其它各类仪器
真空热压炉/Vacuum hot-pressing furnace
BEQ
安徽贝意克
BTF-1200C-VP
主要特点Main features:
Open type vertical heating furnace,tube and flange can pivot and move away from chamber.
开启式立式加热体,炉管法兰可绕轴旋转移出炉腔。
With standard configuration of OD100mm quartz tube and 40T electrical press
标配Φ100mm石英管真空密封,40T电动压力机。
Adopt graphite push rod and mould,at the same time of pressing,heat the powder to common sintering temperature or lower,to get the dender and uniform product after a short time
采用石墨顶杆和石墨模具,在加压的同时使粉末加热到正常烧结温度或更低一些,经过较短时间烧结成致密而均匀的制品。
技术参数Technical Parameters
Power
输入电源
Power rated: 3KW
额定功率:3KW
Voltage
电压
Voltage rated:  AC220V 50/60HZ
额定电压: AC220V 50/60HZ
Working Temperature
工作温度
Max. Temperature: 1200℃ ( 1 hr)
最高温度:1200℃ (1小时)
Continuous working temperature: ≤1150℃
持续工作温度:≤1150℃
Max. heating Rate: ≤10℃/min
最快升温速率:≤10℃/分
Temperature Controller
控温方式
PID automatic control and auto-tune function.
模糊PID控制和自整定调节
30 programmable segments for precise thermal processing.
智能化30段可编程控制
Built-in protection for the over-heated and broken thermocouple.
超温和断偶报警功能
Heating Elements
加热元件
Resistance wire, Fe-Cr-Al Alloy doped by Mo
电阻丝(掺钼铁铬铝合金)
Temperature Accuracy
控温精度
+/- 1℃
Prosessing tube
炉管
Φ100*460mm
 BTF-1200C-VP
Graphite rod diameter
石墨压杆直径
87mm
Pressure maintain time
保压时间
0-50min
Movable distance
压力行程
50mm
Plunger diameter
活塞直径
87mm
Pressure  stability
压力稳定性
≤1MPa/5min
Weight
重量
400kg
Vacuum Flange
真空法兰
Special designed flanges
定制法兰
Vacuum Pressure
真空压力
1pa can be achieved by mechanical pump
机械泵可达1pa
10^-4 pa can be reached by molecular pump
分子泵可达10^-4pa
Please click the picture below to order vacuum parts
点击下列图片订购真空部件
 BTF-1200C-VP  BTF-1200C-VP  BTF-1200C-VP  BTF-1200C-VP
Warranty
质保
One year limited warranty with lifetime support  (Such consumable parts as tO-rings, etc. are NOT supported by the warranty)
一年质保终身支持(消耗品如O型圈等不在质保范围内)
Warning
Graphite must used under anaerobic condition
石墨必须绝氧使用
Considering contact area calculate pressure
计算压强时应考虑接触面积
Small cracks may appear on the surface of the refractory ceramics over extended use. This is a normal occurrence and the cracks may be repaired with alumina coating.
在使用过程中炉膛表面可能出现细小裂纹。这是正常情况,裂纹可以用氧化铝涂层修复。
Compliance
认证
CE Certified
CE认证
The furnace is ready to pass TUV (UL61010) or CSA certification at extra cost.
可付费进行TUV(UL61010)或CSA认证
贝意克是一家专注于新材料设备的研发生产与一体的国家级高新技术企业。
花山工业园
