生化试剂
洋橄榄叶素
洋橄榄叶素
Elaiophylin
进口
美国/TargetMol
面议
销售商:
Product Introduction
Bioactivity
英文名: Elaiophylin
描述: Elaiophylin (Salbomycin) 是一种自噬抑制剂,在卵巢癌细胞中有抗肿瘤活性。它对 Plasmodium falciparum K1a 和 Trypanosoma brucei brucei GUTat 3.1 菌株具有抗原生动物活性,IC50 分别为 0.36 μM 和 0.45 μM。
细胞实验: The adherent mouse fibroblast cell line L-929 is cultured in Eagle's MEM with 0.35 mg/mL sodium bicarbonate, 100 units/mL penicillin/100 μg/mL streptomycin, 10 mM HEPES, and 10% heat-inactivated FBS at 37 °C in culture flasks. The adherent cells are harvested at the logarithmic growth phase after trypsination using 0.05% trypsin in phosphate-buffered saline (PBS) containing 0.02% EDTA. The nonadherent human leukemia cell line K-562, is cultured in RPMI 1640 medium, supplemented with 100 units/mL penicillin/100 μg/mL streptomycin and 10% FBS in culture flasks. L-929 and K-562 cells are inoculated in 0.1 mL culture medium, containing NaHCO3 without HEPES, per well of the 96-well microplates. The plates are previously prepared with dilutions of the Azalomycin-B in 0.1 mL medium. The microplates are kept for 72 hour at 37 °C in a humidified atmosphere containing 5% CO2. The adherent human cell line HeLa is cultured in MEM Eagle with 100 units/mL penicillin/100 μg/mL streptomycin, 10% FBS, and 2 mM l-glutamine in vented culture flasks. The adherent cells are harvested during the logarithmic growth phase after trypsination with 0.4% trypsin in PBS containing 0.02% EDTA. These cells are seeded with in 0.1 mL culture medium per well of the 96-well microplates. HeLa cells are preincubated 48 hours without Azalomycin-B. The dilutions of Azalomycin-B are carried out on the monolayer of HeLa cells after preincubation time. After incubation, the monolayer of the adherent L-929 and HeLa cells are fixed by glutaraldehyde and stained with a 0.05% solution of methylene blue for 15 minutes. After washing the stain is eluted by 0.2 mL of 0.33 N HCl in the wells. The optical densities are measured at 630 nm in a Dynatech MR 7000 microplate reader. After incubation, the K-562 cells are analyzed using an electronic cell analyzer system CASY 1 and software CASYSTAT for determination of IC50 values. The IC50 values are determined by integrated software CASYSTAT. (Only for Reference)
体外活性: Azalomycin-B possesses an antibacterial activity against Gram-positive bacteria. The minimum inhibitory concentration (MIC) of Azalomycin-B against Staphylococcus aureus (SG 511, 285 and 503) is 1.52 μM. The MIC of Azalomycin-B against Streptococcus pyogenes is 0.76 μM and 1.52 μM for strains 306A, and 77A, respectively. The MIC of Azalomycin-B against S. faecium A is 3.05 μM. [1] In vitro, Azalomycin-B shows an antibiotic activity as a rumen fermentation efficiency enhancer and also inhibits lactic acid production in the rumen fluid with IC5O of 2.14 μM. [2] Azalomycin-B inhibits P-type ATPases such as the P-type, K+-dependent ATPase from Escherichia coli, without affecting F-type and V-type ATPases at all. [3] Azalomycin-B shows the potent cytotoxic effect on L929 mouse fibroblast cells, K562 human leukemia cells and HeLa cell cultures with IC50 of 0.29 μM, 0.19 μM and 0.29 μg/mL, respectively. [4] Moreover, Azalomycin-B also produces the cytotoxicity in MRC-5 cells with IC50 of 0.85 μM. [5]
存储条件: Powder: -20°C for 3 years | In solvent: -80°C for 1 year
溶解度: H2O : <1 mg/mL
Ethanol : 5 mg/mL (4.87 mM)
DMSO : 49 mg/mL (47.79 mM)
关键字: Inhibitor | Elaiophylin | Autophagy | inhibit
相关产品: AGN 196996 | Enzastaurin | 3BDO | Nortriptyline hydrochloride | Betulinic acid | Atezolizumab | Doxorubicin hydrochloride | Schisandrol B | MRT68921 HCl | Cisplatin
TargetMol(陶术)作为一家全球性的生物医药领域高科技企业,我们致力于为高校、研究所、医院、企业等各类生物医药研发机构提供优质的产品和服务,为全球医药科学家更高效地完成科研工作助力。可提供20,000+种 抑制剂和激动剂 、800+种 化合物库 、19,000+种 天然产物 ,以及9,000+种 重组蛋白 、多种 多肽 、抗体 和 生命科学试剂盒 等。此外,在上海,TargetMol研发中心配备了 CADD & AIDD研究中心、药理实验室和药物化学合成 平台三大技术中心,可提供虚拟筛选、化合物活性测试、分子间结合力检测和化合物结构优化等技术服务,多方位满足用户的研发需求。
静安区江场三路238号
