文献案例
(1) Zhao, C.; Liu, F.; Feng, L.; Nie, M.; Lu, Y.; Zhang, J.; Wang, C.; Wang, T. Construction of a double-walled carbon nanoring. Nanoscale 2021, 13, 4880-4886.
(2) Li, Y.; Ren, Z.; Gu, M.; Duan, Y.; Zhang, W.; Lv, K. Synergistic effect of interstitial C doping and oxygen vacancies on the photoreactivity of TiO2 nanofibers towards CO2 reduction. Applied Catalysis B: Environmental 2022, 317.
(3) Ru, C.; Chen, P.; Wu, X.; Chen, C.; Zhang, J.; Zhao, H.; Wu, J.; Pan, X. Enhanced Built‐in Electric Field Promotes Photocatalytic Hydrogen Performance of Polymers Derived from the Introduction of B←N Coordination Bond. Advanced Science 2022, 9.
(4) Zhou, J.; Bai, Y.; Qiu, Q.; Liu, S.; Qiu, H.; Zhang, X.; Zhao, H. Ex-situ EPR approach to explore the electrochemical behaviour of Arylboron-Linked conjugated microporous polymer cathode. Chemical Engineering Journal 2023, 452.
(5) Jiang, Y. s.; Yu, F. d.; Ke, W.; Deng, L.; Xia, Y.; Li, X. y.; Que, L. f.; Zhang, N.; Zhao, L.; Wang, Z. b. Accessible Li Percolation and Extended Oxygen Oxidation Boundary in Rocksalt‐like Cathode Enabled by Initial Li‐deficient Nanostructure. Advanced Functional Materials 2023, 33.
(6) Ding, D.; Li, Z.; Yu, S.; Yang, B.; Yin, Y.; Zan, L.; Myung, N. V. Piezo-photocatalytic flexible PAN/TiO2 composite nanofibers for environmental remediation. Science of The Total Environment 2022, 824.
(7) Wang, X.; Su, N.; Wang, X.; Cao, D.; Xu, C.; Wang, X.; Yan, Q.; Lu, C.; Zhao, H. Fabrication of 0D/1D S-scheme CoO-CuBi2O4 heterojunction for efficient photocatalytic degradation of tetracycline by activating peroxydisulfate and product risk assessment. Journal of Colloid and Interface Science 2024, 661, 943-956.
(8) Liu, G.; Yuan, H.; Wang, Z.; Qin, N.; Huang, Y.; Cao, Y.; Li, Y.; Lu, W.; Zeng, C.; Liu, Q.; Lu, Z. Cu single atoms regulating nitrogen active-sites of g-C3N4 for sodium ion storage. Energy Storage Materials 2024, 71.
(9) Zhu, Q.; Shi, L.; Li, Z.; Li, G.; Xu, X. Protonation of an Imine‐linked Covalent Organic Framework for Efficient H2O2 Photosynthesis under Visible Light up to 700 nm. Angewandte Chemie 2024, 136.
(10) Ma, M.; Wang, R.; Shi, L.; Li, R.; Huang, J.; Li, Z.; Li, P.; Konysheva, E. Y.; Li, Y.; Liu, G.; Xu, X. Defect‐Expedited Photocarrier Separation in Zn2In2S5 for High‐Efficiency Photocatalytic C─C Coupling Synchronized with H2 Liberation from Benzyl Alcohol. Advanced Functional Materials 2024.
(11) Wang, R.; Zheng, Z.; Li, Z.; Xu, X. Photocatalytic C-C coupling and H2 production with tunable selectivity based on ZnxCd1-xS solid solutions for benzyl alcohol conversions under visible light. Chemical Engineering Journal 2024, 480.
(12) Lin, G.; Sun, X.; Xu, X. Mg modified LaTiO2N with ameliorated photocarrier separation for solar water splitting. Applied Catalysis B: Environmental 2023, 324.
(13) Li, X.; Wang, G.; Wen, J.; Liu, W.; Zhan, H.; Chen, X.; Li, H.; Bi, S. Facile synthesis of nitrogen vacancy-enriched polymeric carbon nitride via the trace manganese-induced precursor recrystallization process for photocatalytic degradation. Journal of Alloys and Compounds 2024, 970.
(14) Li, S.; Lu, J.; Wang, G.; Li, X.; Liu, W.; Xin, C.; Zhan, H. Study on the performance of photothermal catalyzed carbon dioxide hydrogenation to CH4 over doped sodium tantalate-based perovskite catalysts. Journal of Environmental Chemical Engineering 2024, 12.
(15) Guo, Q.; Li, X.; Liu, X.; Wen, M.; Wang, G.; Zhan, H.; Chen, X.; Li, H.; Ma, J.; Liu, W. Bifunctional nitrogen-doped carbon quantum dot-modified graphitic carbon nitride/cadmium sulfide nanomaterials for antibiotic selective detection and photocatalytic degradation. Materials Today Chemistry 2024, 38.
(16) Yuan, S.; Ding, W.; Li, J.; Wang, X.; Zhang, Y.; Zhao, Y.; Chen, F.; Li, X.; Luo, M. Design and Construction of the Fe2O3/BiVO4 Heterostructure-Based Photoanode for Photo-Electrochemical Desalination. ACS Sustainable Chemistry & Engineering 2024, 12, 6330-6342.
