其它各类仪器
北京赛德凯斯RFG型射频电源
北京赛德凯斯RFG型射频电源
Setcas RFG RF Generator with SP type manual or automatic adapter
北京赛德凯斯电子有限责任公司
RFG
RFG-500型射频电源
电气参数 指标
输出功率 1W-500W连续可调,正反向功率真彩色LCD智能显示
射频末级效率 ≥86%(500W输出时),≥93%(300W输出时)
功率稳定度 ≤ ±0.5%(额定功率输出时)
频率稳定度 ±10ppm
承受最大反射功率 100W(20-30s)
最大输出功率裕度 20%
谐波输出 二次谐波低于 -50dB,三次及更高次谐波低于 -55dB
频率信号 13.56MHz标准正弦波
整机效率 ≥70%
控制信号与后面板电气连接 指标
模拟口 15针D型(阴性)(选配)
串口 RS232/RS485/USB通讯协议(选配)
外部时钟同步(CEX) BNC(阴性)
射频输出口 标准同轴接头输出(M/N型,阴性)
交流供电口 AC220V供电(50Hz)
冷却方式 强制风冷
机械尺寸 指标
体积 132mm(H)X483mm(W)X500mm(D)5.5"(H)17.3"(W)19.7"(D)
重量 18kg
安装 前面板高为标准3U,宽为19英寸
前面板指示 4.3寸TFT真彩数字屏(16:9),分辩率480X272,LED背光,28键键盘,纯铝旋钮
前面板颜色 象牙白(可根据客户需求进行定制)
使用环境 指标
环境温度 0 -40℃
相对湿度 < 85%
RFG-500 RF Generator
Output power:1W-500W continuously adjustable of forward and reverse power for true color LCD intelligent display
RF final stage efficiency:≥86%(500W during output),≥93%(300W during output)
Power stability:≤ ±0.5% (At rated power output)
Frequency stability:±10ppm
Support maximum reflected power:100W(20-30s)
Maximum output power margin:20%
Harmonic output:The second harmonic is lower than -50dB,the third and higher Harmonic are below -55dB
Frequency signal:13.56MHz standard sine wave
Overall efficiency:≥70%
Analog port:15 needle D type(negative)(optional)
Serial port:Communication protocol RS232/RS485/USB(optional)
External clock synchronization(CEX):BNC (negative)
RF output:Standard coaxial connector output(M/N type,negative)
AC power port:AC220V voltage(50Hz)
Cooling method:Forced air cooling
Dimension:132mm(H)X483mm(W)X500mm(D)5.5"(H)17.3"(W)19.7"(D)
Weight:18kgs
Installation:Standard high of front panel 3U, 19 inch (W)
Front panel indication:4.3”TFT true color digital screen(16:9),resolution 480X272,LED back light ,28-key keyboard,pure aluminum knob
Front panel color:Ivory(can be customized according to customer needs)
Temperature of environment:0 -40℃
Relative humidity:< 85%
RFG-1000 RF Generator
Output power:1W-1000W continuously adjustable of forward and reverse power for true color LCD intelligent display
RF final stage efficiency ≥86%(1000W during output),≥93%(700W during output)
Power stability :≤ ±0.5% (At rated power output)
Support maximum reflected power:200W(20-30s)
Weight:18.7kgs
RFG-1500 RF Generator
Output power:1W-1500W continuously adjustable of forward and reverse power for true color LCD intelligent display
RF final stage efficiency:≥86%(1500W during output),≥93%(800W during output)
Support maximum reflected power:300W(20-30s)
Weight:19.9kgs
北京赛德凯斯电子有限责任公司是一家研发型高科技跨国企业,公司专注于集成电路及半导体相关设备,电子类产品的研发,生产与销售。公司一直坚持将产品研发,产品质量,售后服务放在第一位。公司专注于产品研发,擅长于软件开发,互联网技术,物联网传感器技术,工控系統,自动控制系统,机械设计,工业外观设计等技术。研发团队所有人员都具有10年以上集成电路产业相关经验。
本公司所有设备及配件均提供一年质保服务,质保期内运费由我们支付,质保期后检修免费若维修需付材料费。本公司是设备厂家,研发及制造生产一体,提供终身售后服务。
北京市昌平区松园路中国石油大学松园宿舍3号楼2-101
