搅拌器
博奥思BH200-C4低速生物培养磁力搅拌器
Biostream BH200-C4
进口
荷兰/Biostream
BH200-C4
生物培养磁力搅拌器
>BH200-C4生磁力搅拌器是专为实验室生物培养设计的搅拌器,该搅拌器是通过固定电磁铁产生一个旋转磁场,从而带动培养瓶中的磁力搅拌桨发生旋转,搅拌过程不会生热,低噪音,高 效,且没有运动部件的磨损。
> 基于温和混合方式的设计理念,Biostream 磁力搅拌器可以降低在搅拌中对细胞产生剪切作用以及热量传导,适合生物培养的长时间搅拌。
> 根据需要选择下列三种模式:
1. 恒速模式:柔和启动,稳定到达设定速度,该模式适合悬浮细胞培养
2. 间歇启动模式:该模式在培养之初将搅拌按照循环模式柔和开关,以利于贴
壁细胞附着于微载体,经过约4-10 个循环后,再将搅拌速度调整到正常培养速度,该模式适合于细胞的微载体培养。
BH200-C4低速磁力搅拌器
> 适用于低速搅拌和剪切力敏感样品的混合
> 5~200 rpm,有一个搅拌位和四个搅拌位两种型号可选
> 搅拌程序可编程和报警功能
技术参数
参数
BH200-C4低速搅拌器
定货号
B3032101
搅拌位
四位
转速范围
5-200 rpm
适用培养瓶规格
≤3L
外形尺寸:(H×W ×L)
10.2 x 39.4 x 44.5 cm
重量
4.5 kg
额定功率
15W
环境条件
工作温度:14-40℃;湿度:31℃时不高于80%,40℃时不高于50%;海拔高度,低于2000m
工作电源
100-240 VAC, 50/60 Hz
With its headquarter located in Netherland / Europe, Biostream company is famous for its highly qualified bio-equipment including shaking incubator, bioreactor, biochemistry analyser and other biotechnology equipment in the food, biobased fermentation, algae and cell culture field. In the area of photo bioreactors we have developed and produced bioreactors for different kinds of microalgae and phototrophic bacteria. In the biobased field we are producing equipment for pre-treatment, hydrolyses in combination with fermentation. With the focus on service and R&D we can develop customized solutions which are not available on the market yet. Fermentation in the direction of water technology is becoming more interesting and we will also explore new ideas in this field. Together with several partners we can bring new ideas into highly qualified bioequipment.
上海市普陀区华池路58弄1号719/722
