电泳槽
Bio-rad伯乐PROTEAN II xi 2-D 双向电泳槽
The PROTEAN II xi 2-D
进口
美国Bio-rad
PROTEAN II xi 2-D
【介绍】
The PROTEAN II xi 2-D 电泳槽包含聚丙烯酰胺管式双向电泳需要的所有组件。
※ 在PROTEAN II xi 2-D 电泳槽内,可同时进行第一向的管式凝胶电泳和第二向的板式凝胶电泳
※ 运用管式凝胶适配器,一次电泳可聚焦多达16 根第一向IEF 管式凝胶
※ 斜面玻板,易于放置管式凝胶的板式凝胶表面
PROTEAN II xi 2-D 电泳槽组件:
  1. 管式凝胶中央制冷芯
  2. 带密封垫条的电泳中央制冷芯
  3. 缓冲液槽和带有电线的盖子
  4. 板式凝胶灌胶架、玻璃板和三明治夹
  5. 垫圈和塞子
  6. 玻璃管
【订货信息】
PROTEAN II xi 2-D Cell
165-1931
PROTEAN II xi 2-D Cell, includes a central cooling core with gaskets, lower buffer chamber,   lid with cables, 2 sets of glass plates (with beveledinner plates), four 16 cm sandwich clamps, twenty-four 180 mm long glass tubes   (tube diameter = spacer thickness), 2 tube gel adaptors, 16 grommets, 16   stoppers, two 1.0 mm 2-D   combs, four 1.0 mm   spacers, upper buffer dam, casting stand with gaskets, leveling bubble,   instructions
165-1932
PROTEAN II xi 2-D Cell, includes a central cooling core with gaskets, lower buffer chamber,   lid with cables, 2 sets of glass plates (with beveledinner plates), four 16 cm sandwich clamps, twenty-four 180 mm long glass tubes   (tube diameter = spacer thickness), 2 tube gel adaptors, 16 grommets, 16   stoppers, two 1.5 mm 2-D   combs, four 1.5 mm   spacers, upper buffer dam, casting stand with gaskets, leveling bubble,   instructions
165-1933
PROTEAN II xi 2-D Cell, includes a central cooling core with gaskets, lower buffer chamber,   lid with cables, 2 sets of glass plates (with beveledinner plates), four 20 cm sandwich clamps, twenty-four 180 mm long glass tubes   (tube diameter = spacer thickness), 2 tube gel adaptors, 16 grommets, 16   stoppers, two 1.0 mm 2-D   combs, four 1.0 mm   spacers, upper buffer dam, casting stand with gaskets, leveling bubble,   instructions
165-1934
PROTEAN II xi 2-D Cell, includes a central cooling core with gaskets, lower buffer chamber,   lid with cables, 2 sets of glass plates (with beveledinner plates), four 20 cm sandwich clamps, twenty-four 180 mm long glass tubes   (tube diameter = spacer thickness), 2 tube gel adaptors, 16 grommets, 16 stoppers,   two 1.5 mm 2-D   combs, four 1.5 mm   spacers, upper buffer dam, casting stand with gaskets, leveling bubble,   instructions
Note: Each PROTEAN II xi 2-D   cell includes a central cooling core with gaskets, lower buffer chamber, lid   with cables, 2 sets of glass plates (with beveled inner plates), 4 sandwich   clamps, 24 glass tubes (180 mm   long, tube diameter = spacer thickness), 2 tube gel adaptors, 16 grommets, 16   stoppers, two 2-D combs (2), 4 spacers, upper buffer dam, casting stand with   gaskets, leveling bubble, instructions. Each cell includes sandwich clamps   for running gels of the corresponding size (either 16 cm or 20 cm);   1.0 mm and 1.5 mm indicate the   thickness of spacers and combs included with the cell.
Tube Gel Casting Accessories
165-2020
Model 225 Tube Gel Casting Stand
165-3122
5.0 mm ID Glass Tubes, 7.0 mm OD, 125 mm length, 24
165-3136
1.0 mm ID Glass Tubes, 6.0 mm OD, 180 mm length, 24
165-3137
1.5 mm ID Glass Tubes, 7.5 mm OD, 150 mm length, 24
165-3138
1.5 mm ID Glass Tubes, 7.5 mm OD, 180 mm length, 24
165-3150
3.4 mm ID Glass Tubes, 5.0 mm OD, 125 mm length, 24
165-3155
2.4 mm ID Glass Tubes, 4.0 mm OD, 160 mm length, 24
Slab Gel Handcasting Accessories
165-1821
Inner Plates, for 16 cm   cell, 16 x 20 cm,   2, for PROTEAN II xi cell only
165-1822
Outer Plates, for 16 cm   cell, 18.3 x 20 cm,   2, for PROTEAN II xi cell only
165-1823
Inner Plates, for 20 cm   cell, 20 x 20 cm,   2
165-1824
Outer Plates, for 20 cm   cell, 22.3 x 20 cm,   2
165-1827
Beveled Inner Plates, for 2-D tube gel procedures, 16    cm bevel length, 16 x 20    cm, 2, for PROTEAN II xi cell only
165-1828
Beveled Inner Plates, for 2-D tube gel procedures, 16    cm bevel length, 20 x 20    cm, 2, for PROTEAN II xi cell only
165-1843
PROTEAN II xi Spacers, 16 cm, 1.0 mm spacers
165-1848
PROTEAN II xi Spacers, 20 cm, 1.0 mm spacers
165-1897
PROTEAN II xi Comb, 2-D (1 reference well), 1.0    mm
165-1901
PROTEAN II Sandwich Clamps, 16 cm set (1 left, 1   right)
165-1902
PROTEAN II Sandwich Clamps, 20 cm set (1 left, 1   right)
165-1911
Slab Gel Casting Stand, with gaskets
Other Accessories
165-1806
Central Cooling Core, with gaskets
165-1807
Buffer Tank
165-1909
Upper Buffer Dam
165-1943
Tube Gel Loading Needles, 18 cm, 22 gauge, blunt   tip, luer hub (for casting monomer in small-diameter tubes), 2
165-1944
Tube Gel Extrusion Needles, 9 cm, 26 gauge,   beveled tip, luer hub (for removing gels from tubes), 2
System Accessories
165-2025
PROTEAN II xi Multi-Gel Casting Chamber, includes casting chamber, sealing plate, silicone   gasket, 15 separation sheets, 4 acrylic blocks, 10 xi alignment cards,   tapered luer connector, leveling bubble, instructions
165-4121
Model 495 Gradient Former, 100–1,500 ml, includes body with valve stem and tubing connection kit
更多产品资料及其它生命科学仪器相关设备请登录北京赛百奥科技有限公司查询,
http://www.cbio21.com
客服电话010-51282213;
客服QQ:989203;1410116;
客服微信:13601128645
北京赛百奥科技有限公司成立于2003年,注册于北京市海淀区中关村科技园区,是集产品开发、研制、销售、技术与服务为一体的现代化企业。公司自成立之日起,本着以“诚信为本,科技为先,服务至上” 的经营理念为广大客户提供技术先进、品质保证、性价比高的产品及服务。
        在公司不断发展壮大的道路上,我们积累了丰富的服务经验,高度的专业水平,国际性供货体系。为全国科研,教学及工业用户提供先进的技术,前沿的产品及优质的服务。我公司涉及的客户遍布全球,主要为科研院所、大专院校、疾控、检测机构及工业生产等单位,涉及生物制药、食品保健、医疗卫生、检验检疫、环保环监等行业提供丰富的产品及优质的服务。
我公司主要代理经营的产品如下(详细产品信息请登录http://www.cbio21.com查询):
1、瑞士Lonza 龙沙:4D Nucleofector细胞核转仪和试剂盒(原Amaxa),支原体及内毒素检测设备及试剂盒,MODA实验室/生产/质控管理软件,人原代细胞和培养基,琼脂糖和闪胶
2、美国Benchmark:迷你离心机、高速台式离心机、微孔板离心机、采血管离心机;漩涡混合器、管式混合仪、3D混合仪、旋转混合仪、轨道振荡器;组织珠磨器、高速匀浆器;玻璃珠灭菌器、无火焰灭菌器;迷你(CO2)培养箱、CO2(振荡)培养箱、干式恒温器、水浴及水浴振荡器、恒温振荡器、恒温旋转混合仪、微孔板恒温振荡器、防腐型恒温磁力搅拌器等实验室常用桌面设备
3、德国AID 艾迪:EliSpot Reader Classic 酶联免疫斑点分析仪、iSpot Reader 荧光酶联免疫斑点分析仪
4、美国BIO-RAD伯乐:Mini-PROTEAN垂直电泳槽,Trans-Blot 转印槽、Sub-Cell GT水平电泳槽,Trans-Blot SD 半干转印槽、Trans-Blot™ Turbo® 全能型蛋白转膜仪、双向电泳槽、等电聚焦电泳槽、电泳凝胶梯度生成仪、422型电洗脱仪及各规格电泳电源;TC20细胞计数仪,ZOE™荧光细胞成像仪;T100 PCR仪、C1000 PCR仪、S1000 PCR仪、CFX96荧光定量PCR仪;MicroPulser 电穿孔仪、Gene Pulser Xcell 电穿孔系统、基因枪及电击杯、金粉、载体膜、阻挡网、可裂膜等耗材;iMark 酶标仪、1575 洗板机;微量过滤器、多道筛选仪;凝胶成像/化学发光/多色荧光成像系统等。
5、美国SI:漩涡混合器系列
6、德国耶拿(原美国UVP): HB-1000分子杂交箱、HL-2000分子杂交箱、CL-1000紫外交联仪、CX-2000紫外交联仪、凝胶成像/化学发光/多色荧光成像系统、小动物活体成像系统
7、赛百奥CBIO:紫外分析仪,荧光剂检测仪,大肠埃希氏菌检测仪,薄层色谱仪,活体荧光检测仪,紫外光化学反应箱,薄层色谱仪,紫外交联仪,紫外灭菌箱,紫外诱变箱,紫外透照台,紫外割胶仪,电泳凝胶检测仪,电泳凝胶成像仪,薄层色谱照相系统。
8、日本三菱:微需氧及厌氧培养、安宁包系列
9、美国Pall 颇尔:生物反应器(用于间充质干细胞培养的Xpansion 多层平板生物反应器系统、大规模病毒生产装置—iCELLis®生物反应器
),实验室和工业液体及气体过滤产品(针头滤器、囊式滤器、不锈钢圆盘过滤器、圆盘微孔滤膜、超滤离心管、切向流过滤器及膜包、工业不锈钢滤壳及配套滤芯等),微生物检验产品(不锈钢多联过滤器及微检滤膜),蛋白层析(预装柱及层析填料、多孔滤板),Ultroser G血清替代品,核酸蛋白检测(Biodyne A/B膜、BioTrace™ NT纯硝酸纤维素转印膜、FluoroTrans® PVDF膜、UltraBind™ Affinity膜、Immunodyne® ABC膜),  IVD诊断用膜材(硝酸纤维素膜)等
10、Rainin 瑞宁:手动、电动、单道、多道移液器,移液工作站,吸头,真空吸液泵,移液器校准服务
11、METTLER TOLEDO 梅特勒-托利多:(超微量)紫外可见分光光度计、水份测定仪、电位滴定仪、PH计、天平等
12、Euroka Bio 深研: CellSep Pro全封闭自动化细胞处理系统
13、日立:核酸提取纯化-荧光定量PCR一体机、毛细管电泳仪、全自动核酸提取纯化仪、离心机
14、美国AXION:阻抗式无标记、非侵入实时细胞监测系统
15、美国BIOLIFE:无水细胞复苏仪(管式及袋式)
16、德国Sartorius赛多利斯:天平、PH计、电导率仪、水份测定仪、离心机、超纯水机、移液器,实验室耗材(针头滤器、囊式滤器、微孔滤膜、超滤离心管等),微生物检验产品(多联不锈钢滤器、微检滤膜等)
17、ThermoFisher: 3111系列水套CO2培养箱、371 系列 Steri Cycle 高温灭菌型CO2培养箱、311系列直热式CO2培养箱、BB150直热式CO2培养箱、Heracell VIOS 160i CO2培养箱、Heracell VIOS 250i CO2培养箱,超低温冰箱,生物安全柜,液氮罐,离心机,PCR仪,超微量核酸蛋白测定仪。此外,我们还提供全线细胞培养产品。
18、日本Yamato:高压蒸汽灭菌器、干热灭菌器等
19、德国Grumbach:孵化器、孵蛋器
20、美国WESCOR:露点渗透压仪
21、美国SONICS:超声波细胞破碎仪
22、美国WILSON WOLF:G-Rex悬浮细胞培养系统及会呼吸的细胞培养瓶
23、德国徕卡:正置生物显微镜、倒置生物显微镜、体式解剖显微镜、显微照相系统、荧光显微镜及其病理设备
北京海淀区阜成路115号丰裕写字楼509,510室
