细胞生物学试剂
PureCol®EZGel即用型胶原蛋白溶液
ready-to-use collagen solution
进口
进口/Equl-ADVANCEDBIO
系列
优惠
PureCol®EZGel是一种即用型胶原蛋白溶液,只需在培养箱中加热至37°C即可形成牢固的凝胶。该产品由浓度为0.5%(〜5 mg / ml)的纯化的I型胶原蛋白,DMEM / F-12培养基以及L-谷氨酰胺和二肽(L-丙氨酸-L-谷氨酰胺)的混合物组成用于细胞培养的长效L-谷氨酰胺来源。
PureCol®EZGel旨在通过预先配制培养基并将产品调节至中性pH值来提高凝胶稠度。该产品避免了由于试剂添加,pH值调整和处理条件等因素引起的凝胶制备中的不一致。
PureCol®EZGel是提供牢固凝胶的理想选择,也可用于制备用于培养细胞的薄层。 PureCol®EZ Gel胶原蛋白以易于使用的包装形式提供,以供使用和存储。该产品是无菌的,可作为即用型溶液提供。
参数,测试和方法PureCol®EZ Gel I型胶原蛋白#5074
灭菌方法过滤
提取方法酶-端胶原
表格解决方案
包装尺寸35毫升
储存温度2-10°C
自收到之日起至少六个月的保质期
胶原蛋白浓度-双缩脲〜5 mg / mL
胶原蛋白纯度-银染色> 99%
pH值6.9-7.4
动凝胶测试(分钟)<40
凝胶形成管测试(分钟)<40
原纤维形成(吸光度单位)> 0.5
电泳图谱-考马斯亮蓝特征
无菌-USP改良无增长
内毒素-LAL <1.0 EU / mL
渗透压(mOsmo H2O / kg)300-360
细胞附着分析合格
来源牛皮
水凝胶杨氏模量E(Pa)特性
中等补品DMEM / F-12
L-谷氨酰胺和二肽(L-丙氨酸-L-谷氨酰胺)的L-谷氨酰胺来源混合物
Product Description
PureCol® EZ Gel is a ready-to-use collagen solution that forms a firm gel by simply warming to 37°C in an incubator.  The product consists of purified Type I collagen at a concentration of 0.5%, (~5 mg/ml), DMEM/F-12 medium and a mixture of L-glutamine and dipeptide (L-alanine-L-glutamine) to provide a long-lasting L-glutamine source for cell culture.
PureCol® EZ Gel is designed to improve gel consistency by pre-formulation of the medium and adjustment of the product to a neutral pH. This product avoids the inconsistencies in the preparation of the gel that can arise through variables of reagent addition, pH adjustment and handling conditions.
PureCol® EZ Gel is ideal for providing a firm gel and can also be used in the preparation of a thin layer for culturing cells.  PureCol® EZ Gel collagen is provided in a user-friendly packaging for use and storage. This product is sterile and supplied as a ready to use solution.
Parameter, Testing, and Method PureCol® EZ Gel Type I Collagen #5074
Sterilization Method Filtration
Extraction Method Enzyme - atelocollagen
Form Solution
Package Size 35 mL
Storage Temperature 2-10°C
Shelf Life Minimum of 6 months from date of receipt
Collagen Concentration - Biuret ~5 mg/mL
Collagen Purity - Silver Staining >99%
pH 6.9-7.4
Kinetic Gel Test (Minutes) <40
Gel Formation Tube Test (Minutes) <40
Fibrillogenesis (Absorbance Units) >0.5
Electrophoretic Pattern - Coomassie Blue Characteristic
Sterility - USP modified No growth
Endotoxin - LAL <1.0 EU/mL
Osmolality (mOsmo H2O/kg) 300-360
Cell Attachment Assay Pass
Source Bovine Hide
Hydrogel Young's Modulus E (Pa) Characteristic
Medium Supplement DMEM/F-12
L-Glutamine Source Mixture of L-Glutamine and Dipeptide (L-alanine-L-glutamine)
我们提供世界著名品牌的百万种优质产品:
部分仪器>
三维细胞组织培养系统
微囊发生器
微量注射器、助吸器
转定子式均质器、碾槌式匀质器、混涡混合器、旋转器、细胞破碎器、振荡器、搅拌器
加热套
吸入暴露系统/气溶胶发生器
所售仪器类商品,保修一年,终身维修。
上海市徐汇区云锦路500号绿地汇中心A座809,在中国主要城市有销售支持,见www.equl.cn
2380088352, 390113670
上海:021-64280805
