其它各类仪器
英国OXTS惯导RT3000V3总代汽车测试自动驾驶
OXTS
进口
OXTS
RT3000V3
Now with onboard RT-Range S Hunter capabilities
The RT3000 v3 comes with optional RT-Range Hunter capabilities for ADAS
testing. Track up to 4 moving targets, knowing their position, orientation,
speed and acceleration relative to the vehicle under test. It all happens
on one device meaning reduced setup times and less hassle.
/ NEW indoor positioning
interface for testing with
Locata technology indoors
/ High speed GNSS for high
dynamic conditions
/ RTK 1 cm position accuracy
/ 0.150° slip angle accuracy
/ 0.03° Pitch/roll for high accuracy
ride and handling tests
/ Driving robot interface
/ Up to 250 Hz data output rate
/ Dual antenna
/ GPS, GLONASS, Beidou
/ Wheel speed input
Options
/ NEW onboard RT-Range S Hunter
processor for ADAS testing
/ CAN acquisition
/ Network DGPS
/ ISO 17025 calibration
Hardware
GPS+GLONASS RT3000 L1 only RT3000
Performance1
Positioning L1 L1, L2
Position accuracy (CEP)
SPS 1.8 m 1.5 m
SBAS 0.6 m 0.6 m
DGPS 0.4 m 0.4 m
RTK 0.01 m
Velocity accuracy (RMS) 0.1 km/h 0.05 km/h
Roll/pitch accuracy (1σ) 0.05º 0.03º
Heading accuracy (1σ)2 0.1º 0.1º
Track angle accuracy (1σ)3 0.1º 0.07º
Slip angle accuracy (1σ)4 0.2º 0.15º
Hardware
Dimensions 184 x 120 x 71 mm
Mass 1.4 kg
Input voltage 10-50 V dc
Power consumption 15 W
Operating temperature -40º to +70ºC
Environmental protection IP65
Vibration 0.1 g2/Hz, 5-500 Hz
Shock survival 100 g, 11 ms
Internal storage 32 GB
Sensors
Type Accelerometers Gyros
Technology Servo MEMS
Range Optional
10 g
30 g
100º/s
300º/s
Bias stability 2 μg 2º/hr
Linearity 0.01% 0.05%5
Scale factor 0.1% 0.1%
Random walk 0.005 m/s/√hr 0.2º/√hr
Axis alignment <0.05º <0.05º
北京GNSS卫星导航系统,雷达监测与导航系统的市场服务和技术工作。公司根据市场专业化和差异化的细分导向为原则,以客户的价值就是我们的价值为目标,为每个行业提出具有针对性的解决方案。为确保我们的产品和技术服务的精确性,及时性,有效性,满意度,我们严格按照ISO9001:2000质量管理体系来实现公司内部的严密管理程序和顾客端的灵活优化服务水平。
 北京诺耕科技发展有限公司以专业化和以人为本的基本经营理念,专业从事基于惯性测量系统,GNSS卫星导航系统,雷达监测与导航系统的市场服务和技术工作。公司根据市场专业化和差异化的细分导向为原则,以客户的价值就是我们的价值为目标,为每个行业提出具有针对性的解决方案。为确保我们的产品和技术服务的精确性,及时性,有效性,满意度,我们严格按照ISO9001:2000质量管理体系来实现公司内部的严密管理程序和顾客端的灵活优化服务水平。
    公司自成立以来,始终坚持诚信为本,质量为本,服务为本的经营原则,组建了高效的技术服务和市场营销团队,为国内外客户提供优质的产品,解决方案和服务,并且在多个行业和领域占据了市场主导地位。公司在自身飞速发展的同时,并没有忘记回报社会和企业的社会责任,将公益事业和环保事业作为与企业共生共存的事业来做,力争做优秀的企业公民。
我们的价值观:责任、卓越、创新;
我们的愿景-汇聚英才,突破创新,竞争优势,迎接挑战,创造可持续价值;
公司主营产品:
    经营产品有GPS/INS组合导航系统,姿态方位参考系统/AHRS,垂直陀螺/VG,惯性测量单元/IMU,自主驾驶系统,光纤陀螺,微机械陀螺,加速度传感器,倾角传感器,六维力和力矩传感器,GPS接收机,GPS天线,GPS转发器,高精度高动态GPS,微波/毫米波雷达,激光雷达,3D激光测距相机,光学数据传输设备,局域定位系统等。
北京市朝阳区民族园路2号丰宝恒大厦5034
