光谱/分光光度计
红外线和紫外线激光等半导体泵浦固体激光器
进口
美国
CrystaLaser
全国销售服务热线:4006-171751
Tel: 021-33530926   Fax:021-33530928   Email: info@bosontech.com.cn
网址:www.BosonTech.com.cn
美国CrystaLaser,绿激光、蓝激光器、紫激光器、黄激光、红激光、红外线和紫外线激光等半导体泵浦固体激光器
如果您对CrystaLaser产品的价格、厂家、型号等相关信息有什么疑问,请联系我们获取CrystaLaser产品的最新信息。
我们的宗旨是以最好的质量最快的速度服务我们的客户。
CrystaLaser, founded in 1995, located in Reno, Nevada, USA, is a leading manufacturer and designer of ultra-compact diode-pumped solid-state DPSS crystal laser systems. We design, manufacture, assembly and service the laser products in the USA.
CrystaLaser provides turn-key laser solutions. The lasers feature with high laser efficiency, high reliability, high stability and excellent laser beam quality. The lasers are designed very easy to use, plug and play.
CrystaLaser manufactures compact diode-pumped solid-state DPSS crystal laser products including diode-pumped green laser, violet laser, blue laser, yellow laser, orange laser, red laser, infrared laser and ultraviolet UV Laser systems. The Nd:YAG, Nd:YLF, Nd:YVO4, and SHG THG FHG of YAG, YLF and YVO4 lasers with true CW output and Q-switched pulsed output are for industrial instrumentation applications in holography, biomedical, fluorescence, reprographics, laser trapping, interferometry, semiconductor inspection and material processing.
CrystaLaser provides the most wide laser wavelength selections of the compact solid-state lasers. Over 40 laser wavelength selections from UV, blue, green, yellow, red to IR are available
The diode-pumped solid state lasers are based on our proprietary laser cavity technology, which allows the lasers to operate in a single longitudinal mode and single TEMoo mode with low noise and extremely low power consumption in a compact laser housing.
CrystaLaser is the exclusive distributor in the North America for the laser products of Rainbow Photonics, Zurich, Switzerland Infrared tunable cw laser, SBS Cells, DAST Crystals and KNbO3 Waveguides
上海玻色智能科技有限公司是一家仪器设备的代理与系统集成业务的综合性服务商,总部设在上海,业务覆盖国内各著名高校、中国科学院所属各研究所、信息产业部所属各研究所、航空工业总公司所属各研究所等不同系统内的研究机构,以及相关领域内的各大生产型公司。
玻色由具有丰富的仪器设备应用和使用经验的人员组成,我们不仅仅代理设备,我们同时提供基于各种设备本身的各种拓展应用和研发。公司代理的主要产品有海洋光学的光纤光谱仪等,我们在光纤光谱仪行业有着多年的工作经验,积累了大量的应用和研发实例,可以为客户提供一站式的解决方案。
为什么是玻色(Boson)?
玻色子(boson),得名于印度物理学家玻色。玻色子是指自旋为0或整数的粒子,例如光子、π介子等。不遵守泡利不相容原理。在低温时可以发生玻色-爱因斯坦凝聚,符合玻色-爱因斯坦统计。
在这样的一个量子世界里,所有的成员都有标定各自基本特性的四种量子属性:质量、能量、磁矩和自旋。这四种属性当中,自旋的属性是最重要的,它把不同种粒子王国分成截然不同的两类,就好像这个世界上因为性别将人类分成了男人和女人一样意义重大。粒子的自旋不像地球自转那样是连续的,而是一跳一跳地旋转着的。根据自旋倍数的不同,科学家把基本粒子分为玻色子和费米子两大类。费米子是像电子一样的粒子,有半整数自旋(如1/2,3/2,5/2等);而玻色子是像光子一样的粒子,有整数自旋(如0,1,2等)。
这种自旋差异使费米子和玻色子有完全不同的特性。没有任何两个费米子能有同样的量子态:它们没有相同的特性,也不能在同一时间处于同一地点;而玻色子却能够具有相同的特性。基本粒子中所有的物质粒子都是费米子,是构成物质的原材料(如轻子中的电子、组成质子和中子的夸克、中微子);而传递作用力的粒子(光子、介子、胶子、W和Z玻色子)都是玻色子。
玻色科技就是一个传递作用力的小粒子,我们希望收集全世界最优秀的,最顶尖的设备和技术,通过我们的努力,整合为各种应用系统、解决方案,然后传递到中国的客户。
www.bosontech.com.cn
上海市陕西北路1438号财富时代广场1821室
