其他实验耗材
CALIFORNIA FINE WIRE 不锈钢丝
进口
CALIFORNIA FINE WIR
Stainless Steel, was discovered a hundred years ago. However commercial production was little advanced until the invention of the (AOD) Argon Oxygen Decarburization process. The low carbon levels needed to produce stainless steel could not be achieved without preferential oxidation of the chromium. The AOD process enabled the reduction of carbon while minimizing the loss of chromium by utilizing a blend of argon and oxygen gas blown into the molten bath of metal.
Ubiquitous in everyday life, stainless steel is found in many different forms – cookware, utensils, cutlery, jewelry, appliances, medical tubing and needles, building, and architectural materials – due to its myriad of desirable properties. The Gateway Arch in St. Louis is made of Type 304 stainless steel. Stainless steel is corrosion resistant, fire and heat resistant, hygienic, aesthetic, easy to fabricate, has a high impact resistance, and is recyclable. It also has a high strength to weight ratio.
Although a kitchen whisk may be the first stainless steel wire use that comes to mind, other uses such as fasteners, wire mesh belts, braided hoses, welding wire, and springs represent much larger commercial applications. California Fine Wire supplies stainless steel wire to all of its major markets for applications ranging from medical probes to aerospace lock wire, electronic components, and specialty springs.
Stainless steels have excellent ductility and can be supplied by California Fine Wire in ribbon and round forms. Round diameters can be drawn as small as 0.0003” and ribbons from as small as 0.001” x 0.005” to as large as 0.010” x 0.050”. Call us to discover our capability to meet your specific wire needs.
Stainless steel wire can be readily plated with such metals as copper, gold, nickel, silver or tin; and insulated with any of the enamel, ceramic, or PTFE insulating materials offered by California Fine Wire. Whether your application requires the strength, stiffness, corrosion resistance, or hygienic properties of stainless steel.
北京顺鑫成科技有限公司代理进口日本不锈钢毛细管和美国CALIFORNIA FINE WIRE公司生产的金属线。
代理日本精密毛细管,微小管,材质有不锈钢、铜、镍、钛、镍铁合金、铂、铂铱合金等。应用于EDM的电极管、检测P.C.B的接触式探头、光导纤维(金属接头)、半导体制造机械及设备、导管设备等。
不锈钢管(用于医疗设备的功能部件、半导体设备等等。),通过短芯棒拉拔终加工得到光滑内表面;通过NT细切得到无毛刺边缘。
外径 0.05mm—3.0mm
内径 0.02mm—2.9mm
   代理美国CALIFORNIA FINE WIRE生产的各种金属线,加利福尼亚细线公司生产圆形和扁平形状的细线和超细线。服务包括搪瓷、PTFE和陶瓷涂层、电镀、绞合、切割和矫直。加工的合金包括贵金属、不锈钢、铜、电阻合金、耐火合金等。
   以下是CFW生产的一些金属线类型的列表:
贵金属、半导体键合线和带
铜、铜合金、复合金属(包层)
镍、镍合金、电阻丝、电位器合金
铝及合金,低热膨胀(玻璃密封合金)
热电偶线,RTD线,高温(陶瓷绝缘)
不锈钢、音乐线、保险丝线、细线和色带
耐火金属和合金
北京市怀柔区杨宋镇凤翔东大街9号201室
