Teflo PTFE 膜片
Description | Zefluor™ Membrane | Teflo Membrane | Zylon™ Membrane | TF (PTFE) Membrane |
Filter Media/Support | PTFE with PTFE support |
PTFE with PMP (polymethyl- pentene) support ring |
Unsupported PTFE | PTFE on a polypropylene support |
Typical Thickness | 0.5 μm: 178 μm (7 mils) 1 μm: 165 μm (6.5 mils) 2 and 3 μm: 152 μm (6 mils) |
1 μm: 76 μm (3 mils) 2 μm: 46 μm (1.8 mils) 3 μm: 30.4 μm (1.2 mils) |
140 μm (5.5 mils) | 0.2 μm: 139 μm (5.5 mils) 0.45 and 1 μm: 135 μm (5.3 mils) |
Typical Air Flow Rate L/min/cm2 at 0.7 bar (70 kPa, 10 psi) |
0.5 μm: 1 1 μm: 14.6 2 μm: 25.3 3 μm: 53 |
1 μm: 17 2 μm: 53 3 μm: 90 |
5 μm: 13 | 0.2 μm: 2 0.45 μm: 3 1 μm: 7 |
Minimum Bubble Point - IPA bar (psi) |
Not applicable | Not applicable | Not applicable | 0.2 μm: 1.0 (15) 0.45 μm: 0.4 (6) 1 μm: 0.1 (2) |
Water Breakthrough bar (psi) |
Not applicable | Not applicable | Not applicable | 0.2 μm: 2.8 (40) 0.45 μm: 1.1 (16) 1 μm: 1.0 (15) |
Typical Aerosol Retention* | 0.5, 1, and 2 μm: 99.99% 3 μm: 99.98% |
1 and 2 μm: 99.99% 3 μm: 99.79% |
*Following ASTM D 2986-95A 0.3 μm (DOP) at 32 L/min/100 cm2 filter media. |
Part Number | Description | Pkg | ||
Zefluor and Zylon Membrane Disc Filters | ||||
P5PQ025 | Zefluor, 0.5 μm, 25 mm | 100/pkg | ||
P5PQ047 | Zefluor, 0.5 μm, 47 mm | 50/pkg | ||
P5PL025 | Zefluor, 1 μm, 25 mm | 100/pkg | ||
P5PL037 | Zefluor, 1 μm, 37 mm, with support pads | 50/pkg | ||
P5PL047 | Zefluor, 1 μm, 47 mm | 50/pkg | ||
P5PL090 | Zefluor, 1 μm, 90 mm | 50/pkg | ||
P5PL001 | Zefluor, 1 μm, 8 x 10 in. | 25/pkg | ||
60048 | Zefluor, 2 μm, 25 mm | 100/pkg | ||
P5PJ037 | Zefluor, 2 μm, 37 mm, with support pads | 50/pkg | ||
P5PJ047 | Zefluor, 2 μm, 47 mm | 50/pkg | ||
60224 | Zefluor, 2 μm, 70 mm | 25/pkg | ||
P5PJ001 | Zefluor, 2 μm, 8 x 10 in. | 25/pkg | ||
60230 | Zefluor, 3 μm, 50 mm | 50/pkg | ||
60214 | Zefluor, 3 μm, 63 mm | 100/pkg | ||
60537 | Zefluor, 3 μm, 90 mm | 25/pkg | ||
P5PI001 | Zefluor, 3 μm, 8 x 10 in. | 25/pkg | ||
P4PH037 | Zylon, 5 μm, 37 mm, with support pads | 50/pkg | ||
P4PH047 | Zylon, 5 μm, 47 mm | 50/pkg | ||
Teflo Membrane Disc Filters | ||||
R2PL037 | 1 μm, 37 mm | 50/pkg | ||
R2PL047 | 1 μm, 47 mm | 50/pkg | ||
R2PJ037 | 2 μm, 37 mm | 50/pkg | ||
R2PJ041 | 2 μm, 41 mm | 50/pkg | ||
R2PJ047 | 2 μm, 47 mm | 50/pkg | ||
R2PI025 | 3 μm, 25 mm | 50/pkg | ||
60146 | 3 μm, 47 mm | 50/pkg | ||
TF (PTFE) Membrane | ||||
66141 | TF 200, 0.2 µm, 13 mm | 100/pkg | ||
66142 | TF 200, 0.2 µm, 25 mm | 100/pkg | ||
66143 | TF 200, 0.2 µm, 47 mm | 100/pkg | ||
66630 | TF 200, 0.2 µm, 50 mm | 100/pkg | ||
66145 | TF 200, 0.2 µm, 142 mm | 25/pkg | ||
66146 | TF 200, 0.2 µm, 293 mm | 25/pkg | ||
66147 | TF 450, 0.45 µm, 13 mm | 100/pkg | ||
66148 | TF 450, 0.45 µm, 25 mm | 100/pkg | ||
66149 | TF 450, 0.45 µm, 47 mm | 100/pkg | ||
66631 | TF 450, 0.45 µm, 50 mm | 100/pkg | ||
66151 | TF 450, 0.45 µm, 142 mm | 25/pkg | ||
66152 | TF 450, 0.45 µm, 293 mm | 25/pkg | ||
66153 | TF 1000, 1 µm, 13 mm | 100/pkg | ||
66154 | TF 1000, 1 µm, 25 mm | 100/pkg | ||
66159 | TF 1000, 1 µm, 37 mm, with support pads | 100/pkg | ||
66155 | TF 1000, 1 µm, 47 mm | 100/pkg | ||
66158 | TF 1000, 1 µm, 293 mm | 25/pkg |
