其他实验耗材
1.50242.0001 默克 色谱柱柱套件
进口
默克
Supelco 12024AST Astec® CHIROBIOTIC® T 手性 HPLC 色谱柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 24056 SP®-2560毛细管GC色谱柱L × I.D. 100 m × 0.25 mm, df 0.20 μm
Supelco 24217-U VOCOL® 毛细管GC色谱柱L × I.D. 60 m × 0.32 mm, df 1.80 μm
Supelco 504971 Discovery® C18 高效液相色谱柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 505064 Discovery® 反相酰胺 C16 高效液相色谱柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 53827-U Ascentis® Express C18, 2.7 μm HPLC 色谱柱2.7 μm particle size, L × I.D. 10 cm × 4.6 mm
Supelco 53829-U Ascentis® Express C18, 2.7 μm HPLC 色谱柱2.7 μm particle size, L × I.D. 15 cm × 4.6 mm
Supelco 57044 Visiprep™ SPE 真空固相萃取装置DL (Disposable Liner), 12-port model
Supelco 57057 Supelclean™ LC-Florisil® 固相萃取管bed wt. 1 g, volume 6 mL, pkg of 30 ea
Supelco 57114 Supelclean™ ENVI™-18 SPE 小柱bed wt. 2 g, volume 12 mL, pk of 20
Supelco 57059 固相萃取小柱连接管;用于Visiprep DL防交叉污染SPE装置(包含在57044和57265)的一次性小柱连接管PTFE, pk of 100
Supelco 57094 Supelclean™ ENVI-Carb™ SPE 管,bed wt. 500 mg, volume 6 mL, pk of 30
Supelco 58201 SUPELCOSIL™ LC-Diol HPLC 色谱柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 58298 SUPELCOSIL™ LC-18 HPLC 柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 58338 SUPELCOSIL™ LC-NH2 HPLC 色谱柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 58842 SUPELCOSIL™ LC HPLC 色谱柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 58934 SUPELCOSIL™ Suplex™ pKb-100 HPLC 色谱柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 59142 SUPELCOSIL ™ LC-ABZ HPLC 色谱柱5 μm particle size, L × I.D. 25 cm × 4.6 mm
Supelco 59356-U Cyano HPLC 色谱柱5 μm particle size, L × I.D. 15 cm × 4.6 mm
Merck 1.05626.0001 硅胶薄层层析板TLC Silica gel60 Glass plates 10x20cm 50/PK
Merck 1.05554.0001 硅胶薄层层析板TLC Silica gel 60 F254 25 Aluminium sheets 20 x 20 cm
Merck 1.05641.0001 硅胶薄层层析板HPTLC Silica gel 60 50 Glass plates 20 x 10 cm
Merck 1.05729.0001 硅胶薄层层析板TLC Silica gel 60 F254 50 Glass plates 10 x 20 cm
Merck 1.05642.0001 硅胶薄层层析板HPTLC Silica gel 60 F254 50 Glass plates 20 x 10 cm
Merck 1.05715.0001 硅胶薄层层析板TLC Silica gel 60 F254 25 Glass plates 20 x 20 cm
Merck 1.02129.0001 Chromolith® Performance RP-18封端100-4.6 HPLC色谱柱,L × I.D. 100 mm x 4.6 mm HPLC column
Merck 1.50248.0001 色谱柱 Lichrocart 250*4.6  Purospher star NH2
Merck 1.51456.0001 色谱柱 Purospher STAR RP18e 250*4.6 5u CUXM
Merck 1.50242.0001 色谱柱Purospher® STAR RP-18封端(3 µm) LiChroCART® 55-4柱套件,pkg of 1 column, pkg of 1 holder
Merck 1.51486.0001 manu-CART® NT卡套,用于LiChroCART® 2,3,4,4.6 mm i.d.HPLC 柱
上海希言科学仪器有限公司位于上海市松江高科技园区,是一家专业经营实验室耗材的年轻公司,专注于色谱、光谱、环境监测、实验室通用设备的研究、销售、技术支持的体系化服务,主要客户分布于生物医药、食品日化、环境检测、化工纤维等行业。
上海市松江区涞寅路1025号立同商务广场3067室
