生化试剂
坦螺旋霉素
坦螺旋霉素
Tanespimycin
进口
美国/TargetMol
面议
销售商:
Product Introduction
Bioactivity
英文名: Tanespimycin
描述: Tanespimycin (KOS 953) 是一种 Hsp90 抑制剂,可选择性抑制 BT474 肿瘤细胞 Hsp90,IC50为 5 nM。它消耗细胞内 STK38/NDR1,并降低 STK38 激酶活性,还能下调stk38基因表达。
细胞实验: Cells were seeded in 96-well plates at 2,000 cells per well in a final culture volume of 100 μl for 24 h before the addition of increasing concentrations of 17-AAG that was incubated for 5 days. Viable cell number was determined using the Celltiter 96 AQueous Nonradioactive Cell Proliferation Assay. The value of the background absorbance at 490 nm (A490) of wells not containing cells was subtracted. Percentage of viable cells ? (A490 of 17-AAG treated sample/A490 untreated cells) × 100. The IC50 was defined as the concentration that gave rise to 50% viable cell number [1].
激酶实验: Purified native Hsp90 protein or cell lysates in lysis buffer (20 mM HEPES, pH 7.3, 1 mM EDTA, 5 mM MgCl2, 100 mM KCl) were incubated with or without 17-AAG for 30 min at 4 °C, and then incubated with biotin-GM linked to streptavidin magnetic beads for 1 h at 4 °C. Tubes were placed on a magnetic rack, and the unbound supernatant removed. The magnetic beads were washed three times in lysis buffer and heated for 5 min at 95 °C in SDS–PAGE sample buffer. Samples were analyzed on SDS protein gels, and western blots done using indicated antibodies. Bands in the western blots were quantified, and the percentage inhibition of binding of Hsp90 to the biotin-GM was calculated. The IC50 reported is the concentration of 17-AAG needed to cause half-maximal inhibition of binding. For in vitro reconstitution, 5 μM of purified Hsp90 was combined with 1 μM each of Hsp70, Hsp40, p23, and Hop purified proteins [1].
动物实验: B10.BR mice were inoculated with 5×10^5 lymphoma cells through intraperitoneal injection. Seven days following tumor implantation, the mice were I.P. injected with 17-AAG or vehicle (10% DMSO + 40% Cremophor EL: Ethanol (3:1) (v/v) + 50 % PBS) every other day for three weeks. At the cessation of treatment, mice were monitored up to 80 days post tumor cell injection. To determine the effects of 17-AAG on lymphoma initiation in vivo, secondary B10.BR recipient mice were implanted by intraperitoneal injection of 1×10^5 lymphoma cells from the spleens of first-round mice that had been treated with 17-AAG or vehicle. These mice were followed up to 160 days post tumor cell injection to monitor differences in tumor initiation between the mice [4].
体外活性: Hsp90 derived from tumour cells has a 100-fold higher binding affinity for 17-AAG than does Hsp90 from normal cells. In vitro reconstitution of chaperone complexes with Hsp90 resulted in increased binding affinity to 17-AAG, and increased ATPase activity [1]. 17-AAG caused the degradation of HER2, Akt, and both mutant and wild-type AR and the retinoblastoma-dependent G1 growth arrest of prostate cancer cells [2]. Combined 17-AAG and Trastuzumab treatment of ErbB2-overexpressing breast cancer cell lines leads to enhanced ubiquitinylation, downregulation from the cell surface and lysosomal degradation of ErbB2 [3].
体内活性: At non-toxic doses, 17-AAG caused a dose-dependent decline in AR, HER2, and Akt expression in prostate cancer xenografts. This decline was rapid, with a 97% loss of HER2 and an 80% loss of AR expression at 4 h [2]. In contrast, spleens from mice which had received 17-AAG (5 to 40 mg/kg) were dramatically smaller, with less infiltrating lymphoma cells in the spleen, and a lower metastatic spread into other organs, as compared to the vehicle-treated control. In addition, 17-AAG treated mice survived significantly longer compared to mice which had received vehicle alone [4].
存储条件: Powder: -20°C for 3 years | In solvent: -80°C for 1 year
溶解度: DMSO : 58.6 mg/mL (100 mM)
关键字: tumor | stk38 | Inhibitor | KOS953 | cancer | prostate | HSP | Heat shock proteins | Mitophagy | NSC-330507 | Mitochondrial Autophagy | Tanespimycin | Apoptosis | CP127374 | inhibit | Autophagy | CP-127374 | HER2 | KOS-953 | A549 | NSC330507 | Bacterial | Antibiotic
相关产品: Sulfasalazine | Quercetin Dihydrate | Levistolide A | Ethoxysanguinarine | Entinostat | INH6 | Benzbromarone | CDKI-73 | LCS3 | Angiotensin II human
相关库: Drug Repurposing Compound Library | Anti-Cancer Drug Library | Clinical Compound Library | Inhibitor Library | Anti-Cancer Clinical Compound Library | Kinase Inhibitor Library | Anti-Cancer Active Compound Library | Highly Selective Inhibitor Library | Hematonosis Compound Library | Microbial Natural Product Library
TargetMol(陶术)作为一家全球性的生物医药领域高科技企业,我们致力于为高校、研究所、医院、企业等各类生物医药研发机构提供优质的产品和服务,为全球医药科学家更高效地完成科研工作助力。可提供20,000+种 抑制剂和激动剂 、800+种 化合物库 、19,000+种 天然产物 ,以及9,000+种 重组蛋白 、多种 多肽 、抗体 和 生命科学试剂盒 等。此外,在上海,TargetMol研发中心配备了 CADD & AIDD研究中心、药理实验室和药物化学合成 平台三大技术中心,可提供虚拟筛选、化合物活性测试、分子间结合力检测和化合物结构优化等技术服务,多方位满足用户的研发需求。
静安区江场三路238号
