标准品/对照品
CONOSTAN粘度标油
CONOSTAN粘度标油
进口
CANNON
N6
美国凯能Cannon 高剪切标准油
& 透明和不透明液体运动粘度测定法 (包括计算动力粘度)
&  适用校正粘度计之标准液。
& 一般用途的标准粘度液 (General Purpose Viscosity Standards)
&高粘度的标准粘度液 (High-Viscosity Standards)
&低温的标准粘度液 (Low-Temperature Viscosity)
& CCS的标准粘度液 (CCS Viscosity Standards)
& CMRV的标准粘度液 (CMRV Viscosity Standards)
& 粘度杯的标准液 (Viscosity Cup Standards)
& 高温的标准液 (High Temperature)
& THOMAS-STORMER的标准液 (Stormer Standards)
&硅油粘度的标准液 (Silicone Viscosity Standards)
&标准粘度油 (Viscosity Oil Standards)
粘度
CANNON粘度标油用于通用粘度标准的运动粘度 mm2 / s (cst)、动力粘度 mpa s (cp)和密度 g / ml 的标称值。所有CANNON通用粘度标准符合 astm d445 / d446和 iso 3104 / 3105的精密规格。每个标准均提供特定批次的数据。详见下图
美国凯能Cannon 高剪切标准油
* Density values provided at test temperatures
† Data provided at an apparent shear rate of 1 x 106 s-1
¥ Sold in a 1 liter can only
^ Sold in 0.5 liter, 1 liter and 4 liter sizes
‡ Viscosity data also provided at 40 °C and 120 °C
Catalog Number Standards Type Dynamic Viscosity in mPa.s (cP) Applicable ASTM
Method(s)
80 °C 100 °C 150 °C
9727-U45 HT22 * Newtonian 3.5 1.5 D5481
9727-U50 HT39 * Newtonian 4.7 2 D5481
9727-U55 HT75 * Newtonian 7 2.7 D5481
9727-U60 HT150 * Newtonian 10.5 3.7 D5481
9727-U65 HT240 * Newtonian 15.4 5 D5481
9727-U70 HT390 * Newtonian 23.5 7 D5481
9727-U92 HTNN-1 † Non-Newtonian 3.6 D5481 | D4741 | D4683
9727-U94 HTNN-2 † Non-Newtonian 3.1 D5481 | D4741 | D4683
9727-R05. 32 HT22 *¥ Newtonian 3.5 1.5 D4741
9727-R10.032 RL 102 *¥‡ Newtonian 8.4 4.1 1.8 D4741
9727-R15.032 RL 103 *¥‡ Newtonian 12.8 6.1 2.4 D4741
9727-R20.032 RL 104 *¥‡ Newtonian 18 9.8 3.6 D4741
9727-R25.032 RL 105 *¥‡ Newtonian 25.5 12.8 4.4 D4741
9727-R30.032 RL 106 *¥‡ Newtonian 26.9 15.3 5.2 D4741
9727-R35.032 RL 107 * ¥‡ Newtonian 36.8 17.4 5.8 D4741
9727-R62.032 RL 232 †¥ Non-Newtonian 6.2 3.2 D5481 | D4741 | D4683
9727-P10 R-100 *‡ Newtonian 3.5 2.4 1.2 D4683
9727-P15 R-200,R-2200 *‡ Newtonian 5.1 3.4 1.5 D4683
9727-P20 R-300,R-2300 *‡ Newtonian 8 4.8 1.8 D4683
9727-P25 R-350,R-2350 *‡ Newtonian 12.5 7.2 2.7 D4683
9727-P30 R-400,R-2400 *‡ Newtonian 18.1 10 3.6 D4683
9727-P35 R-450,R-2450 *‡ Newtonian 24 13.5 4.1 D4683
9727-P40 R-500 *‡ Newtonian 27 14.5 5 D4683
9727-P45 R-600 *‡ Newtonian 46 23.5 7 D4683
类别 品名 货号 规格 方法
通用粘度标油 N.4(b) 9727-C10 500ml/瓶 符合ASTM D445\446,
ISO 3104/3105,
ASTM D 2162
N.8(b) 9727-C15 500ml/瓶
N1.0(b) 9727-C20 500ml/瓶
N2 9727-C22 500ml/瓶
S3(a) 9727-C25 500ml/瓶
N4 9727-C27 500ml/瓶
S6 9727-C30 500ml/瓶
N7.5 9727-C31 500ml/瓶
N10 9727-C32 500ml/瓶
N14 9727-C34 500ml/瓶
S20 9727-C35 500ml/瓶
N26 9727-C36 500ml/瓶
N35 9727-C37 500ml/瓶
N44 9727-C38 500ml/瓶
S60 9727-C40 500ml/瓶
N75 9727-C41 500ml/瓶
N100 9727-C42 500ml/瓶
N140 9727-C43 500ml/瓶
S200 9727-C45 500ml/瓶
N250 9727-C46 500ml/瓶
N350 9727-C47 500ml/瓶
N415 9727-C48 500ml/瓶
S600 9727-c50 500ml/瓶
N750 9727-c51 500ml/瓶
N1000 9727-c52 500ml/瓶
N1400 9727-c53 500ml/瓶
S2000 9727-c55 500ml/瓶
N2500 9727-c56 500ml/瓶
N4000 9727-c57 500ml/瓶
N5100 9727-c58 500ml/瓶
S8000 9727-c60 500ml/瓶
N10200 9727-c61 500ml/瓶
N15000 9727-c62 500ml/瓶
N18000 9727-c63 500ml/瓶
S30000 9727-c65 500ml/瓶
CCS粘度标油 CL-NNR 9727-N45 500ml/瓶 符合 ASTM D 5293和
SAE Specification J300
CL080 9727-N02 500ml/瓶
CL090 9727-N04 500ml/瓶
CL100 9727-N06 500ml/瓶
CL110 9727-N07 500ml/瓶
CL120 9727-N08 500ml/瓶
CL130 9727-N09 500ml/瓶
CL140 9727-N10 500ml/瓶
CL150 9727-N11 500ml/瓶
CL160 9727-N12 500ml/瓶
CL170 9727-N13 500ml/瓶
CL190 9727-N14 500ml/瓶
CL200 9727-N16 500ml/瓶
CL220 9727-N18 500ml/瓶
CL240 9727-N20 500ml/瓶
CL250 9727-N22 500ml/瓶
CL260 9727-N24 500ml/瓶
CL280 9727-N26 500ml/瓶
CL300 9727-N28 500ml/瓶
CL320 9727-N30 500ml/瓶
CL340 9727-N31 500ml/瓶
CL380 9727-N32 500ml/瓶
CL420 9727-N33 500ml/瓶
CL480 9727-N34 500ml/瓶
CL530 9727-N35 500ml/瓶
CL600 9727-N36 500ml/瓶
CL680 9727-N37 500ml/瓶
CL740 9727-N38 500ml/瓶
8CL 9727-N42 500ml/瓶
14CL 9727-N43 500ml/瓶
Certified Viscosity
“Check Oils” for
SAE Target Viscosities
5W30 Liter 9727-S00.032 1L/瓶 符合 ASTM D 445,
D 5293和 D 4684
5W30 Gallon 9727-S00.128 3.8L/瓶
10W30 Liter 9727-S01.032 1L/瓶
10W30 Gallon 9727-S01.128 3.8L/瓶
15W40 Liter 9727-S02.032 1L/瓶
15W40 Gallon 9727-S02.128 3.8L/瓶
Viscosity Standards for Zahn, Shell, and Ford Cups C6 9727-W10 500ml/瓶 Zahn Cups
符合 ASTM D 4212
Shell Cups
符合ASTM D 4212
Ford Cups
符合 ASTM D 1200
C10 9727-W12 500ml/瓶
C20 9727-W15 500ml/瓶
C35 9727-W20 500ml/瓶
C60 9727-W25 500ml/瓶
C100 9727-W30 500ml/瓶
C200 9727-W35 500ml/瓶
C350 9727-W40 500ml/瓶
C600 9727-W45 500ml/瓶
闪点标油 FPRM10* 9727-A10 200ml/瓶 ASTM D56(50℃),
ASTM D93(55℃)
FPRM11* 9727-A15 200ml/瓶 ASTM D56(66℃),
ASTM D93(72℃)
FPRM14 9727-A20 200ml/瓶 ASTM D92(116℃),
ASTM D93(113℃)
FPRM16 9727-A25 200ml/瓶 ASTM D92(137℃),
ASTM D93(132℃)
FPRM2D 9727-A30 200ml/瓶 ASTM D92(163℃),
ASTM D93(155℃)
FPRM4D 9727-A35 200ml/瓶 ASTM D92(224℃),
ASTM D93(218℃)
FPRM9D 9727-A40 200ml/瓶 ASTM D92(273.8℃),
ASTM D93(224.1℃)
高温粘度标油 HT39 9727-U50 500ml/瓶 符合ASTM D 5481
HT75 9727-U55 500ml/瓶
HT150 9727-U60 500ml/瓶
HT240 9727-U65 500ml/瓶
HT390 9727-U70 500ml/瓶
HTNN-1 9727-U92 500ml/瓶
HTNN-2 9727-U94 500ml/瓶
高粘度标油 N600# 9727-E10 500ml/瓶 符合ASTM D 2170,
D 2171
N1000* 9727-C52 500ml/瓶
N2000# 9727-E15 500ml/瓶
N4000* 9727-C57 500ml/瓶
N8000 9727-E20 500ml/瓶
N15000* 9727-C62 500ml/瓶
N30000 9727-E25 500ml/瓶
N62000 9727-E27 500ml/瓶
N150000 9727-E29 500ml/瓶
N190000 9727-E30 500ml/瓶
N450000 9727-E35 500ml/瓶
N2700000 9727-E40 500ml/瓶
N2700000SP 9727-E42 500ml/瓶
低温粘度标油 N27B 9727-G10 500ml/瓶  符合ASTM D 2983
N27C 9727-G12 500ml/瓶
N115B 9727-G15 500ml/瓶
N60B 9727-G25 500ml/瓶
N120B 9727-G30 500ml/瓶
N480B 9727-G35 500ml/瓶
N1400B 9727-G40 500ml/瓶
N2B 9727-G45 500ml/瓶
N74B 9727-G50 500ml/瓶
N38B 9727-G55 500ml/瓶
N25B 9727-G60 500ml/瓶
N14B 9727-G65 500ml/瓶
MRV标油 N105B 9727-T10 500ml/瓶 符合ASTM D 3829,
ASTM D 4684
YS-30 9727-T20 500ml/瓶
YS-35 9727-T25 500ml/瓶
硅油 RT5 9727-Z10 500ml/瓶 None
RT10 9727-Z14 500ml/瓶
RT50 9727-Z18 500ml/瓶
RT100 9727-Z22 500ml/瓶
RT500 9727-Z26 500ml/瓶
RT1000 9727-Z30 500ml/瓶
RT5000 9727-Z34 500ml/瓶
RT12500 9727-Z38 500ml/瓶
RT30000 9727-Z42 500ml/瓶
RT60000 9727-Z46 500ml/瓶
RT100000 9727-Z50 500ml/瓶
Viscosity Standards for Thomas®-Stormer® Viscometer S200(KU) 9727-Y10 500ml/瓶 None
N350(KU) 9727-Y15 500ml/瓶
K400(KU) 9727-Y20 500ml/瓶
S600(KU) 9727-Y25 500ml/瓶
N1000(KU) 9727-Y30 500ml/瓶
硅浴油   9726-L30 18L/瓶 None
9726-L33 18L/瓶
9726-L36 18L/瓶
9726-L37 1加仑/瓶
9726-L38 1加仑/瓶
9726-L39 1加仑/瓶
9726-L40 1000ML/瓶
天津平行赛思科技有限公司是一家专业从事化学分析 、检验检测设备和消耗材料的贸易公司。公司与世界多家知名企业合作,主要代理进口光谱分析、色谱分析、油品分析所需要标准样品、化学制剂及消耗品。主要合作品牌CONOSTAN、CANNON、VHG、UOP、SPECTRO、PE、SPECTROIL、SCP SCIENCE、BRAND、天瑞仪器等。主要服务领域:石油化工方面、钢铁及电力行业、汽车能源制造领域、环境检测、医药研发、各大专院校等。平行赛思以平行实验室实验用品供应链服务为己任,为广大科研工作者提供便利,解决问题,愿平行赛思的所有用户能平行生活,平行工作,平行人生。
天津市武清开发区福源道北侧创业总部基地
