Epimedin A 朝藿定A 标准品 110623-72-8
本品为分析标准品。
注意事项:储备液建议分装冻存,避免反复冻融(-20℃,1个月);稀释后的工作液建议现用现配/It is recommended to freeze the stock solution in several small portions to avoid repeated freezing and thawing (- 20 ℃, 1 month); The working solution is recommended to be used immediately after dilution
其他产品:
| 草甘瞬 标准品 | 100mg | 瓶 |
| Taurodeoxycholic acid sodium salt;牛磺猪去氧胆酸钠 | 20mg | 瓶 |
| Methyl hesperidin;甲基橙皮苷 | 20mg | 瓶 |
| Succinic acid;琥珀酸 | 20mg | 瓶 |
| Succinic acid;琥珀酸 | 100mg | 瓶 |
| Maleic acid;马来酸 | 20mg | 瓶 |
| trans-2-Butenedioic Acid;延胡索酸/(E)-2-丁烯二酸/富马酸 | 20mg | 瓶 |
| trans-2-Butenedioic Acid;延胡索酸/(E)-2-丁烯二酸/富马酸 | 200mg | 瓶 |
| Ginsenoside Rb2;人参皂苷Rb2 | 20mg | 瓶 |
| Ginsenoside Rc;人参皂苷Rc | 20mg | 瓶 |
| Ethyl Decanoate;癸酸乙酯 | 1mL | 瓶 |
| Sorbic acid;山梨酸 | 250mg | 瓶 |
| Epimedin A;朝藿定A | 20mg | 瓶 |
| Epimedin B;朝藿定B | 20mg | 瓶 |
| Epmedin C;朝藿定C | 20mg | 瓶 |
| Maltotriose;麦芽三糖 | 100mg | 瓶 |
| Zileuton;齐留通 | 100mg | 瓶 |
| AmLodipine Besylate;苯磺酸氨氯地平 | 100mg | 瓶 |
| Metformin Hydrochloride;盐酸二甲双胍 | 200mg | 瓶 |
| L-Argininine monohydrocholoride;L-精氨酸盐酸盐 | 200mg | 瓶 |
| Methyl Arachidate;花生酸甲酯 | 250mg | 瓶 |
| 20(R)Ginsenoside Rh2;(R型)人参皂苷Rh2 | 20mg | 瓶 |
| Decyl alcohol;1-癸醇 | 100mg | 瓶 |
