, metal basis)
7440-47-3 US1086 Chromium Cr Nanopowder / Nanoparticles (Cr, 99.9%, 35-45 nm, metal basis)
7440-50-8 US8001 Cu Wire / Copper Wire, Diameter 100-300nm, Length 5-7um, Purity 99.5%
7440-50-8 US1082 *Copper Nanopowder (Cu, 99.9%,    580 nm, metal basis)
7440-50-8 US1087 *Copper Nanopowder (Cu, 99.9%, 90-250 nm, metal basis)
7440-50-8 US1088 *Copper Nanopowder (Cu, 99.9%, 100nm, metal basis)
7440-50-8 US1089 *Copper Nanopowder (Cu, 99.9%, 70nm, metal basis)
7440-50-8 US1090  *Copper Nanopowder (Cu, 99.9%,   40 nm, metal basis)
7440-50-8 US1827 *Copper Nanoparticles / Nanopowder (Cu, Cu2O Coated, 99%, 30 nm)
7440-50-8 US1828 *Copper Nanoparticles / Nanopowder (Cu, Partially Passivated, 99.8%, 25   nm)
7440-50-8 US1829 *Copper Nanoparticles / Nanopowder (Cu-Carbon Coated, 99.8%, 25 nm)
7439-89-6 US1097 *Iron Nanopowder (Fe, 99.5+%, 95-105nm, metal basis)
7439-89-6 US1099 *Iron Nanopowder (Fe, 99.5+%, 65-75nm, metal basis)
7439-89-6 US1101 *Iron Nanopowder (Fe, 99.5+%, 35-45nm, metal basis)
7439-89-6 US1105 *Iron Nanopowder (Fe, 99.5%, 25 nm, partially passivated, Matal basis)
7439-89-6 US1106 *Iron Nanopowder (Fe, 99.5%, 25 nm, carbon coated, Matal basis)
7440-74-6 US1103 Indium (In) Nanopowder / Nanoparticles (In, 99.99%, 80nm, tetragonal   crystalline, black)
7440-02-0 US1119 *Nickel Nanopowder (Ni, 99.9%, 100 nm, metal basis)
7440-02-0 US1118 *Nickel Nanopowder (Ni, 99.9%, 70 nm, metal basis)
7440-02-0 US1120 *Nickel Nanopowder (Ni, 99.9%, 40 nm, metal basis)
7440-02-0 US1124 *Nickel Nanopowder (Ni, 99.9%, 20nm, partially passivated, metal basis)
7440-02-0 US1125 *Nickel Nanopowder (Ni, 99.9%, 20nm, carbon coated, metal basis)
7440-21-3 US1121 Silicon MicroPowder (Si, 99.9%, 1-3 um, Polycrystalline)
7440-21-3 US1127 Silicon Nanopowder (Si, >99%, 100nm, Polycrystalline   Nanopowder&Nanowire mixed)
7440-21-3 US1130 Silicon Nanopowder (Si, 98+%, <80 nm, laser Synthesized,   Polycrystalline structure )
7440-21-3 US1129 Silicon Nanopowder (Si, 98+%, 50-70 nm, laser Synthesized,   Polycrystalline structure )
7440-21-3 US1131 Silicon Nanopowder (Si, 98+%, 30-50 nm, laser Synthesized,   Polycrystalline structure )
7440-21-3 US1135 Silicon Nanopowder (Si, 98+%, 20-30 nm, laser Synthesized,   Polycrystalline structure )
7440-33-7 US1158 *Tungsten Nanopowder (W, 99.95+%,    70 nm, metal basis)
7440-33-7 US1159 *Tungsten Nanopowder (W, 99.95+%,    40-60 nm, metal basis)
7440-65-5 US1302 Yttrium Powder (Y, 99.9%, 40um)
7440-66-6 US1163 *Zinc Nanopowder (Zn, high purity, >99.99%, 95-105 nm, metal basis)
7440-66-6 US1166 *Zinc Nanopowder (Zn, high purity, 99.99+%,  65-75 nm, metal basis)
7440-66-6 US1167 *Zinc Nanopowder (Zn, high purity, 99.99+%,  35-45 nm, metal basis)
7440-02-0 and 7440-32-6 US1369 *Ni-Ti Alloy Nanopowder, 99.9%, 30-120 nm, Ni:Ti/50:50
7440-31-5 and 7440-50-8  US1469 *Sn-Cu Alloy Nanopowder, 99.9%, 40 nm-100 nm, SN:CU/9:1
7440-31-5 and 7440-50-8  US1470 *Sn-Cu Alloy Nanopowder, 99.9%, 40 nm-100 nm, SN:CU/1:9
7440-31-5 and 7440-50-8  US1471 *Sn-Cu Alloy Nanopowder, 99.9%, 40 nm-100 nm, SN:CU/92:8
7439-89-6   and 7440-02-0  and 7440-48-4 US1569 *Fe-Ni-Co Alloy Nanopowder, 99.9%, 40 nm-100 nm, Fe:Ni:Co/55:28:17
7439-89-6 and 7440-02-0 US1669 *Fe-Ni Alloy Nanopowder, 99.9%, 40 nm-100 nm, Fe:Ni/5:5
7439-89-6 and 7440-02-0 US1670 *Fe-Ni Alloy Nanopowder, 99.9%, 40 nm-100 nm, Fe:Ni/2:8
7439-89-6   and 7440-47-3 and 7440-48-4   US1869 *Fe-Cr-Co Alloy Nanopowder, 99.9%, 40 nm-100nm, Fe:Cr:Co/64:25:11
7440-50-8 and 7440-66-6  US1879 *Cu-Zn Alloy Nanopowder, 99.9%, 40 nm-100 nm, Cu:Zn/5:5
7440-50-8 and 7440-66-6  US1880 *Cu-Zn Alloy Nanopowder, 99.9%, 40 nm-100 nm, Cu:Zn/6:4
7440-22-4/744050-8 US1890 *Ag-Cu Nanopowder, 99.9%, <100nm
7440-22-4/744031-5 US1895 Ag-Sn Nanopowder, 99.9%, <100nm
7440-47-3/7440-02-0 US1769 *Ni-Cr Nnaopowder, 99.9% <100nm
7440-02-0/744047-3/7440-48-4 US1900 *Ni-Cr-Co Nanopowder, 99.9% <100nm
7440-47-3/743989-6/7440-02-0 US316L 316L Nanoparticles / Stainless Steel 316L Nanopowder, 99.9%, 50nm
7440-21-3/742990-5 US1918 Cu-Ni Alloy Nanopowder / Cu-Ni Alloy Nanoparticles, 99.9%, <100nm
7440-21-3/742990-5 US1919 Cu-In Alloy Nanopowder / Cu-In Alloy Nanoparticles, 99.9%, <500nm
7440-21-3/742990-5 US1921 Ag-In Alloy Nanopowder /   Ag-In Alloy Nanoparticles, 99.9%, <100nm
7440-21-3/742990-5 US1922 Cu-In-Ga Alloy Nanopowder   / Cu-In-Ga Alloy Nanoparticles, 99.9%, <500nm
7440-21-3/742990-5 US1923 Cu-In-S Alloy Nanopowder /   Cu-In-S Alloy Nanoparticles, 99.9%, <100nm
7440-22-4/744050-8 US1891 Silver-coated Copper Powder    (800nm, 99.5%, Ag 20wt%, Cu 80wt%)
重庆渝时兴科技有限公司(YusLabTechnologyCo.,Ltd.)由科研仪器试剂领域的专业团队组建而成,致力于提供高品质的实验仪器、科研设备、特种化学品、生物试剂产品和实验耗材等;同时也为客户量身定制实验室系统解决方案。
渝时兴科技,创立以来始终以诚信的经营之道赢得客户的信任。
渝时兴科技与国内外优秀的仪器和试剂供应商保持着密切的合作关系,为研究人员提供前沿的资讯和完备的产品。凭借多年积累的丰富销售经验、完善的售后服务以及雄厚的技术支持力量,渝时兴已是多家世界著名品牌的独家代理、一级代理或特约代理。目前,渝时兴科技主要经营产自欧、美等国家的品牌产品,同时为支持国家民族产业,也经营国内产品。中国科学院和众多国内知名高校皆已成为渝时兴科技的尊贵客户。
安礼路128号大学科技园科创中心
