细胞培养耗材
康宁corning 431943 三角培养瓶,125ml
corning
进口
美国 康宁corning
三角培养瓶,125ml,透气盖,灭菌单
询13816982406
271 4148 吸头,200UL,无色,加长,未灭菌,低吸附,盒装,960/3840 Corning DeckWorks 1 - 200uL Low Binding Pipet Tips, Graduated, Hinged Racks, Natural, Non-Sterile, Polypropylene, 96 Tips/Rack, 10 Racks/Pack, 4 Packs/Case. 96支/盒,40盒/箱  1   2,595.50
272 4131 DeckWorks 200UL透明盒装吸头,1-200ul,960/960 Corning DeckWorks 1 - 200uL Pipet Tips, Graduated, Reload Starter Kit, Natural, Non-Sterile, Polypropylene, 96 Tips/Deck, 10 Decks/Pack, 960 Tips/Pack, 1Pack/Case. and 10 Empty Racks/Case. 96支/盒,10盒/箱  1   594.70
273 3391 Tanswell-96系统 0.4uM孔径 PC(聚碳酸酯)膜 储液盘 接受盘 带双盖 单个包装 完整成套 5个/包 1包/箱 Corning HTS Transwell-96 Permeable Support System with 0.4µm Pore Polycarbonate (PC) Membrane, Sterile, 5/Pack, 5/Case 5个/包,1包/箱  1   35,027.70
274 3271 CellSTACK 10层培养容器 Corning CellSTACK, 10-layer Polystyrene vessel with Vent Caps, TC treated Growth Surface, Sterile, 1 per bag, 6 per case 1个/包,6包/箱  6   询价
275 431943 三角培养瓶,125ml,透气盖,PC(聚碳酸酯)材质,灭菌单独包装,1个/包,24包/箱 125mL Polycarbonate Erlenmeyer Shake Flask with Vent Cap, Sterile,1/bag,24/case 1个/包,24包/箱  1   2,509.10
276 431947 三角培养瓶,1L,透气盖,PC(聚碳酸酯)材质,灭菌单独包装,1个/包,24包/箱 1L Polycarbonate Erlenmeyer Shake Flask with Vent Cap, Sterile,1/bag,24/case 1个/包,24包/箱  1   6,565.70
277 3313 CellSTACK培养容器,5层 Corning CellSTACK, 5-layer Polystyrene vessel with Vent Caps, TC treated Growth Surface, Sterile, 1 per bag, 8 per case 1个/包,8包/箱  8   询价
278 20036 康宁HYPERStack 36层 细胞培养容器 Corning HYPERStack 12-Layer Cell Culture Vessel, CellBIND treated, Sterile, 1 per bag, 4 per case 1/包,2包/箱  1   询价
279 430825T 培养瓶,150cm²,透气盖,PS(聚苯乙烯)材质,灭菌,袋装,5个/包,10包/箱 Corning 150cm² Rectangular Canted Neck TC-treated Cell Culture Flask with Vent Cap, 5/PK, 50/CS 5个/包,10包/箱  1   2,139.10
280 10043 滚瓶转液盖 Corning Aseptic Transfer Cap for use with 850cm² Polystyrene Roller Bottle, 3/8” ID x 1/2” OD, 0.2 µm filter, MPC Quick Connect, Sterile, 1/bag, 2/box 1个/包,2包/箱  2   3,926.60
281 3397 TRANSWELL-24膜嵌套 6.5mm膜直径 0.4um孔径PC(聚碳酸酯)膜 灭菌 袋装 Costar HTS Transwell-24 Permeable Support with 0.4µm Pore Polycarbonate (PC) Membrane, Sterile, 12/Pack, 12/Case 12个/包,1包/箱  1   25,771.50
282 431945 三角培养瓶,500ml,透气盖,PC(聚碳酸酯)材质,灭菌单独包装,1个/包,12包/箱 500mL Polycarbonate Erlenmeyer Shake Flask with Vent Cap, Sterile,1/bag,12/case 1个/包,12包/箱  1   2,678.40
283 431944 三角培养瓶,250ml,透气盖,PC(聚碳酸酯)材质,灭菌单独包装,1个/包,12包/箱 250mL Polycarbonate Erlenmeyer Shake Flask with Vent Cap, Sterile,1/bag,12/case 1个/包,12包/箱  1   1,592.40
284 3269 CellSTACK 2层培养容器 Corning CellSTACK, 2-layer Polystyrene vessel with Vent Caps, TC treated Growth Surface, Sterile, 1 per bag, 5 per case 1个/包,5包/箱  1   询价
285 6524 PCR板封口带 聚乙烯(PE)材质 袋装,100个/包,1包/箱 Corning® PCR Polyethylene 96 Well Microplate Sealing Tape, Nonsterile 100个/包,1包/箱  1   977.10
286 3830 384孔板 SPHEROID 黑色 底透 圆底 超低吸附 多重包被 带盖 灭菌 Corning 384 Well Black Clear Round Bottom Ultra-Low Attachment Spheroid Microplate, Bulk Packed 10 per Bag, with Lid, Sterile 10个/包,5包/箱  1   38,219.80
287 431446 无菌移液盖 2L三角培养瓶,LUER,1个/包,6包/箱 Corning Disposable 48mm Aseptic Transfer Cap for 2L Polycarbonate Erlenmeyer Shake Flask having a 1/8" Dip Tube with Male Luer Lok Disconnect and a 0.2µm Vent,Sterile,Double Bag,1/bag,6/case 1个/包,6包/箱  1   14,271.80
288 3727BC 1536微孔板,白色,平底,TCT,带条码,带盖,灭菌,袋装,10个/包,5包/箱 Corning 1536 Well White Polystyrene TC-Treated Microplate, 10 per Bag, with Lid, With Generic Bar Code, Sterile 10个/包,5包/箱  1   22,810.20
289 3268 细胞工厂, CELLCUBE1层培养容器  Corning CellSTACK, 1-layer Polystyrene vessel with Vent Caps, TC treated Growth Surface, Sterile, 1 per bag, 8 per case 1个/包,8包/箱  1   询价
290 430852 滚瓶,1700cm2,易握盖,PS(聚苯乙烯)材质,有刻度,灭菌,袋装,2个/包,20包/箱 Corning 1700cm² Polystyrene Expanded Surface  Roller Bottle with Easy Grip Cap,Sterile,2/Bag,40/Case 2个/包,20包/箱  20   199.10
291 531123 500 mL离心管,尖底,密封盖,PP,已灭菌 500mL PP Centrifuge Tubes with Plug Seal Cap, Sterile, 5/Pack, 40/Case 5/包,40/箱  1   2,691.50
292 3320 CellSTACK培养容器 CellBIND表面 10层 Corning CellSTACK, 10-layer Polystyrene vessel with Vent Caps, CellBIND treated Growth Surface, Sterile, 1 per bag, 6 per case 1个/包,6包/箱  6   询价
293 4484 100ml移液管 灭菌 独立包装 10个/包 10包/箱 Costar® 100mL Stripette® Serological Pipets, Polystyrene, Individually Plastic Wrapped, Sterile, 10/Bag, 100/Case 10个/包,10包/箱  1   9,529.60
294 3907 滚瓶  850cm²,CellBIND表面,易握盖,2个/包,20包/箱 Corning CellBIND 850cm² Polystyrene Roller Bottle with Easy Grip Cap, Sterile, 2/Bag, 40/Case 2个/包,20包/箱  1   12,641.60
295 431444 无菌移液盖 1L三角培养瓶,LUER,1个/包,5包/箱 Corning Disposable 43mm Aseptic Transfer Cap for 1L Polycarbonate Erlenmeyer Shake Flask having a 1/4" Dip Tube with Male MPC Disconnect and a 0.2µm Vent,Sterile,Double Bag,1/bag,5/case 1个/包,5包/箱  1   12,157.70
296 10024 多层细胞培养瓶,CellBIND表面 Corning CellBIND Surface HYPERFlask Cell Culture Vessel, Treated, Sterile, Bar Coded, 4 per Bag, 24 per Case 4块/包,6包/箱  1   58,831.90
297 2D05C-R-S 0.5ml 2D 条形码管 Co-Molded 2D Bar Coded tubes 96个/盒,10盒/箱  1   询价
298 431306 培养瓶 175cm²  直角角度颈 透气盖 带条形码(cf 431080/431306),7个/包,12包/箱 Corning 175cm² Angled Neck Cell Culture Flask with Vent Cap and Bar Code 7个/包,12包/箱  1   8,507.60
299 3152 康宁125毫升聚苯乙烯一次性旋压瓶,70毫米顶盖,2侧臂,无菌, Corning 125mL Polystyrene Disposable Spinner Flask with 70mm Top Cap and 2 Angled Sidearms, Sterile,1/bag,12/case 1/袋,12/箱  12   1,419.00
300 9186 真空移液管,2ml,灭菌,独立包装,100个/包,10包/箱 Costar® 2mL Aspirating Pipets, Polystyrene, Without Graduations, Individually Wrapped, Sterile, 1/Bag, 1000/Case 100个/包,10包/箱  1   3,142.30
301 3281 康宁33mm聚乙烯填充盖与3/8英寸(9.5毫米)管子与50毫米直径0.2μm孔径疏水膜 Corning CellSTACK Venting Accessory, 33mm HDPE Cap with 7cm of 3/8in ID Tubing and 0.2um Filter, Sterile, 1 per bag, 5 per case 1个/包,5包/箱  1   6,632.10
302 431447 无菌移液盖 2L三角培养瓶,MPCQU,1个/包,6包/箱 Corning Disposable 48mm Aseptic Transfer Cap for 2L Polycarbonate Erlenmeyer Shake Flask having a 1/4" Dip Tube with Male MPC Disconnect and a 0.2µm Vent,Sterile,Double Bag,1/bag,6/case 1个/包,6包/箱  6   2,530.20
303 3006 V型勺/勺康宁抹刀,无菌 Corning Spatula with V-Scoop/Spoon, Sterile 1个/包,100包/箱  1   3,211.10
304 11500 转液盖,100mm直径,5L三角瓶 Corning 100mm Aseptic Transfer Cap for 5L Polycarboante Erlenmeyer Shake Flask with a 0.2µm Vent, and Male MPC Disconnect,Sterile,1/bag,4/case 1个/包,4包/箱  1   11,663.00
305 431445 无菌移液盖 1L三角培养瓶,MPCQU,1个/包,5包/箱 Corning Disposable 43mm Aseptic Transfer Cap for 1L Polycarbonate Erlenmeyer Shake Flask having a 1/8" Dip Tube with Male Luer Lok Disconnect and a 0.2µm Vent,Sterile,Double Bag,1/bag,5/case 1个/包,5包/箱  1   13,467.30
306 431430 储液瓶 150ml方形瓶 带45mm盖子 聚碳酸酯材质 单独包装 12个/包 2包/箱 Corning® 150mL Square Polycarbonate Storage Bottles with 45mm Caps, Individually Wrapped 12个/包2包/箱  1   1,375.70
307 430516 真空过滤系统,1000ml,0.45umCA(醋酸纤维)膜,90mm直径,灭菌,单个包装,1个/包,12包/箱 Corning 1000mL Vacuum Filter/Storage Bottle System, 0.45Micrometer Pore, 54.5cm squared CA Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   4,069.00
308 431684 三角培养瓶,5.0L,透气盖,缓冲底 灭菌 独立包装, Corning 5L Polycarbonate Baffled Erlenmeyer Shake Flask with Vent Cap,Sterile,1/Bag,4/Case 1个/包,4包/箱  1   5,296.50
309 7016 移液管 25ml 条排带塞 红色 三重塑料袋包装 ,25个/包 8包/箱 Costar® 25mL Stripette® Serological Pipets, Polystyrene, Individually Paper/Plastic Wrapped, Triple Bagged, Clean Room Pack Style, Sterile, 25/Bag, 200/Case 25个/包,8包/箱  1   4,581.50
310 431518 三角培养瓶,2LPC材质 带无菌转移盖,带1/4“浸管,0.2μm孔,Male Luer 扣,灭菌 Corning 2L Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap having a 1/4" Dip Tube with Male MPC Disconnect and a 0.2µm Vent,Sterile, 1/bag,3/case 1个/包,3包/箱  1   15,172.60
311 3641 96孔板,平底,非结合表面,未灭菌,荧光测定,25个/包,4包/箱 Corning 96 Well Clear Flat Bottom Polystyrene NBS™ Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   6,163.40
312 7000 移液管,100ml,三重包装,10个/包,10包/箱 Costar® 100mL Stripette® Serological Pipets, Polystyrene, Individually Paper/Plastic Wrapped, Triple Bagged, Clean Room Pack Style, Sterile, 10/Bag, 100/Case 10个/包,10包/箱  10   1,009.50
313 2D20C-R-S Co-molded 2D条形码管,2毫升,灭菌 Co-molded 2D Bar Coded tubes, 2mL, sterilized, 48pcs/rack, 10 racks/Case 48件/架,10架/箱  1   询价
314 2592 96孔条板 高结合 透明 未灭菌 无盖 25/100 Corning 96 Well Clear Polystyrene High Bind Stripwell™ Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   4,226.30
315 431532 储液瓶,500mL Square PET Storage Bottles with 45mm Caps  Corning® 500mL Square PET Storage Bottles with 45mm Caps 12个/包,2包/箱  1   777.40
316 431284 Corning 5L PETG Erlenmeyer Shake Flask, Plain bottom Corning 5L PETG Erlenmeyer Shake Flask, Plain bottom, 1/bag, 4/case 1/包,4包/箱  1   6,872.90
317 20012 康宁HYPERStack 12层 细胞培养容器 Corning HYPERStack 12-Layer Cell Culture Vessel, CellBIND treated, Sterile, 1 per bag, 4 per case 1/包,4包/箱  1   询价
318 3370 96孔板,透明,平底,未处理表面,PS(聚苯乙烯)材质,灭菌,袋装,20个/包,5包/箱 Corning 96 Well Clear Flat Bottom Polystyrene Not Treated Microplate, 20 per Bag, with Lid, Sterile 20个/包,5包/箱  5   577.80
319 3386 TRANSWELL-96系统 3.0 uM孔径, 4个/包,2包/箱 Corning HTS Transwell-96 Permeable Support with 3.0µm Pore Polycarbonate (PC) Membrane, Sterile, 4/Pack, 8/Case 4个/包,2包/箱  1   12,383.40
320 431433 储液瓶 1000ml方形瓶 聚碳酸酯材质,12个/包,2包/箱 Corning® 1L Square Polycarbonate Storage Bottles with 45mm Caps 12个/包,2包/箱  2   2,041.30
321 11501 三角培养瓶,5L,平底,转移盖 Corning 5L Polycarbonate Plain Erlenmeyer Shake Flask with 100mm Disposable Aseptic Transfer Cap containing a 0.2µm Vent and Male MPC,Sterile,1/bag,2/case 1个/包,2包/箱  1   8,903.60
322 3505 96孔FiltrEX滤板,白色,PS(聚苯乙烯),0.2um孔径PVDF(聚偏氟乙烯)亲水膜,灭菌,10个/包,5包/箱 FiltrEX™ 96 Well Filter Plates with 0.2µm PVDF Membrane, Sterile 10个/包,5包/箱  1   19,217.90
323 11705 离心管,50mL PP 可立 ,灭菌,预装封闭系统溶液,带Dip管 Corning Centrifuge Tube, 50mL Polypropylene Tube, self-standing centrifuge tube with Tubing accessories and 0.2um Versapor filter,w ith PP Diptube, Sterile, 1 per bag, 2 per case 1个/包,2包/箱  1   4,261.40
324 3333 CellSTACK,叠放设备,ORAN Corning CellSTACK Filling Accessory, 33mm HDPE cap with 70cm C-Flex Tubing, Male MPC Coupling and Female MPC End Cap, Double bagged, Sterile, 1 per bag, 4 per case 1个/包,4包/箱  1   4,823.90
325 431198 滚瓶,850cm2,易握盖,PS(聚苯乙烯)材质,有刻度,灭菌,袋装,2个/包,20包/箱 Corning 850cm² Polystyrene Roller Bottle with Easy Grip Vent Cap, Sterile, 2/Bag, 40/Case 2个/包,20包/箱  1   3,602.30
326 3153 康宁500ml聚苯乙烯一次性旋压瓶,带瓶盖,无菌 Corning 500mL Polystyrene Disposable Spinner Flask with Solid Caps, Sterile. 1/bag, 12/case 1/袋,12/箱  1   20,972.10
327 3392 Tanswell-96系统 1.0um孔径 PET(聚酯)膜 储液板 接收板带双盖 完整成套 Corning HTS Transwell-96 Permeable Support System with 1.0µm Pore Polyester (PET) Membrane, Sterile, 5/Pack, 5/Case 5个/包,1包/箱  1   35,024.40
328 430662 冻存管,4.0ml,圆底,自立式,外旋密盖,PP(聚丙烯)材质,灭菌,袋装,硅胶垫圈,50个/包,10包/箱 Corning 4mL External Threaded Polypropylene Cryogenic Vial, Self-Standing with Round Bottom 50个/包,10包/箱  1   3,183.80
329 4516 384孔板,黑底透,ULA表面,圆底灭菌,,1个/包,5包/箱 Corning 384 Well Black Clear Round Bottom Ultra-Low Attachment Spheroid Microplate, Ind Packaged, with Lid, Sterile,1/5 1个/包,5包/箱  1   4,550.60
330 431432 储液瓶,500ml方形瓶,聚碳酸酯材质,12个/包,2包/箱 Corning® 500mL Square Polycarbonate Storage Bottles with 45mm Caps 12个/包,2包/箱  1   2,826.60
331 3282 CellSTACK 33mm加样盖 灭菌 Corning CellSTACK Filling Accessory, 33mm HDPE cap with 18in Female Luer and Male Luer Lock Plug, Sterile, 1 per bag, 5 per case 1个/包,5包/箱  1   4,222.80
332 3340 96孔板,透明,平底,CellBIND表面 Corning CellBIND 96 Well Flat Clear Bottom Black Polystyrene Microplates, with Lid, Sterile 5个/包,10包/箱  1   5,384.70
333 3361 96孔酶标板 透明 平底 高结合  PS(聚苯乙烯)材质  带盖 灭菌 袋装 Corning 96 Well EIA/RIA Clear Flat Bottom Polystyrene High Bind Microplate, 20 per Bag, with Lid, Sterile 20个/包,5包/箱  5   740.80
334 431530 储液瓶,125ML,PET,45MM ORANGE CAP,S,IND WRAPPED,12/24 Corning® 125mL Square PET Storage Bottles with 45mm Caps 12个/包,2包/箱  1   513.40
335 3363 96孔板,透明,V型底,PP(聚丙烯)材质,无盖,未灭菌,袋装,25个/包,4包/箱 Corning® 96 Well Clear V-Bottom Polypropylene Not Treated Microplate, 25 per Bag, without Lids, Nonsterile 25个/包,4包/箱  4   861.60
336 3574 384孔板,白色,低边,NBS表面,10个/包,5包/箱 Corning 384 Well Low Flange White Flat Bottom Polystyrene NBS™ Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  5   836.70
337 3374 TRANSWELL-96系统接受板,8.0uM孔径,PET(聚酯)膜,TC表面,带盖,独立包装,1个/包,2包/箱 Corning HTS Transwell-96 Permeable Support with 8.0µm Pore Polyester (PET) Membrane, Sterile, 1/Pack, 2/Case 1个/包,2包/箱  1   2,938.30
338 3694 96孔板,黑色,平底,半区,未处理表面,未灭菌,25个/包,4包/箱 Corning 96 Well Half Area Black Flat Bottom Polystyrene Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   4,461.00
339 4512 384孔板,低体积,白色,中结合表面,圆底,10个/包,5包/箱 Corning 384 Well Low Volume White Round Bottom Polystyrene Not Treated Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   6,141.60
340 431644 滚瓶,850CM,易握型,NT表面,PS材质,灭菌,独立包装 Corning 850cm² Polystyrene Roller Bottle with Easy Grip Cap, Sterile,1/Bag, 40/Case 1个/包,40包/箱  1   8,947.00
341 431282 Corning 3L摇瓶 PETG材质 Corning 3L PETG Erlenmeyer Shake Flask, Plain bottom, 1/bag, 4/case 1个/包,4包/箱  1   4,624.70
342 4591 96孔板,黑色,圆底,ULA,灭菌,带盖,1个/包,24包/箱 Corning 96 Well Black Round Bottom Polystyrene Ulta-Low Attachment Microplate, 1 per Bag, with Lid, Sterile 1个/包,24包/箱  1   8,684.30
343 3956 96孔板  0.5ml圆孔  V形底  PP(聚丙烯)材质 无盖 灭菌 ,10个/包,5包/箱 Corning® 96 Well Clear V-Bottom 0.5mL Polypropylene Deep Well Plate, 10 per Bag, Sterile 10个/包,5包/箱  5   790.90
344 3580 1L悬浮细胞培养瓶,透气盖 灭菌 Corning 1L  Polystyrene Disposable Spinner Flask with Vent Cap, Sterile, 1/bag, 6/case 1个/包,6包/箱  1   16,969.90
345 3657 384孔板,透明,圆底,未灭菌,PP(聚丙烯)材质,25个/包,4包/箱 Corning® 384 Well Clear Round Bottom Polypropylene Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  4   1,371.30
346 3581 3L悬浮细胞培养瓶,透气盖 灭菌 Corning 3L  Polystyrene Disposable Spinner Flask with Vent Cap, Sterile, 1/bag, 4/case 1个/包,4包/箱  1   15,827.80
347 3420 Transwell-膜嵌套,75mm膜直径,3.0um,PC(聚碳酸酯)膜,TC表面,灭菌,1个/包,12包/箱 Costar 75mm Transwell Permeable Support with 3.0µm Pore Polycarbonate (PC) Membrane, Sterile, 1/Pack, 12/Case 1个/包,12包/箱  1   5,900.80
348 7015 移液管10ml 条排 带塞 橙色 三重塑料袋包装,50个/包 4包/箱 Costar® 10mL Stripette® Serological Pipets, Polystyrene, Individually Paper/Plastic Wrapped, Triple Bagged, Clean Room Pack Style, Sterile, 50/Bag, 200/Case 50个/包,4包/箱  1   2,152.20
349 3415 Transwell-24膜嵌套,6.5mm直径,3.0um孔径PC膜,PC(聚碳酸酯)灭菌,12个/包,4包/箱 Costar 6.5mm Transwell Permeable Support with 3.0µm Pore Polycarbonate (PC) Membrane, Sterile, 12/Pack, 48/Case 12个/包,4包/箱  4   730.00
350 3572 384孔板,白色,低边,未处理表面,未灭菌,10个/包,5包/箱 Corning 384 Well Low Flange White Flat   Bottom Polystyrene Not Treated   Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   3,425.70
351 3688 96孔板,白色,平底,半区,TC表面,PS(聚苯乙烯)材质,20个/包,5包/箱 Corning 96 Half Area Well Solid White Flat Bottom Polystyrene TC-Treated Microplates, 20 per Bag, with Lid, Sterile 20个/包,5包/箱  1   6,732.20
352 3764BC 384微孔板,黑底透,低边框,TCT,带条码,带盖。灭菌,袋装,20个/包,5包/箱 Corning 384 well Black with Clear Flat Bottom TC Treated Microplate, with Generic Barcodes, with Lid, Sterile, 100/case 20个/包,5包/箱  1   8,105.50
353 4513 384孔板,低体积,白色,NBS表面,圆底,10个/包,5包/箱 Corning 384 Well Low Volume White Round Bottom Polystyrene NBS™ Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   6,840.50
354 430053 离心管,15ml,密封盖,PET(聚乙烯对苯二酸酯),灭菌,袋包装,50个/包,10包/箱 Corning® 15mL PET Centrifuge Tubes, Bulk Packed with Plug Seal Cap, Sterile, 500/Case 50个/包,10包/箱  10   237.40
355 3504 96孔FiltrEX滤板,白色,PS(聚苯乙烯),0.2um孔径PVDF(聚偏氟乙烯)亲水膜,未灭菌,10个/包,5包/箱 FiltrEX™ 96 Well Filter Plates with 0.2µm PVDF Membrane, Nonsterile 10个/包,5包/箱  1   19,089.20
356 3679 96孔UV板,半区板,紫外透明(UV),未处理表面,未灭菌,25个/包,2包/箱 Corning® Half Area 96 Well Clear Flat Bottom UV-Transparent Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,2包/箱  1   9,536.80
357 430661 冻存管 2.0ml 圆底  非可立, 外旋密盖 PP(聚丙烯)材质 灭菌 袋装 硅胶垫圈 Corning 2mL External Threaded Polypropylene Cryogenic Vial with Round Bottom 10包/箱  1   2,900.00
358 11440 三角培养瓶,1000ml,带转液盖 Corning 1L Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap having a Dip Tube with c-Flex tubing and a Male Luer Lok Disconnect and a 0.2µm Vent,Sterile, 1/bag,4/case 1个/包,4包/箱  1   9,912.70
359 2797 PLATE,96WL,RB,PVC,WO/LID,NS,B,
96孔板 圆底 PVC(聚氯乙烯)材质 无盖 未灭菌 袋装
Corning 96 Well Clear Round Bottom Polyvinyl Chloride (PVC) Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   1,924.60
360 11502 三角培养瓶,5L,挡板底 转移盖 Corning 5L Polycarbonate Baffled Erlenmeyer Shake Flask with 100mm Disposable Aseptic Transfer Cap,0.2µm Vent and Male MPC,Sterile,1/bag,2/case 1个/包,2包/箱  1   9,288.80
361 3702 384孔板,透明,平底,未处理表面,PS(聚苯乙烯)材质,无盖,未灭菌,25个/包,4包/箱 Corning 384 Well Clear Flat Bottom Polystyrene Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   5,306.60
362 431206 真空过滤系统 1000ml 0.45umCA(醋酸纤维)膜 90mm直径 灭菌 单个包装 1个/包 12包/箱 Corning 1000mL Vacuum Filter/Storage Bottle System, 0.45Micrometer Pore, 54.5cm squared CA Membrane, Sterile, Individually Packaged, 12/Case 1个/包12包/箱  1   4,032.70
363 3924 96孔可拆板,黑色,平底,高结合表面,无盖,25个/包,4包/箱 Corning 96 Well Black Polystyrene High Bind Stripwell™ Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   10,423.80
364 431280 Corning 2L PETG Erlenmeyer Shake Flask, Plain bottom Corning 2L PETG Erlenmeyer Shake Flask, Plain bottom, 1/Bag, 6/case 1/包,6包/箱  1   4,355.10
365 3824 384孔板,低容量,白色,硬质,NBS表面,未灭菌,10个/包,5包/箱 Corning Low Volume 384 Well White Flat Bottom Polystyrene NBS™ Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   7,426.80
366 3334 CellSTACK, HDPE 加样盖,33mm, 70cm C-Flex 管子 Corning CellSTACK molded Aseptic Transfer Cap, 33mm HDPE Cap with a Male MPC 1/4in ID and Female MPC End Cap, Double bagged, Sterile, 1 per bag, 4 per case 1个/包,4包/箱  1   4,132.70
367 430015 真空过滤器,1000ml,45mm直径,0.22um孔径CA(醋酸纤维)膜,灭菌,单独包装,1个/包,12包/箱 Corning 1000mL Bottle Top Vacuum Filter, 0.22Micrometer Pore, 54.5cm squared CA Membrane, Fits 45mm Diameter Necks, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   2,575.60
368 3562 一次性无菌移液透气盖配件1 Disposable GL45 Aseptic Transfer Cap for 1L Plastic Spinner Flask, 1/8" Dip Tube, 0.2µm Vent, Male Luer Lock, Sterile 1个/包,2包/箱  1   5,982.90
369 431474 真空过滤系统,1000ML,0.1um PES膜,1个/包,12包/箱 Corning 1000mL Vacuum Filter/Storage Bottle System, 0.1Micrometer Pore, 54.5cm squared  PES Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   4,421.10
370 3381 Tanswell-96系统0.4uM孔径PC(聚碳酸酯)膜,TC表面,储液盘,接受盘,带2盖,完整成套,1个/包,1包/箱 Corning HTS Transwell-96 Permeable Support System with 0.4µm Pore Polycarbonate (PC) Membrane, Sterile, 1/Pack, 1/Case 1个/包,1包/箱  1   7,036.60
371 3428 Transwell-膜嵌套,24mm膜直径,8.0um,PC(聚碳酸酯)膜,TC表面,灭菌,6个/包,4包/箱 Costar 24mm Transwell Permeable Support with 8.0µm Pore Polycarbonate (PC) Membrane, Sterile, 6/Pack, 24/Case 6个/包,4包/箱  4   643.30
372 3615 96孔板 黑色 特殊光学 平底 带盖 未处理表面4包/箱 Corning 96 Well Black Special Optics w/Clear Flat Bottom Polystyrene Not Treated Microplate, 25 per Bag, No Lid, Nonsterile 4包/箱  1   12,736.30
373 3359 96孔板,透明,圆底,PP(聚丙烯)材质,灭菌,袋装,25个/包,4包/箱 Corning® 96 Well Clear Round Bottom Polypropylene Not Treated Microplate, 25 per Bag, without Lids, Sterile 25个/包,4包/箱  4   924.70
374 3880 96孔板 黑色 透明平底 半区 未处理表面 未灭菌 袋装 Corning 96 Well Half Area Black with Clear Flat Bottom Polystyrene Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   9,840.50
375 3080 细粒透镜96圆井微孔板存储垫III,非无菌 Corning® 96 Round Well Microplate Storage Mat III, Nonsterile 25个/包,4包/箱  1   3,728.80
376 430491 冻存管 4.0ml 圆底 可立式 内旋密盖 PP(聚丙烯)材质 灭菌 袋装 硅胶垫圈,50个/包,10包/箱 Corning 4mL Internal Threaded Polypropylene Cryogenic Vial, Self-Standing with Round Bottom 50个/包,10包/箱  1   3,058.20
377 3011 大号细胞刮刀,手柄长39cm,刀口长3.0cm Corning Large Cell Scraper 1个/包,100包/箱  100   50.10
378 3727 1536孔板,白色,平底,TC表面,灭菌,10个/包,5包/箱 Corning 1536 Well White Polystyrene TC-Treated Microplate, 10 per Bag, with Lid, Sterile 10个/包,5包/箱  1   15,089.20
379 3387 HTS,Transwell-96膜嵌套,5.0um孔径PC(聚碳酸酯)膜带盖接收板,袋装,4个/包,2包/箱 Corning HTS Transwell-96 Permeable Support with 5.0µm Pore Polycarbonate (PC) Membrane, Sterile, 4/Pack, 8/Case 4个/包,2包/箱  1   12,387.50
380 3385 HTS Transwell-96 3.0um孔径PC(聚碳酸酯)膜 带盖接收板 单独包装 Corning HTS Transwell-96 Permeable Support with 3.0µm Pore Polycarbonate (PC) Membrane, Sterile, 1/Pack, 2/Case 1个/包,2包/箱  1   3,095.80
381 3561 1升容量一次性转瓶 1个/包 6包/箱 Corning 1L  Polystyrene Disposable Spinner Flask with Solid GL45 Cap, Sterile, 1/bag, 6/case 1个/包,6包/箱  1   16,969.80
382 3766 384孔酶标板 BCB 底边 不结合表面 无盖 未灭菌 Corning 384 well Black with Clear Flat Bottom Non Binding Surface Polystyrene  Microplate with Low Flange, Non Sterile, without Lid, 100/case 25个/包,4包/箱  1   16,816.70
383 430589 培养皿,60mm直径 未处理表面,PS材质,灭菌,20个/包,25包/箱 Corning 60mm x 15mm Style Dish,  Not Tissue Culture-Treated , Sterile, Bulk Packaged,  20/Bag, 500/Case 20个/包,25包/箱  1   2,311.40
384 2481 25/100 低容量条板 8孔 透明 高吸附 不带盖 未灭菌 Corning 96 Well Clear Polystyrene High Bind Low Volume Stripwell™ Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   12,835.60
385 3820 384孔板,低容量,黑色,硬质,NBS表面,未灭菌,10个/包,5包/箱 Corning Low Volume 384 Well Black Flat Bottom Polystyrene NBS™ Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   6,785.10
386 430725 培养瓶,75cm2,直角斜颈(正方斜口)聚酯盖(PHEN),PS(聚苯乙烯)材质,灭菌,袋装,5个/包,20包/箱 Corning 75cm² Rectangular Canted Neck Cell Culture Flask with Phenolic-Style Cap 5个/包,20包/箱  20   112.60
387 3985 384孔板 黑底透 光学影像,TC表面,20个/包,5包/箱 Corning 384 Well Optical Imaging Flat Clear Bottom Black Polystyrene TC-Treated Microplates, 20 per Bag, with Lid, Sterile 20个/包,5包/箱  1   21,438.60
388 3378 TRANSWELL-24系统膜嵌套,0.4uM孔径,PET(聚酯)膜,袋装,12个/包,1包/箱 Costar HTS Transwell-24 Permeable Support with 0.4µm Pore Polyester (PET) Membrane, Sterile, 12/Pack, 12/Case 12个/包,1包/箱  1   22,741.40
389 4558 50ml离心管 平盖,25个/包,5包/箱 Corning® 50mL PP Centrifuge Tubes, Conical Bottom with CentriStar™ Cap, Universal Rack Packed, Sterile, 25/Universal Rack, 300/Case 25个/包,5包/箱  1   3,426.00
390 3600 96孔板,白色,硬质,平底,NBS(非结合)表面,25个/包,4包/箱 Corning 96 Well White Flat Bottom Polystyrene NBS Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  4   2,778.90
391 3402 Transwell-膜嵌套,12mm膜直径,3.0um,PC(聚碳酸酯)膜,灭菌,12个/包,4包/箱 Costar 12mm Transwell Permeable Support with 3.0µm Pore Polycarbonate (PC) Membrane, Sterile, 12/Pack, 48/Case 12个/包,4包/箱  1   3,368.60
392 430756 真空过滤系统 250ml 0.2umCN膜 50mm直径 灭菌 单个包装(cf 430186),1个/包,12包/箱 Corning 250mL Vacuum Filter/Storage Bottle System, 0.22Micrometer Pore, 19.6cm squared Cellulose Nitrate Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   1,644.60
393 431449 无菌移液盖,3L三角培养瓶,MPCQU,1个/包,4包/箱 Corning Disposable 70mm Aseptic Transfer Cap for 3L Polycarbonate Erlenmeyer Shake Flask having a 1/4" Dip Tube with Male MPC Disconnect and a 0.2µm Vent,Sterile,Double Bag,1/bag,4/case 1个/包,4包/箱  1   13,496.50
394 8670 2D 冻存管, 2ml 可立, 内旋橙色盖,灭菌, 50个/包, 10包/箱 Corning 2D Cryogen Tube 2ml Self Stand, Internal Screw Cap Orange Color, Grad., Sterile, Clearline, 50/bag, 500/case 50个/包,10包/箱  1   11,016.30
395 3462 Transwell-膜嵌套,透明,12mm直径,3.0um孔径PE(聚酯)膜,灭菌,12个/包,4包/箱 Costar 12mm Transwell Permeable Support with 3.0µm Pore Polyester (PET) Membrane, Sterile, 12/Pack, 48/Case 12个/包,4包/箱  1   3,457.90
396 7045 移液管5ml 单独包装  三重塑料袋包装,50个/包 4包/箱 Costar® 5mL Stripette® Serological Pipets, Polystyrene, Individually Paper/Plastic Wrapped, Triple Bagged, Clean Room Pack Style, Sterile, 50/Bag, 200/Case 50个/包,4包/箱  1   1,764.00
397 3789A 96微孔板 白色 圆底 NT表面,无盖 PLATE,96WL,WHITE,RB,NT,WO/LID,C/N 25块/包,4包/箱  1   4,170.90
398 3993 96孔板,黑色色,平底,半区,NBS表面,未灭菌,5个/包,5包/箱 Corning 96 Well Half Area Black Flat Bottom Polystyrene NBS Microplate, 5 per Bag, without Lid, Nonsterile 5个/包,5包/箱  1   1,809.50
399 3656 384孔板,透明,圆底,灭菌,PP(聚丙烯)材质,25个/包,4包/箱 Corning® 384 Well Clear Round Bottom Polypropylene Not Treated Microplate, 25 per Bag, without Lid, Sterile 25个/包,4包/箱  4   1,498.50
400 8673 冻存盒, 81 孔,PC材质,配套2D冻存管,带码, 5个/包, 2包/箱 CRYOGEN BOX 81 PLACES IN PC, 132X132 MM FOR 2D TUBES, WHITE BOTTOM AND ORANGE GRID, BARCODED, 5/bag, 10/case; 5个/包,2包/箱  1   3,188.40
401 3826 384孔板  低容量 白色  TC表面 带盖 灭菌 Corning Low Volume 384 Well White Flat Bottom Polystyrene TC-Treated Microplate, 10 per Bag, With Lid, Sterile 10个/包,5包/箱  1   7,532.30
402 3736 未处理的6孔板(袋装),5个/包,20包/箱 Costar 6 Well Clear Not Treated  Multiple Well Plates with Lid, Sterile, Bulk Packed, 5/Bag, 100/Case 5个/包,20包/箱  1   2,969.20
403 7042 移液管2ml 单独包装  三重塑料袋包装,50个/包 20包/箱 Costar® 2mL Stripette® Serological Pipets, Polystyrene, Individually Paper/Plastic Wrapped, Triple Bagged, Clean Room Pack Style, Sterile, 50/Bag, 1000/Case 50个/包,20包/箱  1   6,433.50
404 3797 96孔板,透明,圆底,未处理表面,无盖,未灭菌,袋装,25个/包,4包/箱 Corning 96 Well EIA/RIA Clear Round Bottom Polystyrene Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  4   487.10
405 430767 真空过滤系统,250ml,0.22umCA膜,90mm直径,灭菌,独立包装,1个/包,12包/箱 Corning 250mL Vacuum Filter/Storage Bottle System, 0.22Micrometer Pore, 19.6cm squared Cellulose Acetate Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   1,643.30
406 3798 96孔板 透明 圆底  亲水性表面 无盖 未灭菌 Costar 96-well Clear Round Bottom Treated Microplate, 25 per bag, without lid, Nonsterile 25个/包,4包/箱  4   586.90
407 4251 25ml移液管 灭菌 独立包装,50个/包,4包/箱 Costar® 25mL Stripette® Serological Pipets, Polystyrene, Individually Plastic Wrapped, Sterile, 50/Bag, 200/Case 50个/包,4包/箱  1   1,319.80
408 3005 圆头/勺康宁抹刀,无菌 Corning Spatula with Round End Blade/Spoon, Sterile 1个/包,100包/箱  100   32.20
409 430372 培养瓶,25CM2,直角斜颈,聚酯盖,PS(聚苯乙烯)材质,灭菌,袋装,20个/包,25包/箱 Corning 25cm² Rectangular Canted Neck Cell Culture Flask with Phenolic-Style Cap 20个/包,25包/箱  25   278.60
410 3738 24孔板,未处理表面,带盖,灭菌 Costar 24 Well Clear,  Not Treated  Multiple Well Plates with Lid,  Sterile, Bulk Packaged, 5/Bag, 100/Case 5个/包,20包/箱  20   89.10
411 2580 标准条板 8孔 平底 透明 高结合 用于酶联免疫检测 未灭菌 Corning 96 Well Clear Polystyrene High Bind Stripwell™ Strips, without Frame or Lid, Nonsterile 25个/包,32包/箱  1   3,563.70
412 430055 离心管,15ml,密封盖,PET(聚乙烯对苯二酸酯),灭菌,盒包装,50个/包,10包/箱 Corning® 15mL PET Centrifuge Tubes, Rack Packed with Plug Seal Cap, Sterile, 50/Rack, 500/Case 50个/包,10包/箱  1   1,980.50
413 3565 一次性 500ml转瓶透气盖, 1/8" Dip 管子与 0.2µm 孔径 Corning Disposable Aseptic Transfer Cap for 500mL Polystyrene Spinner Flask, 1/8" Dip Tube and 0.2µm Vent, Male Luer Lok connector, Sterile, 1/bag. 2/case 1个/包,2包/箱  1   4,391.10
414 430489 冻存管 2.0ml 圆底  内旋密盖 PP(聚丙烯)材质 灭菌 袋装 硅胶垫圈,50个/包,10包/箱 Corning 2mL Internal Threaded Polypropylene Cryogenic Vial with Round Bottom 50个/包,10包/箱  10   284.50
415 3961 96孔板,2.0ml方孔,V形底,PP材质,未灭菌,5个/包,20包/箱 Corning® 96 Well Clear V-Bottom 2mL Polypropylene Deep Well Plate, 5 per Bag, Nonsterile 5个/包,20包/箱  20   534.10
416 3598 96孔板,平底,TC表面,PS(聚苯乙烯)材质,带盖,灭菌,5个/包,20包/箱 Corning 96 Well Clear Flat Bottom Polystyrene TC-Treated Microplates, 5 per Bag, with Lid, Sterile 5个/包,20包/箱  1   3,055.00
417 10020 多层细胞培养瓶,CB表面(cellbind).灭菌 带码 Corning CellBIND Surface HYPERFlask M Cell Culture Vessel, Treated, Sterile, Bar Coded, 4 per Bag, 4 per Case 4个/包,1包/箱  1   8,234.10
418 3379 TRANSWELL-24系统 0.4uM孔径 PET(聚酯)膜 单个包装,1个/包,2包/箱 Costar HTS Transwell-24 Permeable Support with 0.4µm Pore Polyester (PET) Membrane, Sterile, 1/Pack, 2/Case 1个/包,2包/箱  1   4,163.90
419 3362 96孔板,白色,平底底,TC表面,PP(聚丙烯)材质,灭菌,袋装,25个/包,4包/箱 Corning 96 Well Solid White Flat Bottom Polystyrene TC-Treated Microplates, 25 per bag, without Lid, Sterile 25个/包,4包/箱  1   4,167.70
420 3384 TRANSWELL-96系统 8.0uM孔径,PET(聚酯)膜,TC表面,接受盘,带盖,袋装,4个/包,2包/箱 Corning HTS Transwell-96 Permeable Support with 8.0µm Pore Polyester (PET) Membrane, Sterile, 4/Pack, 8/Case 4个/包,2包/箱  1   14,333.00
421 3958 96孔板  1.0ml圆孔  圆底 PP材质,灭菌,5个/包,5包/箱 Corning® 96 Well Clear Round Bottom 1mL Polypropylene Deep Well Plate, 5 per Bag, Sterile 5个/包,5包/箱  5   444.40
422 3477 Netwell嵌套(细胞筛网) 15mm直径 PS(聚苯乙烯)嵌套  74um孔径PE(聚酯)膜 灭菌 Costar 15mm Netwell Insert with 74µm Mesh Size Polyester (PET) Membrane, Sterile, 12/Pack, 48/Case 12个/包,4包/箱  1   3,354.20
423 430515 真空过滤系统 1000ml 0.2umNY(尼龙)膜 90mm直径 灭菌 单个包装,1个/包,12包/箱 Corning 1000mL Vacuum Filter/Storage Bottle System, 0.2Micrometer Pore, 54.5cm squared  Nylon Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   4,519.60
424 3550 96孔蛋白结晶微孔板 1ul体积 圆锥平底 晶体杯 96 Well COC Protein Crystallization Microplate with 3:1, 1µL Conical Flat Bottom Crystal Cup Wells, Not Treated, Nonsterile 10个/包,5包/箱  1   10,465.40
425 431272 245mm方型生物测定盒 灭菌(cf 431111/431272/431301) Corning 245mm Square BioAssay Dish with Handles, Not Tissue Culture-Treated, Bulk Packaged, 4/Pack, 16/Case 4个/包,4包/箱  1   2,524.80
426 431475 真空过滤器500ml,45mm直径,0.1um孔径PES(聚醚砜)膜,灭菌,1个/包,12包/箱 Corning 500mL Vacuum Filter/Storage Bottle System, 0.1Micrometer Pore 33.2cm squared Polyethersulfone Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   2,906.50
427 430626 真空过滤器150ml,45mm直径,0.22um孔径CA(醋酸纤维)膜,灭菌,单独包装,1个/包,48包/箱 Corning 150mL Bottle Top Vacuum Filter, 0.22Micrometer Pore, 13.6cm squared CA Membrane, Fits 45mm Diameter Necks, Sterile, Individually Packaged, 48/Case 1个/包,48包/箱  1   4,845.50
428 3396 TRANSWELL-24膜嵌套 6.5mm膜直径 0.4um孔径PC(聚碳酸酯)膜 灭菌单独包装 Costar HTS Transwell-24 Permeable Support with 0.4µm Pore Polycarbonate (PC) Membrane, Sterile, 1/Pack, 2/Case 1个/包,2包/箱  1   4,813.20
429 3544 384孔 低容量 平底 黑色 NBS(无结合)表面 带盖 未灭菌 袋装 10个/包 5包/箱 Corning Low Volume 384 Well Black with Clear Flat Bottom Polystyrene NBS™ Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   9,754.50
430 11415 250ml三角摇瓶,灭菌,带移液盖 Corning 250ml Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap with 1/8" ID C-Flex and Male Luer Lok Disconnect,Sterile,1/bag,4/case 1个/包,4包/箱  1   9,486.80
431 3843 96孔板 WCB,PDL,自制,带盖,灭菌 Corning 96 Well Flat Clear Bottom White Polystyrene Poly-D-Lysine Coated Microplates, 20 per Bag, with Lid, Aseptically Manufactured 20个/包,5包/箱  1   41,400.70
432 3680 384孔板,透明,平底,带盖,未处理表面,灭菌,20个/包,5包/箱 Corning 384 Well Clear Flat Bottom Polystyrene Not Treated Microplate, 20 per Bag, with Lid, Sterile 20个/包,5包/箱  1   4,763.30
433 2D10C-R-S 1.0ml 2D冻存管 Co-Molded 2D Bar Coded tubes 96个/盒,10盒/箱  1   询价
434 431512 三角培养瓶,2LPC材质,带1/8“浸管,0.2μm孔,Male Luer 扣,灭菌 , Corning 2L Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap having a 1/8" Dip Tube with Male Luer Lok Disconnect and a 0.2µm Vent,Sterile, 1/bag,3/case 1个/包,3包/箱  1   11,843.80
435 430588 培养皿,35mm直径 未处理表面,PS材质,灭菌,20个/包,25包/箱 Corning 35mm x 10mm Style Dish,  Not Tissue Culture-Treated, Sterile, Bulk Packaged, 20/Bag, 500/Case 20个/包,25包/箱  25   76.80
436 11425 三角培养瓶,500ml,带转液盖 Corning 500ml Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap with 1/8" ID C-Flex and Male Luer Lok Disconnect,Sterile,1/bag,2/case 1个/包,2包/箱  1   7,446.80
437 3569 1升容量一次性转瓶 Corning 1L Polystyrene Disposable Spinner Flask with Solid Cap and Aseptic Transfer Cap, Sterile, 1/bag, 6/case 1个/包,6包/箱  1   35,113.00
438 431205 真空过滤系统,1000ml,0.22umCA(醋酸纤维)膜,90mm直径,灭菌,单个包装,1个/包,12包/箱 Corning 1000mL Vacuum Filter/Storage Bottle System, 0.22Micrometer, Pore 54.5cm squared  CA Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   3,611.30
439 430773 真空过滤系统 500ml 0.2umNY(尼龙)膜 90mm直径 灭菌 单个包装 1个/包 12包/箱 Corning 500mL Vacuum Filter/Storage Bottle System, 0.2Micrometer Pore 33.2cm squared  Nylon Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   2,969.50
440 431514 三角培养瓶,3LPC材质(Fernbach Desigh),带无菌转移盖,带1/8“浸管,0.2μm孔,Male Luer 扣,灭菌 Corning 3L Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap having a 1/8" Dip Tube with Male Luer Lok Disconnect and a 0.2µm Vent,Sterile, 1/bag,2/case 1/包,2包/箱  1   8,779.20
441 7290 可溶性微载体,Synthemax II涂层 Corning Dissolvable Microcarriers, Synthemax®  II coated, 10 gram vial, 1 vial per case 10G/瓶,1瓶/箱  1   询价
442 431682 三角培养瓶,5L,透气盖 Corning Vent Cap for 5L Erlenmeyer Shake Flask, 1/bag, 24/case 1个/包,24包/箱  1   4,735.00
443 3821 384孔板  低容量 黑色 硬质 未处理表面 无盖 未灭菌 Corning Low Volume 384 Well Black Flat Bottom Polystyrene Not Treated Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   6,680.30
444 431417 可立内旋2ml冻存管,黄色盖,50个/包,10包/箱 Corning 2mL Yellow Cap Internal Threaded Polypropylene Cryogenic Vial, Self-Standing with Round Bottom 50个/包,10包/箱  1   2,462.90
445 3099 康宁聚苯乙烯通用微孔板盖角缺口,无菌 Corning Polystyrene Universal Microplate Lid with Corner Notch, Sterile 25个/包,2包/箱  1   849.20
446 430490 冻存管,4.0ml,圆底,内旋密盖,PP(聚丙烯)材质,灭菌,袋装,硅胶垫圈,50个/包,10包/箱 Corning 4mL Internal Threaded Polypropylene Cryogenic Vial with Round Bottom 50个/包,10包/箱  10   305.90
447 3801 SNAPWELL-膜嵌套 0.4um孔径透明聚酯膜 TC表面 Costar 12mm Snapwell Insert with 0.4µm Pore Polyester (PET) Membrane, Sterile, 6/Pack, 24/Case 6个/包,4包/箱  1   3,016.20
448 3540 384孔 低容量 平底 黑色 未处理表面 无盖 未灭菌,10/包,5包/箱 Corning Low Volume 384 Well Black Clear Flat Bottom Polystyrene Not Treated Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   7,563.70
449 3762 384孔酶标板 低边 未处理表面,无盖,未灭菌 Corning 384 well Black with Clear Flat Bottom Not Treated Polystyrene  Microplate with Low Flange, Non Sterile, without Lid, 100/case 25个/包,4包/箱  1   3,990.40
450 430492 冻存管,5.0ml,圆底,内旋密盖,PP(聚丙烯)材质,灭菌,袋装,硅胶垫圈,50个/包,10包/箱 Corning 5mL Internal Threaded Polypropylene Cryogenic Vial with Round Bottom 50个/包,10包/箱  1   3,287.80
451 3330 CellSTACK HDPE 盖子,33mm,3/8in Corning CellSTACK, 1-layer Polystyrene vessel with Vent Caps, CellBIND treated Growth Surface, Sterile, 1 per bag, 8 per case 1个/包,8包/箱  1   询价
452 431340 透气盖(用于3L三角瓶),70mm, 单个包装 灭菌,1个/包,24包/箱 Corning 70mm Polypropylene Vent Cap for 3L Polycarbonate Erlenmeyer Shake Flask,Sterile,1/bag,24/case 1个/包,24包/箱  1   3,636.90
453 3628 96孔板 平底 带盖 灭菌 TC表面 Corning 96 Well Clear Flat Bottom TC-Treated Microplate, 20 per Bag, with Lid, Sterile 20个/包,5包/箱  1   3,702.80
454 431329 培养瓶,850cm2,直角角度颈,CellBIND表面,透气盖,灭菌,2个/包,20包/箱 Corning CellBIND 850cm² Polystyrene Roller Bottle with Easy Grip Vent Cap, Sterile, 2/Bag, 40/Case 2个/包,20包/箱  20   678.20
455 3585 96孔板,平底,TC表面,PS(聚苯乙烯)材质,带盖,灭菌,5个/包,10包/箱 Costar 96 Well Clear Flat Bottom,  Tissue Culture-Treated Microplates with Lid, Sterile, Bulk Packaged, 5/ Bag, 50/Case 5个/包,10包/箱  1   2,760.10
456 9099 真空移液管 5ml 灭菌 独立包装,1个/包,200包/箱 Costar® 5mL Aspirating Pipets, Polystyrene, Without Graduations, Individually Wrapped, Sterile, 1/Bag, 200/Case 1个/包,200包/箱  1   1,886.40
457 3364 96孔板,透明,平底,PP(聚丙烯)材质,无盖,未灭菌,袋装,25个/包,4包/箱 Corning® 96 Well Clear Flat Bottom Polypropylene Not Treated Microplate, 25 per Bag, without Lids, Nonsterile 25个/包,4包/箱  1   3,446.20
458 3620 离心管,1.7ml,自然色,弹扣盖,未灭菌,袋装,500个/包 Costar 1.7mL Snap Cap Microcentrifuge Tube, Polypropylene, Non-Sterile, 500/Case. 500个/包,1包/箱  1   482.30
459 3696 96孔板 透明 半区 平底 TC处理表面 PS(聚苯乙烯)材质 灭菌 独立包装,50包/箱 Costar 96 Half Area Well , Clear Flat Bottom,  Tissue Culture-Treated Microplate with Lid, Sterile, Individually Wrapped, 50/Case 50包/箱  1   2,673.80
460 431510 三角培养瓶,1LPC材质,带无菌转移盖,带1/8“浸管,0.2μm孔,Male Luer 扣,灭菌 Corning 1L Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap having a 1/8" Dip Tube with Male Luer Lok Disconnect and a 0.2µm Vent,Sterile, 1/bag,4/case 1个/包,4包/箱  1   13,726.60
461 431386 冻存管 2.0ml 圆底  自立式 内旋密盖 PP(聚丙烯)材质 灭菌 袋装 硅胶垫圈(cf 430656/431386),50个/包,5包/箱 Corning 2mL Internal Threaded Polypropylene Cryogenic Vial, Self-Standing with Round Bottom 50个/包,5包/箱  1   2,282.30
462 431219 针头滤器, 26mm直径, 0.2um孔径, RC膜, LL/LS(注射器母口/注射器公口), 灭菌, 单个包装, 1个/包, 50包/箱 Corning 28mm Diameter Syringe Filters, 0.2Micrometer Pore,  Surfactant Free Cellulose Acetate Membrane, Individually Packaged,  Sterile, 50/Case 1个/包,50包/箱  1   2,037.60
463 3737 12孔板,未处理表面,带盖,灭菌 Costar 12 Well Clear, Not Treated,  Multiple Well Plates with Lid, Sterile, Bulk Packaged, 5/Bag, 100/Case 5/包,20包/箱  1   3,246.10
464 3414 Transwell-膜嵌套,24mm膜直径,3.0um,PC(聚碳酸酯)膜,TC表面,灭菌,6个/包,4包/箱 Costar 24mm Transwell Permeable Support with 3.0µm Pore Polycarbonate (PC) Membrane, Sterile, 6/Pack, 24/Case 6个/包,4包/箱  1   2,522.70
465 7287 可溶性微载体,变性胶原涂层 CORNING, Dissolvable Microcarriers, Denatured Collagen coated, 10 gram bottle, 1 bottle per case 10G/瓶,1瓶/箱  1   询价
466 430641U 75培养瓶,TC表面 U型 斜颈 透气盖 Corning 75cm² U-Shaped Canted Neck Cell Culture Flask with Vent Cap 5个/包,20包/箱  1   询价
467 3552 96孔蛋白结晶微孔板,2ul体积,圆锥平底,未处理,未灭菌,10个/包,5包/箱 96 Well COC Protein Crystallization Microplate with 3:1, 2µL Round Bottom Wells, Not Treated, Nonsterile 10个/包,5包/箱  5   2,093.10
468 4511 384孔板,低体积,黑色,中结合表面,圆底,10个/包,5包/箱 Corning 384 Well Low Volume Black Round Bottom Polystyrene Not Treated Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   6,023.30
469 430186 真空过滤系统 1000ml 0.2um CN(硝酸纤维素)膜 90mm直径 灭菌 单个包装,1个/包,12包/箱 Corning 1000mL Vacuum Filter/Storage Bottle System, 0.22Micrometer Pore, 54.5cm squared  CN Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   3,956.00
470 4975 真空移液管 1ml 灭菌 独立包装,50个/包,20包/箱, Costar® 1mL Aspirating Pipets, Polystyrene, Without Graduations, Bulk Packed, Sterile, 50/Bag, 1000/Case 50个/包,20包/箱,  1   3,435.40
471 3098 康宁聚苯乙烯通用微孔板无角缺口盖,无菌 Corning Polystyrene Universal Microplate Lid without Corner Notch, Sterile 25个/包,4包/箱  1   1,883.90
472 3969 CellSTACK配套之硬质瓶盖,33mm直径,黑色,1个/包,6包/箱 Corning CellSTACK 33mm HDPE Cap, Black, Solid, Not Vented, Sterile, Double bagged, 1 per bag, 6 per case 1个/包,6包/箱  6   36.30
473 3885 白底透96孔半区板,TC表面,20块/包,5包/箱 Corning 96 Half Area Well Flat Clear Bottom White Polystyrene TC-Treated Microplates, 20 per Bag, with Lid, Sterile 20块/包,5包/箱  1   11,019.50
474 431520 三角培养瓶,3LPC材质(Fernbach Desigh)带无菌转移盖,,带1/4“浸管,0.2μm孔,Male Luer 扣,灭菌 Corning 3L Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap having a 1/4" Dip Tube with Male MPC Disconnect and a 0.2µm Vent,Sterile, 1/bag,2/case 1个/包,2包/箱  1   11,124.20
475 431841 离心瓶,250ML,PP材质,螺旋盖,非灭菌,袋装 Corning® 250mL PP Centrifuge Bottle with Screw Cap, Nonsterile, 4/Pack, 36/Case 4个/包,9包/箱  1   4,267.60
476 3213 微量离心管,2.0ml,螺旋盖,自然色,未灭菌,袋装 Costar 2.0mL Snap Cap Microcentrifuge Tube, Polypropylene, Non-Sterile, 1000/Case. 500个/包,2包/箱  2   618.50
477 8671 2D 冻存管, 2ml 可立, 外旋橙色盖,灭菌, 50个/包, 10包/箱 Corning 2D Cryogen Tube 2ml Self Stand, External Screw Cap, Orange Color, Grad., Sterile, Clearline, 50/bag,500/case 50个/包,10包/箱  1   11,016.30
478 3310 CellSTACK培养容器,CellBIND表面,2层 Corning CellSTACK, 2-layer Polystyrene vessel with Vent Caps, CellBIND treated Growth Surface, Sterile, 1 per bag, 5 per case 1个/包,5包/箱  1   询价
479 3605 96孔板,白色,圆底,NBS表面,未灭菌,25个/包,4包/箱 Corning 96 Well White Round Bottom Polystyrene NBS Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  4   2,595.10
480 3935 通用板盖,黑色带角缺口,25个/包,2包/箱 Corning Black Polystyrene Universal Microplate Lid with Corner Notch, Sterile 25个/包,2包/箱  1   1,801.10
481 4680 96孔板,黑底透,半区,TC表面,带盖 灭菌 4个/包 4包/箱 Corning 96 Well Half Area High Content Imaging Film Bottom Microplate, with Lid 4个/包,4包/箱  1   9,006.10
482 431220 针头滤器,26mm直径,0.45um孔径,RC(再生纤维素)膜,灭菌,单个包装,1个/包,50包/箱 Corning 28mm Diameter Syringe Filters, 0.45Micrometer Pore Surfactant Free Cellulose Acetate Membrane, Sterile, Individually Packaged, 50/Case 1个/包,50包/箱  50   40.80
483 3591 96孔酶标板 平底 中结合  PS(聚苯乙烯)材质 未灭菌 1个/包 50包/箱 Corning 96 Well EIA/RIA Clear Flat Bottom Polystyrene Not Treated Microplate, Individually Wrapped, without Lid, Nonsterile 1个/包50包/箱  1   1,326.90
484 4801 吸头 盒装,0.1-2.0uL,滤芯 适配(Gilson)吉尔森等微量移液器,96支/盒,10盒/箱 Corning 0.1-2.0uL Filtered IsoTip Universal Fit Racked Pipet Tips (Fits Gilson Pipettors or Other Popular Ultra-Micropipettors), Graduated, Natural, Sterile, 10 Racks/Case., 960 Tips/Case. 96支/盒,10盒/箱  1   1,520.90
485 3508 96孔FiltrEX滤板 透明 PS(聚苯乙烯) 0.2um孔径PVDF(聚偏氟乙烯)亲水膜 未灭菌 袋装 FILTER PLT,96WL,0.2UM,PVDF,CLEAR,PS,NS,BK,10/50 10个/包,5包/箱  1   18,458.50
486 3395 TRANSWELL-24系统 未表面处理 培养储液板 灭菌 袋装 Costar HTS Transwell-24 Reservoir Plate, Clear, Not Treated, Sterile, 12/Pack, 48/Case 12个/包,4包/箱  1   2,558.20
487 430314 管顶真空过滤器,50ml管尺寸,0.45um孔径CA(醋酸纤维)膜,1个/包,12包/箱 Corning 50 mL Tube Top Vacuum Filter System, 0.45Micrometer Pore 13.6cm squared Cellulose Acetate Membrane, Sterile, Individually Packaged,  12/Case 1个/包,12包/箱  1   1,189.60
488 430768 真空过滤系统,250ml,0.45umCA(醋酸纤维)膜,90mm直径,灭菌,独立包装,1个/包,12包/箱 Corning 250mL Vacuum Filter/Storage Bottle System, 0.45Micrometer Pore,  19.6cm squared Cellulose Acetate Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   1,581.30
489 431465 培养瓶,150cm²,NT表面  ,透气盖,5/包,10包/箱 Corning 150cm² Canted Neck Not Treated Cell Culture Flask with Vent Cap 5/包,10包/箱  1   1,865.90
490 3003 康宁无菌V型铲/锥形刀片微铲 Corning Spatula with Tapered Blade/Spoon, Sterile 1个/包,100包/箱  100   32.20
491 7041 移液管,1ml 单独包装  三重塑料袋包装,50个/包 20包/箱 Costar® 1mL Stripette® Serological Pipets, Polystyrene, Individually Paper/Plastic Wrapped, Triple Bagged, Clean Room Pack Style, Sterile, 50/Bag, 1000/Case 50个/包,20包/箱  1   5,341.30
492 430179 容器,250ml,带盖,PP(聚丙烯)材质,灭菌,单独包装,1个/包,100包/箱 Corning® 250mL Container and Lid 1个/包,100包/箱  1   3,207.30
493 431132 滚瓶盖 48mm直径 易握透气盖 灭菌 单个包装 1个/包 300包/箱 Corning Easy Grip Vented Cap for Roller Bottes, Sterile, 1/bag, 300/Case 1个/包,300包/箱  1   7,563.30
494 3822 384孔板  低容量 黑色 硬质 TC表面 带盖 灭菌 Corning Low Volume 384 Well Black Flat Bottom Polystyrene TC-Treated Microplate, 10 per Bag, with Lid, Sterile 10个/包,5包/箱  1   7,658.90
495 3601 黑底透96孔板,HB表面,25块/包,4包/箱 Corning 96 Well Black with Clear Flat Bottom Polystyrene High Bind Microplate, 25 per Bag, without Lid, Nonsterile 25块/包,4包/箱  1   7,827.70
496 3355 96孔板 白色 圆底 PP(聚丙烯)材质 Corning 96 Well White Round Bottom Polypropylene Not Treated Microplate, 25 per Bag, without Lids, Nonsterile 25个/包,4包/箱  1   5,302.50
497 431472 50ml离心管,无盖,灭菌,25个/包,500 Corning® 50mL PP Centrifuge Tubes, Bulk Packed with No Cap, Sterile, 25/Sleeve, 500/Case 25个/包,20包/箱  1   3,834.30
498 3368 96孔酶标板 透明 易洗 中结合 无盖 未灭菌 袋装 手册是未处理表面 Corning 96 Well EIA/RIA Easy Wash™ Clear Flat Bottom Polystyrene Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   3,864.30
499 3642 96孔板 半区板 白色 非结合表面 未灭菌 25个/包 4包/箱 Corning 96 Well Half Area White Flat Bottom Polystyrene NBS Microplate, 25 per Bag, without Lid, Nonsterile 25个/包4包/箱  1   7,794.90
500 431516 三角培养瓶,1L透气盖,无菌转移盖,灭菌,PC材质 Corning 1L Polycarbonate Erlenmeyer Shake Flask with Aseptic Transfer Cap having a 1/4" Dip Tube with Male MPC Disconnect and a 0.2µm Vent,Sterile, 1/bag,4/case 1个/包,4包/箱  1   15,307.20
501 4612 封板膜,聚酯材质,非灭菌,100片/包,5包/箱 Corning® Polyester Microplate Sealing Tape, Nonsterile 100片/包,5包/箱  1   5,020.20
502 3991 96孔板 黑色 平底 NBS表面 未灭菌 袋装,5个/包,5包/箱 Corning 96 Well Black Flat Bottom Polystyrene NBS™ Microplate, 5 per Bag, without Lid, Nonsterile 5个/包,5包/箱  1   1,770.00
503 430824 培养瓶 150cm² 直角斜颈(正方斜口) 聚酯盖 PS(聚苯乙烯)材质 灭菌 袋装,5个/包,10包/箱 Corning 150cm² Canted Neck Cell Culture Flask with Phenolic-Style Cap 5个/包,10包/箱  1   2,468.50
504 3695 96孔板,透明,半区,平底,未处理表面,25个/包,4包/箱 Corning 96 Well Half Area Clear Flat Bottom Polystyrene Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   4,605.90
505 431402 三角培养瓶 1000ml 缓冲底 密闭盖 灭菌,1个/包,25包/箱 Corning 1L  Polycarbonate Baffled Erlenmeyer Shake Flask with Flat Cap,Sterile,1/Bag,25/Case 1个/包,25包/箱  1   6,621.30
506 3725 1536孔板,白色,平底,未处理表面,未灭菌,10个/包,5包/箱 Corning 1536 Well White Polystyrene Not Treated Microplate, 10 per Bag, without Lid, Nonsterile 10个/包,5包/箱  1   13,107.50
507 430049 真空过滤器500ml 45mm直径 0.2um孔径NY(尼龙)膜 灭菌 单独包装,1个/包,12包/箱 Corning 500mL Bottle Top Vacuum Filter, 0.2Micrometer Pore 33.2cm squared Nylon Membrane, Fits 45mm Diameter Necks, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  1   1,913.70
508 3614 黑底透96孔板,TC表面,无盖,25块/包,4包/箱 Corning 96 Well Special Optics Flat Clear Bottom Black Polystyrene TC-Treated Microplates, 25 per Bag, without Lid, Sterile 25块/包,4包/箱  1   13,178.90
509 4810 吸头,1000ul,滤芯,盒装灭菌96支/盒,10盒/箱 Corning 1-200uL Filtered IsoTip Plus Racked Pipet Tips (Fits All Popular Research-Grade Pipettors), Natural, Sterile, 3 Inches Long, 10 Racks/Case., 960 Tips/Case. 96支/盒,10盒/箱  1   2,608.00
510 3004 窄匙/匙康宁抹刀,无菌 Corning Spatula with Narrow Spoon/Spoon, Sterile 1个/包,100包/箱  100   32.20
511 3527 24孔板 透明 TC表面 带盖 Costar 24 Well Clear, Tissue Culture-Treated  Multiple Well Plates with Lid,  Sterile, Bulk Pack, 5/Bag, 100/Case 5个/包,20包/箱  20   212.90
512 431154 真空过滤系统 150ml 0.22umCA(醋酸纤维)膜 50mm直径 灭菌 单个包装9(cf 430516),1个/包,12包/箱 Corning 150mL Vacuum Filter/Storage Bottle System, 0.22Micrometer Pore, 13.6cm squared CA Membrane, Sterile, Individually Packaged, 12/Case 1个/包,12包/箱  12   133.60
513 431224 针头滤器 25mm直径 0.2um孔径 NY(尼龙)膜  LL/LS(注射器母口/注射器公口) 灭菌 单个包装,1个/包,50包/箱 Corning 25mm Diameter Syringe Filters, 0.2Micrometer Pore Nylon Membrane, Sterile, Individually Packaged, 50/Case 1个/包,50包/箱  50   40.80
514 3779 强吸附微载体, 10G Corning Enhanced Attachment Microcarriers, 10g Vial 1瓶/箱  1   1,982.50
515 431843 离心瓶,250ml,螺旋盖,未灭菌 Corning® 250mL PC Centrifuge Bottle with Screw Cap, Nonsterile, 4/Pack, 36/Case 4个/包,36个/箱  1   4,190.20
516 431215 针头滤器 15mm直径 0.2um孔径 RC(再生纤维素)膜   LL/LS(注射器母口/注射器公口) 灭菌 单个包装,1个/包,50包/箱 Corning 15mm Diameter Syringe Filters, 0.2Micrometer Pore Regenerated Cellulose Membrane, Sterile, Individually Packaged,  50/Case 1个/包,50包/箱  1   1,534.40
517 4101 10ml移液管,透明塑料包装,PS(聚苯乙烯)材质,灭菌,独立包装,50个/包,4包/箱 Costar® 10mL Stripette® Serological Pipets, Polystyrene, Individually Plastic Wrapped, Sterile, 50/Bag, 200/Case 50个/包,4包/箱  1   933.00
518 3923 Corning 96 Well White Polystyrene High Bind Stripwell Microplate, 25 per Bag, without Lid, Nonsterile Corning 96 Well White Polystyrene High Bind Stripwell Microplate, 25 per Bag, without Lid, Nonsterile 25/包,4包/箱  1   11,475.30
519 4501 50ml移液管 灭菌 独立包装,25个/包,4包/箱 Costar® 50mL Stripette® Serological Pipets, Polystyrene, Individually Plastic Wrapped, Sterile, 25/Bag, 100/Case 25个/包,4包/箱  1   2,056.80
520 3914 96孔可拆板 黑色 平底 中结合 袋装,25块/包,4包/箱 Corning 96 Well Black Polystyrene Medium Bind Stripwell™ Microplate, 25 per Bag, without Lid, Nonsterile 25块/包,4包/箱  1   10,423.70
521 43923 96孔可拆白色微孔板, 高结合表面,不带盖 非灭菌,25块/包,4包/箱 Costar 1 x 8 Stripwell; 96 Well White Flat Bottom Polystyrene Microplate, High  Bind, Nonsterile, 100/case 25块/包,4包/箱  4   1,383.40
522 3770BC 384微孔板,黑底透,低边框,Cellbind表面,带条码,带盖。灭菌,袋装 Corning 384 well Black with Clear Flat  Bottom CellBIND Treated Polystyrene Micropate, with Low Flange, with Generic Barcodes,with Lid, Sterile, 100/case 20个/包,5包/箱  1   10,899.50
523 431478 SPIN-X超滤浓缩离心管, 500ul处理量, 10K截留分子量, 未灭菌, 单个包装 Corning Spin-X Ultrafiltration  500µL Centrifugal Concentrator, 10,000 Molecular Weight Cut-Off Membrane, Non-Sterile,  25/Case 1个/包,25包/箱  1   2,165.10
524 3693 96孔板,白色,平底,半区,未处理表面,未灭菌,25个/包,4包/箱 Corning 96 Well Half Area White Flat Bottom Polystyrene Not Treated Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   5,479.00
525 430195 滚瓶,490cm2 密封盖,无刻度,灭菌,袋装,2个/包,20包/箱 Corning 490cm² Polystyrene Roller Bottle with Plug Seal Cap, Sterile, 2/Bag, 40/Case 2个/包,20包/箱  1   2,674.20
526 431221 针头滤器 26mm直径 0.8um孔径 ,SFCA    LL/LS(注射器母口/注射器公口) 灭菌 单个包装,1个/包,50包/箱 Corning 28mm Diameter Syringe Filters, 0.8Micrometer Pore Surfactant Free Cellulose Acetate Membrane, Sterile, Individually Packaged, 50/Case 1个/包,50包/箱  1   2,037.60
527 431408 三角培养瓶500ml 缓冲底 密闭盖 灭菌  1个/包 25包/箱 Corning 500ml Polycarbonate Baffled Erlenmeyer Shake Flask with Flat Cap,Sterile,1/Bag,25/Case 1个/包,25包/箱  1   4,932.10
528 3913 96孔STRIPWEL(可拆)板,白色,平底,中结合度,无盖,25个/包,4包/箱 Corning 96 Well White Polystyrene Medium Bind Stripwell Microplate, 25 per Bag, without Lid, Nonsterile 25个/包,4包/箱  1   10,423.70
529 3356 96孔板 黑色 圆底 PP(聚丙烯)材质 Corning® 96 Well Black Round Bottom Polypropylene Not Treated Microplate, 25 per Bag, without Lids, Nonsterile 25个/包,4包/箱  1   5,302.50
530 2506 条板 8孔 DNA表面 平底 无盖 单个包装 DNA-BIND 1 x 8 Stripwell™; 96 Well Polystyrene Microplate without Lid, Nonsterile 1个/包,50包/箱  1   9,624.40
上海辅泽商贸有限公司代理THERMO FISHER
实验室常规设备、检测分析仪器、实验室耗材如下:
实验室常规设备:净化防护、清洁纯化、温度控制、冷冻冷藏、混合破碎、离心浓缩、泵与真空、标签扫描 实验室检测分析仪器:生命科学与生化分析、理化性质分析、小型计量仪、
实验室耗材与安全防护:生物培养、样品采集与保存、离心与过滤、液体处理、色谱耗材、实验室常规耗材、安全防护
实验室常规设备 净化防护:生物安全柜、超净工作台、防护罩台、手套箱 清洁防护:洗瓶机、超声波清洗器、纯水设备
温度控制:培养箱(CO2细胞培养箱、微生物培养箱、低温培养箱、特殊培养箱、通用培养箱)、烘箱、炉具(马弗炉、灰化炉、箱式炉、管式炉)、水浴及水循环、干浴
冷冻冷藏:4℃冰箱、-20℃冰箱、-30℃冰箱、-40℃冰箱、超低温冰箱、深低温冰箱、液氮罐、液氮储存箱、程控降温仪 混合破碎:磁力搅拌器、顶置式搅拌器、振荡器、摇床、研磨机、分散机、超声波破碎仪、匀浆机
离心浓缩:离心机、离心浓缩仪、生物浓缩仪、冷冻干燥系统、快速蒸发系统、旋转蒸发仪 泵与真空设备:蠕动泵、活塞泵、隔膜泵、旋片泵、杂交泵、螺旋泵等 标签扫描:标签书写仪、编码扫描仪、标签生成器 实验室检测分析仪器 生命科学与生化分析:微孔板读数仪、酶标仪、洗板机、微孔板上样辅助仪、微孔板振荡器、热封仪、自动移液工作站、自动分液器、磁珠提取纯化系统、PCR仪、干胶仪、流式细胞仪、细胞离心涂片机
理化性质分析:天平、水分测定仪、电化学(卡尔费休水分仪、电位滴定、水质分析、PH计、电导率计、多叁数测试仪、电极、标准液)、折光仪、分光光度计、浊度仪、胆红素测定仪、热值分析、溶解氧分析、粘度计 小型计量仪:温/湿度计、风速计、转速计、计数器、流量计、压力计、数据采集、声光测定等
实验室耗材与安全防护 生物培养:细胞培养瓶/管、细胞培养皿、细胞培养板、细胞培养小室、细胞培养玻片、细胞培养载体、细胞刮刀/刮铲、多层细胞培养瓶、细胞工厂、果蝇培养、细胞培养皿、涂布与接种、红外接种环灭菌
样品采集与保存:样品采集、样品运输、样品保存、样品冻存(冻存管及配件、冻存管架、梯度降温盒、冻存盒、冰盒、真空绝热瓶、2D冻存系统) 微孔板与PCR耗材:Nunc微孔板、96孔板、384孔板、微孔板配件、PCR耗材
离心与浓缩:离心管、离心瓶、离心管架、过滤器、漏斗、过滤接收瓶、滤膜/滤纸 液体处理:手动移液器、电动移液器、连续分配器、瓶口分配器、分液器、移液吸头、移液管、滴管、滴定管、移液配件/储液槽、胶管、胶管连接 色谱耗材:National样品瓶和样品盖、气相色谱柱、液相色谱柱
实验室常规耗材:试剂瓶/罐、量筒、烧杯、容量瓶、锥形瓶、洗瓶、试管、称量器具、载玻片/盖玻片、磁力搅拌子、搅拌棒、比色皿、电容孔杯、干燥器/干燥柜、封口膜/铝箔、袋子、实验室文具/工具、推车、实验室清洁、坩埚/喂养针/研体
安全防护:生物废物处理、危险品存放、医药急救用品、个人防护、擦拭用品、环境防护
耗材: Axygen、BD、Corning、Schott、NUNC、millipore、merck JET NEST NALGENE
分子生物学:电泳、凝胶成像、分光光度计、酶标仪、洗板机、杂交仪、摇床等
细胞生物学:显微镜、CO2培养箱、液氮罐、细胞破碎仪、渗透压计等 药品食品:溶出度仪、硬度仪、崩解时限仪、粉碎机、制粒机、压片机、旋转蒸发仪、熔点仪等 物理化学:浊度计、光泽度计、白度计、色度计、防爆冷柜、氮吹仪、密度计、水分测定仪、定氮仪等
微生物学:微好氧/厌氧工作站、菌落计数仪、蠕动泵、培养基制备分装仪等
通用仪器:超净台、超声波清洗机、PH计、天平、磁力搅拌器、培养箱、水浴箱、灭菌器、离心机、安全柜、切片机、层析柜、制冰机、干式恒温器、混匀小精灵、微孔板的恒温振荡器、烘箱等
Thermo:CO2培养箱、纯水、液氮罐、马弗炉、细胞破碎仪、摇床、搅拌器、金属浴、超 低温冰箱、离心机、安全柜、离心浓缩仪、酶标仪、洗板机、分光光度计移液器等系列产品 Zealway:高校系列、GIT系列、GR系列
SCILOGEX:离心机、混匀仪、磁力搅拌器、摇床、旋转蒸发仪、金属浴、PCR仪、大容量电动移液器 金凤液氮罐:液氮生物容器、大口径液氮容器、自增压式液氮容器、贮奶桶
超微量分光光度计:Thermo NanoDrop™ One/OneC 、德国IMPLEN NP60/80 Touch Hair、-AUCMA:-86℃、-60℃、-50℃、-40℃、-25℃、2-8℃系列冰箱
SANTN:霉菌培养箱、恒温培养箱、光照培养箱、精密鼓风干燥培养箱、恒温恒湿箱、生化培养箱
试剂:Thermo、Gibco、invitrogen、pierce、life、hyclone、peprotech、biolegend、assay biotech、Simga-aldrich、Qiagen、CST、Abcam、R&D、Vector、santa cruz、Novus、Jackson、MN、corning、Sciencell、ZYMO、eBioscience、NEB、oxoid、wako、amresco、biovison、biotium、takara、roche、promega、bio-rad、selleck、abnova、bd、cayman、merck millpore、yeasen、solarbio、excell bio、KleanAB、Sangon、rhawn、macklin、aladdin、Energy Chemical、biomerieux 耗材: Corning、Axygen、BD、NUNC、nalgene、Schott、、Millipore、Merck、 QSP、nest、pall、 merck millpore、JET、AMMES、Bio-rad、Eppendorf、 brand、Thermo Fisher、百得BIOHIT、BIO-DL
上海辅泽商贸有限公司,是一家专注于生命科学领域的企业,是中国领先的实验室消耗品供应商。我们提供涉及分子生物学、细胞生物学、生物化学、免疫学、生态学、生物安全食品药品检验及临床检测等诸多领域的仪器和消耗品。 我们专业,所以值得信赖;我们专注,所以我们高速发展;我们信奉“客户第一,员工第二,股东第三”;我们坚持“团结创新,合作共赢”;我们将竭尽所能,为您提供最便捷、最专业的采购服务,节省您的时间和成本。
上海市虹口区曲阳路900弄复城国际1号楼3025室
