GE lifescience凝胶填料 现货列表
名称 | 规格 | 货号 |
HiTrap | 11-0034-53 | |
SEPHADEX G-10 | 100 G | 17-0010-01 |
SEPHADEX G-25 MEDIUM | 100 G | 17-0033-01 |
SEPHADEX G-75 | 100 G | 17-0050-01 |
SEPHAROSE CL-4B 1 L | 1L | 17-0150-01 |
CM-SEPHADEX C-25 | 100 G | 17-0210-01 |
HITRAP PROTEIN A HP | 5 X 1 ML | 17-0402-01 |
HITRAP PROTEIN G HP | 1 X 5 ML | 17-0405-01 |
SEPHAROSE 4B | 15G | 17-0430-01 |
Q SEPHAROSE FAST FLOW | 25 ML | 17-0510-10 |
PHASTGEL GRADIENT | 17-0540-01 | |
SEPHACRYL S-200 HR | 750ML | 17-0584-01 |
SEPHACRYL S-100HR | 750ML | 17-0612-01 |
LYSINE-SEPHAROSE 4B 15 G | 17-0690-01 | |
HITRAP NHS-ACTIV HP, | 5X1ML | 17-0716-01 |
DEAE SEPHAROSE FAST FLOW | 500ml | 17-0709-01 |
DEAE SEPHAROSE FAST FLOW | 25ml | 17-0709-10 |
CM SEPHAROSE FAST FLOW | 500ML | 17-0719-01 |
SP SEPHAROSE FAST FLOW, | 300ML | 17-0729-01 |
SP SEPHAROSE FAST FLOW | 25 ML | 17-0729-10 |
GLUTATHIONE SEPHAROSE 4B | 10 M | 17-0756-01 |
PERCOLL | 1L | 17-0891-01 |
PHENYL SEPHAROSE 6FF (HS) 200 | 200ML | 17-0973-05 |
HEPARIN SEPHAROSE 6 FF | 50ML | 17-0998-01 |
Q SEPHAROSE HIGH PERF. | 75ML | 17-1014-01 |
SUPERDEX 200 PREP GRADE | 150ML | 17-1043-01 |
SUPERDEX 200 PREP GRADE, 25 M | 25 M | 17-1043-10 |
SUPERDEX 75 PREP GRADE | 150ML | 17-1044-01 |
HITRAP SP HP | 5X1ML | 17-1151-01 |
HITRAP SP HP | 5X5ML | 17-1152-01 |
HITRAP Q HP | 5X1ML | 17-1153-01 |
HITRAP Q HP | 5X5ML | 17-1154-01 |
HIPREP 16/60 SEPHACRYL | S-300H | 17-1167-01 |
RESOURCE Q | 1ML | 17-1177-01 |
RESOURCE S | 1ML | 17-1178-01 |
RESOURCE ISO | 1ML | 17-1185-01 |
IMMOBILINE DRYSTRIP PH 3-10 L, | 17-1234-01 | |
RPROTEIN A SEPHAROSE FF | 5 ML | 17-1279-01 |
SDS | 100g | 17-1313-01 |
UREA, | 500G | 17-1319-01 |
HITRAP DESALTING, 5X5ML | 5X5ML | 17-1408-01 |
Q SEPHAROSE XL, | 300 ML | 17-5072-01 |
HITRAP RPROTEIN A FF | 5X1ML | 17-5079-01 |
HIPREP 16/10 DEAE FF | 17-5090-01 | |
MONO Q 5/50 GL | 5/50 GL | 17-5166-01 |
MONO S 5/50 GL | 5/50 GL | 17-5168-01 |
NI SEPHAROSE HP | 100 ML | 17-5268-02 |
SUPERDEX 75 | 10/300GL | 17-5174-01 |
GLUTATHIONE SEPHAROSE HP | 25 ML | 17-5279-01 |
NPROTEIN A SEPHAROSE 4 FF | 5ML | 17-5280-01 |
NI SEPHAROSE 6FF | 25 ML | 17-5318-01 |
NI SEPHAROSE 6FF, | 100 ML | 17-5318-02 |
NI SEPHAROSE 6 FF | 5 ML | 17-5318-06 |
HISTRAP FF | 5 X 1 ML | 17-5319-01 |
IPG-BUFFER, PH 4-7L | PH 4-7L | 17-6000-86 |
IMM. DRYSTRIP PH 3-10, | 24CM | 17-6002-44 |
IMM. DRYSTRIP PH 3-10 NL, | 24CM | 17-6002-45 |
CHART PAPER 1 ROLL OF | 25M | 18-1001-44 |
ONLINE FILTER KIT, PKG/10(100 | PKG/10(100 | 18-1027-11 |
SEAL KIT 10ML | 10ML | 18-1120-77 |
ON-LINE FILTER (10 ML/MIN) | 18-1120-94 | |
FILTER KIT, HR 10 (REPL. 18154 | 18-3575-01 | |
COLUMN XK16/20 | 16/20 | 18-8773-01 |
COLUMN XK16/40 | 16/40 | 18-8774-01 |
COLUMN XK16/70 | 16/70 | 18-8775-01 |
COLUMN XK16/100 | 16/100 | 18-8776-01 |
ANTI-HIS ANTIBODY | 27-4710-01 | |
GEL FILTRATION CAL KIT HMW | 28-4038-42 | |
TRICORN | 10/150COLUMN | 28-4064-16 |
illustra plasmid Mini | 50NAP | 28-9042-69 |
CYPHER 5E NHS ESTER | 1MG | PA15401 |
HYBCND-N+ | 30CMX3M | RPN303B |
HYBOND-C, | 30CMX3M | RPN303C |
HYBCND-P PVDF MEMBRANE | 30CM | RPN303F |
ECL WESTERN BLOTTING REAGENTS | RPN2106 | |
ECL WESTERN BLOTTING DETECTION | RPN2209 | |
GLYCINE ULTRAPURE | 1kg | 16407 |
GLYCINE ULTRAPURE | 5kg | 16407 |
N,N'-METHYLENE-BIS-ACRYLAMIDE, | 75821 | |
TRIS, ULTRAPURE | 1kg | 75825 |
TRIS, ULTRAPURE | 5kg | 75825 |
CELL TYPE4 UV SILICA | 10MM | 80-2002-77 |
MICROSPIN G-50 COLUMNS | 250 CO | 27-5330-02 |
5NMOL CYDYE DIGE FLUOR MIN KIT | 25-8010-65 | |
SEPHADEX G-25 MEDIUM | 25 G | 17-0033-10 |
SEPHACRYL S-100 HR | 150 ML | 17-0612-10 |
BLUE SEPHAROSE 6 FAST FLOW | 500ML | 17-0948-02 |
SOURCE 30Q | 50 ML | 17-1275-01 |
SOURCE 30S | 50 ML | 17-1273-01 |
CM SEPHAROSE FAST FLOW | 25 ML | 17-0719-10 |
SOURCE 15Q, | 10 ML | 17-0947-20 |
INJECTION FILL PORT | 18-1127-66 | |
SEPHACRYL S-400 HR | 150 ML | 17-0609-10 |
KVICKLAB 1.2 FT2, 10KD SELECT | 56-4113-26 | |
HITRAP HEPARIN HP | 1 X 5 ML | 17-0407-01 |
SEPHADEX G-50 FINE | 100 G | 17-0042-01 |
SEPHACRYL S-300 HR | 150 ML | 17-0599-10 |
SOURCE 15S | 10 ML | 17-0944-10 |
SEPHADEX G-25 FINE | 100 G | 17-0032-01 |
SEPHACRYL S-200 HR | 150 ML | 17-0584-10 |
PHENYL SEPHAROSE 6 FF(LS) | 1L | 17-0965-03 |
单位名称: |
北京市朝阳区马甸桥南元辰鑫大厦
联系电话: |
Email: |
