液相色谱
New Objective GlassTip玻璃喷针 Native MS
offine nano glass tip
进口
美国 New Objective
GlassTips (质谱离子源纳喷针
离线纳喷雾分析
离线分析的特征是通过注射器或加液枪不连续的导入样品到喷针,随之进入质谱。喷针内的液体受静电吸引流动,流速受高电压和源入口的负压影响。
GlassTips™电喷针提供了离线纳喷雾应用在灵敏度和灵活性方面的充分结合。这些高性能纳喷雾针采用高品质硼硅酸盐玻璃制成。每个纳喷雾针都有特殊设计的内夹层以自动吸入样品。独特精确的喷嘴口径,免除了使用前的开口操作。
GlassTip™纳喷雾针
在纳喷雾实验中,GlassTips纳喷雾针以非常简单的方式持久重复的引入样品产生纳喷雾。高品质硼硅酸盐材质和精密工艺保证规格指标,GlassTips纳喷雾针取出即用,无需开口操作。
  • 严格的视频检验以符合严格的指标
  • 耐用、惰性、多镀层
  • 无开口操作
  • 简便、自动充样
BG10-78-4-CE-20 GlassTips: standard coated, 1.0 mm OD, 0.78 mm ID, 4 um tip ID, box of 20
BG10-78-4-N-20 GlassTips: non-coated,  1.0 mm OD, 0.78 mm ID, 4 um tip ID,
box of 20
BG12-94-4-CE-20 GlassTips: standard coated, 1.2mm OD, 0.94mm ID, 4 um tip ID, box of 20
BG12-94-4-N-20 GlassTips: non- coated, 1.2mm OD, 0.94mm ID, 4 um tip ID, box of 20
其他型号纳喷针请来电咨询:
地址:上海市徐汇区钦州北路1122号90号楼905室
电话:021-54666233
邮箱:info@newobjective.com.cn
微信:18100095051
For two decades, New Objective has lead high-sensitivity LC-MS reasearch through innovative life-science sample prep and delivery tools. Founded in 1997 on PicoTip technology, New Objective has remained on the cutting edge of nanobore chromatography and nanospray-based mass spectrometry through engaging, ongoing communication with our customers, continuous innovation, and unwavering commitment to quality. Gary Valaskovic, New Objective's co-founder, explains the company's customer-driven culture: "Our hands-on sales and support approach ensures that our customers have a direct line to the company. Mutually beneficial, it's through this continual communication loop that New Objective is able to improve upon current products and meet our customers' changing needs." Through this open line of communication, the original PicoTip product line quickly expanded. New columns and emitters were added, including PicoFrit columns, which combine a nanobore column with an integral ESI emitter. In order to maximize nanospray productivity and reproducibility, the PicoView source was developed to work in conjunction with PicoTip emitters and PicoFrit columns. PicoView models are available for the world's leading mass spectrometer systems, including Thermo, Applied Biosystems, and Bruker. The Digital PicoView takes experimental flexibilty and control to an even higher level, with software controlled stage positioning and automated tip rinsing. New Objective's expanded product line is designed for unprecedented ease of use in biomolecule nanoscale analysis. Nanobore IntegraFrit Sample Traps, in a wide range of diameters and chemistries, feature facile, finger-tight fittings and enable multidimensional LC. Zero dead-volume PicoFrit columns, packed with the highest performance peptide analysis chemistries, ensure optimal chromatographic peak shape for the highest sensitivity. Pre-cut fused-silica tubing provides for fast and reliable connections especially when coupled with the unique true zero-dead-volume PicoClear connector. 迈特敖丰(上海)科技有限公司为 New Objective China的官方销售公司。
上海市徐汇区钦州北路1122弄90号楼905室
