其他生物试剂
NIST系列产品-陶瓷和硬质合金维氏硬度
Vickers Hardness, Ceramics and Hardmetals
进口
NIST
40 g
ZSR-2831 陶瓷和硬质合金维氏硬度 Vickers Hardness, Ceramics and Hardmetals each
ZSR-2841 半导体薄膜:AlxGa1-XAS外延层 Semiconductor Thin Film: AlxGa1-xAs Epitaxial Layers
(Al mole fraction x near 0.20)
disk
ZSR-2842 半导体薄膜:AlxGa1-XAS外延层 Semiconductor Thin Film: AlxGa1-xAs Epitaxial Layers
(Al mole fraction x near 0.30)
disk
ZSR-2855 聚乙烯中的添加元素 Additive Elements in Polyethylene 3 Levels, 80 g each
ZSR-2859 Restricted Elements in Polyvinyl Chloride Restricted Elements in Polyvinyl Chloride 25 g
ZSR-2861 Restricted Elements in Polyvinyl Chloride Restricted Elements in Polyvinyl Chloride 25 g
ZSR-2891 乙醇水溶液(NOM。,0.02%) Ethanol-Water Solution
(Nominal Mass Fraction 0.02 %)
5 x 1.2 mL
ZSR-2892 乙醇水溶液(NOM。,0.04%) Ethanol-Water Solution
(Nominal Mass Fraction 0.04 %)
5 x 1.2 mL
ZSR-2893a Ethanol-Water Solution (Nominal Mass Fraction 0.08 %) Ethanol-Water Solution
5 x 1.2 mL
ZSR-2895 乙醇水溶液(NOM。,0.2%) Ethanol-Water Solution
(Nominal Mass Fraction 0.2 %)
5 x 1.2 mL
ZSR-2896 乙醇水溶液(NOM。,0.3%) Ethanol-Water Solution
(Nominal Mass Fraction 0.3 %)
5 x 1.2 mL
ZSR-2897a 乙醇水溶液(标称质量分数2%) Ethanol-Water Solution
(Nominal Mass Fraction 2 %)
5 x 10 mL
ZSR-2898a 乙醇水溶液,(标称质量分数6%) Ethanol-Water Solution
(Nominal Mass Fraction 6 %)
5 x 10 mL
ZSR-2899a 乙醇-水溶液,(质量标称25%)[危险品] Ethanol-Water Solution
(Nominal Mass Fraction 25 %)
5 x 10 mL
ZSR-2900 乙醇-水溶液,(标称95.6%)[危险品] Ethanol-Water Solution
(Nominal Mass Fraction 95.6 %)
5 x 10 mL
ZSR-2910b 羟基磷灰石 Hydroxyapatite 2 g
ZSR-2940a 荧光光谱的相对强度校正标准:橙色发射 Relative Intensity Correction Standard for Fluorescence Spectroscopy: Orange Emission solid glass cuvette
ZSR-2941a 荧光光谱的相对强度校正标准:绿色发射 Relative Intensity Correction Standard for Fluorescence Spectroscopy: Green Emission solid glass cuvette
ZSR-2944 相对强度校正标准荧光光谱仪:红色发射 Relative Intensity Correction Standard for Fluorescence Spectroscopy: Red Emission each(12.5 x 12.5 x 45)mm
ZSR-2971 24R,25-Dihydroxyvitamin D3 Calibration Solution[干冰运输&危险品] 24R,25-Dihydroxyvitamin D3 Calibration Solution 5 ampoules x 1 mL
ZSR-2973 Vitamin D Metabolites in Frozen Human Serum (High Level)[干冰运输] Vitamin D Metabolites in Frozen Human Serum (High Level) 2 vials x 1 mL
ZSR-2975 柴油颗粒物 Diesel Particulate Matter (Industrial Forklift) 1 g
ZSR-3030 单甲基胂酸标准溶液 Monomethylarsonic Acid Standard Solution 2 x 5 mL
ZSR-3031 二甲基胂酸标准溶液 Dimethylarsinic Acid Standard Solution 2 x 5 mL
ZSR-3033 砷甜菜碱标准溶液 Arsenobetaine Standard Solution 2 x 5 mL
ZSR-3034 Arsenocholine标准溶液 Arsenocholine Standard Solution 2 x 5 mL
ZSR-3035 Arsenic Species in Apple Juice[干冰运输] Arsenic Species in Apple Juice 5 x 1.5 mL
ZSR-3036 Arsenic Acid (AsV) Standard Solution[危险品] Arsenic Acid (AsV) Standard Solution 2 x 10 mL
ZSR-3037 Arsenous Acid (AsIII) Standard Solution[危险品] Arsenous Acid (AsIII) Standard Solution 2 x 10 mL
ZSR-3060 Monoester Phthalates in Acetonitrile[危险品] Monoester Phthalates in Acetonitrile 5 ampoules x 1.2 mL
ZSR-3077 多氯联苯1242变压器油 Aroclor 1242 in Transformer Oil 5x1.2 mL
ZSR-3079 多氯联苯1254变压器油 Aroclor 1254 in Transformer Oil 5x1.2 mL
ZSR-3080 多氯联苯1260变压器油 Aroclor 1260 in Transformer Oil 5x1.2 mL
ZSR-3101a 铝(Al)标准溶液[危险品] Aluminum (Al) Standard Solution 5 x 10 mL
ZSR-3104a Barium (Ba) Standard Solution[危险品] Barium (Ba) Standard Solution 5 x 10 mL
ZSR-3105a 铍(Be)标准溶液[危险品] Beryllium (Be) Standard Solution 5 x 10 mL
ZSR-3107 硼(B)标准溶液(标称为5mg / g) Boron (B) Standard Solution 50 mL
ZSR-3108 镉(Cd)标准溶液[危险品] Cadmium (Cd) Standard Solution 5 x 10 mL
ZSR-3109a 钙(Ca)标准溶液[危险品] Calcium (Ca) Standard Solution 5 x 10 mL
ZSR-3110 铈(Ce)标准溶液[危险品] Cerium (Ce) Standard Solution 5 x 10 mL
ZSR-3111a 铯(Cs)标准溶液[危险品] Cesium (Cs) Standard Solution 5 x 10 mL
ZSR-3112a 铬(Cr)标准溶液[危险品] Chromium (Cr) Standard Solution 5 x 10 mL
ZSR-3114 铜(Cu)标准溶液[危险品] Copper (Cu) Standard Solution 5 x 10 mL
ZSR-3116a 铒标准溶液[危险品] Erbium (Er) Standard Solution 5 x 10 mL
ZSR-3118a 钆(Gd)标准溶液[危险品] Gadolinium (Gd) Standard Solution 5 x 10 mL
ZSR-3119a 镓(Ga)标准溶液[危险品] Gallium (Ga) Standard Solution 5 x 10 mL
ZSR-3120a 锗标准溶液[危险品] Germanium (Ge) Standard Solution 50 mL
ZSR-3121 金(Au)标准溶液[危险品] Gold (Au) Standard Solution 5 x 10 mL
ZSR-3122 铪(Hf)标准溶液[危险品] Hafnium (Hf) Standard Solution 50 mL
ZSR-3123a 钬(Ho)标准溶液[危险品] Holmium (Ho) Standard Solution 5 x 10 mL
ZSR-3127a 镧(La)标准溶液[危险品] Lanthanum (La) Standard Solution 5 x 10 mL
ZSR-3128 铅(Pb)标准溶液[危险品] Lead (Pb) Standard Solution 5 x 10 mL
ZSR-3129a 锂(Li)标准溶液[危险品] Lithium (Li) Standard Solution 5 x 10 mL
ZSR-3130a 镥(Lu)标准溶液[危险品] Lutetium (Lu) Standard Solution 5 x 10 mL
ZSR-3131a 镁(Mg)标准溶液[危险品] Magnesium (Mg) Standard Solution 5 x 10 mL
ZSR-3132 锰(Mn)标准溶液[危险品] Manganese (Mn) Standard Solution 5 x 9 mL
ZSR-3133 汞(Hg)标准溶液[危险品] Mercury (Hg) Standard Solution 5 x 10 mL
ZSR-3134 钼(Mo)标准溶液[危险品] Molybdenum (Mo) Standard Solution 5 x 10 mL
ZSR-3135a 钕(Nd)标准溶液[危险品] Neodymium (Nd) Standard Solution 5 x 10 mL
ZSR-3136 镍(Ni)标准溶液[危险品] Nickel (Ni) Standard Solution 5 x 10 mL
ZSR-3137 铌(Nb)标准溶液[危险品] Niobium (Nb) Standard Solution 50 mL
ZSR-3139a 磷(P)标准溶液[危险品] Phosphorus (P) Standard Solution 5 x 10 mL
ZSR-3140 铂(Pt)标准溶液[危险品] Platinum (Pt) Standard Solution 5 x 10 mL
ZSR-3141a 钾(K)标准溶液[危险品] Potassium (K) Standard Solution 5 x 10 mL
ZSR-3142a 镨 (Pr) 标准溶液[危险品] Praseodymium (Pr) Standard Solution 5 x 10 mL
ZSR-3143 铼 (Re) 标准溶液[危险品] Rhenium (Re) Standard Solution 5 x 10 mL
ZSR-3145a 铷(Rb)标准溶液[危险品] Rubidium (Rb) Standard Solution 5 x 10 mL
ZSR-3147a 钐 (Sm) 标准溶液[危险品] Samarium (Sm) Standard Solution 5 x 10 mL
ZSR-3148a 钪(Sc)标准溶液[危险品] Scandium (Sc) Standard Solution 5 x 10 mL
ZSR-3149 硒(Se)标准溶液[危险品] Selenium (Se) Standard Solution 5 x 10 mL
ZSR-3151 银(Ag)标准溶液[危险品] Silver (Ag) Standard Solution 5 x 10 mL
ZSR-3152a 钠(Na)标准溶液[危险品] Sodium (Na) Standard Solution 50 mL
ZSR-3155 钽(Ta)标准溶液[危险品] Tantalum (Ta) Standard Solution 50 mL
ZSR-3156 Tellurium (Te) Standard Solution[危险品] Tellurium (Te) Standard Solution 5 x 10 mL
ZSR-3157a 铽(Tb)标准溶液[危险品] Terbium (Tb) Standard Solution 5 x 10 mL
ZSR-3158 Thallium (Tl) Standard Solution[危险品] Thallium (Tl) Standard Solution 5 x 10 mL
ZSR-3161a 锡(Sn)标准溶液[危险品] Tin (Sn) Standard Solution 50 mL
ZSR-3164 Uranium (U) Standard Solution (Radioactive)[危险品] Uranium (U) Standard Solution
(Radioactive)
5 x 10 mL
ZSR-3165 Vanadium (V) Standard Solution [危险品] Vanadium (V) Standard Solution 5 x 10 mL
ZSR-3166a 镱(Yb)标准溶液[危险品] Ytterbium (Yb) Standard Solution 5 x 10 mL
ZSR-3167a 钇(Y)标准溶液[危险品] Yttrium (Y) Standard Solution 5 x 10 mL
ZSR-3168a Zinc (Zn) Standard Solution[危险品] Zinc (Zn) Standard Solution 5 x 10 mL
ZSR-3177 氯化汞标准溶液[危险品] Mercuric Chloride (HgCl2) Standard Solution 5 x 10 mL
ZSR-3181 硫酸根离子标准溶液 Sulfate Anion (SO42–) Standard Solution 5 x 10 mL
ZSR-3182 氯离子标准溶液 Chloride Anion (Cl–) Standard Solution 5 x 10 mL
ZSR-3183 Fluoride Anion (F-) Standard Solution Fluoride Anion (F–) Standard Solution 50 mL
ZSR-3184 溴离子标准溶液 Bromide Anion (Br–) Standard Solution 5 x 10 mL
ZSR-3185 硝酸根离子标准溶液 Nitrate Anion (NO3–) Standard Solution 5 x 10 mL
ZSR-3186 Phosphate Anion (PO43-) Standard Solution Phosphate Anion (PO43–) Standard Solution 5 x 10 mL
ZSR-3222 Cigarette Tobacco Filler Cigarette Tobacco Filler 20 x 10 g
ZSR-3232 Kelp Powder (Thallus laminariae) Kelp Powder (Thallus laminariae) 3 x 5 g
ZSR-3233 强化早餐麦片 Fortified Breakfast Cereal 60 g each
ZSR-3234 大豆粉 Soy Flour 50 g
ZSR-3235 Soy Milk Soy Milk 10 x 10 mL
ZSR-3246 银杏叶(叶) Ginkgo biloba (Leaves) 5 X 3 g
ZSR-3247 Ginkgo biloba (Extract) Ginkgo biloba (Extract) 5 x 1 g
ZSR-3248 银杏含片 Ginkgo-Containing Tablets 5 x 1 g
ZSR-3250 锯齿草(果) Saw Palmetto (Serenoa repens) Fruit 5 x 6 g
ZSR-3251 锯齿棕提取物 Saw Palmetto (Serenoa repens) Extract 5 x 1 mL
ZSR-3252 蛋白混合饮料 Protein Drink Mix 5 pouches x 10 g each
ZSR-3253 Yerba Mate Leaves Yerba Mate Leaves 2 x 10 g
ZSR-3254 茶树(绿茶)叶 Green Tea (Camellia sinensis) Leaves 5 x 3 g
ZSR-3255 茶树(绿茶)提取物 Green Tea (Camellia sinensis) Extract 5 x 1 g
ZSR-3256 绿茶含固体口服剂型 Green Tea-Containing Solid Oral Dosage Form 5 x 2.5 g
ZSR-3262 St. John's Wort (Hypericum perforatum L.) Aerial Parts St. John’s Wort (Hypericum perforatum L.) Aerial Parts 5 packets x 3.3 grams
ZSR-3275 ω-3和ω-6脂肪酸鱼油 Omega-3 and Omega-6 Fatty Acids in Fish Oil 3 ea (2 ampoule x 1.2 mL)
ZSR-3278 食用油中维生素E Tocopherols in Edible Oils 5 x 1 mL
ZSR-3281 Cranberry (Fruit) Cranberry (Fruit) 5 x 6 g
ZSR-3282 Low-Calorie Cranberry Juice Cocktail Low-Calorie Cranberry Juice Cocktail 5 x 1.2 mL
ZSR-3287 Blueberry (Fruit) Blueberry (Fruit) 5 pouches x 5 g each
ZSR-3290 干猫粮 Dry Cat Food 5 pouches x 10 g each
ZSR-3451 低温塞贝克系数标准 Low-Temperature Seebeck Coefficient Standard (10 K to 390 K) bar
ZSR-3530 Iodized Table Salt (Iodide) Iodized Table Salt (Iodide) 1 bottle x 200 g
ZSR-3600 Absolute Intensity Calibration Standard for Small-Angle X-ray Scattering Absolute Intensity Calibration Standard for Small-Angle X-ray Scattering coupon
ZSR-3667 肌酐[干冰运输] Creatinine in Frozen Human Urine 1 bottle x 10 mL
ZSR-3671 NIST标准品[干冰运输] Nicotine Metabolites in Human Urine
(Frozen)
3 vials x 10 mL
ZSR-3672 NIST标准品[干冰运输] Organic Contaminants in Smokers' Urine
(Frozen)
5 vials x 10 mL
ZSR-3673 NIST标准品[干冰运输] Organic Contaminants in Non-Smokers' Urine
(Frozen)
5 vials x 10 mL
ZSR-3949 NIST标准品 [干冰运输][干冰运输] Folate Vitamers in Frozen Human Serum 3 vials x 1 mL
ZSR-4352 人类肝粉 Human Liver Environmental Radioactivity Standard 45 g
ZSR-4353a 洛基平底鞋土壤数2 Rocky Flats Soil Number 2 75 g
ZSR-4358 Ocean Shellfish Radionuclide Standard Ocean Shellfish Radionuclide Standard 1 x 150 g
ZSR-4359 Seaweed Radionuclide Standard Seaweed Radionuclide Standard 300 g
ZSR-4990c 草酸[危险品] Oxalic Acid 8 x 28 g
ZSR-8017 聚乙烯涂层银纳米粒子(公称直径为75nm) Polyvinylpyrrolidone Coated Silver Nanoparticles
(Nominal Diameter 75 nm)
5 vials
ZSR-8323 Yeast Protein Extract[干冰运输] Yeast Protein Extract 3 vials x 0.2 mL
ZSR-8366 EGFR and MET Gene Copy Number Standards for Cancer Measurements EGFR and MET Gene Copy Number Standards for Cancer Measurements 6 vials, 100 µL each
ZSR-8375 Microbial Genomic DNA Standards for Sequencing Performance Assessment Microbial Genomic DNA Standards for Sequencing Performance Assessment
(MG-001, MG-002, MG-003, MG-004)
4 vials, 1 each
ZSR-8391 Human DNA for Whole-Genome Variant Assessment (Son of Eastern European Ashkenazim Jewish Ancestry) Human DNA for Whole-Genome Variant Assessment
(Son of Eastern European Ashkenazi Jewish Ancestry)
(HG-002)
1 vial
ZSR-8392 Human DNA for Whole-Genome Variant Assessment (Trio of Eastern European Ashkenazim Jewish Ancestry) Human DNA for Whole-Genome Variant Assessment
(Family Trio of Eastern European Ashkenazi Jewish Ancestry)
(HG-002, HG-003, HG-004)
3 vials, 1 each
ZSR-8393 Human DNA for Whole-Genome Variant Assessment (Son of Chinese Ancestry) Human DNA for Whole-Genome Variant Assessment
(HG-005)
1 vial
ZSR-8398 对于全基因组变异评估人类DNA(犹他州/欧洲血统女儿) Human DNA for Whole-Genome Variant Assessment
(Daughter of Utah/European Ancestry)
(HG-001)
1 vial
ZSR-8420 电解铁 Electrolytic Iron
Thermal Conductivity (λ) and Electrical Resistivity (ρ)
as a Function of Temperature from 2 K to 1000 K
0.64 D x 5.0
ZSR-8446 全氟羧酸和全氟辛烷磺酰胺类甲醇[危险品] Perfluorinated Carboxylic Acids and Perfluorooctane Sulfonamide in Methanol 4 x 1.2 mL
ZSR-8447 全氟磺酸甲醇[危险品] Perfluorinated Sulfonic Acids in Methanol 3 x 1.2 mL
ZSR-8480 二次铁素体数标准 - 低范围 Secondary Ferrite Number Standard - Low Range 10x12x20
ZSR-8481 二次铁素体标准 - 高范围 Secondary Ferrite Number Standard - High Range set (8)
ZSR-8496 桉树硬木 Eucalyptus Hardwood Bleached Kraft Pulp 10 sheets
ZSR-8505 钒原油 Vanadium in Crude Oil 250 mL
ZSR-8529 IAEA-S-3(中银硫硫同位素) IAEA-S-3
(Sulfur Isotopes in Silver Sulfide)
1 bottle x 0.5g
ZSR-8536 GISP水 GISP—Greenland Ice Sheet Precipitation
(Hydrogen and Oxygen Isotopes in Water)
20 mL
ZSR-8539 国家统计局22油 NBS22 Oil
(Carbon and Hydrogen Isotopes in Oil)
1 mL
ZSR-8540 IAEA-CH-7(聚乙烯箔碳和氢同位素) IAEA-CH-7
(Carbon and Hydrogen Isotopes in Polyethylene Foil)
3.5 g
ZSR-8546 NBS28(硅和氧硅砂同位素) NBS28
(Silicon and Oxygen Isotopes in Silica Sand)
0.4 g
ZSR-8547 IAEA-N-1 IAEA-N-1
(Nitrogen Isotopes in Ammonium Sulfate)
0.5 g
ZSR-8548 IAEA-N-2 IAEA-N-2
0.5 g
ZSR-8550 USGS25 USGS25
0.8 g
ZSR-8551 USGS26 USGS26
0.8 g
ZSR-8552 NSVEC NSVEC
(Nitrogen Isotopes in Gaseous Nitrogen)
300 umol
ZSR-8553 IAEA-S-4 (Soufre De Lacq)(Sulfur Isotopes in Elemental Sulfur) [危险品] IAEA-S-4 (Soufre de Lacq) (Sulfur Isotopes in Elemental Sulfur) 0.5 g
ZSR-8555 IAEA-S-2 IAEA-S-2 (Sulfur Isotopes in Silver Sulfide) 0.5 g
ZSR-8557 NBS127 NBS127 (Sulfur and Oxygen Isotopes in Barium Sulfate) 0.5 g
ZSR-8562 CO2-13C富集,古生物原产地(二氧化碳) CO2-13C-enriched, Paleomarine Origin (Carbon Dioxide) set (2)
ZSR-8564 二氧化碳生物,现代生物质起源(二氧化碳) CO2-Biogenic, Modern Biomass Origin (Carbon Dioxide) set (2)
ZSR-8568 USGS34氮和氧同位素硝酸盐[危险品] Nitrogen and Oxygen Isotopes in Nitrate (USGS34) 0.9 g
ZSR-8569 USGS35氮和氧同位素硝酸盐[危险品] Nitrogen and Oxygen Isotopes in Nitrate (USGS35) 0.9 g
ZSR-8599 恒基兆业辉钼矿 Henderson Molybdenite 10 g
ZSR-8610 Mercury Isotopes in UM-Almaden Mono-Elemental Secondary Standard[危险品] Mercury Isotopes in UM-Almaden Mono-Elemental Secondary Standard 4 x 5 mL
ZSR-8671 NISTmAb, Humanized IgG1κ Monoclonal Antibody[干冰运输] NISTmAb, Humanized IgG1K Monoclonal Antibody 1 vial x 800 µL
ZSR-8704 水牛城河底泥 Buffalo River Sediment 50 g
ZSR-8785 空气中颗粒物过滤介质 Air Particulate Matter on Filter Media 3 filters
ZSR-8786 过滤空白RM 8785 Filter Blank for RM 8785 filter
ZSR-8850 Y型分子筛 Zeolite Y 35-40 g
ZSR-8851 Zeolite A Zeolite A 35-40 g
ZSR-8852 铵ZSM-5分子筛 Ammonium ZSM-5 Zeolite 35-40 g
ZSR-C2415a 电池铅(UNS 52770) Battery Lead (UNS 52770) disk
ZSR-C1252a 磷脱氧铜-铜九 Phosphorus Deoxidized Copper - Cu IX (block form) block
ZSR-C1115 商业青铜A(块) Commercial Bronze A (block form) disk
ZSR-C1137a 白口铸铁 White Cast Iron (disk form) disk
ZSR-C1145a 白口铸铁 White Cast Iron (disk form) disk
ZSR-C1151a 不锈钢23Cr-7NI Stainless Steel 23 Cr-7 Ni (disk form) disk
ZSR-C1152a 不锈钢18Cr-11Ni Stainless Steel 18 Cr-11 Ni (disk form) disk
ZSR-C1153a 不锈钢17Cr-9Ni Stainless Steel 17 Cr-9 Ni (disk form) disk
ZSR-C1154a 不锈钢19Cr-13Ni Stainless Steel 19 Cr-13 Ni (disk form) disk
ZSR-C1173 铸钢3 Cast Steel 3 (disk form) disk
ZSR-C1248 镍铜合金 Nickel-Copper Alloy (66Ni-30Cu) disk
ZSR-C1251a 磷脱氧铜-铜八 Phosphorus Deoxidized Copper - Cu VIII (block form) block
ZSR-C1253a 磷脱氧铜-铜X Phosphorus Deoxidized Copper - Cu X (block form) block
ZSR-C1285 LA钢(A242)(MOD)。 Low Alloy Steel (A242 Mod.) (disk form) disk
ZSR-C1291 高合金白口铸铁(镍硬,I型) High Alloy (Ni-Hard, Type I) disk
ZSR-C1292 高合金白口铸铁I(镍硬,IV型) High-Alloy White Cast Iron (Ni-Hard, Type IV) (disk form) disk
ZSR-C1296 不锈钢 Stainless Steel (disk form) disk
ZSR-C2400 高合金钢ACI(17/4 PH) Fe-Cr-Ni Alloy UNS J92180 (disk form) disk
ZSR-C2416 子弹铅 Bullet Lead disk
ZSR-C2417 铅基合金 Lead-Base Alloy disk
ZSR-927f NIST标准品 Bovine Serum Albumin (7 % Solution) (Total Protein Standard) 10 ampoules x 2.2 mL
ZSR-2972b 25-羟基维生素D2和D3校准溶液[干冰运输&危险品] 25-Hydroxyvitamin D2 and D3 Calibration Solutions 15 ampoules x 1.2 mL
ZSR-114r 硅酸盐水泥细度标准 Portland Cement Fineness Standard 20 vials x 5 g
ZSR-1270a 低合金钢,A336 (F-22)
(磁盘形式)
Chromium-Molybdenum Low Alloy Steel, A336 (F-22)
(disk form)
disk
ZSR-1412a 多组分玻璃 Multicomponent Glass
(disk form)
disk
ZSR-143d 胱氨酸 Cystine 2 g
ZSR-1450e 热导率-纤维玻璃板 Thermal Conductivity - Fibrous Glass Board each
ZSR-1476a 支链聚乙烯树脂 Branched Polyethylene Resin 12 g
ZSR-1548b 典型饮食 Typical Diet 2 x 5 g
ZSR-1565 玉米中的真菌毒素 Mycotoxins in Corn 2 x 60 g
ZSR-1762b 低合金钢(磁盘形式) Low Alloy Steel
(disk form)
disk
ZSR-17g 蔗糖 光学旋转 Sucrose
Optical Rotation
60 g
ZSR-1849b 婴儿/成人营养配方奶粉I(以牛奶为基础)[干冰运输] Infant/Adult Nutritional Formula I (milk-based) 10 pouches X 10 g each
ZSR-1936 五大湖沉积物 Great Lakes Sediment 50 g
ZSR-1949 NIST标准品[干冰运输] Frozen Human Prenatal Serum 8 vials (2 each level)
上海甄准生物科技有限公司(简称甄准®)专业提供科研试剂产品,主要包括高端化学试剂、生物学试剂、分析标准品、对照品、标准物质等,应用覆盖药物分析领域、食品安全领域、聚合物研究领域、环境监测领域,客户广泛分布于食品、制药、政府机构、第三方检测、环境测试机构、化工、科研院校、生物工程等行业。
上海甄准生物拥有充满活力的团队,持续创新,致力于为客户提供高质量产品和优质的服务。
*企业文化: 用心甄选,追求精准。
*服务理念:真心倾听您每一个标准。
*产品定位:甄准®科研试剂供应商。
*品牌形象:甄准®(代理、经销国外进口原装产品线)、zzstandard®(中药植物提取物产品线)、GlycoSci®(糖/碳水化合物产品线)、IsoReag®(稳定性同位素标记物产品线)。
甄准生物将一如既往,关注您的研发生产项目,为您提供最高性价比产品和服务。
Striving for high quality products and immediate service, we, SHANGHAI ZZBIO CO., LTD, shall do our best to ensure that your experiments and projects will be successful.
Our core business is to supply quality reference standard materials, high purity bio-chem reagents and technical consultancy to laboratories, universities, research institutions, hospitals, pharmaceutical companies, and drug manufacturers. These products can be supplied in quantities from a few milligrams to grams, and even to kilograms.
If you have special requirements, please contact us freely. We have considerable experience in custom-made products and will be very glad to discuss your needs.
上海甄准生物科技有限公司
客服01:13917991872 QQ:3001034031
客服02:13816009161 QQ:3001086693
客服04:15800340161 QQ:3001010259
客服05:19921389057 QQ:3004995018
客服06:18901678489 QQ:3004909899
客服07:13795317828 QQ:3001080377
客服08:13918293035 QQ:3001005926
客服09:13916577892 QQ:3001007248
客服10:13651665725 QQ:3001028570
客服11:19921087069 QQ:3004931168
客服12:18918753302 QQ:3001080321
客服13:18217024652 QQ:3001084617
客服14:15102117276 QQ:3001090745
客服15:19921389125 QQ:3004937757
客服16:15316187026 QQ:3004961006
客服17:18018502489 QQ:3001074579
客服18:13391016096 QQ:3004957527
电话:021-58979353
电话:021-68920155
电话:021-68404353
邮箱:info@zzsrm.com
邮箱:tech@zzbioco.com
地址:上海市闵行区浦江镇三鲁公路3398号国茸1号楼B-506室   邮编:201112
021-68920155-2011
