均质/粉碎
nG7400高压均质机
nG7400高压均质机
nG7400 High Pressure Homogeniser
进口
英国/Homogenising Sys
nG7400
详情请查询021-57652529,010-62846910
HOMOGENISING SYSTEMS
THE NEW HOME OF THE RANGE OF HIGH PRESSURE STANSTED HOMOGENISERS AND CELL DISRUPTER
"nm‑GEN‑7400" SERIES
ROBUST ‑ HIGH PERFORMANCE ‑ VERSATILE ‑ RELIABLE
STANSTED 高压均质和细胞破碎的新家庭成员
“nm -GEN- 7400”系列
健壮的-高性能-多功能-可靠
NANOPARTICLES
LIPOSOMES
MICROEMULSIONS
DEAGGLOMERATION
CELL RUPTURE
HP PASTEURISATION
纳米粒子
脂质体
微乳化
解聚松团作用
细胞破碎
高压杀菌
PRESSURES to 420 MPa 60,000 psi
FULLY CONTROLLABLE HOMOGENISING VALVES
MICRO CHANNEL DEVICE
BACK PRESSURE CONTROL
PROCESS TEMPERATURE CONTROL
EASY TO USE, CLEAN & MAINTAIN
REPRODUCIBLE RESULTS
SCALE UP
压力达到420MPa 60000psi
完全可控均质阀
微通道装置
背压控制
工艺温度控制
易于使用,清洁和维护
可重复的结果
可等量放大
The nm‑GEN 7400 Series "Hy‑Drive" series of homogenisation / cell rupture systems have been developed to meet the special requirements associated with biotechnology, chemical and pharmaceutical processing applications.
These systems complimented by smaller and larger models ranges offering processing from a  few ml to many m3.
The nm‑GEN‑7400 Series is suitable for pilot and production applications.
The processing module is fully enclosed and the systems incorporate synchronised pair(s) of electro‑hydraulic high pressure intensifiers. These intensifiers feed the product at high pressure through a pressure processing head.
STANSTED high pressure homogenisers offer optimal processing by providing the user with the both Piston Gap homogenising valves or a Micro Channel Device (interaction chamber). Systems may be supplied with either or both options depending on the optimal choice the processing application.
Our piston gap devices offer market leading pressure capability to 420 MPa (60,000 psi , 4200bar) and the range includes a number of optimised geometric patterns and profiles for optimal performance in each application. These devices incorporate advanced hard materials for optimal wear resistance and are simple to clean and maintain.
Our micro channel devices provide multiple configurations including “Z” and “Y” paths a range of channels sized for control of shear rates Our assemblies incorporate hard wearing polycrystalline diamond channels and assemblies by be simply opened and reassembled for cleaning, inspection and refurbishment.
System control is provided through a dedicated PLC with HMI or IPC with touch screen interface. Systems are designed to provide compliance with cGMP & FDA‑GMP. Systems can be offered with IQ/OQ documentation, full materials certification. 21 CFR part 11 compliance can be provided . Production pharmaceutical applications are offered with finely polished finish on wetted surfaces, CIP and SIP capabilities Systems can be supplied with many options to allow custom configuration, so of these include
Back Pressure Module. A second stage homogenisation valve for us in the range 2‑20% of system maximum working pressure
Micro channel processing modules (for use up to 420 MPa (60,000 psi , 4200 bar)
Outlet Heat Exchanger. May be used to cool or heat product as required. Suitable for connection to external fluid circulation systems ‑20°C to +120°C
Inlet Heat Exchanger. May be used to cool or heat product as required. Suitable for connection to external fluid circulation systems ‑20°C to +120°C
Pressurised feed reservoir for use with high viscosity products.
The nm‑GEN‑7400 series is designed to provide the ultimate tool for R & D STANSTED and Production applications. The range has market leading pressure capability and construction incorporates the most advanced corrosion resistant materials and latest manufacturing techniques to ensure exceptional performance and reliability.
Attention to detail in design and manufacture ensures wetted surfaces our suitably polished, high pressure ram plungers and primary wear surfaces utilise super hard materials and ceramics. We retain full documentation for materials and instrumentation to ensure all appropriate documentation is available for system validation.
Our latest generate control interface combines a touch screen HMI / IPC and PLC combination with advanced control logic and safety interlocking for the system. Our menu driven user interface allows operator to easily set up and control processing primary processing parameters and to data log, record, store and retransmit process data for full integration into production lines.
nm - GEN 7400系列“Hy - Drive”系列均质/细胞破裂系统已开发,以满足与生物技术,化学和制药加工应用相关的特殊要求。
这些系统补充了较小和较大的模型范围,提供从几毫升到许多升的处理。
nm‑GEN‑7400系列适用于中试和生产应用。
处理模块是完全封闭的,系统包括同步对电液高压增强器。这些增强器在高压下喂入产品并通过高压处理头。
STANSTED高压均质机通过为用户提供活塞间隙均质阀或微通道设备(相互作用室)提供最佳处理。根据加工应用的最佳选择,系统可以提供其中一种或两种选择。
我们的活塞间隙装置提供市场领先的压力能力,达到420MPa (60000psi, 4200bar),该系列包括许多优化的几何图案和轮廓,可在每种应用中实现最佳性能。这些装置采用先进的硬质材料,具有最佳的耐磨性,易于清洁和维护。
我们的微通道设备提供多种配置,包括“Z”和“Y”路径,用于控制剪切速率的一系列通道。我们的组件包括耐磨的多晶金刚石通道和组件,只需打开和重新组装即可进行清洁,检查和翻新。
系统控制通过专用的PLC与人机界面或IPC与触摸屏界面提供。系统旨在提供符合cGMP和FDA - GMP。系统可以提供IQ/OQ文件,全材料认证。21 CFR第11部分的合规性可以通过以下方式进行验证。CIP和SIP功能系统可以提供许多选项,以允许定制配置,其中包括
整机背压模块。我们的二级均质阀在系统最大工作压力的2 - 20%范围内
微通道处理模块(用于高达420 MPa (60,000 psi, 4200 bar))
输出热交换器。可根据需要用于冷却或加热产品。适用于连接外部流体循环系统- 20°C至+120°C
进口热交换器可根据需要用于冷却或加热产品。适用于连接外部流体循环系统- 20°C至+120°C
用于高粘度产品的加压进料储罐。
nm‑GEN‑7400系列旨在为STANSTED和生产应用的研发提供终极工具。该系列具有市场领先的压力能力,结构采用最先进的耐腐蚀材料和最新的制造技术,以确保卓越的性能和可靠性。
对设计和制造细节的关注确保了湿润的表面,我们适当抛光的高压柱塞和主要磨损表面使用超硬材料和陶瓷。我们保留材料和仪器的完整文件,以确保所有适当的文件可用于系统验证。
我们最新的生成控制界面结合了触摸屏HMI / IPC和PLC结合先进的控制逻辑和系统的安全联锁。我们的菜单驱动用户界面允许操作员轻松设置和控制加工主要加工参数,并对数据进行日志,记录,存储和重新传输过程数据,以便完全集成到生产线中。
SERVICES
Electrical Supply
3.7‑4 kW systems
208‑460V 3ph 50/60Hz
Compressed Air (or nitrogen)
6 barg (75 psig) minimum
10 barg (150 psig) maximum
Cooling Fluid Drive System
Inlet connection G 1/2
Outlet connection G 1/2
0.2 barg (3 psig) minimum
3.0 barg (45 psig) maximum
+4°C minimum
+30°C maximum
Cooling / Heating Fluid
(if required)
‑20°C minimum
+80°C maximum
PHYSICAL DATA
Width 1000 mm
Depth 800 mm
Height 2000 mm
Weight 475 kg ‑ 550
Depending on model
Process Connections
Inlet connection 3/4" Triclamp
Outlet connection 1/2" Triclamp
电力供应
3.7 - 4 kW系统
压缩空气(或氮气)
至少6巴(75磅压)
最大10bar (150 psig)
冷却液驱动系统
进气口连接g1 /2
出线连接g1 /2
最小0.2巴(3 psig)
3.0 barg (45 psig)最大值
+ 4°C最低
+ 30°C最大
冷却/加热流体
出口热交换器
(如果需要的话)
进气口连接g1 /2
出线连接g1 /2
最小0.2巴(3 psig)
- 20°C最低
+ 80°C最大
物理数据
宽度1000mm
深度800毫米
高度2000mm
重量475 kg - 550
取决于模型
过程连接
入口连接3/4“Triclamp
插座连接1/2“Triclamp
STANSTED bench top systems complement the range of large scale systems. On left small scale production pharmaceutical production system with CIP and SIP capacility and HMI/PLC control with touch operation
STANSTED台式系统补充了大型系统的范围。左图为具有CIP和SIP能力的小规模制药生产系统,采用触摸操作的HMI/PLC控制
STANSTED pressure intensifiers. Graphic above (left) shows a typical STANSTED  twin intensifier configuration. The graphic on the right shows the pressure vs time profile for a normal intensifier system and the bottom right the pressure vs time profile for a synchronised intensifier pair. Smooth pressure delivery reduces fatigue and ensures a more unitform STANSTED processing
STANSTED压力增强器。上图(左)显示了一个典型的STANSTED双增强器配置。右图显示了正常增强器系统的压力与时间曲线,右下角显示了一对同步增强器的压力与时间曲线。平稳的压力输送减少了疲劳,并确保更均匀的STANSTED加工
公司致力于提供领先的生物医药纳米均质分散解决方案,专注于生物制药、纳米递送、药剂制剂、纳米技术行业。主要产品有以下三个板块:
新型制剂设备有脂质纳米颗粒合成系统、微流控设备、微流控纳米药物制备系统、微流控芯片、脂质纳米颗粒(Lnps)生产设备,可应用载体平台有核酸类药物mRNA/DNA/siRNA、小分子药物 Small molecule drugs、蛋白质和多肽 Proteins and peptides及其它药物平台,可应用于药物输送、核酸脂质纳米颗粒合成、聚合物纳米颗粒合成如 PLGA/PLGA-PEG、脂质/脂质体合成、凝胶颗粒合成等。
脂质体、乳剂、微胶囊制备设备有高压微通道射流均质仪、超高压纳米均质机、高压均质机、高压乳匀机、高压脂质体挤出器,可应用于脂质体、乳剂、纳米粒、混悬剂、分散液、微胶囊、细胞破壁、降低药物粒径至纳米结构。
此外我们研发、装配和销售进口品牌及自主品牌标签的磷脂、脂质体、mRNA新冠辅料和其它试剂耗材,具体可查看我司产品中心的试剂、耗材介绍,相关产品会慢慢更新以加强我们的产品及服务管线。
售后问题请电话咨询:021-57652529,13386106441
松江区广富林路658弄255号1926室
