美国TMC STACIS 4 主动隔振系统
Active degrees of freedom | 6 |
Active bandwidth | 0.2 Hz - 150 Hz |
Isolation at 1 Hz | 85% - 96% |
Isolation at 2 Hz | 96-99.9% |
Settling time (typical) | 0.02 sec |
Internal noise | <0.05 nm RMS |
Operating load range per isolator | Low capacity: 400-1100 lbs (182-500 kg) Med capacity: 900-2100 lbs (410-955 kg) Hi capacity: 1900-4500 lbs (864-2045 kg) |
Stiffness (1000 lb / 454 kg mass, Med capacity isolator) | 40,000 lb/in. (73 x 105 N/m) |
Magnetic field emitted at maximum 4 in.(102 mm) from the isolator | <0.02 μG broadband RMS |
Environmental and safety | CE and RoHS compliant, designed to comply with NRTL safety certification standards |
Active isolation elements | Piezoelectric elements are actuated by a high-voltage amplifier. Vertical actuators support the isolated payload. |
Passive isolation element | Single isotropic hard-mount elastomer (no compressed air supply required) |
Vibration sensor elements | Geophone type inertial sensors measure floor vibration and deliver a signal to the control system proportional to the velocity of vibration motion |
Active feedback control loop | Floor vibration is measured, processed and attenuated below the spring supporting the isolated surface |
Isolator dimensions (WxDxH) | 11.75 x 12.5 x 10.8 in. 300 x 320 x 275 mm |
Isolator weight | 75 lb (34 kg) |
Operating temperature | 50° - 90° F 10° - 32° C |
Storage temperature | -40° - 130° F -40° - 55° C |
Humidity | 80% Maximum at 68 degrees F (20 degrees C), Maximum dewpoint: 18 degrees C |
System power requirements | 100, 120, 230, 240 VAC 50/60 Hz AC; <600 W CE compliant |
Isolator count per system | minimum of 3, no maximum |
Options | laminated stainless steel platforms, frames, risers, leveling devices, earthquake restraints, lifthoods |
Dimensions (WxDxH) | 19 x 8.5 x 1.75 in. 483 x 216 x 45 mm |
Weight | 6.3 lb (2.9 kg) |
Processor | 150/75 MHz dual core |
Sampling rate | 10 kHz |
Analog outputs | 16 channels |
Analog inputs | 16 channels |
Status light | single LED |
Front panel ports | 1x serial USB 2.0 1x serial Micro-USB 1x Ethernet RJ-45 2x BNC |
Rear panel ports | 1x serial USB 2.0 1x Ethernet RJ-45 1x RS-232 DB-9 legacy serial for legacy STACIS 2100 isolators |
User interface | Front panel LCD display Character menu on HyperTerminal Extended GUI for Microsoft Windows Embedded Ethernet GUI |
森泉光电有限公司是生物器材领域仪器设备代理与系统集成业务的综合性服务商。公司总部设在青岛,在上海和北京设有分公司,业务范围涵盖国内各著名高校和科研院所,以及国内知名企业。主要的生物器材设备是TMC隔震平台及Siskiyou的生命科学机械件。
我们拥有优质的产品,稳定的供货渠道,强大的技术支持和成熟的销售服务经验,可提供诸多生物器材应用解决方案,竭诚为您提供最满意的服务!
单位名称: |
青岛市黄岛区峨眉山路396号光谷软件园57号楼501
联系电话: |
Email: |
