9301-6528安捷伦100ml带盖溶剂瓶
5191-4182 | 样品瓶盖 | Cap,VL,black,screw,PTFE/sil,2ml,100pk |
5191-4286 | 过滤器 | ValueLab filter Nylon 13mm 0.2um 100/pk |
5191-4287 | 过滤器 | ValueLab filter Nylon 13mm 0.45um 100/pk |
5191-4290 | 过滤器 | ValueLab filter PTFE 13mm 0.2um 100/pk |
5191-4294 | 过滤器 | ValueLab fltr PTFE-Q 13mm 0.2um 100/pk |
5191-5851 | 泵油 | Agilent Vacuum Fluid 45 Platinum, 1Qt |
5200-0176 | 喷嘴 | FID Jet, universal fit, 0.011 inch ID |
5982-0101 | 反萃管 | Polish Tube-NaCl/MgSO4, 50/PK |
5982-1010 | 过滤柱 | QuEChERS dSPE EMR-Lipid |
5982-4432 | 过滤柱 | Carbon - Box, 50x 3 ml tubes, 250 mg |
5982-9313 | 陶制均质子 | Ceramic Homogenizers, 50ml tubes,100/pk |
6310001200 | 石墨管 | Graphite tubes, partitioned, 10/pk |
9301-0718 | 铝质瓶盖 | 20mm silver alum safety crimp cap 100pk |
9301-0719 | 塑料隔垫 | 20mm Tan PTFE/White silicone septa,100PK |
9301-0721 | 铝质瓶盖 | 20mm silver alum crimp cap,100pk |
9301-0722 | 样品瓶架 | 12mm Plastic vial rack, 5/PK |
9301-6524 | 溶剂瓶 | Solvent bottle clear, 1000ml |
9301-6526 | 溶剂瓶 | Solvent bottle amber, 1000ml |
9301-6528 | 溶剂瓶 | Solvent bottle clear, 1000ml with cap |
CP17973 | 过滤器 | Gas Clean Filter Carrier Gas |
G1099-20133 | 陶瓷绝缘体 | Repeller insulator |
G1314-60100 | 长寿命氘灯 | D2 Lamp L6903 with Box |
G1314-60101 | 长寿命氘灯 | Deuterium lamp w. RFID for VWD |
G3440-81011 | 手拧柱螺帽 | Column Nut Assy, Finger Tight |
G3440-81013 | 手拧柱螺帽 | Collared Column Nut, Self-Tightening MSD |
G4513-80209 | 注射器 | Syringe 10ul straight, FN 23/42/HP |
G7005-60061 | 离子源芯 | Filament,high temperature EI for GCMS |
OT3-2 | 过滤管 | Trap, O2/H2O, 1/8in |
RMSH-2 | 过滤管 | Big Universal Trap, 1/8inch fttgs,Helium |
X3760-64004 | 泵油 | AVF Platinum |
上海希言科学仪器有限公司位于上海市松江高科技园区,是一家专业经营实验室耗材的年轻公司,专注于色谱、光谱、环境监测、实验室通用设备的研究、销售、技术支持的体系化服务,主要客户分布于生物医药、食品日化、环境检测、化工纤维等行业。
单位名称: |
上海市松江区涞寅路1025号立同商务广场3067室
联系电话: |
Email: |
