其他实验耗材
美国 CALIFORNIA FINE WIRE不锈钢丝
进口
CFW
CFW103
MATERIAL SPECIFIC RESISTANCE (Ω–CM/F) MELTING POINT °C COMPOSITION
Aluminum
1 ALUMINUM 1% SILICON 15.2 657
2 ALUMINUM 1199 15.97 660 Al99.99%
3 ALUMINUM EC 1350 16.83 657 Al99.45%
4 ALUMINUM 2024   20.25 638 Al93.84%Cu4.5%Mg1.5%Mn0.16%
5 ALUMINUM 3003 20.25 634 Al98.8%Mn1.2%
6 ALUMINUM 4043 25 632 Al94.75%Si5.25%
7 ALUMINUM 5005 19.95 652 Al99.2%Mn0.8%
8 ALUMINUM 5052   10.23 649 Al97.25%Cr0.25%Mn2.5%
9 ALUMINUM 5056   35.79 638 Al94.6%Cr0.1%Mg0.1%Mn0.1%
10 ALUMINUM 6061  23.04 649 Al97.9%Cr0.25%Cu0.25%Mg1%Si0.6%
Copper
1 ALLOY 725 94.3 1060 Cu88.2%Ni9.5%Sn2.3%
2 BE COPPER ALLOY 10 CDA 175    22.8 1029 Be0.55%Co2.55%Cu96.9%
3 BE COPPER ALLOY 25 CDA 172   46.2 865 Be1.8%Cu98.1%
4 BE COPPER CDA 17410   36.9 1025 Be0.3%Co0.5%Cu99%
5 BRASS FREE-CUT CDA 360   39.9 885 Cu61.5%Pb3.1%Zn35.4%
6 BRASS 7030 CDA 230 37 915 Cu70%Zn30%
7 BRASS GILDING CDA 210   18.5 1050 Cu95%Zn5%
8 CADMIUM COPPER CDA 162 11.5 1030 Cd1%Cu99%
9 COMMERCIAL BRONZE 90% CDA 220 23.6   Cu90%Zn10%
10 COPPER 27% NICKEL CLAD   14 1100 Cu99.9%Ni99%
11 COPPER 99.95% CDA 102 OF   10.3 1083 Cu99.5%min
12 COPPER 99.99% CDA 101   10.3 1083 Cu99.99%min
13 COPPER ETP MAGNET WIRE  10.3   Cu99.9%min
14 COPPER NICKEL 20% 160 1150 Cu79%Ni21%
15 COPPER ZIRCONIUM CDA 150   11.2 980 Cu99.85%Zr0.15%
16 CUPRO NICKEL 70-30  225 1170 Cu69.5%Fe0.5%Ni30%
17 LOW BRASS CDA 240   32.4 965 Cu80%Zn20%
18 NICKEL SILVER CDA 752   173 1070 Cu65%Ni18%Zn17%
19 NICKEL SILVER CDA 757 130 1040 Cu65%Ni12%Zn23%
20 NICKEL SILVER CDA 764   189 1020 Cu60%Ni18%Zn22%
21 PD-135 11.3 1080 Cd1%maxCr1%maxCu99%min
22 PH BRONZE 5% CDA 510 A 69.1 950 Cu94.8%P0.2%Sn5%
23 PH BRONZE 8% CDA 521 C 79.8 880 Cu92%P0.16%Sn8%
24 PH BRONZE 10% CDA 524 D 94.3 845 Cu90%Sn10%
Nickel
1 ALLOY 99 48 1450 Ni99.8%min
2 DURANICKEL 301   255 1450 Al4%-4.75%Ni93%Ti0.25%-1%
3 MONEL 400     290 1350 Cu32.5%Fe2.5%Mn2%Ni63%
4 MONEL 404     319 1299 Cu43%-48%Ni52%-57%
5 Monel K 500 370   Al2.3%-3.15%Cu23.35%-34.5%Fe2%maxMn1.5%maxNi63%-70%
6 NICKEL 205 50 1450 Ni99.45%min
7 NICKEL 211     102 1430 Mn4.75%Ni93.7%
8 NICKEL 220     45 1450
9 NICKEL 270     45 1450 Ni99.97%min
10 NICKEL A/200   48 1450 Ni99%min
Precious Metal
1 ALLOY 20-245   245
2  ALLOY 406 75
3 ALLOY 411     37.0009   Ag89%Pd11%
4 ALLOY 417     57
5 ALLOY 422 180 1880
6 ALLOY 443     80
7 ALLOY 446     190
8 ALLOY 486     610 1700
9 GOLD 99.99% BE MOD   12.6 1063 Au99.99%min
10 GOLD 99.99% 14.14 1063 Au99.99%min
11 PALLADIUM 60 1554 Pd99%min
12 PLATINUM 8% TUNGSTEN     400 1870 Pt92%W8%
13 PLATINUM 10% IRIDIUM     150 1775 Ir10%Pt90%
14 PLATINUM 10% RHODIUM      111 1850 Pt90%Rh10%
15 PLATINUM 20% IRIDIUM    186 1840 Ir20%Pt80%
16 PLATINUM 20% RHODIUM     125 1900 Pt80%Rh20%
17 PLATINUM PURE TC GRADE     64 1773 Pt99.99%min
18 RHODIUM 99.8% 30 1960 Rh99.8%min
19 SILVER 99.99% 8.8 960 Ag99.99%
Resistance Wire
1 MANGANIN 230 SHUNT 230 1020 Cu84%Mn12%Ni4%
2 MANGANIN 290   290 1020 Cu84%Mn12%Ni4%
3 NICKEL ALLOY 30 30 1100 Cu98%Ni4%
4 NICKEL ALLOY 60     60 1100 Cu94%Ni6%
5 NICKEL ALLOY 90     90 1100 Cu90%Ni10%
6 NICKEL ALLOY 120     120 1425 Fe30%Ni70%
7 NICKEL ALLOY 180     180 1100 Cu78%Ni22%
8 NICO 294 1210 Cu55%Ni45%
9 NIFE 5200   120 1425 Fe30%Ni70%
10 STABLOHM 610 (TOPHET D) 610 1300 Cr20%Fe45%Ni35%
11 STABLOHM 650 650 1395 Cr20%Ni80%Si1%-2%
12 STABLOHM 675   675 1350 Cr16%Fe34%Ni60%
13 STABLOHM 710   710 1377 Cr30%Ni70%
14 STABLOHM 750   750 1510 Al4%Cr15%Fe81%
15 STABLOHM 800 A 800 1395 Al2.5%Cr20%Cu2.5%Ni75%
16 STABLOHM 812   812 1510 Al4.5%Cr21%Fe74.5%
17 STABLOHM 875 875 1520 Al5.5%Cr22.5%Fe72%
Stainless Steel
1 STAINLESS STEEL 302 420 1399
2 STAINLESS STEEL 304 420 1399
3 STAINLESS STEEL 305     420 1399
4 STAINLESS STEEL 308     455 1399
5 STAINLESS STEEL 309 170 1399
6 STAINLESS STEEL 310     520 1399
7 STAINLESS STEEL 316     470 1371
8 STAINLESS STEEL 316L   445 1399
9 STAINLESS STEEL 347     470 1399
10 STAINLESS STEEL 430     360 1427
材料应用
Glass Sealing Alloy
1 Alloy 36 495 1427 Fe64%,Ni36%
2 Alloy   42 430 1427 Fe59%,Ni41%
3 Alloy   42-6 570   Cr6%,Fe52%,Ni42%
4 Alloy   52 258 1426 Fe50%,Ni50%
5 Dumet 58   Cu99.9%
6 Kovar 294 1450 Co17%,Fe54%,Ni29%
Refractory Metals
7 Molybdenum 31 2610 Mo99.9%
8 Tantalum R05200 74.6 2890 Ta99.96%
9 Tantalum R05400 81.2 2890 Ta99.96%
10 Tantalum 81.2 2890 Ta99.96%
11 Titanium 99% 252 1660 Ti99%
12 Tungsten 99.95% CS 33 3420 W99.95%
Special Application
13 Inconel 600 620 1354 Cr17%,Fe10%,Ni72%
14 NI SPAN C ALLOY 902 611 1455 Cr5.75%,Fe51.9%,Ni43%,Si1%,Ti2.75%
15 Steel Copper Clad 40% Cond 25.9   Cu99.99%
16 Zinc 99.95% 35.58 419 Zn99.5%
17 Zirconium 99.% 240   Zr99.9%
Spring Wire
18 Elgiloy 599 1427 Co40%,Cr20%,Fe18%
,Mo7%,Ni15%
19 Inconel 625 776 1288 Cr23%,Mo10%,Nb4.15%,Ni4.15%,Ta4.15%
20 Inconel 718 751 704 Cr17%,Fe8%,Mn2.5%,Ni63.25%,Ti3%
21 Inconel x750 731 816 Cr17%,Mn1%,Nb1.2%,Ni70%Ta1.2%,Ti2.75%
Thermocouple Wire
22 Alumel TC Type K STD 177 1400 Al2%,Mn2%,Ni95%
23 Chromel   P TC Type E STD 425 1427 Cr10%,Ni90%
24 Chromel P TC Type K STD 425 1430 Cr10%,Ni90%
25 Constantan TC Type E STD 294 1221 Cu55%,Ni45%
26 Constantan TC Type J STD 294 1221 Cu55%,Ni45%
27 Constantan TC Type T STD 294   Cu55%,Ni45%
28 Copper TC Type T STD 10.3   Cu99.99%
29 Iron TC Type J SPL 75 1496 Fe99%
北京顺鑫成科技有限公司代理进口日本不锈钢毛细管和美国CALIFORNIA FINE WIRE公司生产的金属线。
代理日本精密毛细管,微小管,材质有不锈钢、铜、镍、钛、镍铁合金、铂、铂铱合金等。应用于EDM的电极管、检测P.C.B的接触式探头、光导纤维(金属接头)、半导体制造机械及设备、导管设备等。
不锈钢管(用于医疗设备的功能部件、半导体设备等等。),通过短芯棒拉拔终加工得到光滑内表面;通过NT细切得到无毛刺边缘。
外径 0.05mm—3.0mm
内径 0.02mm—2.9mm
   代理美国CALIFORNIA FINE WIRE生产的各种金属线,加利福尼亚细线公司生产圆形和扁平形状的细线和超细线。服务包括搪瓷、PTFE和陶瓷涂层、电镀、绞合、切割和矫直。加工的合金包括贵金属、不锈钢、铜、电阻合金、耐火合金等。
   以下是CFW生产的一些金属线类型的列表:
贵金属、半导体键合线和带
铜、铜合金、复合金属(包层)
镍、镍合金、电阻丝、电位器合金
铝及合金,低热膨胀(玻璃密封合金)
热电偶线,RTD线,高温(陶瓷绝缘)
不锈钢、音乐线、保险丝线、细线和色带
耐火金属和合金
北京市怀柔区杨宋镇凤翔东大街9号201室
