其它各类仪器
LIA-MV-150锁相放大器模块45KHZ频率
LOCK-IN AMPLIFIER MODULES SERIES
进口
德国FEMTO
LIA-MV-150
FEATURES
  • Current and voltage input
  • Working frequency up to 45 kHz
  • Adjustable sensitivity, time constant and phase
  • Local and remote control
  • Compact and EMI-shielded case
COMPACT MODULE
In modern optoelectronic systems lock-in-amplification is one of the most useful techniques to get rid of unwanted noise and to improve the measurement sensitivity. Therefore we have created a miniaturized, powerful module operating reliably even in heavy noise environments.
TWO WAYS OF PROGRAMMING
The amplifier settings - e.g. phase, gain, time constant - are controlled either by switches directly on the amplifier module or externally using a standard digital I/O computer board. The variable working frequency is determined by an external reference signal which may be e.g. the synchronization signal of a chopper wheel or the modulation signal of a laser. The current input is well suited for amplifying signals from high impedance sources like photodiodes or PMTs while the voltage input can be used to measure signals from low impedance sources like pyros or coils.
APPLICATIONS
  • Spectroscopy
  • Laser stabilization
  • Luminescence, fluorescence, phosphorescence measurements
  • Light scattering measurements
  • Opto-electronical quality control
  • Integration in industrial and scientific measurement systems
  • OEM systems
Model LIA-MV-150-S
Standard
LIA-MV-150-D
True-Differential Input
Voltage Input BNC connector
Single-ended
Instrumentation amplifier
Noise 12 nV/√Hz
Lemo® connector
True-differential
Noise 12 nV/√Hz
Current Input BNC connector
Transimpedance amplifier, gain 1 kV/A
Noise 4 pA/√Hz
Lemo® connector
Noise 4 pA/√Hz
Sensitivity
(Full Scale)
Voltage: 3 µV to 100 mV, switchable in 1-3-10
Current: 3 nA to 100 µA, switchable in 1-3-10
Working Frequency 10 Hz - 45 kHz
Reference Input ±100 mV to ±5 V, switchable to TTL
Phase Adjustable 0° - 360° (8-bit resolution),
Temperature drift <0,01°/K
Demodulator 50 dB max. dynamic reserve
Time Constants 3 ms to 10 s, switchable in 1-3-10, slope switchable 6 dB or 12 dB/octave
Output X [R · cos(angle)], ±10 V full scale, short-circuit protected
Digital Control 16 TTL, CMOS, opto-isolated
8 Bits phase, 4 Bits time constant, 4 Bits sensitivity
Power Supply ±15 V, 100 mA typ.
Case 170 x 60 x 30 mm (L x W x H), Weight 370 g
深圳市嘉士达精密仪器有限公司是一家生产、销售为一体的重品质、创新型、多元化检测仪器公司。一直以来我们专注于安规检测仪器设备、IP防护试具、弹簧冲击器,传感器、环境测试设备、防水试验设备、量规和防滑检测设备的生产和销售,代理FEMTO放大器、OPHIR功率计等进口仪器设备。精益求精,创造符合国际标准规范要求的产品,客户产业遍及于电子电器、光电通讯、机械制造、塑胶五金、汽车等科技产业,公司一贯坚持从产品研发到售后服务,每一个环节之间,都以客户的需求作为出发点。以质量求生存,诚信谋发展,竭诚与国内外商家双赢合作。
西乡街道臣田社区宝民二路东方雅苑
