BIO-RAD伯乐脉冲场电泳系统
CHEF-DR II脉冲场电泳系统
应用灵活
CHEF–DR II 系统采用120° 固定角度,经优化以适合最常用的分离跨度。通过调低电压及延长电泳时间,可用于分离6 Mb 的片段。
【订货信息】
目录 # |
描述 |
170-3612 |
CHEF-DR II System, 100/120 V, includes electrophoresis cell, drive module, control module, variable-speed pump, 14 x 13 cm casting stand with frame and platform, comb holder, 15-well, 1.5 mm thick comb, screened cap, disposable plug molds, 12' Tygon tubing, 2 plugs S. cerevisiae DNA size standards, 5 g pulsed field certified agarose, 5 g Certified megabase agarose, instructions |
170-3615 |
CHEF-DR II System, 220/240 V |
170-3725 |
CHEF-DR II Chiller System, 120 V, includes electrophoresis cell, drive module, control module, variable-speed pump, 14 x 13 cm casting stand with frame and platform, comb holder, 15-well, 1.5 mm thick comb, screened cap, disposable plug molds, 12' Tygon tubing, 2 plugs S. cerevisiae DNA size standards, 5 g pulsed field certified agarose, 5 g Certified megabase agarose, instructions; includes cooling module |
170-3727 |
CHEF-DR II Chiller System, 220/240 V 价格¥255988.00 |
170-3728 |
CHEF-DR II Chiller System, 100 V |
CHEF-DR III 可变角脉冲场电泳系统
【介绍】
用户化
使用CHEF–DR III 系统,用户可自己设置条件。指导手册记录了大量不同分离跨度下的电泳条件。
应用灵活
CHEF–DR III 系统能编程电泳角度,为200 kb 到>6Mb 的DNA 分子提供快速、高分辨率的分离。CHEF–DR III系统能选择特定DNA 大小跨度的最佳电压梯度、转换时间及角度。可编程3 个连续执行的电泳条件模块,增加了 电泳可运行的条件,从而进一步优化分离。
【订货信息】
目录 # |
描述 |
170-3695 |
CHEF-DR III System, 100/120 V, includes power module, electrophoresis cell, variable-speed pump, 14 x 13 cm casting stand with frame and platform, comb holder, 15-well, 1.5 mm thick comb, screened cap, disposable plug molds, 12' Tygon tubing, 2 plugs S. cerevisiae DNA size standards, two 0.5 A FB fuses, 5 g pulsed field certified agarose, 5 g Certified megabase agarose, instructions |
170-3697 |
CHEF-DR III System, 220/240 V |
170-3700 |
CHEF-DR III Chiller System, 120 V, includes power module, electrophoresis cell, variable-speed pump, 14 x 13 cm casting stand with frame and platform, comb holder, 15-well, 1.5 mm thick comb, screened cap, disposable plug molds, 12' Tygon tubing, 2 plugs S. cerevisiae DNA size standards, two 0.5 A FB fuses, 5 g pulsed field certified agarose, 5 g Certified megabase agarose, instructions; includes cooling module |
170-3702 |
CHEF-DR III Chiller System, 220/240 V |
CHEF Mapper XA 脉冲场电泳系统
【介绍】
自动化
CHEF Mapper XA 系统为你提供2 种途径 以优化分离。独特的自动计算功能整合了11 个关键变量及设定起始分离条件,能为你的分 离自动选择最佳条件。以Windows 为基础的交互式运算程序可用于改进实验流程。程序能让你同时确定多个电泳变量以得出最优化的分离规程。
用户化
繁忙的实验室需要能储存关键分离条件的设备。CHEF Mapper XA 系统能储存多达99 个程序。
应用灵活
CHEF Mapper XA 系统是最灵活的PFGE 单元。与其它PFGE 系统相比,CHEF Mapper XA 系统可获得更高的分辨率、更快的速度和更高的精确度,是所有PFGE 应用的理想选择。
CHEF Mapper XA 系统能让你选择0°–360° 内的任何脉冲角度,使你用一个系统就能完成染色体和质粒DNA 的最佳分离。
精确的片段大小分离需要一个扩展的线性分离跨度。通过逐渐改变电泳过程中的转换时间来转换时间梯度,从而增加片段迁移率。非线性(例如,凹形或凸形)梯度改变电泳起始到结束过程中的转换时间增量。非线性梯度可线性分离50–700 kb 片段,获得更精确的片段大小。
【订货信息】
目录 # |
描述 |
CHEF Mapper Systems |
170-3670 |
CHEF Mapper XA Chiller System, 120 V, includes CHEF Mapper XA power module, embedded auto-algorithm for protocol optimization, interactive algorithm program disk, electrophoresis cell, cooling module, variable-speed pump, Tygon tubing (12'), 14 x13 cm (W x L) casting stand, 15-well 1.5 mm comb and comb holder, screened cap, disposable plug molds, leveling bubble, cables, S. cerevisiae standards, two 0.5 A FB fuses, 5 g pulsed field certified agarose, 5 g Certified megabase agarose, instructions |
170-3671 |
CHEF Mapper XA Chiller System, 100 V |
170-3672 |
CHEF Mapper XA Chiller System, 220 V |
170-3673 |
CHEF Mapper XA Chiller System, 240 V, includes CHEF Mapper XA power module, embedded auto-algorithm for protocol optimization, interactive algorithm program disk, electrophoresis cell, cooling module, variable-speed pump, Tygon tubing (12'), 14 x13 cm (W x L) casting stand, 15-well 1.5 mm comb and comb holder, screened cap, disposable plug molds, leveling bubble, cables, S. cerevisiae standards, two 0.5 A FB fuses, 5 g pulsed field certified agarose, 5 g Certified megabase agarose, instructions |
Accessories |
162-0196 |
Zeta-Probe GT Membrane, 30 cm x 3.3 m, 1 roll |
162-0197 |
Zeta-Probe GT Membrane, 20 cm x 3.3 m, 1 roll |
170-3622 |
Reusable Plug Mold, 10 plug |
170-3623 |
Preparative Comb, 14 cm wide, 1.5 mm thick, with 2 outer wells for size standards |
170-3627 |
15-Well Comb, 21 cm wide, 1.5 mm thick |
170-3628 |
30-Well Comb, 21 cm wide, 1.5 mm thick |
170-3643 |
Gel Scoop |
170-3644 |
Variable-Speed Pump, 120 V |
170-3645 |
45-Well Comb, 21 cm wide, 1.5 mm thick |
170-3648 |
Electrodes, thick gauge (0.02"), 6 |
170-3654 |
Cooling Module, 120 V |
170-3655 |
Cooling Module, 220/240 V |
170-3688 |
Cooling Module, 100 V |
170-3689 |
Standard Casting Stand, includes 14 x 13 cm frame and platform |
170-3699 |
Combination Comb Holder |
170-3704 |
Wide/Long Combination Casting Stand, includes 21 x 14 cm frame and platform |
170-3711 |
Screened Caps, 5 |
170-3713 |
50-Well Disposable Plug Molds, 5 |
170-4046 |
Leveling Table, 20 x 30 cm |
170-4322 |
20-Well Comb, 14 cm wide, 1.5 mm thick, adjustable height |
170-4323 |
15-Well Comb, 14 cm wide, 0.75 thick, adjustable height |
170-4324 |
15-Well Comb, 14 cm wide, 1.5 mm thick, adjustable height |
170-4325 |
10-Well Comb, 14 cm wide, 0.75 mm thick, adjustable height |
170-4326 |
10-Well Comb, 14 cm wide, 1.5 mm thick, adjustable height |
170-4344 |
30-Well Comb, 14 cm wide, 1.5 mm thick, adjustable height |
Agaroses and Size Standards |
162-0017 |
Low Melt Preparative Grade Agarose, 25 g |
162-0019 |
Low Melt Preparative Grade Agarose, 100 g |
162-0135 |
Chromosomal Grade Agarose, 25 g |
162-0136 |
Chromosomal Grade Agarose, 100 g |
162-0137 |
Pulsed Field Certified Agarose, 100 g |
162-0138 |
Pulsed Field Certified Agarose, 500 g |
170-3592 |
CHEF Bacterial Genomic DNA Plug Kit, contains 12 ml cell suspension buffer, 1.3 ml proteinase K, 30 ml proteinase K reaction buffer, 12 ml 2% CleanCut agarose, 60 ml 10x wash buffer, 1.6 ml lysozyme (25 mg/ml), 30 ml lysozyme buffer, screened cap, 2 disposable plug molds, instructions |
170-3593 |
CHEF Yeast Genomic DNA Plug Kit, contains 12 ml cell suspension buffer, 1.3 ml proteinase K, 30 ml proteinase K reaction buffer, 12 ml 2% CleanCut agarose, 60 ml 10x wash buffer, 1.6 ml lyticase, 25 ml lyticase buffer, screened cap, 2 disposable plug molds, instructions |
170-3605 |
CHEF DNA Size Marker, S. cerevisiae, 0.2–2.2 Mb, 5 agarose blocks, sufficient for 25–40 plugs |
170-3624 |
CHEF DNA Size Standard, 5 kb ladder, 24–40 applications |
170-3633 |
CHEF DNA Size Marker, S. pombe, 3.5–5.7 Mb, 5 agarose blocks, sufficient for 25–40 plugs |
170-3635 |
CHEF DNA Size Standard, lambda ladder, 0.05–1 Mb, 5 agarose blocks, sufficient for 25–40 plugs |
170-3667 |
CHEF DNA Size Marker, H. wingei, 1–3.1 Mb, 5 agarose blocks, sufficient for 25–40 plugs |
170-3707 |
CHEF DNA Size Standard, 8–48 kb, 125 lanes |
脉冲场标准品和分子量标尺
【介绍】
脉冲场电泳标准品可为您节省数天的准备时间。Bio-Rad 提供了从质粒插入的FIGE 分离到最大染色体分离的 标准品。脉冲场标准品以低熔点琼脂糖凝胶块形式提供,凝胶块可根据上样孔大小而随意切割。
【技术指标】
脉冲场标准品比较
分子量跨度范围 |
组成 |
含量 |
应用数量 |
5 kb 梯度 |
4.9–120 kb |
pBR328 多联体 |
20 µg ,200 µl |
20–25 |
8–48 kb 梯度 |
8.3–48.5 kb |
λ 降解混合物 |
25 µg, 125 µl |
125 |
λ DNA 梯度 |
0.05–1 Mb |
λcl 857 Sam7 多联体 |
5 个琼脂糖凝胶块 |
25–40 |
S. cerevisiae |
0.2–2.2 Mb |
Saccharomyces cerevisiae |
5 个琼脂糖凝胶块 |
25–40 |
H. wingei |
1–3.1 Mb |
Hansenula wingei |
5 个琼脂糖凝胶块 |
25–40 |
S. pombe |
3.5–5.7 Mb |
Schizosaccharomyces pombe |
5 个琼脂糖凝胶块 |
25–40 |
分子质量标尺
Bio-Rad 精确的分子质量标尺能在凝胶上正确定量DNA,是光密度分析和图像分析的理想选择。这些标尺有5 根条带,分别含有 100、70、50、20 和10 ng DNA。精确EZ Load 分子质量标尺可直接上样。
CHEF 基因组DNA插块试剂盒
【介绍】
CHEF 基因组DNA 插块试剂盒为PFGE 制备完整 的染色体大小的DNA 提供了方便。对于如此大的分子, 机械抽提会产生DNA 机械剪切, 导致了不好的PFGE 分离效果。要解决这个问题,通过将全细胞包埋于琼 脂糖中进行裂解和去蛋白质,最终获得完整的纯化 DNA。Bio-Rad 提供3 种试剂盒,分别用于制备细菌 (溶菌酶敏感)、哺乳动物的基因组DNA 及酵母染色体 (YACs)。每个试剂盒包括制备100 个插块所需要的酶、 反应缓冲液和限制性酶切CleanCut 琼脂糖,也包括一 次性插块模和屏蔽帽以简化插块处理。每个试剂盒都 经过严格测试,保证所制备的基因组DNA 能被限制性 酶切并可在CHEF 电泳系统中分离。
分离E.coli 染色体酶切片段。 泳道1 和14,S.cerevisiae 染色体;泳道2 和13,λ 分子 量梯度;泳道3-6,DH5 alphaF' 染色体DNA 的NotI 消化物(泳 道3);HB101( 泳道4 );MC 1061(泳道5);MV 1190 (泳道 6)。泳道8-11,DH5 alphaF' 染色体DNA 的SfiI 消化物( 泳道 8);HB101( 泳道9 );MC1061( 泳道10 );MV1190 ( 泳道 11)。DNA 片段在0.5 x TBE, 14°C, 6 V/cm (200 V),120° 角 度,2.77–26.32 秒线性转换时间梯度,于1.0% 脉冲场 Certified 琼脂糖凝胶上分离。
【订货信息】
目录 # |
描述 |
170-3592 |
170-3593 |
170-3594 |
CleanCut Agarose, 2%, 12 ml |
更多产品资料及其它生命科学仪器相关设备请登录www.cbio21.com查询,
客服电话010-51282213;客服QQ:989203;1410116;客服微信:13601128645
北京赛百奥科技有限公司成立于2003年,注册于北京市海淀区中关村科技园区,是集产品开发、研制、销售、技术与服务为一体的现代化企业。公司自成立之日起,本着以“诚信为本,科技为先,服务至上” 的经营理念为广大客户提供技术先进、品质保证、性价比高的产品及服务。
在公司不断发展壮大的道路上,我们积累了丰富的服务经验,高度的专业水平,国际性供货体系。为全国科研,教学及工业用户提供先进的技术,前沿的产品及优质的服务。我公司涉及的客户遍布全球,主要为科研院所、大专院校、疾控、检测机构及工业生产等单位,涉及生物制药、食品保健、医疗卫生、检验检疫、环保环监等行业提供丰富的产品及优质的服务。
我公司主要代理经营的产品如下(详细产品信息请登录http://www.cbio21.com查询):
1、瑞士Lonza 龙沙:4D Nucleofector细胞核转仪和试剂盒(原Amaxa),支原体及内毒素检测设备及试剂盒,MODA实验室/生产/质控管理软件,人原代细胞和培养基,琼脂糖和闪胶
2、美国Benchmark:迷你离心机、高速台式离心机、微孔板离心机、采血管离心机;漩涡混合器、管式混合仪、3D混合仪、旋转混合仪、轨道振荡器;组织珠磨器、高速匀浆器;玻璃珠灭菌器、无火焰灭菌器;迷你(CO2)培养箱、CO2(振荡)培养箱、干式恒温器、水浴及水浴振荡器、恒温振荡器、恒温旋转混合仪、微孔板恒温振荡器、防腐型恒温磁力搅拌器等实验室常用桌面设备
3、德国AID 艾迪:EliSpot Reader Classic 酶联免疫斑点分析仪、iSpot Reader 荧光酶联免疫斑点分析仪
4、美国BIO-RAD伯乐:Mini-PROTEAN垂直电泳槽,Trans-Blot 转印槽、Sub-Cell GT水平电泳槽,Trans-Blot SD 半干转印槽、Trans-Blot™ Turbo® 全能型蛋白转膜仪、双向电泳槽、等电聚焦电泳槽、电泳凝胶梯度生成仪、422型电洗脱仪及各规格电泳电源;TC20细胞计数仪,ZOE™荧光细胞成像仪;T100 PCR仪、C1000 PCR仪、S1000 PCR仪、CFX96荧光定量PCR仪;MicroPulser 电穿孔仪、Gene Pulser Xcell 电穿孔系统、基因枪及电击杯、金粉、载体膜、阻挡网、可裂膜等耗材;iMark 酶标仪、1575 洗板机;微量过滤器、多道筛选仪;凝胶成像/化学发光/多色荧光成像系统等。
5、美国SI:漩涡混合器系列
6、德国耶拿(原美国UVP): HB-1000分子杂交箱、HL-2000分子杂交箱、CL-1000紫外交联仪、CX-2000紫外交联仪、凝胶成像/化学发光/多色荧光成像系统、小动物活体成像系统
7、赛百奥CBIO:紫外分析仪,荧光剂检测仪,大肠埃希氏菌检测仪,薄层色谱仪,活体荧光检测仪,紫外光化学反应箱,薄层色谱仪,紫外交联仪,紫外灭菌箱,紫外诱变箱,紫外透照台,紫外割胶仪,电泳凝胶检测仪,电泳凝胶成像仪,薄层色谱照相系统。
8、日本三菱:微需氧及厌氧培养、安宁包系列
9、美国Pall 颇尔:生物反应器(用于间充质干细胞培养的Xpansion 多层平板生物反应器系统、大规模病毒生产装置—iCELLis®生物反应器
),实验室和工业液体及气体过滤产品(针头滤器、囊式滤器、不锈钢圆盘过滤器、圆盘微孔滤膜、超滤离心管、切向流过滤器及膜包、工业不锈钢滤壳及配套滤芯等),微生物检验产品(不锈钢多联过滤器及微检滤膜),蛋白层析(预装柱及层析填料、多孔滤板),Ultroser G血清替代品,核酸蛋白检测(Biodyne A/B膜、BioTrace™ NT纯硝酸纤维素转印膜、FluoroTrans® PVDF膜、UltraBind™ Affinity膜、Immunodyne® ABC膜), IVD诊断用膜材(硝酸纤维素膜)等
10、Rainin 瑞宁:手动、电动、单道、多道移液器,移液工作站,吸头,真空吸液泵,移液器校准服务
11、METTLER TOLEDO 梅特勒-托利多:(超微量)紫外可见分光光度计、水份测定仪、电位滴定仪、PH计、天平等
12、Euroka Bio 深研: CellSep Pro全封闭自动化细胞处理系统
13、日立:核酸提取纯化-荧光定量PCR一体机、毛细管电泳仪、全自动核酸提取纯化仪、离心机
14、美国AXION:阻抗式无标记、非侵入实时细胞监测系统
15、美国BIOLIFE:无水细胞复苏仪(管式及袋式)
16、德国Sartorius赛多利斯:天平、PH计、电导率仪、水份测定仪、离心机、超纯水机、移液器,实验室耗材(针头滤器、囊式滤器、微孔滤膜、超滤离心管等),微生物检验产品(多联不锈钢滤器、微检滤膜等)
17、ThermoFisher: 3111系列水套CO2培养箱、371 系列 Steri Cycle 高温灭菌型CO2培养箱、311系列直热式CO2培养箱、BB150直热式CO2培养箱、Heracell VIOS 160i CO2培养箱、Heracell VIOS 250i CO2培养箱,超低温冰箱,生物安全柜,液氮罐,离心机,PCR仪,超微量核酸蛋白测定仪。此外,我们还提供全线细胞培养产品。
18、日本Yamato:高压蒸汽灭菌器、干热灭菌器等
19、德国Grumbach:孵化器、孵蛋器
20、美国WESCOR:露点渗透压仪
21、美国SONICS:超声波细胞破碎仪
22、美国WILSON WOLF:G-Rex悬浮细胞培养系统及会呼吸的细胞培养瓶
23、德国徕卡:正置生物显微镜、倒置生物显微镜、体式解剖显微镜、显微照相系统、荧光显微镜及其病理设备
单位名称: |
北京海淀区阜成路115号丰裕写字楼509,510室
联系电话: |
Email: |
