描述:
Pkg of 60, 7 x 8.4 cm sheets, absorbent filter paper, for use with Mini-PROTEAN or Ready Gel Precast Gels, precut to gel dimensions
一包60张7 x 8.4厘米的吸水滤纸,与迷你PROTEAN或现成凝胶预制凝胶一起使用,预切割成凝胶尺寸
Bio-rad伯乐BLOT PAPER,7x8.4cm,ETHK,60PK转印滤纸1703966
产品介绍:
Use this 7 x 8.4 cm extra thick blot absorbent filter paper in blotting applications as part of the gel, membrane, and filter paper stack, or sandwich.
This filter paper is precut to fit Mini-PROTEAN or Ready Gel Precast Gels and can be used with any semi-dry or wet transfer blotting system.
在吸干应用中,使用这种7 x 8.4厘米的超厚吸干滤纸作为凝胶、膜和滤纸堆叠或三明治的一部分。
这种滤纸经过预切割,适合Mini-PROTEAN或Ready Gel预制凝胶,可以与任何半干或湿转移印迹系统一起使用。
产品特点
These blot absorbent filter papers are:
- Made of 100% cotton fiber
- Produced using ultrapure water and contain no additives
- Suitable for use with alcohol and other organic solvents
- Provide a uniform flow of buffer through the gel to the transfer membrane in a blotting sandwich
这些吸污滤纸是:
由100%棉纤维制成
使用超纯水生产,不含添加剂
适用于酒精和其他有机溶剂
在印迹三明治中,通过凝胶向转移膜提供均匀的缓冲液流
其他规格
| Dimensions |
Sheets/Package |
Gel Compatibility |
Catalog Number |
| 7 x 8.4 cm |
60 |
Mini-PROTEAN and ReadyGel Mini Gels |
1703966 |
| 7.5 x 10 cm |
60 |
1703965 |
| 8 x 13.5 cm |
60 |
Criterion™ Midi Gels |
1703967 |
| 10 x 15 cm |
30 |
1703958 |
| 14 x 16 cm |
30 |
PROTEAN® II xi Gels |
1703968 |
| 15 x 15 cm |
30 |
1703959 |
| 15 x 20 cm |
30 |
1703960 |
| 19 x 18.5 cm |
30 |
PROTEAN II XL Gels |
1703969 |
更多
迷你离心机查看
www.lingyi17.cn
