动物实验仪器
大鼠气道给药,小鼠气道给药套装
大鼠气道给药,小鼠气道给药套装
大鼠气道给药,小鼠气道给药套装,大鼠呼吸道给药,小鼠呼吸道给药套装
动物气道给药,动物气道给药套装,动物肺
动物气道给药,动物气道给药套装,动物肺
请致电:021-35183767,Email:yuyan0317@126.com
大小鼠气管给药喷雾器(Liquid Aerosol Devices, MicroSprayer® Aerosolizers) 输送气溶胶提供了更好的方案,直接对大鼠、小鼠气管内进行定量雾化给药,方便、安全、快捷。
套装主要包括气溶胶雾化喷射头,高压注射器组成。
有两种型号可供选择:大鼠型气管内定量给药套装,小鼠型气管内定量给药套装
大小鼠气管内定量给药装置的主要特色:
产品介绍:
·  快速、精确的直接肺部给药——气溶胶无浪费
·  纯机械 动力,无外部空气进入
·  不需加热、 推进剂、超声波或压缩空气等,对药物物影响
·  手持式设计的独特专利,使用非常方便
·  喷射头顶端圆滑的设计,保证安全、温和的插入气管内
·  可高温高压消毒灭菌,可重复使用
·  比其它雾化器和吸入设备提供更高浓度发药物体积或剂量
·  比传统滴注法给药提供更均匀的药物分布
使用方法示意图:
Expanding the reach of aerosol drug delivery
Deliver a soft mist directly to the lung with
Penn-Century’s unique liquid and dry powder devices
大小鼠气管内给药装置:
consists of the MicroSprayer® Aerosolizer – Model IA-1C-M and the FMJ-250 High Pressure Syringe, which is required for use of the Model IA-1C devices. The MicroSprayer® Aerosolizer – Model IA-1C-M is designed for fast, targeted, air-free intratracheal aerosol administration to mouse. The device generates a precisely quantifiable, highly-concentrated, air-free plume of liquid aerosol directly into the lungs or other locations. It may also be used for intranasal or in vitro applications. It can aerosolize a wide range of liquids or particle solutions/suspensions, including pharmaceutical, and biologic formulations, contrast/imaging agents and toxicological materials. (It is does not administer dry powders.)
The portion that is inserted into the trachea measures 1.25″. For intrapulmonary applications, the tip of the device is gently inserted down the trachea of the anesthetized animal – near to, but not touching the carina (first bifurcation).
· Quick, precise aerosol dosing directly to the lungs – with no waste
· Purely mechanical, air-free technology
· Uses no heat, propellant, ultrasound or compressed air. No air burden to subject.
· Unique patented design is light, hand-held, easy to use
· Rounded tip permits safe, gentle intratracheal insertion
· Fully sterilizable, autoclavable and reusable
· Delivers a far higher volume and concentration than is possible with nebulizer/inhalation systems
· Produces a far broader, more uniform distribution than liquid bolus/droplet instillation methods
大鼠、小鼠喉镜
小鼠专用喉镜,明亮清晰的照明,更方便观察气管和会厌。
It is makes intratracheal intubation and insertion of Penn-Century’s MicroSprayer® Aerosolizers and Dry Powder Insufflators™ easier, quicker and safer. Each laryngoscope comes with a small, tapered stainless steel blade that is custom-made for use with a specific experimental animal. The blade assembly at the top of the handle is detachable. Additional blade assemblies may be purchased for use with animals of other sizes.
· Long-lasting fiber-optic LED light source offering clear, bright illumination
· Easy-grip handle in a curved ergonomic shape that rests in the palm of the hand
· Handle is coated with non-slip green Santoprene™ rubber
· Long-lasting illumination. Operates with a 3 volt lithium battery provided
· Custom-made stainless steel blade tip for holding aside the animal’s tongue
· Both the handle and detachable blade assembly are sterilizable and autoclavable
大鼠、小鼠气管插管平台
The Mouse Intubation Platform is specially designed to assist researchers working with PennCentury intratracheal aerosol devices or intubation procedures in mice. The Mouse Intubation Platform provides a simple, durable, lightweight, easy-touse system for supporting the anesthetized mouse during intubation and/or insertion of our aerosol delivery devices. Features solid Plexiglass®/Perspex® base and stainless steel support rod, easily attached to any standard lab clamp stand (not included).
· Special adjustable neck support with Delrin® fittings to facilitate visualization of the trachea.
· Stainless steel posts with plastic “wire” maintain the anesthetized animal in the correct position for intubation, suspended from the front incisors.
· Two side posts to secure the mouse on its back with a rubber band.
· Additional, adjustable stainless steel side posts prevent lateral movement of the mouse during intubation
如需做大小鼠的气管插管手术,还可以配套使用 气管插管平台、可调角度手术板、大小鼠气管插管工具包套装
气管插管平台
可调角度手术板
大小鼠气管插管工具包套装
您想了解更多详细资料吗?
请与我们联系:
TEL:021-35183767,18502129044
QQ:3007536034
Mail:yuyan0317@126.com
欢迎您的咨询!
         卓越品质  贴心服务    ---玉研仪器
上海玉研科学仪器有限公司是一家专业为生物、医学、药物研发等科研领域提供科学仪器和技术服务的公司。我们着力引进和开发应用成熟、性能先进的实验设备和实验方法,为科学研究和实验室建设提供有效、合理的解决方案。
玉研仪器专注于生理、药理、毒理等动物实验和研究的相关领域,为客户提供动物麻醉与辅助呼吸、生理信号检测与记录、动物给药与暴露染毒、呼吸功能测量与肺功能研究、代谢与缺血缺氧研究、疼痛与炎症研究、小动物行为学研究、神经科学研究、小动物活体成像、生化检验、动物手术与辅助设备、动物手术器械等多方面的科学仪器产品和定制化服务。
玉研仪器致力于打造动物科研仪器领域的百科全书!
经营理念:诚信经营、实干兴邦、积极进取、回报社会
服务理念:客户至上、主动服务、快速响应、解决彻底
我们的使命:提供优质产品和高效服务,助力科研,成就科研
关注玉研仪器微信号:
在接到用户仪器维护和保养服务通知后,相应维修中心将在4小时内响应;并将派遣合格维修工程师在4个工作日内抵达现场进行维修并解决问题。(上海地区24小时内负责维修或更换损坏的零件) 专业的售后服务队伍 在保修期内,凡非人为因素导致仪器的故障均免费维护,售后服务中心将为用户免费更换配件,不收取任何费用,仪器保修期为:1年
上海市闵行区兴梅路579号科技绿洲B1栋3层
