MCH卫生级可压缩层析柱
货号 | 规格 | 柱管内径(mm) | 柱管高度(mm) | 装填高度(cm) | 工作压力(≤bar) | 重量(kg) |
JZ-0316 | MCH70/500 Column | 70 | 500 | 0-35 | 8 | 15 |
JZ-0317 | MCH70/750 Column | 70 | 750 | 20-60 | 8 | 17 |
JZ-0318 | MCH70/950 Column | 70 | 950 | 40-80 | 8 | 20 |
JZ-0301 | MCH100/500 Column | 100 | 500 | 0-35 | 8 | 17 |
JZ-0302 | MCH100/750 Column | 100 | 750 | 20-60 | 8 | 20 |
JZ-0303 | MCH100/950 Column | 100 | 950 | 40-80 | 8 | 22 |
JZ-0304 | MCH140/500 Column | 140 | 500 | 0-35 | 6 | 25 |
JZ-0305 | MCH140/750 Column | 140 | 750 | 20-60 | 6 | 28 |
JZ-0306 | MCH140/950 Column | 140 | 950 | 40-80 | 6 | 30 |
JZ-0307 | MCH200/500 Column | 200 | 500 | 0-35 | 6 | 36 |
JZ-0308 | MCH200/750 Column | 200 | 750 | 20-60 | 6 | 39 |
JZ-0309 | MCH200/950 Column | 200 | 950 | 40-80 | 6 | 42 |
JZ-0310 | MCH300/500 Column | 300 | 500 | 0-35 | 4 | 66 |
JZ-0311 | MCH300/750 Column | 300 | 750 | 20-60 | 4 | 71 |
JZ-0312 | MCH300/950 Column | 300 | 950 | 40-80 | 4 | 75 |
JZ-0313 | MCH450/500 Column | 450 | 500 | 0-32 | 4 | 200 |
JZ-0314 | MCH450/750 Column | 450 | 750 | 20-57 | 4 | 215 |
JZ-0315 | MCH450/1000 Column | 450 | 1000 | 40-82 | 4 | 230 |
单位名称: |
苏州工业园区新平街388号腾飞科技园23幢3层05单元
联系电话: |
Email: |
