小规模生产型高压均质机
Small production high pressure homogenizer
·Product application: pharmaceutical industry, food and cosmetics industry, biotechnology, fine chemicals...
·Independent homogeneous area, easy to clean and maintain;
·The machine complies with GMP design and can connect to SIP/CIP devices for online operation;
·Equipped with ABB5.5KW and 7.5KW high-power motors to ensure stable operation under high pressure;
·Built-in cooling system can absorb crushing heat directly and quickly to ensure the activity of intracellular proteins;
·Optional cooling coil, two-stage homogeneous module, ceramic valve;
·The valve assembly is equipped with ultra-wear-resistant Stellite alloy material and synthetic diamond material;
·Full screen touch intelligent control, online display work graph, data can be copied,Food grade and drug grade hygiene clean design;
·Equipped with high precision digital display pressure sensor, accurate to 1bar;
·Using 380V three-phase power supply, matching low temperature circulation cold water group.
Model | Working Pressure | Flow | Steps | Piston Number | Power |
AS-80 | 1500bar | 80L/H | One Step | 2 | 5.5kw |
AS-80Plus | 1500bar | 80L/H | Two Steps | 2 | 5.5kw |
AS-120 | 1500bar | 120L/H | One Step | 3 | 7.5kw |
AS-120Plus | 1500bar | 120L/H | Two Steps | 3 | 7.5kw |
公司致力于提供领先的生物医药纳米均质分散解决方案,专注于生物制药、纳米递送、药剂制剂、纳米技术行业。主要产品有以下三个板块:
新型制剂设备有脂质纳米颗粒合成系统、微流控设备、微流控纳米药物制备系统、微流控芯片、脂质纳米颗粒(Lnps)生产设备,可应用载体平台有核酸类药物mRNA/DNA/siRNA、小分子药物 Small molecule drugs、蛋白质和多肽 Proteins and peptides及其它药物平台,可应用于药物输送、核酸脂质纳米颗粒合成、聚合物纳米颗粒合成如 PLGA/PLGA-PEG、脂质/脂质体合成、凝胶颗粒合成等。
脂质体、乳剂、微胶囊制备设备有高压微通道射流均质仪、超高压纳米均质机、高压均质机、高压乳匀机、高压脂质体挤出器,可应用于脂质体、乳剂、纳米粒、混悬剂、分散液、微胶囊、细胞破壁、降低药物粒径至纳米结构。
此外我们研发、装配和销售进口品牌及自主品牌标签的磷脂、脂质体、mRNA新冠辅料和其它试剂耗材,具体可查看我司产品中心的试剂、耗材介绍,相关产品会慢慢更新以加强我们的产品及服务管线。
单位名称: |
松江区广富林路658弄255号1926室
联系电话: |
Email: |
