大容量离心机
碟片离心机
碟片离心机
Disc Centrifuge Biodiesel Refining Process Machine
china
DHC
Disc Centrifuge Biodiesel Refining Process Machine Disc Mini Centrifuge
Product description:
Disc separator usage in beverage purification.
Reyes separator for beverages are designed in hygienic design and allow for the reliable separation of the finest solid particles possible by the increased centrifugal acceleration.
The gentle product feed by the hydrohermetic feed avoids shear forces on the product.
The result is a more gentle treatment and an optimum clarifying effect, particularly for sensitive products. Oxidation pick up is prevented by the hydrohermetic seal.
Feature:
• Full automation possible with PLC automatic control panel.
• Centrifugal separation requiring no filter media.
• High reliability drive train system backed by delivery of over 1,000 units a year.
• Bowl design with superior separation performance and with good response to discharge loads.
• Pilot valve regulates total/partial discharge of solids.
• Super partial discharger (option) minimizes liquid loss and maximizes thickening of solid.
• fraction for discharge.
• Vibration-proof design realizes long working life.
Technical parameter
Item Modle DHN/Z204 DHN/Z360 DHN/Z400 DHN/Z470 DHN/Z500
Capacity 500-2000 L/H 2000-4000L/H 4000-5000L/H 5000-8000L/H 8000-10000 L/H
Discharge time and Interval Discharge time can be adjusted from 0.1~0.9 second, and discharge time interval can be adjusted from 1~240 minutes according to the raw material
Motor Power 5.5KW 7.5KW 7.5KW 15KW 22KW
Turn on time 5~8minute
Stopped time (withoutbrake) ≤40minute
Input pressure 0~0.1mpa
Output pressure 0~0.3mpa
Working water pressure 0.2≤p≤0.45m pa
Noise ≤76dB
Max vibrate 1.5mm/
Weight 220kg ~550kg ~810kg ~1680kg ~2260kg
Dimension(mm) 830X610X600 1130x1050x1400 1500×1100×1400 1772×1473×1855 1800×1
Liaoyang Shenzhou Machinery Equipment Co., Ltd is a professional for supplier of pharmaceutical and chemical machine in China.We have a well-experienced team and a professional design institute,With rich experiences in pharmaceutical machinery and equipment including packing machine, centrifuge, falling film evaporator, distillation,mixer, tablet press machine, suppository production line,dryer,capsule filling machine ,capsule and so on.
No. 85, Ganqu Road, Liaoyang Development Zone, Liaoyang, Liaoning, China
