液相色谱
带共栓、刻度的SPITZ管12mmφ
带共栓、刻度的SPITZ管12mmφ
进口
岛津
【GL-SPE 带浓缩管、共栓存储器的SPITZ管】
在GL-SPE浓缩管上,刻有校准为1.0mL或0.5mL的计量刻度,可以方便地对样品进行定容操作※
GL-SPE吸引分流装置使用SPITZ管(2种)以及GL-SPE浓缩管7mL;SPS24可使用SPITZ管12mmφ与GL-SPE浓缩管7mL;empore分流器可使用GL-SPE浓缩管10mL。
注)2.0mL以上的刻度,以及SPITZ管的刻度是用来标示基准量的
产品名称:Transmission Spectral Databases
品牌:美国PIKE公司
产品价格:面议(RMB)
PART NUMBER DESCRIPTION
008-4001 SDBS Transmission by KBr Pellet Spectral Database
(22,995 spectra)
008-4004 SDBS Transmission by Liquid Film Spectral Database
(7,018 spectra)
008-4005 SDBS Transmission by Nujol Mull Spectral Database
(21,127 spectra)
Application Based Spectral Databases
008-5002 Transmission Applications – Polymers and Polymer Additives
(1,273 spectra)
008-5003 Transmission Applications – Food Additives and Food
Packaging (1,684 spectra)
008-5004 Transmission Applications – Solvents (668 spectra)
008-5005 Transmission Applications – Organometallics and Inorganics
(1,445 spectra)
008-5006 Transmission Applications – Biochemicals (4,590 spectra)
008-5007 Transmission Applications – Aldehydes and Ketones
(4,226 spectra)
008-5008 Transmission Applications – Alcohols and Phenols
(2,744 spectra)
008-5009 Transmission Applications – Esters and Lactones
(4,335 spectra)
008-5010 Transmission Applications – Hydrocarbons (1,417 spectra)
008-5011 Transmission Applications – Flavors, Fragrances and
Cosmetic Ingredients (1,912 spectra)
008-5012 Transmission Applications – Pesticides (958 spectra)
008-5013 Transmission Applications – Semiconductor Chemicals
(664 spectra)
008-5014 Transmission Applications – Forensic (1,555 spectra)
008-5015 Transmission Applications – Dyes, Pigments and Stains
(1,473 spectra)
008-5016 Transmission Applications – Sulfur and Phosphorus
Compounds (5,025 spectra)
008-5017 Transmission Applications – Hazardous Chemicals
(2,664 spectra)
008-5018 Transmission Applications – Hazardous and Toxic Chemicals
(6,604 spectra)
008-5020 Transmission Applications – Pharmaceuticals, Drugs and
Antibiotics (2,806 spectra)
008-5021 Transmission Applications – High Production Volume (HPV)
Chemicals (1,123 spectra)
产品名称:ATR Spectral Databases
品牌:美国PIKE公司
产品价格:面议(RMB)
008-1000 Aldrich ATR Spectral Database (18,513 spectra)
008-2000 IChem ATR Spectral Database (13,557 spectra)
008-3000 Aldrich-IChem ATR Spectral Database Package (36,639 spectra)
ATR Application Specific Spectral Databases
008-3002 ATR Applications – Polymers and Polymer Additives
(4,520 spectra)
008-3003 ATR Applications – Food Additives and Food Packaging
(2,762 spectra)
008-3004 ATR Applications – Solvents (667 spectra)
008-3005 ATR Applications – Organometallics and Inorganics
(2,149 spectra)
008-3006 ATR Applications – Biochemicals (5,343 spectra)
008-3007 ATR Applications – Aldehydes and Ketones (3,482 spectra)
008-3008 ATR Applications – Alcohols and Phenols (2,671 spectra)
008-3009 ATR Applications – Esters and Lactones (4,170 spectra)
008-3010 ATR Applications – Hydrocarbons (1,175 spectra)
008-3011 ATR Applications – Flavors, Fragrances and Cosmetic
Ingredients (2,716 spectra)
008-3012 ATR Applications – Pesticides (1,820 spectra)
008-3013 ATR Applications – Semiconductor Chemicals (919 spectra)
008-3014 ATR Applications – Forensic (3,579 spectra)
008-3015 ATR Applications – Dyes, Pigments and Stains (2,857 spectra)
008-3016 ATR Applications – Sulfur and Phosphorus Compounds
(5,336 spectra)
008-3017 ATR Applications – Hazardous Chemicals (3,730 spectra)
008-3018 ATR Applications – Hazardous and Toxic Chemicals
(8,136 spectra)
008-3020 ATR Applications – Pharmaceuticals, Drugs and Antibiotics
(2,715 spectra)
008-3021 ATR Applications – High Production Volume (HPV) Chemicals
(1,315 spectra)
008-3025 ATR Applications – Coatings (1,809 spectra)
008-3026 ATR Applications – Paints (2,507 spectra)
产品名称:PIKECalc Software
品牌:美国PIKE公司
产品价格:面议(RMB)
162-5420 007-0300 PIKECalc Software
产品名称:Reference Standards
品牌:美国PIKE公司
产品价格:面议(RMB)
162-5420 1.5 mil Polystyrene Reference Standard
162-5430 3.0 mil Polystyrene Reference Standard
162-5440 55 micron Polystyrene Reference Standard
162-5450 NIST Traceable Polystyrene Reference Standard
Specular Reflectance Standard
162-5460 Specular Reflectance Standard
NIR and UV-Vis Diffuse Reflectance Standards
162-5480 Diffuse PTFE Reference (1" optical area)
162-5481 Diffuse Gold Reference (1" optical area)
162-5482 Diffuse Gold Reference (1.7" optical area)
Mid-IR Diffuse Reflectance Standards
162-5485 Mid-IR Diffuse Reflectance Wavelength Standard
162-5486 Mid-IR Diffuse Reflectance Wavelength, recertification
ATR Reference Standard
162-5470 ATR Reference Standard
162-5475 ATR Reference Standard with Recommended Validation
Procedure and Validation Certificate
162-5476 ATR Reference Standard, recertification
NIR Wavelength Standard
048-3070 Traceable NIR Reference Standard
048-3071 Traceable NIR Reference Standard, recertification
产品名称:Falcon UV-VIS
品牌:美国PIKE公司
产品价格:面议(RMB)
110-60XXX UV-Vis Falcon Base
Temperature Controllers
076-1230 Digital Temperature Control Module
076-1430 Digital Temperature Control Module PC Control (USB)
Sample Holders and Spacers
111-3610 5 mm Vial Holder
111-3620 8 mm Vial Holder
111-3630 12 mm Vial Holder
111-3640 1 cm Cuvette Holder
162-1201 Spacer for 1 mm Cuvette
162-1202 Spacer for 2 mm Cuvette
162-1205 Spacer for 5 mm Cuvette
XXX Spectrophotometer Codes
100 Agilent/Varian – Cary 50
110 Agilent/Varian – Cary 100, 300
120 Agilent/Varian – Cary 4000, 5000, 6000i
600 Jasco – 600 series
700 PerkinElmer Lambda 650, 750, 850, 950 and 1050
730 PerkinElmer – Lambda 25, 35, 45
200 Shimadzu – 1600 and 1700
210 Shimadzu – 1800 Series
400 Thermo Fisher Scientific – Evolution 300/600
410 Thermo Fisher Scientific – Evolution 200
产品名称:UV-Vis VeeMAX
品牌:美国PIKE公司
产品价格:面议(RMB)
013-10XXX UV- Vis VeeMAX Variable Angle Specular Reflectance Accessory
UV-Vis VeeMAX Replacement Parts
300-0300 UV Aluminum Mirror (25.4 mm x 25.4 mm)
013-4015 Aperture Mask Set (7 mm, 13 mm, and 25 mm x 4 mm)
 以下是美国PE产品
以下是美国PE产品
Aluminum Al N3050103 N3050303
Antimony Sb N3050170 N3050370
Arsenic As N3050105 N3050305
Barium Ba N3050109 N3050309
Beryllium Be N3050110 N3050310
Bismuth Bi N3050111 N3050311
Boron B N3050108 N3050308
Cadmium Cd N3050115 N3050315
Calcium Ca N3050114 N3050314
Chromium Cr N3050119 N3050319
Cobalt Co N3050118 N3050318
Copper Cu N3050121 N3050321
Dysprosium Dy N3050122 N3050322
Erbium Er N3050123 N3050323
Europium Eu N3050124 N3050324
Gadolinium Gd N3050129 N3050329
Gallium Ga N3050128 N3050328
Germanium Ge N3050130 N3050330
Gold Au N3050107 N3050307
Hafnium Hf N3050133 N3050333
Holmium Ho N3050135 N3050335
Indium In N3050137 N3050337
Iridium Ir N3050138 N3050338
Iron Fe N3050126 N3050326
Lanthanum La N3050141 N3050341
Lead Pb N3050157 N3050357
Lithium Li N3050142 N3050342
Magnesium Mg N3050144 N3050344
Manganese Mn N3050145 N3050345
Mercury Hg N3050134 N3050334
Molybdenum Mo N3050146 N3050346
Neodymium Nd N3050150 N3050350
Nickel Ni N3050152 N3050352
Niobium Nb N3050149 N3050349
Palladium Pd N3050158 N3050358
Phosphorus P N3050155 N3050355
Platinum Pt N3050162 N3050362
Potassium K N3050139 N3050339
Praseodymium Pr N3050161 N3050361
Rhenium Re N3050165 N3050365
Rhodium Rh N3050166 N3050366
Samarium Sm N3050174 N3050374
Scandium Sc N3050171 N3050371
Selenium Se N3050172 N3050372
Silicon Si N3050173 N3050373
Silver Ag N3050102 N3050302
Sodium Na N3050148 N3050348
Strontium Sr N3050176 N3050376
Tantalum Ta N3050177 N3050377
Tellurium Te N3050180 N3050380
Terbium Tb N3050178 N3050378
Thallium Tl N3050183 N3050383
Thulium Tm N3050184 N3050384
Tin Sn N3050175 N3050375
Titanium Ti N3050182 N3050382
Tungsten W N3050187 N3050387
Vanadium V N3050186 N3050386
Ytterbium Yb N3050190 N3050390
Yttrium Y N3050189 N3050389
Zinc Zn N3050191 N3050391
Zirconium Zr N3050192 N3050392
Silver,Gold Ag,Au N3050201 N3050401
Calcium,Magnesium Ca,Mg N3050202 N3050402
Calcium,Zinc Ca,Zn N3050203 N3050403
Potassium,Sodium K,Na N3050204 N3050404
Platinum,Ruthenium Pt,Ru N3050205 N3050405
Tin,Tellurium Sn,Te N3050206 N3050406
Calcium,Magnesium,Zinc Ca,Mg,Zn N3050208 N3050408
Copper,Iron,Nickel Cu,Fe,Ni N3050209 N3050409
Copper,Iron,Manganese,Zinc Cu,Fe,Mn,Zn N3050212 N3050412
Silver,Chromium,Copper,Iron,Nickel Ag,Cr,Cu,Fe,Ni N3050213 N3050413
Cobalt,Chromium,Copper,Manganese,Nickel Co,Cr,Cu,Mn,Ni N3050214 N3050414
Cobalt,Chromium,Copper,Iron,Manganese,Nickel Co,Cr,Cu,Fe,Mn,Ni N3050217 N3050417
Aluminum,Calcium,Copper,Iron,Magnesium,Silicon,Zinc Al,Ca,Cu,Fe,Mg,Si,Zn N3050218 N3050418
        北京博德恒悦科贸有限公司是在北京中关村注册的一家集研发、生产、销售为一体的科学仪器技术企业,并负责相关产品在中国大陆地区的技术支持、销售及专业的售后服务。
主要代理全球闻名的美国SPEX公司;德国J. Engelsmann AG公司;美国CARVER公司;德国ZOZ公司以及美国PIKE公司生产的实验室器材、消耗品等科技产品。
公司的产品广泛应用、服务于石油、化工、航空、航天、电子、冶金、环保、食品安全、医疗卫生、科研及高等院校等检测及研究机构。
北京博德恒悦科贸有限公司的理念是“一流的产品,优质的服务”,竭诚欢迎与各界同仁,有志之士进行广泛的友好合作。
北京市海淀区骚子营1号院西楼13室
