DNA/有机/多肽合
全新标准的DNA/RNA合成仪
全新标准的DNA/RNA合成仪
进口
美国/Molecular
OligoMaker 48
电话:13381606441,021-57652529
OligoMaker 48
Up to 48 primers in one run
Instrument
Subject                                                             Description
Capacity:From 1 to 48 primers in one run
Scale of synthesis:10, 50, 200 and 1000 nmol scale
Support material: CPG or Universal support in standard columns
Standard Phosphoramidite positions:4 x 120-ml or 180-ml bottles + 2 x 10-ml
Up to 8 Extra amidite positions:10-ml or 30-ml bottles
Standard 2 activator positions:Activating in parallel – 1L
Standard 2 wash positions:Washing in parallel – 1L
Standard 1 deblocking position:Deblocking – 1L
Standard 1 Ox position:Oxidizer – 1L
Standard Cap A position:Capping simultaneously with Cap B – 1L
Standard Cap B position:Capping simultaneously with Cap A – 1L
Ox2 position:Option - thioates
1 free position:Custom specified
Pressure on reagents:Each bottle can be pressurized and depressurized individually
Only one gas connection: One gas for making pressure in the bottles and purging during synthesis
Instrument - and Cleaning:650 x 550 x 500 mm (L x W x H) - Design with large straight surfaces
Maintenance: Replacing valves and tubing within a few minutes
Spare parts:Spare parts are in stock
Power:115V or 220V
Safety:Overfloating by accident is directed to waste container.
QC:All instruments undergo a strict quality control process in our lab
Certification:CE marking
Service:ON-call service
Software
Subject                                                             Description
Touch screen:10" touch screen
Wi-Fi :Instrument can be operated as stand-alone
IUPAC codes:Mixed bases are available (Wobbles)
Chemical consumption:Automatically calculation of the single reagent consumption Coupling time:Adjustable
Draining time:Draining time is automatically adjusted depending of finished oligos
设备
主题   描述
处理能力:一次从1到48个引物
合成规模:10,50,200和1000nmol尺度
支撑材料:CPG或标准柱的通用支撑
标准磷酰胺位置: 4 x 120ml或者180ml 瓶子 + 2 x 10ml
最多8个额外的酰胺位置:10ml 瓶子
标准2催化剂位置:平行活化剂 – 1L
标准2清洗位置:平行清洗剂 – 1L
标准1保护剂位置:保护剂 – 1L
标准1氧化剂位置:氧化剂 – 1L
标准 Cap A 位置:与Cap B同时capping – 1L
标准 Cap B 位置:与Cap A同时capping – 1L
Ox2位置:选项 - 硫醇盐
1自由位置:自定义指定
试剂压力:每个瓶子可以分别加压和减压
只有一个气体连接:一种气体,用于在瓶内加压和合成过程中吹扫
设备尺寸:650 x 550 x 500 mm (长 x 宽 x 高)
清洗:具有大直表面的设计
维护:几分钟内更换阀门和管道
备件:备件有库存
电源:115V或者220V
安全:意外溢出的液体被引导至废物容器。
QC:所有仪器在我们实验室都经过严格的质量控制过程
证书:CE 标志
服务:ON-call 服务
软件
主题   描述
触摸屏:10" 触摸屏
控制系统和WI-Fi:设备可以独立操作
IUPAC代码:混合基可用(摆动)
化学品消耗:单试剂消耗量的自动计算
耦合时间:可调节
排水时间排水时间根据成品低聚物自动调整
上海凡夏生物科技有限公司成立于2021年,公司位于上海近郊松江国际商务园区,主要经营生物科学、生物技术、医药化工相关的试剂、耗材和仪器设备。目前主要代理销售丹麦Bscience超低温冰箱、医药冰箱;Smart Ultrapure系列超纯水系统;丹麦OligoMaker全新标准的DNA/RNA合成仪;美国PreciGenome脂质纳米颗粒合成系统、微流控设备、微流控纳米药物制备系统;Foregene梯度PCR仪、实时荧光定量PCR仪和PCR试剂盒;德国Inheco公司实验室自动化循环温控模块、加热制冷振荡孵育模块;美国Alpaqua磁力架;Biohandler生物智能液体处理工作站、核酸提取仪和高精度微升分液器;美国Gyrosproteintechnologies多肽合成仪;Taidu蛋白纯化系统。我们为客户提供便捷、稳定、可靠的设备、配件及售后服务。
上海市松江区茸梅路1108号茸锦商务楼501室
