CO2/细胞培养箱
博奥思 BCI-850G GMP CO2培养箱
进口
荷兰/Biostream
BCI-850G
面议
满足GMP 标准的CO2 培养箱,符合GMP 相关规定和要求,协助客户在符合GMP 标准下,完成多种实验和试验; 整个内腔体材料为高品质不锈钢,圆角设计易于清洗,易清洁,也可用化学品清洗。
> RS485/RJ45 通讯接口,可用于远程控制和连接电脑
> USB 通讯接口,插入 U 盘后可实时记录和保存数据, 导出 CSV 文件
    SIEMENS 控制器  HMI 触摸屏
技术参数
型号
BCI-850G
订货号(标准型)
B6015850
箱体容积[L]
850
温度显示精度 [℃ ]
±0.1 (37℃ )
温场均匀性[℃ ]
±0.5 (37℃ / RT.20℃ )
加热功率 [W]
1400
CO2 入口压力范围[bar]
0.7~1.0
搁板数(标准/ 小于等于)
3/15
内部尺寸[WxDxH][mm]
700x800x1530
外部尺寸[WxDxH][mm]
820x930x1840
重量 [kg]
266
With its headquarter located in Netherland / Europe, Biostream company is famous for its highly qualified bio-equipment including shaking incubator, bioreactor, biochemistry analyser and other biotechnology equipment in the food, biobased fermentation, algae and cell culture field. In the area of photo bioreactors we have developed and produced bioreactors for different kinds of microalgae and phototrophic bacteria. In the biobased field we are producing equipment for pre-treatment, hydrolyses in combination with fermentation. With the focus on service and R&D we can develop customized solutions which are not available on the market yet. Fermentation in the direction of water technology is becoming more interesting and we will also explore new ideas in this field. Together with several partners we can bring new ideas into highly qualified bioequipment.
上海市普陀区华池路58弄1号719/722
