生化试剂
枸橼酸铋钾
枸橼酸铋钾
Bismuth Subcitrate Potassium
进口
美国/TargetMol
面议
销售商:
Product Introduction
Bioactivity
英文名: Bismuth Subcitrate Potassium
描述: Bismuth subcitrate potassium 是针对 12 种幽门螺杆菌菌株的抗生素,MIC50为 8 μg/ml。它用于幽门螺杆菌感染的上胃肠道疾病的研究。
体外活性: Colloidal Bismuth Subcitrate is crystallized in dilute HCl at pH 3, and unique assembly of three basic bismuth citrate dimeric units ([Bi(cit)2Bi]2-) leads to the formation of two-dimensional sheets and 3D polymer, the solubility of Colloidal Bismuth Subcitrate in water is found to be dramatically affected by pH, from >70 mg/mL at pH 7 to only about 1 mg/mL at pH 3. [1] Bismuth Subcitrate is effective against the 12 C. pyloridis strains with MIC50 of 8 μg/mL. Bismuth Subcitrate combined with oxolinic acid exhibits synergistic activity against the 12 C. pyloridis strains. [2] Colloidal bismuth subcitrate (5 mg/mL) significantly increases the frequencies of sister-chromatid exchange (SCE) and micronucleus rate in peripheral lymphocytes compared with controls in human whole blood cultures. [3] Bismuth Subcitrate (100 μM) inhibits Helicobacter pyloriF1-ATPase activity, and inhibition is prevented and reversed by the mercaptan glutathione, indicating that Bismuth Subcitrate interfere with sulfhydryl groups of the enzyme. [4] Colloidal Bismuth Subcitrate (150 mg/mL) inhibits the lipolytic activity of C. pylori filtrate, causing a 21% reduction in lipase activity and a 60% reduction in the activity of phospholipase A. [5]
存储条件: Powder: -20°C for 3 years | In solvent: -80°C for 1 year
溶解度: H2O : 127.8 mM
关键字: inhibit | Inhibitor | Bismuth subcitrate | Antibiotic | Bacterial | Bismuth Subcitrate Potassium
相关产品: Diiodohydroxyquinoline | Erythromycin estolate | Lauramine oxide | Sulbactam sodium | Dimboa | Crystal Violet | Berberine chloride hydrate | Diaveridine | 6-AZATHYMINE | Heraclenol
TargetMol(陶术)作为一家全球性的生物医药领域高科技企业,我们致力于为高校、研究所、医院、企业等各类生物医药研发机构提供优质的产品和服务,为全球医药科学家更高效地完成科研工作助力。可提供20,000+种 抑制剂和激动剂 、800+种 化合物库 、19,000+种 天然产物 ,以及9,000+种 重组蛋白 、多种 多肽 、抗体 和 生命科学试剂盒 等。此外,在上海,TargetMol研发中心配备了 CADD & AIDD研究中心、药理实验室和药物化学合成 平台三大技术中心,可提供虚拟筛选、化合物活性测试、分子间结合力检测和化合物结构优化等技术服务,多方位满足用户的研发需求。
静安区江场三路238号
