其他实验耗材
Sutter 玻璃毛细管
Sutter 玻璃毛细管
Sutter
进口
美国Sutter
B/BF
500~1000
美国Sutter公司提供各种类型的玻璃毛细管
Thick/Standard Wall Borosilicate Glass
With Filament
Catalog Number Outside Diameter Inside Diameter Overall Length Pieces per Package
BF100-50-7.5 1.00mm 0.50mm 7.5cm 225
BF100-50-10 1.00mm 0.50mm 10cm 225
BF100-50-15 1.00mm 0.50mm 15cm 225
BF100-58-10 1.00mm 0.58mm 10cm 250
BF100-58-15 1.00mm 0.58mm 15cm 250
BF120-60-10 1.20mm 0.60mm 10cm 225
BF120-69-7.5 1.20mm 0.69mm 7.5cm 250
BF120-69-10 1.20mm 0.69mm 10cm 250
BF120-69-15 1.20mm 0.69mm 15cm 250
BF150-75-7.5 1.50mm 0.75mm 7.5cm 225
BF150-75-10 1.50mm 0.75mm 10cm 225
BF150-86-7.5 1.50mm 0.86mm 7.5cm 250
BF150-86-10 1.50mm 0.86mm 10cm 250
BF150-86-15 1.50mm 0.86mm 15cm 250
BF200-100-10 2.00mm 1.00mm 10cm 225
BF200-116-10 2.00mm 1.16mm 10cm 250
BF200-116-15 2.00mm 1.16mm 15cm 250
Without Filament
B100-20-10* 1.00mm 0.20mm 10cm 225
B100-50-10 1.00mm 0.50mm 10cm 225
B100-50-15 1.00mm 0.50mm 15cm 225
B100-58-10 1.00mm 0.58mm 10cm 250
B100-58-15 1.00mm 0.58mm 15cm 250
B120-69-8 1.20mm 0.69mm 8cm 250
B120-69-10 1.20mm 0.69mm 10cm 250
B120-69-15 1.20mm 0.69mm 15cm 250
B150-86-7.5 1.50mm 0.86mm 7.5cm 250
B150-86-10 1.50mm 0.86mm 10cm 250
B150-86-15 1.50mm 0.86mm 15cm 250
B200-116-10 2.00mm 1.16mm 10cm 250
B200-116-15 2.00mm 1.16mm 15cm 250
* The ends are not fire polished. Special order minimum of 2.
Heavy Polished Thick/Standard and Thin Walled Borosilicate Glass1
With Filament
BF150-86-7.5HP 1.50mm 0.86mm 7.5cm 250
BF150-86-10HP 1.50mm 0.86mm 10cm 250
BF150-110-7.5HP 1.50mm 1.10mm 7.5cm 225
BF150-110-10HP 1.50mm 1.10mm 10cm 225
Without Filament
B100-30-7.5HP 1.00mm 0.30mm 7.5cm 225
B100-50-7.5HP 1.00mm 0.50mm 7.5cm 225
B150-86-7.5HP 1.50mm 0.86mm 7.5cm 250
B150-86-10HP 1.50mm 0.86mm 10cm 250
B150-110-7.5HP 1.50mm 1.10mm 7.5cm 225
B150-110-10HP 1.50mm 1.10mm 10cm 225
1Useful for added protection of gaskets and wire in headstages.
Thin Wall Borosilicate Glass
With Filament
BF100-78-10 1.00mm 0.78mm 10cm 250
BF100-78-15 1.00mm 0.78mm 15cm 250
BF120-94-8 1.20mm 0.94mm 8cm 250
BF120-94-10 1.20mm 0.94mm 10cm 250
BF120-94-15 1.20mm 0.94mm 15cm 250
BF150-110-7.5 1.50mm 1.10mm 7.5cm 225
BF150-110-10 1.50mm 1.10mm 10cm 225
BF150-117-10 1.50mm 1.17mm 10cm 250
BF150-117-15 1.50mm 1.17mm 15cm 100
BF150-120-10 1.50mm 1.20mm 10cm 250
BF165-120-7.5 1.65mm 1.20mm 7.5cm 225
BF165-120-10 1.65mm 1.20mm 10cm 225
BF200-156-10 2.00mm 1.56mm 10cm 250
BF200-156-15 2.00mm 1.56mm 15cm 100
Without Filament
B100-75-10 1.00mm 0.75mm 10cm 225
B100-75-15 1.00mm 0.75mm 15cm 225
B120-90-8 1.20mm 0.90mm 8cm 225
B120-90-10 1.20mm 0.90mm 10cm 225
B120-90-15 1.20mm 0.90mm 15cm 225
B150-110-7.5 1.50mm 1.10mm 7.5cm 225
B150-110-10 1.50mm 1.10mm 10cm 225
B150-117-10 1.50mm 1.17mm 10cm 225
B200-156-10 2.00mm 1.56mm 10cm 250
B200-156-15 2.00mm 1.56mm 15cm 100
Multibarrel Borosilicate Glass*
With Filament
Catalog Number Number of Barrels In/Outside Diameter Overall Length Pieces per Package
2BF100-50-10 2 barrels 1.00/0.50 10cm 75
2BF100-75-10 2 barrels 1.00/0.75 10cm 75
2BF150-86-10 2 barrels 1.50/0.86 10cm 100
2BF150-86-15 2 barrels 1.50/0.86 15cm 100
3BF100-50-10 3 barrels 1.00/0.50 10cm 75
3BF100-75-10 3 barrels 1.00/0.75 10cm 75
3BF120-69-10 3 barrels 1.20/0.69 10cm 100
3BF120-69-15 3 barrels 1.20/0.69 15cm 100
Without Filament
3B100-75-10 3 barrels 1.00/0.75 10cm 75
4B100-75-10 4 barrels 1.00/0.75 10cm 75
* Multibarrel borosilicate requires a custom filament.
Please contact Sutter Instrument for more information when ordering.
Quartz Glass
With Filament
QF100-50-7.5 1.00mm 0.50mm 7.5cm 100
QF100-50-10 1.00mm 0.50mm 10cm 100
QF100-60-7.5 1.00mm 0.60mm 7.5cm 100
QF100-60-10 1.00mm 0.60mm 10cm 100
QF100-70-7.5 1.00mm 0.70mm 7.5cm 100
QF100-70-10 1.00mm 0.70mm 10cm 100
QF100-70-15 1.00mm 0.70mm 15cm 100
QF120-60-7.5 1.20mm 0.60mm 7.5cm 100
QF120-60-10 1.20mm 0.60mm 10cm 100
QF120-90-10 1.20mm 0.90mm 10cm 100
QF150-75-7.5 1.50mm 0.75mm 7.5cm 100
QF150-75-10 1.50mm 0.75mm 10cm 100
Quartz Glass
Without Filament
Q100-30-7.5 1.00mm 0.30mm 7.5cm 100
Q100-30-15 1.00mm 0.30mm 15cm 100
Q100-50-7.5 1.00mm 0.50mm 7.5cm 100
Q100-50-10 1.00mm 0.50mm 10cm 100
Q100-70-7.5 1.00mm 0.70mm 7.5cm 100
Q100-70-10 1.00mm 0.70mm 10cm 100
Q120-40-7.5 1.20mm 0.40mm 7.5cm 100
Q120-60-7.5 1.20mm 0.60mm 7.5cm 100
Q120-90-7.5 1.20mm 0.90mm 7.5cm 100
Q120-90-10 1.20mm 0.90mm 10cm 100
Q150-50-7.5 1.50mm 0.50mm 7.5cm 100
Q150-75-7.5 1.50mm 0.75mm 7.5cm 100
Q150-75-10 1.50mm 0.75mm 10cm 100
Q150-110-10 1.50mm 1.10mm 10cm 100
Q165-115-10 1.65mm 1.15mm 10cm 100
Solid Quartz Rod
Catalog Number Style Outside Diameter Overall Length Pieces per Package
QR100-7.5 solid 1.00mm 7.5cm 100
QR100-10 solid 1.00mm 10cm 100
QR100-15 solid 1.00mm 15cm 100
Quartz Theta Glass
Catalog Number Outside Diameter Septum Thickness Overall Length Pieces per Package
QT120-90-7.5 1.20/0.9mm 0.15mm 7.5cm 50
Multibarrel Quartz Glass
Catalog Number Number of Barrels OD/ID in mm Overall Length Pieces per Package
7Q033-16-10 7 barrel 1.00/[.33/.16ea] 10cm 50
Aluminosilicate Glass
With Filament
AF100-64-10 1.00mm 0.64mm 10cm 100
AF120-77-10 1.20mm 0.77mm 10cm 100
AF120-87-10 1.20mm 0.87mm 10cm 100
AF150-100-10 1.50mm 1.00mm 10cm 100
Without Filament
A100-64-10 1.00mm 0.64mm 10cm 100
A120-77-10 1.20mm 0.77mm 10cm 100
A120-87-10 1.20mm 0.87mm 10cm 100
A150-100-10 1.50mm 1.00mm 10cm 100
Borosilicate Theta Glass
Catalog Number O.D/I.D. Septum Thickness Overall Length Pieces per Package
BT-150-10 1.50/1.17mm 0.165mm 10cm 100
Solid Borosilicate Rod
BR-100-10 solid 1.00mm 10cm 250
BR-100-15 solid 1.00mm 15cm 250
上海宇北医疗器械有限公司
SRstar Instruments Ltd.
定位:独家引进与分享世界最前沿创新技术和尖端设备
追求:最具创新与价值的生物医学服务型企业
执行:为员工创造价值,为用户提供优质服务
总部分布点:上海 北京  重庆
渠道商点:中国 各省市
网址: www.srstar.com.cn
上海市闵行区吴中路1059号灿虹精英大厦712
