其他实验耗材
集菌罐
集菌罐
canister
北京
Mainly Technology Parameters:
Subject Data
Max pressure 0.4MPa
Canister bottle tolerable pressure ≤0.5Mpa
The highest temperature 60℃
Soft tube length 90~150cm
The length varies with the number of goods.
Tube flow Two canister bottle(220 serials)≥300ml/min
Three canister bottle(330 serials)≥400ml/min
Distribution uniformity Two canister bottle(220 serials) Distribution difference coefficient≤10%
Three canister bottle(330 serials) Distribution difference coefficient≤16%
Microorganism Recovery and Growth Performance Strain             Experimental strain addition quantity    Growth situation
Staphylococcus aureus  CMCC(B) 26 003     <100cfu      24hours growth well
Pseudomonas aeruginosa CMCC(B)10104     <100cfu      24hours growth well
Bacillus subtilis          CMCC(B)63 501     <100cfu      24hours growth well
Clostridium sporogenes CMCC(B)64 941      <100cfu      24hours growth well
candida albican         CMCC(F)98 001     <100cfu      48hours growth well
Aspergillus niger      CMCC(F)98 003     <100cfu      48hours growth well
Aseptic Performance Thioglycolate fluid medium :no bacterial growth
Tryptone soybean broth medium : no bacterial growth
3.Main parts ‘ Materials
Name Material specification
Canister bottle Acrylonitrile-styrene copolymer (SAN)
Canister bottom Acrylonitrile-styrene copolymer ( SAN)
Air filter Hydrophobic PTFE 0.22µm
Respirator methacryIate-Butadiene-Styrene copolymer ( MBS)
Filter disc membrane Mixed cellulose(CN—CA),(NYLON)
Tube polyvinyl chloride (PVC)
Syringe needle Stainless (316L)
Protective cap silicon rubber  (Si)
Package The composite film is polyethylene terephthalate(PET) ,Dialysis film is Tyvek TM1059B
Note:Tyvek TM is DUPONT company Registered trademark
  1. Filter disc membrane parameters
Goods No./Model Bottom color Micro size Membrane diameter Filter area Hydrophilic/hydrophobic
PY220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
SDY220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
APY220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
DGB220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
CN220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
DCN220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
KDGB220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
KSF220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
NKF220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
KAPY220/330 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
EVS2/3 Blue 0.45µm 47mm 14.5cm2 Hydrophilic
  1. Consist of parts:
Model Consist of:
PY220 2Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
PVC220 1Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
DGB220 2Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
SDY220 1Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
APY220 1Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
YLQ220 1Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
1connector
KSF220 1针头/1针头呼吸器/1分液器/1阻滞扣/1导管/2护帽/2杯体呼吸器/2杯体/2滤膜/2帽塞/2底座
KAPY220 1Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
NKF220 3Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
KDGB220 2Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
PRJ220 1Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
CN220 1Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
DCN220 1Syringe needle /1Needle respirator/1liquid separator/1Block buckle /1Tube /2protective cap/2Canister respirator /2Canister bottle/2Filter disc membrane /2Cap plug /2Bottom
    2004年,全自动过滤器完整性测试仪的诞生开启了钮因科技在中国振奋人心的旅程!    如今,钮因科技已为国内外几千家制药行业客户提供专业服务,为中国制药行业及企业的国际化和高质量发展全面赋能。我们始终秉持创造一个专业和专注的初心,对安全标准的严格坚守和对创新科学的不懈推进成就了今天的钮因。目前,北京钮因华信科技发展有限公司是中国制药装备协会会员、中国疫苗行业协会会员,致力于制药行业精密测试仪器及相关耗材的研发、生产、销售一体化的高新技术企业,拥有实力雄厚的研发与客户服务团队,主要技术骨干与技术均来自于国内科研院所,在自动化工艺设计等交叉应用技术方面具有一定的实力。我公司在技术上不断探索和创新,所开发的产品系列覆盖了从无菌过滤生产工艺、制药用水等所需的原材料、设备等多个关键环节。     主要产品有:全自动过滤器完整性测试仪、总有机碳TOC分析仪、包装密封性检测仪、手套完整性测试仪、RTP完整性检测仪、袋子检漏仪、渗透压摩尔浓度测试仪、电子加热套、滤芯滤器,还有微粒分析仪和拉曼光谱仪等,已为国内大量制药企业、相关实验室提供了优质、便捷的服务。其测试方法均满足FDA、中国药典及GMP法规以及EP和USP的要求。      北京钮因通过科学研究助力解决产品安全、信息安全及可持续发展带来的挑战,传递信任,为制药行业创新产品和创新技术的安全应用保驾护航。 每一位钮因员工都满怀热诚地为创建一个更安全的制药产品检测环境而努力。
欢迎关注微信公众号
售后服务承诺: ◆ 三个月内出现质量问题可换货; ◆ 现场安装调试培训; ◆ 每月电话回访,定期上门回访; ◆ 仪器有问题24小时响应并给出解决方案; ◆ 维修期间可提供备用机服务; 感谢您的阅读,如果您对以上内容任何疑问,可来电咨询。 顺祝您生活愉快!
北京市石景山区紫御国际2-501
