CO2/细胞培养箱
博奥思 BCI-1200 CO2培养箱
博奥思 BCI-1200 CO2培养箱
进口
荷兰/Biostream
BCI-1200
面议
二氧化碳培养箱很适合动物细胞培养、生殖细胞培养、厌氧细胞培养。适合微生物的培养及孵化实验,种子培育及组织培养实验需求。
报警系统
CO2 和温度有偏离时,会进行蜂鸣报警
良好空气和湿度对流
良好的空气对流,良好温场均匀性。六面箱体侧壁加热,附件顶置空气循环风扇,确保良好对流效应
易于清洗
圆角设计易于清洗,内腔材质为 SUS304不锈钢
温度上限设置
当温度控制故障,或者某个点的温度超过设定的上限温度,设备会自动切断电源,确保样品及设备自身安诠
带孔的承重搁板
带孔的承重隔板,可承重 50kg,不锈钢材质可有效防腐蚀、防污染
无冷凝
箱门带加热单元,以及整个培养箱的框架式设计,可以确保不会在箱体及玻璃观察窗上冷凝
技术参数
温度范围: 室温 +5~60℃
温度分辨率: 0.1℃
干热灭菌: ≤125℃
控制方式: 数字 PID
CO2 范围: 0% ~ 20%
CO2 精度: ±0.1% (5% / 37℃ )
CO2 分辨率: 0.1%
CO2 传感器: 双光束红外 CO2 传感器
显示屏: TFT 触摸屏
操作面板: 触摸屏控制面板
夹套类型: 气套式(六面梯度加热)
腔体材料: 不锈钢(304)
技术参数
型号
BCI-1200
订货号(标准型)
B6011122*
箱体容积 [L]
1204
显示分辨率 [℃ ]
±0.1℃ (37℃ )
温场均匀性 [℃ ]
±0.5℃ (37℃ / RT.25℃ )
加热功率 [W]
1600
CO2 入口压力范围 [bar]
0.7~1.0
搁板数 (标准/最大)
0/35
内部尺寸 [WxDxH][mm]
868x720x1927
外部尺寸 [WxDxH][mm]
990x855x2123
重量 [kg]
323
*代表BCI-1200不含玻璃门,带玻璃观察窗。
With its headquarter located in Netherland / Europe, Biostream company is famous for its highly qualified bio-equipment including shaking incubator, bioreactor, biochemistry analyser and other biotechnology equipment in the food, biobased fermentation, algae and cell culture field. In the area of photo bioreactors we have developed and produced bioreactors for different kinds of microalgae and phototrophic bacteria. In the biobased field we are producing equipment for pre-treatment, hydrolyses in combination with fermentation. With the focus on service and R&D we can develop customized solutions which are not available on the market yet. Fermentation in the direction of water technology is becoming more interesting and we will also explore new ideas in this field. Together with several partners we can bring new ideas into highly qualified bioequipment.
上海市普陀区华池路58弄1号719/722
