ibid耗材 81150 高壁培养皿
81150 | µ-Dish 35 mm, 高壁培养皿, 有hydrogel layer ,不贴壁,生物惰性表面 | µ-Dish 35 mm, high with non-adherent, passivated Bioinert surface | 30 | 5980.00 |
81156 | µ-Dish 35 mm, 高壁培养皿,ibiTreat底部处理 | µ-Dish 35 mm, high ibiTreat: Ø 35 mm, high wall (2 ml volume), #1.5 polymer coverslip, tissue culture treated, sterilized | 60 | 3980.00 |
81156-400 | µ-Dish 35 mm, 高壁培养皿,ibiTreat底部处理 | µ-Dish 35 mm, high ibiTreat: Ø 35 mm, high wall (2 ml volume), #1.5 polymer coverslip, tissue culture treated, sterilized | 400 | 23800.00 |
81151 | µ-Dish 35 mm, 高壁培养皿,无包被 | µ-Dish 35 mm, high Uncoated: Ø 35 mm, high wall (2 ml volume), #1.5 polymer coverslip, hydrophobic, sterilized | 60 | 3980.00 |
80416 | µ-Dish 35 mm, 四区块 高壁培养皿,ibiTreat底部处理 | µ-Dish 35 mm Quad ibiTreat: Ø 35 mm, #1.5 polymer coverslip, tissue culture treated, sterilized | 60 | 6980.00 |
80411 | µ-Dish 35 mm, 四区块 高壁培养皿,无包被 | µ-Dish 35 mm Quad Uncoated: Ø 35 mm, #1.5 polymer coverslip, hydrophobic, sterilized | 60 | 6980.00 |
80136 | µ-Dish 35 mm, 低壁培养皿,ibiTreat底部处理 | µ-Dish 35 mm, low ibiTreat: Ø 35 mm, low wall (800 µl volume), #1.5 polymer coverslip, tissue culture treated, sterilized | 60 | 3880.00 |
80131 | µ-Dish 35 mm, 低壁培养皿,无包被 | µ-Dish 35 mm, low Uncoated: Ø 35 mm, low wall (800 µl volume), #1.5 polymer coverslip, hyrophobic, sterilized |
60 | 3880.00 |
80137 | µ-Dish 35 mm, 低壁培养皿,玻璃底 | µ-Dish 35 mm, low Glass Bottom: Ø 35 mm, low wall (800 µl volume), #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized, 5 per case | 60 | 4680.00 |
81136 | µ-Dish 50 mm, 低壁培养皿,ibiTreat底部处理 | µ-Dish 50 mm, low ibiTreat: Ø 50 mm, low wall (3 ml volume), #1.5 polymer coverslip, tissue culture treated, sterilized | 30 | 3980.00 |
81131 | µ-Dish 50 mm, 低壁培养皿,无包被 | µ-Dish 50 mm, low Uncoated: Ø 50 mm, low wall (3 ml volume), #1.5 polymer coverslip, hydrophobic, sterilized | 30 | 3980.00 |
81158 | µ-Dish 35 mm,高壁,玻璃底 | µ-Dish 35 mm, high Glass Bottom: Ø 35 mm, high wall (2 ml volume), # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 60 | 4280.00 |
81158-400 | µ-Dish 35 mm,高壁,玻璃底 | µ-Dish 35 mm, high Glass Bottom: Ø 35 mm, high wall (2 ml volume), # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 400 | 24800.00 |
81291 | µ-Dish 35 mm, high ESS 弹性支撑表面,1.5kPa,无包被 | µ-Dish 35 mm, high ESS 1.5 kPa Uncoated: Ø 35 mm, high wall (2 ml volume), elastic surface with a stiffness of 1.5 kPa, hydrophobic, sterilized | 30 | 5480.00 |
81391 | µ-Dish 35 mm, high ESS 弹性支撑表面,15kPa,无包被 | µ-Dish 35 mm, high ESS 15 kPa Uncoated: Ø 35 mm, high wall (2 ml volume), elastic surface with a stiffness of 15 kPa, hydrophobic, sterilized | 30 | 5480.00 |
81191 | µ-Dish 35 mm, high ESS 弹性支撑表面,28kPa,无包被 | µ-Dish 35 mm, high ESS 28 kPa Uncoated: Ø 35 mm, high wall (2 ml volume), elastic surface with a stiffness of 28 kPa, hydrophobic, sterilized | 30 | 5480.00 |
81199 | µ-Dish 35 mm, high ESS 弹性支撑表面,混装(含1.5kPa,15kPa,28kPa各10个),无包被 | µ-Dish 35 mm, high ESS Variety Pack Uncoated: Ø 35 mm, high wall (2 ml volume), elastic surface with a stiffness of 1.5, 15, and 28 kPa, hydrophobic, sterilized |
3x10 | 5980.00 |
81148 | µ-Dish 35 mm,高壁,玻璃底,50微米格子培养皿 | µ-Dish 35 mm, high Grid-50 Glass Bottom: Ø 35 mm, high wall (2 ml volume), grid repeat distance 50 µm, # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized |
30 | 5480.00 |
81168 | µ-Dish 35 mm,高壁,玻璃底,500微米格子培养皿 | µ-Dish 35 mm, high Grid-500 Glass Bottom: Ø 35 mm, high wall (2 ml volume), grid repeat distance 500 µm, # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized |
30 | 5480.00 |
81166 | µ-Dish 35 mm,高壁,ibiTreat底部处理,500微米格子培养皿 | µ-Dish 35 mm, high Grid-500 ibiTreat: Ø 35 mm, high wall (2 ml volume), grid repeat distance 500 µm, #1.5 polymer coverslip, tissue culture treated, sterilized | 60 | 4980.00 |
80156 | µ-Dish 35 mm,低壁,ibiTreat底部处理,500微米格子培养皿 | µ-Dish 35 mm, low Grid-500 ibiTreat: Ø 35 mm, low wall (800 µl volume), grid repeat distance 500 µm, #1.5 polymer coverslip, tissue culture treated, sterilized | 60 | 4880.00 |
80050 | DIC专用培养皿盖 | DIC Lid for µ-Dishes, with a glass insert, suitable for use with all ibidi 35 mm dishes, sterilized | 15 | 1980.00 |
80055 | DIC专用通道载玻片盖子盖 | DIC Lid for µ-Slides: suitable for use with all ibidi µ-Slides (except Channel and Ph+ versions), sterilized | 15 | 1980.00 |
81218-200 | 玻璃底35mm共聚焦培养皿 | Glass Bottom Dish 35 mm: Ø 35 mm, high wall (2 ml volume), # 1.5 (170 μm -10 µm / + 20 μm) D 263 M Schott glass, sterilized | 200 | 7980.00 |
81218-800 | 玻璃底35mm共聚焦培养皿 | Glass Bottom Dish 35 mm: Ø 35 mm, high wall (2 ml volume), # 1.5 (170 μm -10 µm / + 20 μm) D 263 M Schott glass, sterilized | 800 | 32800.00 |
82426 | µ-Plate 24孔培养板,ibiTreat底部处理 | µ-Plate 24Well Black ID 14 mm ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 7880.00 |
82421 | µ-Plate 24孔培养板,无包被 | µ-Plate 24Well Black ID 14 mm Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 7880.00 |
89626 | µ-Plate 96孔培养板,ibiTreat底部处理 | µ-Plate 96 Well ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 7480.00 |
89621 | µ-Plate 96孔培养板,无包被 | µ-Plate 96 Well Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 7480.00 |
89646 | µ-Plate 96孔血管生成培养板,ibiTreat底部处理 | µ-Plate Angiogenesis 96 Well ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 12880.00 |
+ for all μ-Slides, μ-Dishes, and μ-Plates |
80206 | µ-Dish 35 mm,低壁,预置伤口愈合插件培养皿,ibiTreat 底部处理 | Culture-Insert 2 Well in µ-Dish 35 mm, low ibiTreat: ready to use, tissue culture treated, sterilized | 30 | 5780.00 |
81176 | µ-Dish 35 mm,高壁,预置伤口愈合2孔插件培养皿,ibiTreat 底部处理 | Culture-Insert 2 Well in µ-Dish 35 mm, high ibiTreat: ready to use, tissue culture treated, sterilized | 30 | 5780.00 |
80366 | µ-Dish 35 mm,高壁,预置伤口愈合3孔插件培养皿,ibiTreat 底部处理 | Culture-Insert 3 Well in µ-Dish 35 mm, high ibiTreat: ready to use, tissue culture treated, sterilized | 30 | 6880.00 |
80466 | µ-Dish 35 mm,高壁,预置伤口愈合4孔插件培养皿,ibiTreat 底部处理 | Culture-Insert 4 Well in µ-Dish 35 mm, high ibiTreat: ready to use, tissue culture treated, sterilized | 30 | 6980.00 |
80209 | 伤口愈合2孔插件 | 25 Culture-Inserts 2 Well for self-insertion: in a 10 cm transport dish, sterilized | 25 | 3180.00 |
80209-150 | 伤口愈合2孔插件-150 | 25 Culture-Inserts 2 Well for self-insertion: in a 10 cm transport dish, sterilized | 6x25 | 16800.00 |
80369 | 伤口愈合3孔插件 | 25 Culture-Inserts 3 Well for self-insertion: in a 10 cm transport dish, sterilized | 25 | 3580.00 |
80469 | 伤口愈合4孔插件 | 25 Culture-Inserts 4 Well for self-insertion: in a 10 cm transport dish, sterilized | 25 | 3980.00 |
80242 | 预置伤口愈合2孔插件24孔培养板 | Culture-Insert 2 Well 24 ibiTreat: a µ-Plate 24 Well with 24 ready to use Culture-Inserts 2 Well, tissue culture treated, sterilized | 3 | 10980.00 |
80406 | µ-Dish 35 mm,高壁,预置4孔插件培养皿,ibiTreat 底部处理 | micro-Insert 4 Well in µ-Dish 35 mm, high ibiTreat: ready to use, tissue culture treated, sterilized | 30 | 6980.00 |
80486 | µ-Dish 35 mm,高壁,预置4孔FulTrac插件培养皿,ibiTreat 底部处理 | micro-Insert 4 Well FulTrac in µ-Dish 35 mm, high ibiTreat: ready to use, tissue culture treated, sterilized | 30 | 8980.00 |
80409 | 4孔插件 | 25 micro-Inserts 4 Well for self-insertion: in a 10 cm transport dish, sterilized | 25 | 3980.00 |
80489 | 4孔FulTrac插件 | 25 micro-Inserts 4 Well FulTrac for self-insertion: in a 10 cm transport dish, sterilized | 25 | 5380.00 |
80286 | µ-Slide 2孔腔室载玻片,ibiTreat底部处理 | µ-Slide 2 Well ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 2980.00 |
80281 | µ-Slide 2孔腔室载玻片,无包被 | µ-Slide 2 Well Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 2980.00 |
80287 | µ-Slide 2孔腔室载玻片,玻璃底 | µ-Slide 2 Well Glass Bottom: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 3980.00 |
80296 | µ-Slide 2孔Ph+腔室载玻片,ibiTreat底部处理 | µ-Slide 2 Well Ph+ ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 3780.00 |
80297 | µ-Slide 2孔Ph+腔室载玻片,玻璃底 | µ-Slide 2 Well Ph+ Glass Bottom: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 4980.00 |
80420 | µ-Slide 4孔腔室载玻片,生物惰性表面 | µ-Slide 4 Well Bioinert: #1.5 polymer coverslip, surface passivation with Bioinert, sterilized | 15 | 6980.00 |
80426 | µ-Slide 4孔腔室载玻片,ibiTreat底部处理 | µ-Slide 4 Well ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 2980.00 |
80424 | µ-Slide 4孔腔室载玻片,Poly-L-Lysine底部处理 | µ-Slide 4 Well Poly-L-Lysine: #1.5 polymer coverslip, sterilized | 15 | 6880.00 |
80421 | µ-Slide 4孔腔室载玻片,无包被 | µ-Slide 4 Well Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 2980.00 |
80427 | µ-Slide 4孔腔室载玻片,玻璃底 | µ-Slide 4 Well Glass Bottom: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 3980.00 |
80446 | µ-Slide4孔Ph+腔室载玻片,ibiTreat底部处理 | µ-Slide 4 Well Ph+ ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 3680.00 |
80447 | µ-Slide 4孔Ph+腔室载玻片,玻璃底 | µ-Slide 4 Well Ph+ Glass Bottom: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 4980.00 |
80826 | µ-Slide 8孔腔室载玻片,ibiTreat底部处理 | µ-Slide 8 Well ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 2980.00 |
80826-90 | µ-Slide 8孔腔室载玻片,ibiTreat底部处理 | µ-Slide 8 Well ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 90 | 14800.00 |
80822 | µ-Slide 8孔腔室载玻片,Collagen IV底部处理 | µ-Slide 8 Well Collagen IV: #1.5 polymer coverslip, sterilized | 15 | 6980.00 |
80824 | µ-Slide 8孔腔室载玻片,Poly-L-Lysine底部处理 | µ-Slide 8 Well Poly-L-Lysine: #1.5 polymer coverslip, sterilized | 15 | 6980.00 |
80821 | µ-Slide 8孔腔室载玻片,无包被 | µ-Slide 8 Well Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 2980.00 |
80827 | µ-Slide 8孔腔室载玻片,玻璃底 | µ-Slide 8 Well Glass Bottom: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 3980.00 |
80827-90 | µ-Slide 8孔腔室载玻片,玻璃底 | µ-Slide 8 Well Glass Bottom: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 90 | 19980.00 |
80829 | µ-Slide 8孔腔室载玻片,Collagen I底部处理 | µ-Slide 8 Well Collagen I: #1.5 polymer coverslip, sterilized, individually packed | 15 | 6980.00 |
80800 | µ-Slide 8孔独立高壁腔室载玻片,生物惰性表面 | µ-Slide 8 Well high Bioinert: #1.5 polymer coverslip, surface passivation with Bioinert, sterilized | 15 | 7480.00 |
80801 | µ-Slide 8孔 独立高壁腔室载玻片,无包被 | µ-Slide 8 Well high Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 2980.00 |
80802 | µ-Slide 8孔 独立高壁腔室载玻片,Collagen IV底部处理 | µ-Slide 8 Well high Collagen IV: #1.5 polymer coverslip, sterilized | 15 | 6980.00 |
80804 | µ-Slide 8孔 独立高壁腔室载玻片,Poly-L-Lysine底部处理 | µ-Slide 8 Well high Poly-L-Lysine: #1.5 polymer coverslip, sterilized | 15 | 6980.00 |
80806 | µ-Slide 8孔独立高壁腔室载玻片,ibiTreat底部处理 | µ-Slide 8 Well high ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 2980.00 |
80806-90 | µ-Slide 8孔独立高壁腔室载玻片,ibiTreat底部处理 大包装 | µ-Slide 8 Well high ibiTreat, Bulk Pack: #1.5 polymer coverslip, tissue culture treated, sterilized | 90 | 14800.00 |
80806-G500 | µ-Slide 8孔独立高壁腔室500um格子底载玻片,ibiTreat底部处理 | µ-Slide 8 Well high Grid-500 ibiTreat: #1.5 polymer coverslip, grid repeat distance 500 µm, tissue culture treated, sterilized | 15 | 4980.00 |
80807 | µ-Slide 8孔独立高壁腔室载玻片,玻璃底 | µ-Slide 8 Well high Glass Bottom: #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 3980.00 |
80807-90 | µ-Slide8孔独立高壁腔室载玻片,玻璃底 大包装 | µ-Slide 8 Well high Glass Bottom, Bulk Pack: #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 90 | 19980.00 |
80808 | µ-Slide 8孔独立高壁可粘性腔室载玻片 | sticky-Slide 8 Well high: sterilized | 15 | 4980.00 |
80809 | µ-Slide 8孔独立高壁腔室载玻片,Collagen I底部处理 | µ-Slide 8 Well high Collagen I: #1.5 polymer coverslip, sterilized, individually packed | 15 | 8980.00 |
81811 | µ-Slide 18孔腔室载玻片,无包被 | µ-Slide 18 Well Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 3280.00 |
81816 | µ-Slide 18孔腔室载玻片,ibiTreat底部处理 | µ-Slide 18 Well ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 3280.00 |
81817 | µ-Slide 18孔腔室载玻片,玻璃底 | µ-Slide 18 Well Glass Bottom:#1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 4380.00 |
81818 | µ-Slide 18孔腔室粘性载玻片 | sticky-Slide 18 Well: sterilized | 15 | 3980.00 |
80826-G500 | µ-Slide 8孔 500微米格子腔室载玻片,ibiTreat底部处理 | µ-Slide 8 Well Grid-500 ibiTreat: #1.5 polymer coverslip, grid repeat distance 500 µm, tissue culture treated, sterilized | 15 | 5380.00 |
80055 | DIC专用腔室载玻片盖 | DIC Lid for µ-Slides, suitable for use with all ibidi µ-Slides (except Channel and Ph+ versions), sterilized | 15 | 1980.00 |
81506 | µ-Slide 血管生成载玻片,ibiTreat底部处理 | µ-Slide Angiogenesis ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 5980.00 |
81501 | µ-Slide 血管生成载玻片,无包被 | µ-Slide Angiogenesis Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 5980.00 |
81507 | µ-Slide 血管生成载玻片玻璃底, #1.5H (170 µm +/- 5 µm) D 263 M Schott glass | µ-Slide Angiogenesis Glass Bottom: #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 5980.00 |
81806 | µ-Slide 2孔细胞共培养载玻片,ibiTreat底部处理 | µ-Slide 2 Well Co-Culture ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 3980.00 |
81826 | µ-Slide 18孔培养载玻片,ibiTreat底部处理 | µ-Slide 18 Well - Flat ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 3680.00 |
81821 | µ-Slide 18孔培养载玻片,无包被 | µ-Slide 18 Well - Flat Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 3680.00 |
80381 | 3孔可移除插件培养载玻片 | 3 Well Chamber, removable: microscopy glass slide, sterilized | 15 | 3880.00 |
80841 | 8孔可移除插件培养载玻片 | 8 Well Chamber, removable: microscopy glass slide, sterilized | 15 | 3980.00 |
81201 | 12孔可移除插件培养载玻片 | 12 Well Chamber, removable: microscopy glass slide, sterilized | 15 | 3980.00 |
10811 | 3/8/12可移除腔式载玻片用盖玻片 | Coverslips for Chambers, removable: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, 24 mm x 60 mm, unsterile |
100 | 1380.00 |
10815 | 3孔培养片专用盖玻片及配套工具 | Coverslips and Coverslip Pick-Up Tool for 3 Well Chamber, removable: # 1.5H (170 µm+/- 5 µm) D 263 M Schott glass, Ø 15 mm, unsterile, including one silicone rubber tool for convenient glass coverslip handling | 100 | 2980.00 |
10812 | 可粘载玻片配套底片,玻璃底 | Coverslips for sticky-Slides: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, 25 mm x 75 mm, unsterile | 100 | 3880.00 |
10813 | 可粘载玻片配套底片,无包被 | Coverslips for sticky-Slides Uncoated: # 1.5 polymer coverslip, hydrophobic, 25 mm x 75 mm, unsterile | 100 | 3880.00 |
10814 | 可粘载玻片配套底片,ibiTreat底部处理 | Coverslips for sticky-Slides ibiTreat: # 1.5 polymer coverslip, tissue culture treated, 25 mm x 75 mm, unsterile | 100 | 3880.00 |
10816 | 带格子盖玻片 500um | Gridded Glass Coverslips Grid-500: Ø 28 mm, #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, grid repeat distance 500 μm, unsterile | 100 | 8980.00 |
10817 | 带格子盖玻片 50um | Gridded Glass Coverslips Grid-50: Ø 28 mm, #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, grid repeat distance 50 μm, unsterile | 100 | 8980.00 |
80106 | µ-Slide I 单通道培养载玻片,ibiTreat底部处理 | µ-Slide I ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4380.00 |
80166 | µ-Slide I 0.2mm高度 单通道培养载玻片,ibiTreat底部处理 | µ-Slide I 0.2 Luer ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4380.00 |
80167 | µ-Slide I 0.2mm高度 单通道玻璃底培养载玻片 #1.5H (170 µm +/- 5 µm) D 263 M Schott glass | µ-Slide I 0.2 Luer Glass Bottom: #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 5998.00 |
80161 | µ-Slide I 0.2mm高度 单通道培养载玻片,无包被 | µ-Slide I 0.2 Luer Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 4380.00 |
80176 | µ-Slide I 0.4mm高度 单通道培养载玻片,ibiTreat底部处理 | µ-Slide I 0.4 Luer ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4380.00 |
80177 | µ-Slide I 0.4mm高度 单通道玻璃底培养载玻片 #1.5H (170 µm +/- 5 µm) D 263 M Schott glass | µ-Slide I 0.4 Luer Glass Bottom: #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 5998.00 |
80172 | µ-Slide I 0.4mm高度 单通道培养载玻片,CollagenIV底部处理 | µ-Slide I 0.4 Luer Collagen IV: #1.5 polymer coverslip, sterilized | 15 | 7980.00 |
80171 | µ-Slide I 0.4mm高度 单通道培养载玻片,无包被 | µ-Slide I 0.4 Luer Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 4380.00 |
80186 | µ-Slide I 0.6mm高度 单通道培养载玻片,ibiTreat底部处理 | µ-Slide I 0.6 Luer ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4380.00 |
80187 | µ-Slide I 0.6mm高度 单通道玻璃底培养载玻片 #1.5H (170 µm +/- 5 µm) D 263 M Schott glass | µ-Slide I 0.6 Luer Glass Bottom: #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 5998.00 |
80181 | µ-Slide I 0.6mm高度 单通道培养载玻片,无包被 | µ-Slide I 0.6 Luer Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 4380.00 |
80196 | µ-Slide I 0.8mm高度 单通道培养载玻片,ibiTreat底部处理 | µ-Slide I 0.8 Luer ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4380.00 |
80197 | µ-Slide I 0.8mm高度 单通道玻璃底培养载玻片 #1.5H (170 µm +/- 5 µm) D 263 M Schott glass | µ-Slide I 0.8 Luer Glass Bottom: #1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 5998.00 |
80191 | µ-Slide I 0.8mm高度 单通道培养载玻片,无包被 | µ-Slide I 0.8 Luer Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 4380.00 |
81106 | µ-Slide单通道培养载玻片,混装,ibiTreat底部处理 | µ-Slide I Luer Variety Pack ibiTreat: #1.5 polymer coverslip, tissue culture treated, 4 times each channel height, 200 / 400 / 600 / 800 µm, sterilized | 16 | 4480.00 |
81101 | µ-Slide单通道培养载玻片,混装,无包被 | µ-Slide I Luer Variety Pack Uncoated: #1.5 polymer coverslip, hydrophobic, 4 times each channel height, 200 / 400 / 600 / 800 µm, sterilized | 16 | 4480.00 |
80376 | 三通道3D灌流载玻片,ibiTreat底部处理 | µ-Slide III 3D Perfusion ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 5980.00 |
80371 | 三通道3D灌流载玻片,无包被 | µ-Slide III 3D Perfusion Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 5980.00 |
80126 | µ-Slide Y通道培养载玻片,ibiTreat底部处理 | µ-Slide y-shaped ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4780.00 |
80316 | µ-Slide 三合一通道培养载玻片,ibiTreat底部处理 | µ-Slide III 3in1 ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 5380.00 |
80311 | µ-Slide 三合一通道培养载玻片,无包被 | µ-Slide III 3in1 Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 5380.00 |
80666 | µ-Slide 0.1mm高度 六通道培养载玻片,ibiTreat底部处理 | µ-Slide VI 0.1 ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 5480.00 |
80661 | µ-Slide 0.1mm高度 六通道培养载玻片,无包被 | µ-Slide VI 0.1 Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 5480.00 |
80609 | µ-Slide 0.4mm高度 六通道培养载玻片,Collagen I底部处理 | µ-Slide VI 0.4 Collagen I: #1.5 polymer coverslip, sterilized, individually packed | 15 | 6980.00 |
80600 | µ-Slide 0.4mm高度 六通道培养载玻片,生物惰性表面 | µ-Slide VI 0.4 Bioinert: #1.5 polymer coverslip, surface passivation with Bioinert, sterilized | 15 | 8480.00 |
80606 | µ-Slide 0.4mm高度 六通道培养载玻片,ibiTreat底部处理 | µ-Slide VI 0.4 ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4880.00 |
80606-90 | µ-Slide 0.5mm高度 六通道培养载玻片,ibiTreat底部处理 | µ-Slide VI 0.4 ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 90 | 25800.00 |
80602 | µ-Slide 0.4mm高度 六通道培养载玻片,CollagenIV底部处理 | µ-Slide VI 0.4 Collagen IV: #1.5 polymer coverslip, sterilized | 15 | 8980.00 |
80604 | µ-Slide 0.4mm高度 六通道培养载玻片,Poly-L-Lysine底部处理 | µ-Slide VI 0.4 Poly-L-Lysine: #1.5 polymer coverslip, sterilized | 15 | 8980.00 |
80601 | µ-Slide 0.4mm高度 六通道培养载玻片,无包被 | µ-Slide VI 0.4 Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 4980.00 |
80607 | µ-Slide 0.5mm高度 六通道培养载玻片,玻璃底 | µ-Slide VI 0.5 Glass Bottom: # 1.5H (170 µm +/- 5 µm) D 263 M Schott glass, sterilized | 15 | 6980.00 |
80626 | µ-Slide 六通道培养载玻片,平版,ibiTreat底部处理 | µ-Slide VI - Flat ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4880.00 |
80621 | µ-Slide 六通道培养载玻片,平版,无包被 | µ-Slide VI - Flat Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 4880.00 |
80326 | µ-Slide 细胞趋化载玻片,ibiTreat底部处理 | µ-Slide Chemotaxis ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 10 | 9880.00 |
80322 | µ-Slide 细胞趋化载玻片,Collagen IV底部处理 | µ-Slide Chemotaxis Collagen IV: #1.5 polymer coverslip, sterilized | 10 | 9880.00 |
87171 | µ-Slide 单通道3D培养载玻片,无包被 | µ-Slide I Luer 3D Uncoated: #1.5 polymer coverslip,hydrohobic, sterilized | 15 | 4980.00 |
87176 | µ-Slide 单通道3D培养载玻片,ibitreat底部处理 | µ-Slide I Luer 3D ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 4980.00 |
2021年12月20日起暂停销售ibipore系列产品 |
85116 | µ-Slide ibiPore培养载玻片,可视化Transwell 0.5µm/20%, ibiTreat底部处理 | µ-Slide Membrane ibiPore 0.5µm/20% Flow ibiTreat: #1.5 polymer coverslip, tissue culture treated, 0.5 µm porous glass membrane, 20% porosity, sterilized |
10 | 19980.00 |
85116-S | µ-Slide ibiPore培养载玻片,可视化Transwell 0.5µm/20%, ibiTreat底部处理,小包装 | µ-Slide Membrane ibiPore 0.5µm/20% Flow ibiTreat Trial Pack: #1.5 polymer coverslip, tissue culture treated, 0.5 µm porous glass membrane, 20% porosity, sterilized | 2 | 4980.00 |
85126 | µ-Slide ibiPore培养载玻片,可视化Transwell 3.0µm/5%, ibiTreat底部处理 | µ-Slide Membrane ibiPore 3.0µm/5% Flow ibiTreat: #1.5 polymer coverslip, tissue culture treated, 3.0 µm porous glass membrane, 5% porosity, sterilized |
10 | 19980.00 |
85126-S | µ-Slide ibiPore培养载玻片,可视化Transwell 3.0µm/5%, ibiTreat底部处理,小包装 | µ-Slide Membrane ibiPore 3.0µm/5% Flow ibiTreat Trial Pack: #1.5 polymer coverslip, tissue culture treated, 3.0 µm porous glass membrane, 5% porosity, sterilized | 2 | 4980.00 |
85136 | µ-Slide ibiPore培养载玻片,可视化Transwell 5.0µm/5%, ibiTreat底部处理 | µ-Slide Membrane ibiPore 5.0µm/5% Flow ibiTreat: #1.5 polymer coverslip, tissue culture treated, 5.0 µm porous glass membrane, 5% porosity, sterilized |
10 | 19980.00 |
85136-S | µ-Slide ibiPore培养载玻片,可视化Transwell 5.0µm/5%, ibiTreat底部处理,小包装 | µ-Slide Membrane ibiPore 5.0µm/5% Flow ibiTreat Trial Pack: #1.5 polymer coverslip, tissue culture treated, 5.0 µm porous glass membrane, 5% porosity, sterilized | 2 | 4980.00 |
85146 | µ-Slide ibiPore培养载玻片,可视化Transwell 8.0µm/5%, ibiTreat底部处理 | µ-Slide Membrane ibiPore 8.0µm/5% Flow ibiTreat: #1.5 polymer coverslip, tissue culture treated, 8.0 µm porous glass membrane, 5% porosity, sterilized |
10 | 19980.00 |
85146-S | µ-Slide ibiPore培养载玻片,可视化Transwell 8.0µm/5%, ibiTreat底部处理,小包装 | µ-Slide Membrane ibiPore 8.0µm/5% Flow ibiTreat Trial Pack: #1.5 polymer coverslip, tissue culture treated, 8.0 µm porous glass membrane, 5% porosity, sterilized | 2 | 4980.00 |
80816 | smart slideRoche Cedex XS细胞计数分析仪专用 | Smart Slide: for Cedex® XS Analyzer, 15 x 8 measurements, sterilized | 15 | 4380.00 |
80828 | 8well 可粘载玻片 | sticky-Slide 8 Well: sterilized | 15 | 4980.00 |
80829 | 8well 可粘载玻片,Collagen I底部处理 | µ-Slide 8 Well Collagen I: #1.5 polymer coverslip, sterilized, individually packed | 15 | 8980.00 |
81128 | 单通道可粘载玻片 0.1mm高 | sticky-Slide I 0.1 Luer: sterilized | 15 | 4980.00 |
80168 | 单通道可粘载玻片 0.2mm高 | sticky-Slide I 0.2 Luer: sterilized | 15 | 4980.00 |
80178 | 单通道可粘载玻片 0.4mm高 | sticky-Slide I 0.4 Luer: sterilized | 15 | 4980.00 |
80188 | 单通道可粘载玻片 0.6mm高 | sticky-Slide I 0.6 Luer: sterilized | 15 | 4980.00 |
80198 | 单通道可粘载玻片 0.8mm高 | sticky-Slide I 0.8 Luer: sterilized | 15 | 4980.00 |
80328 | 细胞趋化可粘载玻片 | sticky-Slide Chemotaxis: sterilized | 10 | 10800.00 |
80608 | 六通道可粘载玻片 | sticky-Slide VI 0.4: sterilized | 15 | 5880.00 |
10802 | 流体实验 弯头 鲁尔转接头 | Elbow Luer Connector Male: white Polypropylene, sterilized | 25 | 1280.00 |
10820 | 嵌入式鲁尔注入端口 | In-line Luer Injection Port: with silicone septum, single packed, sterilized | 25 | 1580.00 |
10821 | 软管夹 | Hose Clip | 5 | 1580.00 |
10822 | 鲁尔公插头 | Luer Plug Male: natural Polypropylene, sterilized | 25 | 1580.00 |
10823 | 鲁尔母固定连接器 | Female Luer Lock Coupler: natural Polypropylene, sterilized | 25 | 1580.00 |
10824 | 鲁尔公接头 | Luer Connector Male: natural Polypropylene, sterilized | 25 | 1580.00 |
10825 | 鲁尔固定母接头 | Luer Lock Connector Female: natural Polypropylene, sterilized | 25 | 1580.00 |
10826 | 鲁尔固定公接头 | Luer Lock Connector Male: natural Polypropylene, sterilized | 25 | 1580.00 |
10827 | Y型软管配件0.8mm | Y Tube Fitting 0.8 mm ID: natural Polypropylene, sterilized | 25 | 1580.00 |
10828 | Y型软管配件1.6mm | Y Tube Fitting 1.6 mm ID: natural Polypropylene, sterilized | 25 | 1580.00 |
10829 | 减管径配件 | Fitting Reducer 0.5/0.8 to 1.6: natural Polypropylene, sterilized | 25 | 1580.00 |
10830 | ibidi串联连接管 | Serial Connector for µ-Slides: sterilized | 6x2 | 2680.00 |
10831 | 适配管道套装 | Tube Adapter Set: sterilized | 6x2 | 2680.00 |
10840 | ibidi硅胶管 0.5mm | Silicone Tubing 0.5 mm ID: 5 m, sterilized | 1 | 1980.00 |
10841 | ibidi硅胶管 0.8mm | Silicone Tubing 0.8 mm ID: 5 m, sterilized | 1 | 1980.00 |
10842 | ibidi硅胶管 1.6mm | Silicone Tubing 1.6 mm ID: 5 m, sterilized | 1 | 1980.00 |
10961 | 灌流管,蓝色,15cm管长,0.8mm内径,10ml储液管 | Perfusion Set BLUE: length 15 cm, ID 0.8 mm, 10 ml reservoirs, designed for low flow rates | 4 | 7980.00 |
10962 | 灌流管,红色,15cm管长,1.6mm内径,10ml储液管 | Perfusion Set RED: length 15 cm, ID 1.6 mm, 10 ml reservoirs, designed for high flow rates | 4 | 7980.00 |
10963 | 灌流管,白色,50cm管长,0.8mm内径,10ml储液管 | Perfusion Set WHITE: length 50 cm, ID 0.8 mm, 10 ml reservoirs, designed for low flow rates and microscopy | 4 | 7980.00 |
10964 | 灌流管,黄绿色,50cm管长,1.6mm内径,10ml储液管 | Perfusion Set YELLOW-and-GREEN: length 50 cm, ID 1.6 mm, 10 ml reservoirs, designed for high flow rates and microscopy | 4 | 7980.00 |
10965 | 灌流管,黄色,15cm,0.5mm内径,2ml储液管 | Perfusion Set YELLOW: length 15 cm, ID 0.5 mm, 2 ml reservoirs, designed for low volumes and µ-Slides with 0.1 mm channel height | 4 | 7980.00 |
10966 | 灌流管,黑色,50cm,0.5mm内径,2ml储液管 | Perfusion Set BLACK: length 50 cm, ID 0.5 mm, 2 ml reservoirs, designed for low volumes, µ-Slides with 0.1 mm channel height, and microscopy | 4 | 7980.00 |
10967 | 灌流管,褐色,100cm,0.5mm内径,2ml储液管 | Perfusion Set BROWN: length 100 cm, ID 0.5 mm, 2 ml reservoirs. Sterile and ready-to-use tubing sets for flow assays with the ibidi Pump System, individually packed. | 4 | 7980.00 |
10968 | 灌流管,灰色,100cm,0.8mm内径,10ml储液管 | Perfusion Set GREY: length 100 cm, ID 0.8 mm, 10 ml reservoirs. Sterile and ready-to-use tubing sets for flow assays with the ibidi Pump System, individually packed. | 4 | 7980.00 |
10969 | 灌流管,橘色,100cm,1.6mm内径,10ml储液管 | Perfusion Set ORANGE: length 100 cm, ID 1.6 mm, 10 ml reservoirs. Sterile and ready-to-use tubing sets for flow assays with the ibidi Pump System, individually packed. | 4 | 7980.00 |
10971 | 带滤芯储液池套装 10ml | Filter/Reservoir Set, 10 ml: 2 replacement reservoirs with mounted filters, ready to use, sterilized | 10 | 5980.00 |
10972 | 带滤芯储液池套装 2ml | Filter/Reservoir Set, 2 ml: 2 replacement reservoirs with mounted filters, ready to use, sterilized | 10 | 5980.00 |
10974 | 带滤芯储液池套装 50ml | Filter/Reservoir Set, 50 ml: 2 replacement reservoirs with mounted filters, ready to use, sterilized | 10 | 5980.00 |
10976 | 流体单元适配支架 10ml | Reservoir Holder for Fluidic Unit, 10 ml | 1 | 2080.00 |
10977 | 流体单元适配支架 2ml | Reservoir Holder for Fluidic Unit, 2 ml | 1 | 2080.00 |
10978 | 流体单元适配支架 50ml | Reservoir Holder for Fluidic Unit, 50 ml | 1 | 2080.00 |
80350 | µ-Slide球体灌注通道培养载玻片,生物惰性表面 | µ-Slide Spheroid Perfusion Bioinert: #1.5 polymer coverslip, surface passivation with Bioinert, sterilized | 15 | 9880.00 |
80351 | µ-Slide球体灌注通道培养载玻片,无包被 | µ-Slide Spheroid Perfusion Uncoated: #1.5 polymer coverslip, hydrophobic, sterilized | 15 | 7980.00 |
80356 | µ-Slide球体灌注通道培养载玻片,ibiTreat底部处理 | µ-Slide Spheroid Perfusion ibiTreat: #1.5 polymer coverslip, tissue culture treated, sterilized | 15 | 7980.00 |
83801 | µ-Slide 8孔 独立高壁腔室载玻片(带µ-Pattern RGD微图案表面),生物惰性表面 | µ-Slide 8 Well high µ-Pattern RGD, sqr20, pit110, hex: #1.5 polymer coverslip, micropatterned surface with RGD motif, 20 μm squares, 110 μm pitch, hexagonal layout, surface passivation with Bioinert, sterilized | 10 | 14800.00 |
83801-S | µ-Slide 8孔 独立高壁腔室载玻片(带µ-Pattern RGD微图案表面),生物惰性表面,小包装 | µ-Slide 8 Well high µ-Pattern RGD, sqr20, pit110, hex Trial Pack: #1.5 polymer coverslip, micropatterned surface with RGD motif, 20 μm squares, 110 μm pitch, hexagonal layout, surface passivation with Bioinert, sterilized | 2 | 3480.00 |
83601 | µ-Slide 0.4mm高度 六通道培养载玻片(带µ-Pattern RGD微图案表面),生物惰性表面 | µ-Slide VI 0.4 µ-Pattern RGD, sqr20, pit110, hex: #1.5 polymer coverslip, micropatterned surface with RGD motif, 20 μm squares, 110 μm pitch, hexagonal layout, surface passivation with Bioinert, sterilized | 10 | 14800.00 |
83601-S | µ-Slide 0.4mm高度 六通道培养载玻片(带µ-Pattern RGD微图案表面),生物惰性表面,小包装 | µ-Slide VI 0.4 µ-Pattern RGD, sqr20, pit110, hex Trial Pack: #1.5 polymer coverslip, micropatterned surface with RGD motif, 20 μm squares, 110 μm pitch, hexagonal layout, surface passivation with Bioinert, sterilized | 2 | 3480.00 |
83802 | µ-Slide 8孔 独立高壁腔室载玻片(带µ-Pattern RGD微图案表面),生物惰性表面 | µ-Slide 8 Well high µ-Pattern RGD, cir100, pit500, hex: #1.5 polymer coverslip, micropatterned surface with RGD motif, 100 μm circles, 500 μm pitch, hexagonal layout, surface passivation with Bioinert, sterilized | 10 | 14800.00 |
83802-S | µ-Slide 8孔 独立高壁腔室载玻片(带µ-Pattern RGD微图案表面),生物惰性表面,小包装 | µ-Slide 8 Well high µ-Pattern RGD, cir100, pit500, hex Trial Pack: #1.5 polymer coverslip, micropatterned surface with RGD motif, 100 μm circles, 500 μm pitch, hexagonal layout, surface passivation with Bioinert, sterilized | 2 | 3480.00 |
83602 | µ-Slide 0.4mm高度 六通道培养载玻片(带µ-Pattern RGD微图案表面),生物惰性表面 | µ-Slide VI 0.4 µ-Pattern RGD, cir100, pit500, hex: #1.5 polymer coverslip, micropatterned surface with RGD motif, 100 μm circles, 500 μm pitch, hexagonal layout, surface passivation with Bioinert, sterilized | 10 | 14800.00 |
83602-S | µ-Slide 0.4mm高度 六通道培养载玻片(带µ-Pattern RGD微图案表面),生物惰性表面,小包装 | µ-Slide VI 0.4 µ-Pattern RGD, cir100, pit500, hex Trial Pack: #1.5 polymer coverslip, micropatterned surface with RGD motif, 100 μm circles, 500 μm pitch, hexagonal layout, surface passivation with Bioinert, sterilized | 2 | 3480.00 |
83851 | µ-Slide 8孔 独立高壁腔室载玻片(带µ-Pattern RGD测试图案),生物惰性表面 | µ-Slide 8 Well high µ-Pattern RGD Test Patterns 1: #1.5 polymer coverslip, micropatterned surface with RGD motif, 15 patterns, surface passivation with Bioinert, sterilized | 2 | 4580.00 |
83651 | µ-Slide 0.4mm高度 六通道培养载玻片(带µ-Pattern RGD测试图案),生物惰性表面 | µ-Slide VI 0.4 µ-Pattern RGD Test Patterns 1: #1.5 polymer coverslip, micropatterned surface with RGD motif, 15 patterns, surface passivation with Bioinert, sterilized | 2 | 4580.00 |
80030 | 载玻片磁性显微镜观察支架 | µ-Slide Microscopy Rack: with magnetic fixation, base | 1 | 4880.00 |
80035 | 培养皿磁性显微镜观察支架 | µ-Dish Microscopy Rack: with magnetic fixation, base | 1 | 4980.00 |
80031 | 载玻片磁性固定盖 | Magnetic Lid for µ-Slides | 4 | 8880.00 |
80036 | 35mm低壁培养皿磁性固定盖 | Magnetic Lid for µ-Dish 35 mm, low | 1 | 1480.00 |
80037 | 35mm高壁培养皿磁性固定盖 | Magnetic Lid for µ-Dish 35 mm, high | 1 | 1480.00 |
80003 | 载玻片支架 | µ-Slide Rack: for eight slides, aluminum | 1 | 1980.00 |
80040 | 工具夹用于可粘性载玻片 | Clamp for sticky-Slides | 1 | 1380.00 |
80042 | 用于可粘性单通道腔室载玻片的适配器 | Adapter for sticky-Slide I Luer | 1 | 8380.00 |
80043 | 用于可粘性六通道0.4高度腔室载玻片的适配器 | Adapter for sticky-Slide VI 0.4 | 1 | 8380.00 |
80044 | 用于可粘性细胞趋化性载玻片的适配器 | Adapter for sticky-Slide Chemotaxis | 1 | 8380.00 |
80045 | 用于可粘性8孔/8孔高壁/18孔腔室载玻片的适配器 | Adapter for sticky-Slide 8 Well | 8 Well high | 18 Well | 1 | 8380.00 |
单位名称: |
上海市虹口区曲阳路900弄复城国际1号楼3025室
联系电话: |
Email: |
