VWR |Amresco 生化试剂全系列
| 包装规格编号 | CAS No. | 名称 | 英文名称 | 纯度/规格 | 价格 |
| VWR0694-1L | 9002-93-1 | 曲拉通 X-100 | TRITON X-100 | Reagent Grade | 953 |
| VWR0694-4L | 9002-93-1 | 曲拉通 X-100 | TRITON X-100 | Reagent Grade | 3642 |
| VWRCBRGTE170-1KG | 三(羟甲基)甲基甘氨酸 | TRICINE BUFFER | 5499 | ||
| VWR0887-500g | 7647-17-8 | 氯化铯 | CESIUM CHLORIDE | 3652 | |
| VWR0511-50G | 7365-45-9 | HEPES FREE ACID | HEPES FREE ACID | High Purity Grade | 685 |
| VWR0511-1KG | 7365-45-9 | HEPES FREE ACID | HEPES FREE ACID | High Purity Grade | 1720 |
| VWR0511-250G | 7365-45-9 | HEPES FREE ACID | HEPES FREE ACID | High Purity Grade | 652 |
| VWRE490-20ML | 青霉素/链霉素 (无菌) | PEN STREP GAMMA-20ML | 473 | ||
| VWRJ358-250MG | 4800-94-6 | 羧苄青霉素钠 | CARBENICILLIN DISODIUM SALT | 858 | |
| VWRJ358-1G | 4800-94-6 | 羧苄青霉素钠 | CARBENICILLIN DISODIUM SALT | 1870 | |
| VWR1B1773-0.4ML | VIVIDPRO PLUS? 试剂 | VIVIDPRO PLUS? | 1760 | ||
| VWR1B1773-1ML | VIVIDPRO PLUS? 试剂 | VIVIDPRO PLUS? | 1484 | ||
| VWR0741-50G | 7177-48-2 | 氨苄青霉素,三水,未灭菌 | AMPICILLIN TRIHYDRATE, NON-STERILE | 1826 | |
| VWR0741-100G | 7177-48-2 | 氨苄青霉素,三水,未灭菌 | AMPICILLIN TRIHYDRATE, NON-STERILE | 2420 | |
| VWR0395-50KG | 7447-40-7 | 氯化钾 | POTASSIUM CHLORIDE | 19800 | |
| VWR0395-500G | 7447-40-7 | 氯化钾 | POTASSIUM CHLORIDE | 594 | |
| VWR0395-2.5KG | 7447-40-7 | 氯化钾 | POTASSIUM CHLORIDE | 1540 | |
| VWR0395-12KG | 7447-40-7 | 氯化钾 | POTASSIUM CHLORIDE | 3630 | |
| VWR0395-1KG | 7447-40-7 | 氯化钾 | POTASSIUM CHLORIDE | 748 | |
| VWR0339-25G | 69-52-3 | 氨苄青霉素钠 | AMPICILLIN SODIUM SALT | 1650 | |
| VWR0339-100G | 69-52-3 | 氨苄青霉素钠 | AMPICILLIN SODIUM SALT | 3520 | |
| VWRE477-20ML | 氨苄青霉素钠(无菌) | GAMMA IRRADIATED AMPICILLIN | 550 | ||
| VWRN683-500G | 531-75-9 | 马栗树皮甙 | ESCULIN | 14850 | |
| VWRN683-F10KG | 531-75-9 | 马栗树皮甙 | ESCULIN | 262174 | |
| VWRN683-25G | 531-75-9 | 马栗树皮甙 | ESCULIN | 1848 | |
| VWRN683-1KG | 531-75-9 | 马栗树皮甙 | ESCULIN | 26950 | |
| VWRE480-20ML | 69-57-8 | 青霉素G 钠 (无菌) | PENICILLIN-20ML | 495 | |
| VWR94271-25G | 66-81-9 | 放线菌酮(环已亚胺) | CYCLOHEXIMIDE CRYSTALLINE *INT’L ONLY* | 8800 | |
| VWR0213-25G | 55963-78-5 | 多聚茴香脑磺酸钠 | SODIUM POLYANETHOLE SULFONATE | 1210 | |
| VWR0213-1KG | 55963-78-5 | 多聚茴香脑磺酸钠 | SODIUM POLYANETHOLE SULFONATE | 16865 | |
| VWRE781-1KG | 9004-53-9 | 糊精,白 | DEXTRIN, WHITE | 880 | |
| VWRE781-F25KG | 9004-53-9 | 糊精,白 | DEXTRIN, WHITE | 7150 | |
| VWRE781-500G | 9004-53-9 | 糊精,白 | DEXTRIN, WHITE | 616 | |
| VWRE858-100MG | 1264-72-8 | 硫酸粘菌素 | Colistin Sulfate | 605 | |
| VWRE858-1G | 1264-72-8 | 硫酸粘菌素 | Colistin Sulfate | 2310 | |
| VWR9946-500G | 59-67-6 | 烟酸 | Nicotinic Acid | 880 | |
| VWRN401-1KG | 磷酸盐肉汤 | Tryptose Phosphate Broth | 3080 | ||
| VWR0779-100G | 150-13-0 | 对氨基苯甲酸 | P-Aminobenzoic Acid | 605 | |
| VWR0779-25G | 150-13-0 | 对氨基苯甲酸 | P-Aminobenzoic Acid | 484 | |
| VWR0717-100G | 9001-75-6 | 胃蛋白酶1:10,000 | Pepsin 1:10,000 | 2970 | |
| VWR0717-25G | 9001-75-6 | 胃蛋白酶1:10,000 | Pepsin 1:10,000 | 2853 | |
| VWRE580-250G | 16774-21-3 | 硝酸高铈铵 | CERIC AMMONIUM NITRATE | 3300 | |
| VWRE580-50G | 16774-21-3 | 硝酸高铈铵 | CERIC AMMONIUM NITRATE | 1100 | |
| VWRE580-5KG | 16774-21-3 | 硝酸高铈铵 | CERIC AMMONIUM NITRATE | 13200 | |
| VWRE799-1KG | 85-83-6 | ?苏丹四号红 | SUDAN RED 4 | 3520 | |
| VWR0771-100G | 737-31-5 | 二醋碘苯酸钠 | Sodium Diatrizoate | 1980 | |
| VWR0771-50G | 737-31-5 | 二醋碘苯酸钠 | Sodium Diatrizoate | 1210 | |
| VWR1B1668-25ML | LDS上样缓冲液,还原性(4X) | LDS SAMPLE LOADING BUFFER,REDUCING (4X) | 770 | ||
| VWR1B1668-5ML | LDS上样缓冲液,还原性(4X) | LDS SAMPLE LOADING BUFFER,REDUCING (4X) | 275 | ||
| VWRN313-Q-SAMPLE | Ezvision DNA染料(三条指示带),6X | EZ-VISION? THREE, DNA DYE AS LOADING BUFFER 6X | 308 | ||
| VWRN313-KIT | Ezvision DNA染料(三条指示带),6X | EZ-VISION? THREE, DNA DYE AS LOADING BUFFER 6X | 1392 | ||
| VWR0817-5G | 14348-40-4 | 3-羟基-2,4,6-三溴苯甲酸 | 2,4,6-Tribromo-3-Hydroxybenzoic Acid | 770 | |
| VWR0817-500G | 14348-40-4 | 3-羟基-2,4,6-三溴苯甲酸 | 2,4,6-Tribromo-3-Hydroxybenzoic Acid | 26473 | |
| VWR0817-100G | 14348-40-4 | 3-羟基-2,4,6-三溴苯甲酸 | 2,4,6-Tribromo-3-Hydroxybenzoic Acid | 5725 | |
| VWR0817-10G | 14348-40-4 | 3-羟基-2,4,6-三溴苯甲酸 | 2,4,6-Tribromo-3-Hydroxybenzoic Acid | 1386 | |
| VWR9944-500G | 98-92-0 | 烟酰胺 | Niacinamide | 1496 | |
| VWR1B1662-250U | DNA,双链特异性,热不稳定 | DNA,DOUBLE-STRAND SPECIFIC,HEAT LABILE | 15152 | ||
| VWR1B1662-1000U | DNA,双链特异性,热不稳定 | DNA,DOUBLE-STRAND SPECIFIC,HEAT LABILE | 22880 | ||
| VWR1B1669-25ML | LDS上样缓冲液,非还原性(4X) | LDS SAMPLE LOADING BUFFER,NON-REDUCING (4X) | 814 | ||
| VWR1B1669-5ML | LDS上样缓冲液,非还原性(4X) | LDS SAMPLE LOADING BUFFER,NON-REDUCING (4X) | 286 | ||
| VWRN983-100G | 877-24-7 | 邻苯二甲酸氢钾 | Potassium Hydrogen Phthalate | 649 | |
| VWRK719-120ML | 牛血清白蛋白溶液,30% | Bovine Serum Albumin, 30% Solution | 1328 | ||
| VWRK719-500ML | 牛血清白蛋白溶液,30% | Bovine Serum Albumin, 30% Solution | 6526 | ||
| VWRK719-50ML | 牛血清白蛋白溶液,30% | Bovine Serum Albumin, 30% Solution | 2147 | ||
| VWRN583-100MG | 64485-93-4 | 头孢噻肟钠 | Cefotaxime Sodium Salt | 605 | |
| VWRN583-500MG | 64485-93-4 | 头孢噻肟钠 | Cefotaxime Sodium Salt | 1188 | |
| VWRN650-Q-SAMPLE | EZ-Vision? Two DNA染料 6X | EZ-VISION? TWO, DNA DYE AS LOADING BUFFER 6X | 308 | ||
| VWRN650-KIT | EZ-Vision? Two DNA染料 6X | EZ-VISION? TWO, DNA DYE AS LOADING BUFFER 6X | 671 | ||
| VWR0579-P20KG | 8002-43-5 | 卵磷脂 | LECITHIN | 11440 | |
| VWR0579-1KG | 8002-43-5 | 卵磷脂 | LECITHIN | 1496 | |
| VWR0579-250G | 8002-43-5 | 卵磷脂 | LECITHIN | 781 | |
| VWR1B1656-Kit | 胶体考马斯亮蓝染色蛋白 | COLLOIDAL COOMASSIE PROTEIN STAIN | 2464 | ||
| VWR0955-1KG | 25322-68-3 | 聚乙二醇3350 | Polyethylene Glycol 3350 | 864 | |
| VWR0955-500G | 25322-68-3 | 聚乙二醇3350 | Polyethylene Glycol 3350 | 1646 | |
| VWRN984-100G | 7784-24-9 | 十二水合硫酸铝钾 | ALUMINUM POTASSIUM SULFATE DODECAHYDRATE | 594 | |
| VWRN984-500G | 7784-24-9 | 十二水合硫酸铝钾 | ALUMINUM POTASSIUM SULFATE DODECAHYDRATE | 1100 | |
| VWR0170-50G | 83-07-8 | 4-氨基安替比林 | 4-AMINOANTIPYRINE | 1034 | |
| VWR0170-100G | 83-07-8 | 4-氨基安替比林 | 4-AMINOANTIPYRINE | 1155 | |
| VWRK480-10KG | 6138-23-4 | D-海藻糖 | TREHALOSE DIHYDRATE | 44000 | |
| VWRJ531-1KG | 30525-89-4 | 聚甲醛(小球) | PARAFORMALDEHYDE PRILLS | 2200 | |
| VWRJ531-500G | 30525-89-4 | 聚甲醛(小球) | PARAFORMALDEHYDE PRILLS | 1650 | |
| VWRK565-10KG | 钼酸,85% | MOLYBDIC ACID, 85% | 33000 | ||
| VWRK689-250MG | 氢可的松-3-羧甲基肟 | HYDROCORTISONE-3-CARBOXYMETHYLOXIME | 59873 | ||
| VWR1B1607-1ML | 2XRNA上样缓冲液(含EB) | RNA LOADING BUFFER WITH ETHIDIUM BROMIDE,2X | 402 | ||
| VWR1B1607-5X1ML | 2XRNA上样缓冲液(含EB) | RNA LOADING BUFFER WITH ETHIDIUM BROMIDE,2X | 990 | ||
| VWR1B1606-5X1ML | 2XRNA上样缓冲液 | RNA LOADING BUFFER,2X | 858 | ||
| VWR1B1606-1ML | 2XRNA上样缓冲液 | RNA LOADING BUFFER,2X | 198 | ||
| VWR1B1368-5G | 127-07-1 | 羟基脲 | HYDROXYUREA | 1430 | |
| VWRK480-100G | 6138-23-4 | D-海藻糖 | TREHALOSE DIHYDRATE | 3850 | |
| VWRK480-25G | 6138-23-4 | D-海藻糖 | TREHALOSE DIHYDRATE | 1045 | |
| VWRK480-1KG | 6138-23-4 | D-海藻糖 | TREHALOSE DIHYDRATE | 7590 | |
| VWRK480-5KG | 6138-23-4 | D-海藻糖 | TREHALOSE DIHYDRATE | 24233 | |
| VWRE912-500G | 108321-27-3 | PIPES二钾盐 | PIPES, DIPOTASSIUM SALT | 13981 | |
| VWRE912-100G | 108321-27-3 | PIPES二钾盐 | PIPES, DIPOTASSIUM SALT | 1705 | |
| VWRE912-1KG | 108321-27-3 | PIPES二钾盐 | PIPES, DIPOTASSIUM SALT | 4246 | |
| VWR1B1335-100G | 9004-98-2 | 聚氧乙烯油酸酯 O10 | BRIJ O10 | 990 | |
| VWR1B1335-500G | 9004-98-2 | 聚氧乙烯油酸酯 O10 | BRIJ O10 | 1430 | |
| VWRK828-5G | 磷酸葡萄糖酸 | 6 PHOSPHOGLUCONIC ACID | 20889 | ||
| VWR1B1581-KIT-100ML | HRP化学荧光底物试剂盒(基础) | VisiGlo? Prime HRP Chemiluminescent Substrate Kit | 5390 | ||
| VWR0494-5G | 1077-28-7 | DL-硫辛酸(氧化态) | DL-THIOCTIC ACID (OXIDIZED) | 858 | |
| VWR0494-25G | 1077-28-7 | DL-硫辛酸(氧化态) | DL-THIOCTIC ACID (OXIDIZED) | 773 | |
| VWR0770-P12KG | 7783-13-3 | 四水磷酸氢铵钠 | SODIUM AMMONIUM PHOSPHATE TETRAHYDRATE | 11007 | |
| VWR0770-500G | 7783-13-3 | 四水磷酸氢铵钠 | SODIUM AMMONIUM PHOSPHATE TETRAHYDRATE | 825 | |
| VWR0770-F34KG | 7783-13-3 | 四水磷酸氢铵钠 | SODIUM AMMONIUM PHOSPHATE TETRAHYDRATE | 19861 | |
| VWR0770-P25KG | 7783-13-3 | 四水磷酸氢铵钠 | SODIUM AMMONIUM PHOSPHATE TETRAHYDRATE | 15530 | |
| VWR0770-1KG | 7783-13-3 | 四水磷酸氢铵钠 | SODIUM AMMONIUM PHOSPHATE TETRAHYDRATE | 1430 | |
| VWRE278-100G | 25322-69-4 | 聚乙二醇 2000 | POLYPROPYLENE GLYCOL 2000 | 704 | |
| VWRE278-500G | 25322-69-4 | 聚乙二醇 2000 | POLYPROPYLENE GLYCOL 2000 | 966 | |
| VWR1B1524-500G | 聚醚(聚氧乙烯聚氧丙烯)6800 | Pluronic PE 6800 | 1430 | ||
| VWR1B1509-10G | 鱼精DNA钠盐 | DNA,SALT,FISH SPERM | 968 | ||
| VWR1B1509-25G | 鱼精DNA钠盐 | DNA,SALT,FISH SPERM | 2975 | ||
| VWR1B1509-5G | 鱼精DNA钠盐 | DNA,SALT,FISH SPERM | 616 | ||
| VWR1B1473-100G | 5328-37-0 | L-阿拉伯糖 | L-ARABINOSE | 880 |
