生物显微镜
日本奥林巴斯正置生物显微镜CX23
日本奥林巴斯正置生物显微镜CX23
进口
日本
CX23
• Ergonomic grips add safety when retrieving the
microscope from high places.
• Colored grips indicate the appropriate places to
hold the microscope.
• Smooth, rounded design eliminates sharp edges.
• The CX23 microscope is one of the lightest in its
class, with a total weight of approx. 5.9 kg
(13.01 lbs).
• The arm is angled to keep user’s wrists in a
comfortable, neutral position.
• The eyepiece can be fifi xed in place to help prevent
damage or loss during transportation.
• A rackless stage and stage cover enable safety and
stability during long periods of use.
•A locking pin keeps the observation tube in place.
•Interpupillary adjustments, ranging from 48 to 75
mm, enables individual users to set it to their needs.
•Eyepoint adjustments accommodate the user’s
height and provide greater comfort.
•Left and right diopter adjustment enable optimal
focus for each eye.
• An inward-facing rotating nosepiece facilitates
a larger working area above the stage, enabling
easier operation and specimen exchange
or making it easier to apply oil to immersion
objectives.
Objectives with long working distances provide
clearance for thick samples and slides.
Bring specimens into focus quickly by using the
coaxial knobs for fifi ne or coarse adjustments.
The microscope is built for durability and precise
control, whether accessed from the left or right
side.
• A torque release function helps prevent damage
if excess force is applied to the coarse focusing
knob or stage knob.
• The focus lock helps prevent the objectives from
damaging the specimen.
• Field number (FN) of 20 provides a wide fifi eld of
view.
The CX23 microscope features plan achromat
objectives that preserve outstanding image flfl atness
throughout the fifi eld of view.
•The energy saving LED light source provides a long
operation lifetime of 20,000 hours.
•Daylight balanced LED illumination preserves the
vivid colors on HE-stained samples.
• A storage compartment on the back of the CX23
microscope makes it easy to stow the power cable
after use.
• Protect your investment with an optional custom
designed wooden case.
When the CX23 microscope needs to be left
unattended, a built-in security slot enables
attachment of an anti-theft cable.
CX23 Specifi cations
DIMENSIONS
Unit: mm
*The dimension may vary according to interpupillary distance.
398
240
198
62*
Dedicated wooden case (optional)
Model CX23LEDRF (S1/S2) CX23RTFS2
Body Aluminum die-cast metal frame, protective plastic covering
Optical System Infinity optical system
Illumination System Built-in transmited illumination system
LED power consumption: 0.5 W (nominal value)
Focusing •Stage height movement •Coarse movement stroke: 15 mm •Coarse adjustment limit stopper
•Torque adjustment for coarse adjustment knob •Fine focus knob (minimum adjutsment gradations: 2.5 μm)
Revolving Nosepiece Fixed quadruple nosepiece with inward tilt
Stage Wire movement mechanical fixed stage
•Size (W × D): 174 mm × 89 mm •Traveling range (X × Y): 76 mm × 30 mm
•Specimen holder •Specimen position scale
Observation
Tube
Type Binocular, anti-fungal Trinocular, anti-fungal
Eyepiece (anti-fungal) 10X Field Number (FN): 20 15X Eyepiece (FN): 12 (optional)
Tube inclination 30°
Light path selector None Eyepiece/Camera port = 100/0 or 0/100
Interpupillary distance adjusting range 48 – 75 mm
Eyepoint adjustment 370.0 – 432.9 mm
Condenser •Abbe condenser NA 1.25 with oil immersion •Built-in aperture iris diaphragm
Objectives Plan Achromat, anti-fungal
4X NA 0.1 W.D. 27.8 mm
10X NA 0.25 W.D. 8.0 mm
20X NA 0.4 W.D. 2.5 mm (optional)
40X NA 0.65 W.D. 0.6 mm
100XOil NA 1.25 W.D. 0.13 mm (CX23LEDRFS1 built-in, CX23LEDRFS2/RTFS2 optional)
Optional Accessories Reflection mirror (CH20-MM), eyepiece micrometer
Dust cover, darkfield stop (CH2-DS+CH2-FH)
Field Diaphragm (CX23-FS)*
Dedicated wooden case (CH20-WB2)
Dust cover, darkfield filter (CH2-DS)
Dimensions (W × D × H) 198 mm × 398 mm × 386 mm 198 mm × 398 mm × 430 mm
Weight Approximately 5.9 kg Approximately 6.5 kg
Rated Voltage/Electric Current AC 100 – 240 V 50/60 Hz 0.4 A
Power Consumption Less than 2 W
*CX23-FS is included in CX23RTFS2 standard set
青岛安道科技有限公司,您身边的显微专家!青岛安道成立于2020年,总部位于青岛,公司主营德国徕卡、蔡司、日本奥林巴斯、尼康显微镜、重庆澳浦显微镜,英国Linkam热台、美国Instec热台、加拿大BII阴极发光仪,实验室仪器设备等。青岛安道 客户涵盖农林、医疗、机械、冶金、电力、石化、地质等行业,在高等院校、科研院所、医疗卫生、工矿企业、工业材料、农业系统、畜牧系统、军工系统精密仪器制造等领域具有相当的知名度与影响力。安道科技响应“中国制造2025”强国战略的号召,整合全球智力资源,引进欧美先进科技,为中国制造业的提升和“中国梦”的实现做出自己的贡献青岛安道自成立以来,通过过硬的实力和周到的服务迅速赢得了广大客户的认可,客户覆盖全国大部分地区,包括清华大学、北京大学、中科院大学、北京科技大学、中国地质大学、北京航空航天大学、中国石油大学(华东)、山东大学、山东科技大学、青岛大学、中科院海洋所、青岛海洋地质所、国家海洋局、中航工业科技集团、海信集团、海尔集团等单位,并多次在政府采购和知名企业招标采购中成为中标供应商。 青岛安道秉承“花最少的钱,干最好的事”的经营理念和科学的规范管理,凝聚了大量的优秀人才。公司拥有专业的市场、营销、和技术服务团队,为安道的高速发展增添了不竭动力。如今的安道从商海大浪中走来,意气风发,独占鳌头;在未来,青岛将一如既往致力于材料、生物分析技术的创新与发展,与国内外客户共同开创世界科技发展的未来。。
山东省青岛市黄岛区开拓路277号兴悦华城东区26-1-1203室
18254212521;18562862086
